View Full Version : Forced Induction
  1. Rear mount
  2. approx hp of sts
  3. Indiana (IRP) Fuel pump help
  4. Procharger Fitment ???
  5. stainless vs aluminum IC piping?
  6. Going from a P1 to a D1-what kind of increase in boost will I see?
  7. PVC boosted blow-by!
  8. OBX truck shorty headers
  9. MAP Sensor pop-out?
  10. S/c ??
  11. Altitude and F/I?
  12. Whats Best Turbo For Street/strip
  13. Track last Friday night.vid
  14. Will any UD pully do for a turbo?
  15. new best track time!!!
  16. Questions about supercharging
  17. Who can get me incon turbo's?
  18. crossover question....
  19. Cooling turbos?
  20. Car runs -- TTi street T76 kit
  21. MP122H Dyno Numbers.
  22. Turbo Question
  23. ok the beast runs but..im smoking like a champ..
  24. tuning sts cars
  25. t60, t60-1 and t-61
  26. For those who haven't actually seen a Tial WG spring
  27. Its Over!
  28. Front mount intercooler in an F-Body
  29. Twin or Single?
  30. What connecting rods/pistons should I go with when running a kb on a ls6(stock cubes)
  31. F1 Procharger
  32. Single or Twin?
  33. F1R Intake pipe??
  34. What do I need to change on my motor for a turbo setup
  35. Total weight of a twin turbo setup?
  36. Were can I find 4.25" t-bolt clamps?
  37. Need to find forged pistons to get a 346 to 8.5/ Short block because I threw a rod
  38. Enough cam for SC'd motor?
  39. Cubes vs SC/TT for RR Q.
  40. ProCharger dealers?
  41. Powerdyne Blower
  42. Some more Alky Control Kit results.
  43. Up date on my turbo setup
  44. Anyone know Phillip Bridges? (95 turbo TA)
  45. t74, 1.00 on stock 346....
  46. Should i get the hot parts turbo shorty headers coated?
  47. TT 67mm
  48. plagued with exhaust leaks on a turbo car
  49. ATI inlet hat on and off track results
  50. The Red Rocket Steps it up a notch!
  51. FI 383 Stroker on the way!
  52. Turbo runs great only one problem
  53. where to buy meth kit?
  54. Ati p1sc1 idler pulley...?
  55. Paging Jose @ Forced Inductions
  56. Will an STS off an LT1 work on a LS1
  57. Just for fun- Guess the mods
  58. Turbo Question
  59. Pretty parts!
  60. It has arrived!!!
  61. POR-15 on crossover & DP= cool
  62. First Rear Mounted Turbo in the 7s
  63. What Electronic Boost Controller???
  64. head gasket bummer
  65. Sts High Boost Problem
  66. I need an intake elbow
  67. Track Tonight!
  68. alc/meth kit
  69. we have ignition!!!! *video*
  70. Turbo Technology?
  71. Those that PM'ed me here are the S95 pics
  72. diesel help
  73. Accessory Pulley ? Whipple 3.3L 10 Rib
  74. LS1-LS2 Keene Bell 2.6 2.8
  75. upgraded injectors are in...but...
  76. turbo carnage
  77. sts?s and motor?s
  78. does anyone know how to work the HKS evc limited edtion black boost controller....
  79. STS and SFCs will they fit and any sugg.?
  80. What to look for in used D1SC?
  81. which block
  82. alk/meth question
  83. something to laugh about
  84. ProCharger sales.....vs. other SC sales. Looking for info
  85. What size intercooler?
  86. Procharger question
  87. Oil Smell on Procharged C6
  88. dyno results...horrible
  89. ***Hi-Flo Track Times *** videos to come
  90. Ohio Forced Inductions Inc GTO Hot Part Pics...
  91. how fast would a .81 A/R come into bull boost on a 355?
  92. New ARP headstuds.
  93. Phamspeed budget kit - Big Mistake?
  94. One more time before my turbo gets here
  95. Ok..so how about THIS cam?
  96. Tc76 Arrived!!!!
  97. Question about Reichard Racing pullies
  98. sts in houston
  99. Intercooler Ice Box question
  100. New TV81 Turbo Specs & Pics...
  101. Getting ready for FI
  102. How do I hook up a manual boost controller...
  103. innovative street heat turbos
  104. Pete and Craig raise the bar again 8.39 @ 163.55
  105. Cast aluminum 180 degree elbow for LT F-Body?
  106. ~Homemade STS~
  107. need a procharger intake hat or like
  108. innovative T-76 with a .81 A/R for 355????
  109. Stock Head Gaskets/Bolts good to what PSI?
  110. quick question
  111. Navy David SS ????
  112. Whose car is this?
  113. At what point do GM heads not cut it?
  114. Search down--anyone use the stock fans as pushers with the ATI fan and shroud?
  115. Props to Mike Brown...
  116. Is a solid roller setup beneficial to turbos?
  117. Homemade Kit
  118. A few rear mount questions (and PCV pics)
  119. Procharger people: Has anyone had any experiences with the PRO YANK 3400
  120. Got the Alky Kit & KB BAP Installed
  121. my T/A smokin vid.
  122. Oil Restrictor Where?
  123. ?????
  124. any feedback for the MP t70?
  125. Help Finding Fittings
  126. home made turbo headers back from Jet hot
  127. 10 sec junkyard motor... going 9's soon?
  128. drag week thrash help...
  129. Anybody running a carb and turbo?
  130. TTI street kit clearance-minimum should be what?
  131. Replacement belts for ATI Procharger
  132. North Vs South Photo Album! (also need info)
  133. Mysterious Lack of Boost
  134. Somebody better jump on this deal on an F1 ProCharger!
  135. Turbo and Nitrous ??
  136. ~Twin Rear Mount~
  137. Congrats to Tom Kempf on his new best...
  138. How's this cam for FI?
  139. 31 psi Video
  140. sts cam selection
  141. Oil evac setup vs: catch can / pvc setup
  142. Those who run scavenge pumps
  143. Is there some super secret trick to V band clamps?
  144. Someone please lend a hand here.....
  145. Long tubes and Rear mount turbo
  146. Whining noise in my bird
  147. alot of smoke
  148. results on the stocker
  149. Untuned STS 60mm... Xylene an option???
  150. Heat wrapping crossover gained 3 psi
  151. New Maggie MP122H
  152. Roofer Dave's car 7.69 last night
  153. Serpentine Belt siz for a Pro Charged 01 Z06!
  154. would you put a blower on this LS1?
  155. coating the hot side of the turbo
  156. The butt blower is here!!!
  157. not starting right and a P0343 code, what's up?
  158. n/a or turbo or supercharged please help
  159. Oil line restrictor poll - guys chime in
  160. Paint Vs Coating Intercooler tubing
  161. New pulley?
  162. GM Vented Oil Cap
  163. Boost Motor Help
  164. Sts?
  165. Turbo Suggestions Please
  166. Tee'ing off the brake booster line?
  167. North vs South Shootout - Extra $100.00 of ATI ProChargers from Exotic Performance Pl
  168. Downpipe size T70
  169. Who is running a 8.9 or below CR??
  170. WTF! Car wont make boost on dyno..
  171. turbo tuning opinions
  172. Spool time
  173. AN size drain line with scavange pump
  174. Worth It or Wait???
  175. what converter
  176. look at this cam.....give input
  177. What do you think about this LT1 turbo cam.
  178. How to remove EVAP system - does it hurt anything?
  179. Safe boost??
  180. Will a small cam increase your IAT on a turbo setup?
  181. AllPro FI head guys... what plugs are you running?
  182. Truck manifold peepz q's within...
  183. PCV Z06 Catch Vent $10!
  184. how much of a restriction would a 90* angle coming of the turbo be?!?
  185. Well I think it popped. You tell me....
  186. new t-70 but no v-band
  187. ~Custom Turbo Kit~
  188. Guys, I need some input
  189. sts dyno graph?
  190. TurboLS1SS, I'm almost ready for ya...
  191. Opinions???
  192. How much power can you be robbing by running dirty air filters?
  193. What does a dying turbo sound like?
  194. what pistons is everyone using
  195. What compression for sts
  196. what intercooler is everyone using
  197. Gathering correct parts for my build... few questions
  198. guys check out this cam
  199. new to the s/c world and need help
  200. The Real Price of Forced Induction
  201. ~Help me build something FAST~
  202. Cant stop the smoking
  203. Having great results with Procharger on C6 Corvettes
  204. Procharger question
  205. My two best friends.....
  206. Twin gt40's or single GT55 (91mm)
  207. Need help with O2 sensors
  208. The "Some Hi-Flo shiznit came in today" POST IS NOW A STICKY
  209. Pics of Camaro front end w/ FMIC
  210. Can you guys post some pics of your fmic/airdam setups please?
  211. Mustang S.c.
  212. HELP NEEDED!!!! Oil remote pump
  213. Can a/c condensor be used as cooler for A2W setup?
  214. What would make more power and throttle response?
  215. ls1 missing at high rpms help?
  216. silicone elbow blew with only 10lb.
  217. sts rear mount #'s on a stock car
  218. Source for Garrett parts
  219. Turbo question (please dont laugh)
  220. Procharger Bracket flex
  221. Header recommendation
  222. Made a new inlet hat for my Procharger (Warning!! alot of pics)
  223. Dream car with a nightmare!
  224. What does a turbo rebuild cost?
  225. Porting the throttle body.
  226. New Filter?
  227. Questions about turbos
  228. Vortech users come in
  229. is there a way ti keep the AC
  230. Looking for an Incon turbo or compressor housing.
  231. Power differences between truck manifolds and headers
  232. Duke goes 7.51 @ 186MPH!
  233. wire diogram for sts setup
  234. What kind of difference in 1/4 mile times do you see from summer to cooler weather?
  235. STS Z06 PCV Vent!
  236. Vic Jr. Intake = hp??
  237. oil catch can questions
  238. Paxton for an LT1 ????
  239. Are there still any issues with the Procharger SC units?
  240. getting there w GT47-88, #'s inside...
  241. Ohio Forced Inductions Inc. F-body hot parts pics
  242. what r the day 2 day problems running FI
  243. What does this mean?
  244. What exhaust housing choices do I have with this turbo?
  245. Where to find this turbo?
  246. garrett or turbonetics???
  247. Supercharger or Turbo
  248. Need A TURBO or S/C ????
  249. Lt1 CAmaro front mount
  250. TTi log and spark plug wire clearance?
