PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 [108] 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228
  1. TBSS Single turbo setup?? Anyone done a nice clean setup on one
  2. sts turbo gt70???
  3. DIY rear mounted turbo
  4. bypassing an internal wastegate
  5. Been out of the game for years, need help with new FI car
  6. Catch can setup question.
  7. Too much boost too quick, idea's?
  8. flipping truck manifold!?!
  9. relocating a/c and alternator with truck headers?
  10. Need alternate LS2 vacuum/boost source for Elect. Boost Controller?
  11. need some vacuum and oil line routing help.
  12. Speartech LS9 Supercharger Swap!
  13. Intercooler Question
  14. Just picked up LQ9, some questions
  15. Rookie turbo question
  16. Placement of Air Filters
  17. Anyone tried Champion fans yet?
  18. Has anyone seen what this guy did with this nova 5.3+91mm=8.76
  19. What engine oil for 650+ after breakin?
  20. Spectre air filters?
  21. belt length ?
  22. Kaboom
  23. Which belt on vortech?
  24. How long will my bone stock A4 last after the vortech v1 install?
  25. Diamond dish piston boosted with S91 turbo !
  26. Magnacharger Questions
  27. 6-10psi T70 Stock Motor TR6s?
  28. IAT Style and Mounting...
  29. possible misfire above 12psi, any ideas
  30. magna charger
  31. Want a Budget Turbo Setup!
  32. Poll: What compression are you running at +/- 800RWHP?
  33. Front mount on 67 Firebird
  34. Max Hp w/GT42/74
  35. boost on 11.8:1 CR?
  36. what MPH should i gain going to XR-1 mufflers
  37. 317 Heads on ls1... too much misinformation.Help...
  38. Motor Time, opinions and help appreciated
  39. Cam help needed!
  40. Power Steering cooler ??
  41. ShurFlo Scav Pumps?
  42. budget turbo motor: LQ4/LQ9 or L92
  43. Need help with cam selection on 408/LS3
  44. 112 lsa with turbo
  45. Converter stall speed vs spool up
  46. Open dump wastegates? Who's running them?
  47. FANTAZ28 wanted for murder!!!
  48. divided vs. undivided turbines.... What size A/R? Also WG size questions!
  49. twin turbo downpipes
  50. Show me your front mount turbo exhaust setup
  51. turbo cooling???
  52. rear mount turbos
  53. Need help picking a BOV for APS car
  54. Hobbs switch
  55. 408ci F-1R Compression
  56. ATI ProCharger GTO Overdrive Pulley for Fluidampr Available at EPP
  57. LMR Twin Turbo Camaro at 60-130mph Event 9/20/09
  58. Anyone making 700rwhp on stock block 346/347ci single turbo
  59. tuning for boost
  60. charged 3800 pulley
  61. reverse flow stock fans?
  62. Planning a big turbo build....
  63. opinions on stacking head gaskets?
  64. 2010 Camaro SS ProCharger Cog Kits are Available!
  65. Which Aftermarket Engine Management System?
  66. Backfire between shifts after Maggie?
  67. what size wast gate should be used for a 83mm turbo
  68. how big is to big when it comes to pipping
  69. Swapping the rear pullies on a 112?
  70. Help!l STS Oil Problem
  71. stock 6.0 turbo 600hp?
  72. vertical radiator and a/c
  73. Front or rear mount turbo kit
  74. stock ls1 and 2 turbos
  75. Best Procharger Prices around, Complete Kits / Parts etc
  76. -3 an feed line ok for T6 turbo?
  77. fuse block covers?
  78. Turbo timers which ones do you use
  79. Turbo Boost on a 5,3 lm7 engine
  80. TT LS1 typhoon back to the track
  81. Procharger guys, what gears are you guys running?
  82. What do you guys think?
  83. LSXTREME improvement update
  84. inconsistent boost
  85. Finally did it, I love my ProCharger, lol.
  86. will a t76s fit on my car?
  87. need some help on wastegate flange
  88. Anyone got pics of where they installed meth nozzle in reference to IAT?
  89. Best way to figure what BOV spring is needed?
  90. STS guys who went to bigger turbo in here please??
  91. Vertical Rad And A/C??
  92. 2 issues wth installing my d1sc, thoes with one come in
  93. Turbo camaro?
  94. underdrive pulley question
  95. STS dealers?
  96. Newest member of the 7 second club
  97. 98 Firebird Turbo Project ( 1200 HP )
  98. Can an angular discharged vortech v1 be converted to straight discharge? Help!
  99. STS guys with Meth in here please?
  100. Wastegate Max Boost Without CO2?
  101. Traded Victor jr for Fast. Good decision?
  102. new to turbo...again!
  103. need help picking turbo....
  104. Aeromotive or Holley boost referenced FPR?
  105. carbed and boosted 6.0....
  106. Anyone know what these are?
  107. Low Boost problems....98 ls1 sts kit.
  108. AFR heads
  109. Boost Spike! - 427TT - Damn HKS EVC IV let me down - Need EBC recommendations..
  110. Crank driven (no belt) F1R for a LS motor?
  111. ported 241's or stock 317's??? HELP!!
  112. For the ones building their own Front Mount setup...
  113. Best twin turbo kit for 08 Z06
  114. Will a V1 vortech supercharger fit on an ls1?
  115. Let's debate this cam for a PT88 370ci turbo build.
  116. APS 427 turbo kit?????
  117. Weird back fire issue--imput please
  118. Dry Nitrous
  119. Problems at the dyno :(
  120. forged piston broke... what happened
  121. twin garret gt28's on froged 347 ?
  122. is it possible
  123. Interest in turbo headers?
  124. Cobalt 2 bar MAP & 31x12x4 intercooler for sale...
  125. Procharger Startup
  126. Rwhp guess on LS2 with T70 intercooled
  127. how much boost?
  128. question for the meth users (lol)
  129. 2 or 3 bar, maybe SD?
  130. Another ebay start up thread
  131. Lower Compression or Forged?
  132. Edelbrock Victor Jr FI Limits?
  133. Twin Ta Build
  134. valve cover pcv question
  135. Would you use a 3" moroso Spiral muffler?
  136. WTF Do I get a 2psi check valve?
  137. how strong is a ls7 block
  138. Going to the drag strip later today. Shift question...
  139. What OEM GM app. is 3 BAR MAP from?
  140. BOV @ Idle ??
  141. The EPP Forced Inductions Cam
  142. It's back!
  143. meth injection with blowthru carb>>????
  144. Thinking of a procharger
  145. Accufab 4 barrel t body for boost lsx
  146. Are all t4 flanges the same
  147. Going rate for used P1/D1 complete kits?
  148. Y2KHawk??
  149. Turbo Setup!!!! KYTP!!!!
  150. Can someone help me with this whole METH thing??
  151. whipple f-body kit :D
  152. Any manifolds that allow factory location of Alt. On LS2??
  153. GT47-88 Flange Question
  154. boost controllers
  155. F-1R Cog Project
  156. brainstorming turbo location
  157. Twin turbo downpipe options
  158. How hot will ceramic coating get?
  159. upgrading to the tvs2300 on my 402
  160. Quick Injector Question
  161. manifold build
  162. pt88 on an lq4?
  163. 93+Methanol - Race Gas?
  164. Ohio boys and Mightymouse aint got sh*t on me
  165. LS1 or LQ4/9
  166. dumping downpipe behind rear tire
  167. aps oil feed bolts and drilling them larger ?
  168. aps tt kit , th400 and transbrake question ????
  169. Video of 88mm turbo 402 C4 Vette
  170. New Best 9.38@153.6
  171. Cammed and Blown V
  172. boost+4l80e
  173. Were to find a full D1 for a LT1????
  174. The LS Drag Radial Record Reset 7.11
  175. Cog Setup?
  176. TT Chevelle goes 10.53 @ 133.68
  177. TTI 60 trim in action
  178. Downpipe help
  179. When venting motor.... Whats enough?
  180. Phil Thomas @ MIR 7.29 @ 194
  181. Some more video of the urbo express van in action
  182. Got the ebay turbo kit on
  183. Turbo stuff for sale
  184. Ohio Boys@MIR
  185. Rearmount stand alone
  186. Crane map sensor
  187. Procharger intake hat
  188. Turbo'd 5th gen FINALLY
  189. Fuel pressure pin on bs3
  190. 6.2 Turbo build questions??
  191. cubic inch question help !!!!!!!!!!!!!!!!!!!!!!
  192. 1st time going to dyno next week, any advice?
  193. Time to upgrade.
  194. Oil pressure gauge
  195. TC78 or PTE78 for LS2?
  196. 02 z28 w/ vortech leaking oil
  197. Power difference ?
  198. Which head gaskets to use with my turbo setup?
  199. Mufflers
  200. rearmount turbo wideband location
  201. twins or procharger?
  202. Has anyone moved the cruise control module?
  203. truck manifold turbo in 3rd gen with LSX questions...
  204. Procharger crank bolt?
  205. 402 APS kit with LG's new turbo up and running
  206. Rufretic.... What up?
  207. procharger help
  208. What problems did you have???
  209. Does anyone have an off the shelf 3.9" stroke crank?
  210. gm or arp bolts for heads?
  211. a2w tank
  212. Stock clutch Dyno Capacity.
  213. Ninetres 2-step installed!!!!!!!
  214. where to buy supercharger by itself?
  215. How restrictive is my exhaust 800rwhp
  216. Which single Turbo for a 6.0 truck engine?
  217. Should I descreen MAF for FI setup??
  218. building boost options
  219. What to buy question
  220. Might be picking up an LQ9/4 this weekend
  221. My Budget TC78 in the 9's
  222. waterpump heater hoses
  223. My observation of my MPT76 Turbo -- MPT owners come on in!!
  224. rods and crank
  225. 6.0L Iron + o-rings?
  226. LS6 PCV conversion worth it?
  227. ebay turbo set up
  228. master power turbo
  229. Boost-A-Pump w Hotwire kit/Oil pump
  230. Help picking next mod
  231. anybody paint there procharger?
  232. Any single in/dual out mufflers that dont suck?
  233. A must do modification (F body APS)
  234. 5.7ltr LS1 Holden Commodore - Maggie 122 - 10.96@130mph
  235. Lsx shootout bound!!!!!!!!
  236. Of things to come.. (almost finished)
  237. truck manifold pipe gaskets?
  238. Front O2s in Charge Pipe?
  239. Ok, supercharger or turbo... lets here what you like more on the LS1
  240. LS1 studs
  241. EPP cam installed!
  242. boost/pulley change
  243. methanol controllers
  244. 9.52@152.64 Time for a chute!
  245. MAF change
  246. 408 Truck Manifold Build
  247. Some turbo help needed
  248. Time for my Front mount!
  249. Help! SBC + Magnacharger torque spec question
  250. a little more boost on my ofi kit
