View Full Version : Forced Induction
  1. polished intake elbow, pic
  2. Better to part out or sell as complete turnkey?
  3. Wastegate: Dump to atmosphere or back to exhaust?
  4. Harlan Two step??
  5. Those interested in Magnuson kits for F-body, step inside
  6. Plug suggestion for big BOOST
  7. SLP 402 with ATI ProCharger D-1SC at 16 psi of boost = 757 rwhp on Mustang Dyno!
  8. transam FI custom bumper
  9. Too leave the dynatechs on or not
  10. whats the best intercooler?
  11. Meth Kit Or Intercooler
  12. wrap this up fooooo!!! question
  13. I got a Tial 50mm BOV and a Rattle snake
  14. T-Bolt clamps... CHEAPEST price anywhere
  15. Which low CR heads?
  16. Anyone seen this video of MIke's Turbo CE
  17. Stock..Sts...yes??
  18. What's an acceptable amount of shaft endplay?
  19. Compression for Turbo Setup???
  20. quick ?
  21. FMIC finally on, thanks TRT Billy.
  22. D1sc?
  23. LS2 stock boost
  24. whos car is this?
  25. Should I or Shouldn't I??
  26. What do you guys think?
  27. I Love Boost :d!!!@!@%@#$%
  28. Vortech S-trim
  29. Oil restrictor size
  30. Powder Coating IC's? How much?
  31. New best
  32. Questions about the P-1SC system
  33. What would you rather have?
  34. Turbo 6m cars
  35. Need to find a 3.5" to 3" 90 degree elbow ASAP
  36. intake runner length affecting fuel distribution?
  37. New Bests
  38. Videos - my turbo trans am
  39. Has anyone ever had any issues with their alternators while under boost?
  40. Will it fit?
  41. 02 ls1 procharger part#
  42. LT1 procharged question
  43. New numbers with the Meth!
  44. Wrapping hot parts
  45. spider intake
  46. Look At What Im Wanna Do To The K Member
  47. FM Turbo Location high or low pics inside
  48. Wot Afr ?
  49. Hp/Cid ect..
  50. daily driver reliability
  51. Exhaust Restriction
  52. Switching from 3.73s to 3.42s worth it to load the turbo?
  53. Maf before or after turbo????
  54. Starting FI from Scratch
  55. Am I doing this right?
  56. vortech guys , need help
  57. General FI question
  58. New Best ET 8.66@140 mph!!
  59. Has anyone kaboom'd driveline on the dyno?
  60. T60, T67, or T76 on Daily Driver ??
  61. What Wideband do you use?
  62. To AC or Not to AC
  63. Anybody running a roots style on their LS1?
  64. Limits of stock ls1 intake on FI setup
  65. 38mm wastegate?
  66. STS Droptop with SFC Pics 56k warning
  67. WooHoo! New best Time tonight...
  68. cheater cam from TR
  69. I need your help about LS engines.
  70. T76 to T88 spool difference with an auto?
  71. Which heads, any gains ???
  72. procharger help
  73. Wooo woooo - is that an IC in his trunk ???
  74. IC Pic's?
  75. Twin Turbo guys fuse box relocate
  76. stroked turbo setup, why 6.0L block?
  77. New Turbo Project
  78. Single Turbo Project!
  79. Its has begun!!!! T76 build PICS!!!!
  80. sts w/ subframe connectors
  81. Opinions needed. Which combo?
  82. 2.73s for an M6/ boosted 383?
  83. STS question again
  84. Simple boosting question
  85. i just found out what meth really is!
  86. Torque?
  87. H2o2 / ASC Methanol / Nitromethane blend - for water/alcohol injection systems
  88. Digital gauges for A-Piller What brand is the BEST?
  89. STS CC Pics
  90. Question with FI tune
  91. meth users, what size injectors are you using??
  92. Calling all 383 LT1 vortech supercharger guys!
  93. Bigger Airl filter????
  94. STS questions
  95. AZPS New part for F/I applications
  96. boost valvesprings....
  97. hey guys
  98. [Speed Inc] Streetable 'Race' Twin Turbo System
  99. Alt relo bracket and aftermarket fuel rails?
  100. Vortech MD Results 589 RWHP 486 RWTQ!
  101. Setup Help...
  102. Meth users: Where did you mount the tank and pump?
  103. MIGHTYMOUSE 'help' FUND HERE:
  104. Head gaskets good or bad? (pics inside)
  105. larger filter for turbo setup!?!
  106. LS6 cam good for turbo setup on a LS1
  107. How to break in FI Stroker
  108. Ohio forced induction inc single turbo numbers GTO/f-body
  109. turbonetics BOV
  110. t60 or t67?
  111. How loud is the blower whine on a P1SC?
  112. Argggh, my car is eating belts
  113. how much boost
  114. Wormy and Roofer Dave in GMHTP
  115. Will this cam play nice with a Procharger?
  116. Forced Induction and Electric Water Pump
  117. Stall
  118. What size is your front mount Intercooler?
  119. Larger Air Filter for procharger setup
  120. C5 or Firebird
  121. I think I just found a way to get a free 50 rwhp!!!
  122. What is the happy medium between timing and boost?
  123. Final round of mods, I think thats about it lol
  124. What makes engine oil "turbo approved"
  125. What kind of turbo?
  126. Carburetor + blower on LS1?
  127. Video from Weekend of September 16th
  128. Where to buy SS header flanges?
  129. Anyone running a G5X3 112 LSA with boost? OPINIONS WANTED.
  130. Magnuson MP122H install
  131. Best prep for an LSX boost motor...
  132. Well She's Finally Back Together
  133. Turbo setup
  134. Turbo Timer Install help..
  135. how long will this last????
  136. Finally! >650 rwhp with TTi Street Kit!
  137. superchargers pro&cons
  138. How to bring your IAT's down, pics inside
  139. Magnacharger
  140. ARP rod bolts allow more boost???
  141. is anyone runninga a blowthrew carb turbo set up
  142. Track vid
  143. My projected setup for next year...what would it be good for?
  144. turbo
  145. Pulley change questions
  146. 408's With PT88 Come In
  147. 6.0 LQ9 Heads on 347 F1A setup?
  148. PCV suggestions w/pics
  149. Dyno Battle Results
  150. LS6 valley cover on LS1... PCV question
  151. Can someone explain this to me
  152. 20 cases of ProCharger oil in stock at Exotic Performance Plus!
  153. sts + lowered = good/bad idea??
  154. Help Me Choose A Turbo
  155. Ceramic Coating
  156. good daily driver?
  157. 4 psi on a 7.25 spring?
  158. Need help building a turbo motor
  159. Custom Turbo's keeping AC???
  160. How much boost do you run on pump gas? What power do u make?
  161. New numbers with the D1SC!!!!!!
  162. MightyMouse video 9-15-06 :-(
  163. New Best at the track... STS
  164. altternator bracket for FI
  165. Did Mightymouse crash?
  166. Turbo Help! Feeling very humble right now
  167. Injector questions
  168. Building a motor for boost.
  169. Pics of some of the progress on the Twin Turbo T/A!
  170. jet coating hot parts? anyone?
  171. VFN cowl induction hood with Vortech?
  172. Dropping fuel pressure on dyno
  173. Dynamic Compression Ratio and Forced Induction
  174. GMC 1500 Turbo Exhaust Manifold
  175. YSi head unit mounting question
  176. ~Custom Rear Mount HELP~
  177. corvette + sts single turbo???
  178. garrett 71mm or 76mm?
  179. Are 64cc chambers too small??
  180. GMR single kit numbers anyone??
  181. prochargher inlet hat options (Cobra head intake)
  182. wats the max HP on stock maf and no return
  183. victor jr. intake
  184. Any V6 guys in here running roots style s/c
  185. Procharger Help
  186. Horsepower TV Installing A C6 STS Kit This Weekend!
  187. P&P m90 and fwi install
  188. Manifold kits
  189. need suggestions
  190. LS2 cam choice now for future FI plans
  191. GMR Keep A/C
  192. need reducer couplings...
  193. Turbosmart E-Boost Location in Camaros?
  194. Thinking of De-Modding, Need a Shop
  195. my 1rst run on my d1sc
  196. belt started squealing soon after supercharger went on
  197. F1a Procharger set-up HELP
  198. What size turbo for a V6 'maro?
  199. Mild steel or stainless??
  200. 9.6 to 1 compression?
  201. Minimum ground clearance for turbo is?
  202. Read what i just bought!
  203. HMT(Turbo): Anyone tried this?
  204. Turbocharger for LT
  205. Where to get turbo car tuned in Florida
  206. worlds quickest pump gas car
  207. What kind of power would this make?
  208. Hey Bill/Marko/Hiflo/SCTC in here!!
  209. Ngk Tr-6
  210. Pulley Change?
  211. How is it possible
  212. Vortech+LS6 valvesprings= safe?
  213. lifting heads on iron block
  214. Front Mount Camaros
  215. 1000~rwhp on pump gas?
  216. Best stall for FI(auto guys Help!!)
  217. Scavenger pump options
  218. sd-concepts ?'s
  219. Meth Inj Questions
  220. twin turbo rear mount
  221. Breaking Piston
  222. cutting out under high Boost?
  223. ~LOW budget turbo build~
  224. Where to run charge pipe on drivers side
  225. Added some underhood bling and picked up 2psi...
  226. Iat??
  227. Any reason why my car won't make more than 9psi?
  228. high hp auto guys inside please...
  229. 11.50s at 89 mph....letting of at the 8th...VIDEO inside
  230. Did some test driving - learned some things
  231. Installed Ling. MAF and 60lb injectors
  232. ?????????'s on boost
  233. D-1SC & a shot?
  234. Rear mount
  235. approx hp of sts
  236. Indiana (IRP) Fuel pump help
  237. Procharger Fitment ???
  238. stainless vs aluminum IC piping?
  239. Going from a P1 to a D1-what kind of increase in boost will I see?
  240. PVC boosted blow-by!
  241. OBX truck shorty headers
  242. MAP Sensor pop-out?
  243. S/c ??
  244. Altitude and F/I?
  245. Whats Best Turbo For Street/strip
  246. Track last Friday night.vid
  247. Will any UD pully do for a turbo?
  248. new best track time!!!
  249. Questions about supercharging
  250. Who can get me incon turbo's?
