- wastegate question
- where to but 5" exhaust?
- p1sc @ 5 psi on stock tranny/tires/rear safe?
- Turbo Orientation
- Max power on a P600B
- Virginia Speed forced induction engines
- Forged pistons on stock rods Hp/TRQ limitation?
- budget twin turbo 6.0 questions
- APS passing smog in So-Cal
- turbo question??
- what rear gear is best for turbo's
- Stock LS2 + boost + spray?
- Stock cam or Xfi 292
- best intake for forged ls2 w 317's d1sc
- Updates on our TT C5 Z06 w/ short Vids..
- Holset Diesel turbos
- Looking for TC76 rear mount results
- What's the difference in truck manifolds and camaro manifolds
- poll do it your self or a shop
- STS??? APS??? opinions and advice wanted
- Boost Bleeding Off = Bent Intake Valve?
- is this normal for a blow off valve?
- Auto or manual for a procharger
- Blower cam 346
- DIY TT piping
- Looking for yellow silicon hose in 1 1/4"
- HSRK on ProCharger?
- turbo cam
- tell me what you think...
- maf to sd step by step what do I have to do?
- anyone SC and 60#Siemens using LS1edit?
- How much overlap is wanted with a blower vs turbo?
- GT-55-94T vs FI98X
- Whats the highest boost on 2bar setup?
- wantin a bigger motor for my turbo build
- Out with the Old in with the New!!!
- A few turbo questions
- Why am I not making any boost?
- Heat wrap for rear mount turbo help please!
- gauges
- Boost leak symptoms and speed density.
- heat issues, coolant/tranny/oil....Help!
- D1SC on Ebay...Question
- wastegate sizing
- To turbo or not to turbo that is the question
- Anyone use the AEM Meth kit?
- 7 seconds...FINALLY!
- 5.3 and s480? yes/no?
- Cheapest d1sc kit
- My99 problems questions, ideas..
- 2010 camaro- procharger finally got it right for the fbody!
- Oil feed and drain on wrong side?
- HOLSET HX-35 DIESEL TURBO. need help ASAP!
- how much can stock ls6 handle
- which procharger headunit???
- cheap turbo build??
- Help with PBV on on procharger kit.
- PTK/Ebay Kit Belt Issues
- The best place to measure boost
- MAF Limit
- intercooler piping?
- where is the ideal place to measure boost?
- Will this turbo work?
- Got my F3/Geardrive today...Pics!
- do i change motor oil when i go turbo?
- L92's and boost
- Confused on Speed Density pish posh..
- need powerdyne bd-11a parts list please
- What's everyone running for a coolant overflow?
- quater mile times
- New aps lg upgrade pics
- vortech sq9 pulley change
- Mahle Pistons?
- 403 l92 turbo build advice needed.
- Vortech's new VTS twin screw blower... will they make kits for vettes and camaros?
- New FANTAZ Video!
- PCM learn mode for SC and 60#inj tune
- My KYTP GT47-88 Manifold kit
- MSD8733 Launch controllers available!!!
- ***power difference with compression help ASAP***
- changing head gasket. need help picking
- Anyone have the fenix999 alt. bracket? What size belt do I need?
- busted 90mm FAST intake
- Bottom support for vertical mount rad setup?
- Solid motor mount and rubber tranny mount question
- Not a GM Platform but a GM engine with TT
- D1SC & short belt mod on an F-Body
- Back-firing out of the exhaust
- Can some share me some hptunes for similar setup?
- procharger set-up
- What spark plugs for a 9.8 to1 boost 427 motor ?
- New Turbo exhaust
- ati j-bracket good enough?
- sell fast intake or not?
- Low boost HELP!
- Manifold mounted supercharger with drive in front and inlet straight into the back?
- Turbo vs. Supercharger help
- Complete ATI ProCharger/EPP LS1 F Body D-1SC Kit On Sale!
- gtm tc78 vs t78 vs precision 78gts
- Different Way To Ask The Q
- C5 front mount w/a intercooler
- Twin Turbo 434 LSX Corvette
- TurboD Lt1
- Anybody mind taking a look at my Idle Airflow table?
- results from modifying and re-tuning my rear mount
- Manual boost controller (sponsors?)
- Single Plane or Stock intake on LT1?
- APS allternate mass air pipe?
- Octane Booster
- thread size on sts checkvalve?
- best place to purchase a set of stainless header flanges and any primary size sugest?
- Video walk around lsx 434 tt
- Realistic price for my motor/blower setup?
- can 5.3L heads be used?
- how interchangeable are meth kits?
- Solve a dispute between me and a buddy
- Procharger BPV problem?
- My 370 buildup (for F1 procharger) WARNING: long post & lots of pics!
- Wide band bung?
- help..tt intercooler on single t70
- turbo oil return on front timing cover?
- Fuel drops 5 psi
- E85 and meth injection
- Want to replace Procharger 16" Fan
- Twin Charged, Compound boost with BW S475 Turbo and TVS 1900 Blower On A Truck
- Over heating with a verticle griffin. Anyone else??
- What gears to run with T76
- Already bought two turbos, now I think I want to go bigger
- Help with turbo oil connections?
- STS / cam question
- More power needed !
- Found a boost leak...
- anyone have video of their atmosphere WG?
- Turbo question
- Got my car tuned...questions...
- Another option for the puller fans
- Vortech T-trim Upgrade
- Switching exhaust setup for FI
- Need to quiet the car down, a LOT! My idea in here
- throwing belts
- POWER from a D1
- New to F1 section need injector help
- LS1 92 Z28 swap... which turbo?tc78? BW s475?Ideas?
- Just curious as to how much weight a Procharger setup adds?
- Can't go WOT
- Eating map sensors
- duramax diesel turbo on my ls1?
- Could my cam Really be Hurting me?
- How much hp can a stock ls1 handle safely on 93 octane?
- Feels like throttle slams shut.
- Help me figure out what is holding me back.
- what would good heads be for FI
- Guys with FI cars!
- Drilling holes in MLS head gaskets ?
- Cats to catless throw off tune???
- New alternator bracket
- D1SC Question
- How to determine What Size Turbo I have?
- Procharger Question
- NINETRES in NHRA??? 144mph??? Oh yes.
- High Comp & Boost
- Need some help please!!!
- The new 2010 FORD SHO
- looseing boost
- Piston Talk
- Started my turbo build! PICS!!
- FI + spray
- Good crank for supercharged application?
- Big Red Race Valve Placement?
- Stupid Question
- Wanting to go S/C. Looking for some input.
- Anyone running Precision 6262's??
- Radiator question
- Which cam for sts turbo
- Confusing O2 readings, need expert opinion
- LMR Twin Turbo Corvette Dyno Vid!!
- roots vs twin screw
- Twin MC76 turbonetics turbos for sale!!!!!
- Is my wg 2 small?
- Who's best to get a Custom Intercooler from?
- Opinion on custom 76mm Turbo set up for my 2010 Camaro
- FMIC on Vortech instead of Aftercooler
- 5.3L Boost questions?
- WG Dump Question
- Gforce Engineering's GTO Turbo build
- Burkhart's Dog Days of Summer Sale
- 347
- Project NIGHTMARE for LSX Shootout!
- Head gaskets
- Vid 1st crank 434 LSX TT
- Turbo with a 6 Speed?
- no Boost
- If I hit the rev limiter under boost will it blow?
- Who runs with no intercooler?
- Wiseco GFX rings good?
- Can anyone give me an idea what some parts are worth (parting car)?
- turbo guys in here need help
- EPP Front Mount F1A Air Inlet
- 98 f-body 2bar conversion wiring pigtail?
- Powerdyne supercharger??
- Belt for P1SC
- New APS Upgraded Turbos
- Fastest 60 Turbo F-body
- Speed Inc TT LS Typhoon 1/4 mile video
- 317 heads or 243s
- want to see what material you all are using for your turbo setup
- How much boost can I run and how is this cam?
- f1r procharger questions?
- blower got crazy loud
- alittle different turbo question
- smallest procharger 8 rib pulley?
- will it fit?
- cam help!!!
- What would you do?
- FI question
- 8-Rib Gates Belt
- Vid-1st crank of LSX 434TT
- Wastegate(s) question
- Which turbo(s) would work best for me?
- wtf do i do for a turbo exhaust?
- What size pushrod to buy for boosted 427 with TFS245 heads
- HP limits of 317 heads
- boost with procharger
- Main bearing wear with a supercharger
- t88 seized t4
- Forged 347 + Meth + D1SC.
- Blow-Off, Pop-off, Wastegate on a SC Engine
- Wideband questions,opinions..observations..
- stock LS1 psi?
- Thinking about getting heads what CR should I got for
- HELP: changing a2w too a2a need help to kinda understand it and do it
- Turbo Newbie!!
- need help with fuel system/boost referenced regulator
- interchangability between GTO/Fbody Prochargers?
- eboost2 install tips and tricks and pics???
- Rule 3700 pump part 2.
- Eagle or Callies crank for FI?
- Vic Jr or LS6?
- Intercooler piping
- LT1 vs LS1 Procharger kits
- We're getting ready to hit the track with an F-1C on the EPP Camaro
- The Trickflow 245 heads what the intake runner height and width
- Anyone running one of these?
- Anyone have results after adding methanol w/NO tuning?
- which heads should i go with?
- Backyard turbo
- Meth color?
- Should i trying a EFI super victor or victor jr with new motor ? whats needed to run
- Aps guys who are running front sway with spacers come on in!
- Is my Impeller Screwed Up?
