View Full Version : Forced Induction
  1. Camshaft choice for STS
  2. 1995 camaro lt1 vortech supercharger runs lean
  3. wastegate ?
  4. Why wouldn't this work for the truck mani guys? Keep A/C
  5. gaskets?
  6. Golden Eagle Vacuum Manifold
  7. charge pipe sizes
  8. Any downside to knockoff wastegates? (examples inside)
  9. Is this turbo for real?
  10. ball bearing turbos....justify the cost
  11. Typically, how muh to make your own turbo kit?
  12. Is anyone interested in an Incon kit?
  13. flipped Mac mid lenghts?
  14. search is broken...what radiator?
  15. test runs in Nova
  16. Final FMIC install pics.
  17. Cutout
  18. new ideas
  19. Questoin About two bar?
  20. FI help
  21. New 10 Rib 'Vette Blower Mt. From ECS
  22. Anyone Want To Swap 96's For 83's??
  23. Are Precision On-center Turbine Housings Same Size As Turbonetics??
  24. wtf is up w/this...
  25. hey i need 2 V-band clamps
  26. Procharged guys, what exact plug are you running...
  27. Extra injectors or Methanol-
  28. New Friend for the camaro is here.....
  29. So 15lbs of boost isnt 15lbs of boost?
  30. ATI Cooling Improvement (Pics)
  31. No power
  32. How Much Airflow Am I Actually Taking In?? Experts??
  33. F1/F2 Procharger system...
  34. meth or nitrous?
  35. Gmr
  36. STS oil return into oil level sensor?
  37. Kenne Bell BAP-will a 40 amp be okay for a single pump?
  38. FMIC Pressure loss question
  39. Hi-Flo Update 6-7-2006
  40. Loss of a/c questions
  41. Scaling IFR to get negative LTFTrims for 60lb injectors-26%!!! FI application
  42. to MAF or not to MAf that is my question
  43. Power differance between mid frame and large frame turbos???
  44. Pulleys, Meth, And Boost Amount ?s
  45. 35 fi
  46. impression of my 1st CAS TT ride
  47. Maiden Voyage-Twin T67's-Short Video
  48. help! intermittent misfire
  49. high rpm closed throttle with SC
  50. F2 in a WS6....anyone done it?
  51. LS7 build up
  52. Can I tilt my radiator forward with the condenser still attatched?
  53. PCV Options HELP!!!!!!!
  54. Synergy All in One product line....
  55. what can you do to move oem radiator forward some
  56. Oil to Rear Mount Turbo
  57. Radiator Size
  58. wow crazy 99 pcv (not) valve
  59. plug gap for 20+PSI
  60. crank case pressure problem ???
  61. Turbo question
  62. Boost reference (fuel regulator) for STS...good setup?
  63. Who sells Procharger headunits?
  64. Whats the RWHP record with a F1R?
  65. blown Z06 fuel problem...??
  66. Quick Truck Question
  67. cutting radiator support?
  68. how to move radiator forward
  69. 90 mm throttle body for ls6
  70. phamspeed FMIC PICS
  71. flx-220
  72. to big for a 4.3L?
  73. Did some WOT Logs-I think I have a fuel issue-help?
  74. Why do you get more HP with a turbo set up?
  75. New Supercharger! now 1 question
  76. Need help with procharger noise/pulley issue *pics*
  77. bleeding off boost with this cam
  78. rear mount build up questions
  79. Few Q's
  80. GLM Tuned 382/Vortech (719hp 757tq)
  81. STS troubleshooting help
  82. 346/D-1SC@16psi=717rwhp@5200rpm Whats next?
  83. oil return question
  84. New 2 step and much much more just released by Synergy
  85. GMR Speed Twin Turbo
  86. Fmic??
  87. What's my compressor wheel trim?
  88. Kaos Released II ...w/pics
  89. Help me find this flange
  90. Some C5R pics
  91. MTI Procharged C6, Stock Block, Cam, and Heads - 711 rwhp!
  92. STS guys come inside
  93. Motor is once again ready to rumble!!!
  94. What exact sparkplugs for DART 225 heads on D1SC blower 9:5 LS6 motor?
  95. Explain A/R !!!
  96. Where To Buy V Band Clamps
  97. WTF Texas speed....????
  98. Turbo C4 dyno vids and initial numbers
  99. 700 rwhp with procharger possible ??
  100. menthal? alchol? gas pump fuel
  101. The new set up is up and running just working out a few bugs
  102. Roofer Dave's car ... 7.87 @ 179
  103. Vortech 38lb injectors rated at what pressure?
  104. turbo to big for the 4.3L?
  105. Tuning straight methanol, gots a question for the meth freaks..
  106. 25 to Blow
  107. Supercharging an LS1
  108. Water, Alky, Meth wtf is the difference?
  109. I was wondering????.............
  110. Hairspray??
  111. A/F Meter
  112. Timing Q
  113. Kenny Bell LS1??
  114. 408 iron and d1sc procharger
  115. bob @ EPP
  116. Another Hot Turbo Car?
  117. my FI PCV/Crank VAC system.
  118. turbo question here!!
  119. Oil pressure changes?
  120. The 9 Second STS build...
  121. coolant over flow tank?
  122. most rwhp out of sts turbo?
  123. Mounting of DevilsOwn pump?
  124. So what's the latest greatest clutch for FI?
  125. Can't make more than 13 psi
  126. The car runs!!!
  127. Video Of My 14 Psi, 751 Rwhp 93 Octane Dyno!
  128. should i run this
  129. Procharger Clutch setup...Help
  130. FI for California guys!
  131. Methanol More Boost???
  132. STS style turbo kit !------- and some general turbo questions
  133. What do you think I will spend????
  134. blue smoke at startup?
  135. Happy Birthday Kyle (NA$TY-TA)!
  136. Turbo Kit done, with Forward headers!!!
  137. First E85 LSx setup? Anyone doing this?
  138. What's the max with this setup?
  139. Thoughts on this cam for turbo????
  140. Safe amount of boost on a stock bottom end?
  141. Cut out after turbo yes or no
  142. Tuning?
  143. what is the difference in 98 knock sensors vs 99-02
  144. Initial Startup/Dyno of My Twin T-67's
  145. Video of my Nova idling
  146. Cost to rebuild 60-1 Turbonetics turbos????
  147. Laminova intercoolers?
  148. 6.0 heads n/a?
  149. W2W "SUPER" nova
  150. Reichard Racing 3.600 DIA Pulley...Boost?
  151. I hate fuel injection, but i love Forced induction (thinking out of box)
  152. anyone run boost w/o 2 bar pcm upgrade?
  153. My thoughts about meth injection
  154. From nitrous to turbo-----------!!!!!!!!------
  155. Oil Feed line question with Pic.
  156. turbo question
  157. Whats it good for?
  158. bov?
  159. STS owners, oil return?
  160. how much for procharger installed
  161. Should VE and MAF be calibrated for 9psi?
  162. leak checks
  163. DCR, 92 octane, F-1 or YSi trim , and me...
  164. At 10#`s of boost what would be the hp difference
  165. Need Vortech Instructions
  166. Couple shakedown passes *video*
  167. MP T70s mounted
  168. Downpipe flex pipe?
  169. How Much Boost?
  170. What upgrades could I do with a P1SC Procharger, to get the most out of it?
  171. Any before/after results of going LSX78 to 90/90 on 346-348 LS1 turbo car
  172. FMIC Installed (w/pics) Boost control Q too.
  173. i have a 8 rib ATI kit, what do i upgrade for the SDCE?
  174. Looking for a Turbo tune in Norfolk, Va area.
  175. How many larger turbo (80+mm) street cars?
  176. Paging Intmd8, how is your staged fuel injection working out?
  177. Big single turbo peepz, what muffler are you running?
  178. Caveman, did you sell your T-Trim car?
  179. A realistic HP guess?
  180. Jose Line One Jose Line One
  181. how much rwhp per 1 lb of boost???
  182. F-1 Growl
  183. Frustrated... Procharger guys... PLEASE HELP!!!
  184. Strange boost problem
  185. I bought a Procharger today!!!
  186. GT42 guys inside...
  187. Hp/Tq #'s From Truck Mani Setups??
  188. procharger cam ?
  189. Timing question...
  190. What shortblock "upgrades" should i look into for my build?
  191. Trick to Sealing V-Band clamps?
  192. pvc question
  193. need a drain flange...help me out please
  194. boost + ls1
  195. 1500 Rwhp.
  196. Trims?
  197. Tell me about your ATI 8-Rib experience
  198. Checklist
  199. map tune or maf for sc
  200. z06 Cam after FI
  201. u guys still using TR6 plugs for 750rwhp?
  202. cam good for a supercharger
  203. What do i need to use a MAP sensor instead of MAF?
  204. 751 RWHP on 93 Octane
  205. very disappointed in CAS kit...i need some serious help please!!
  206. What is the rail to rail width on 4'th gen camaros?
  207. ??? on turbos
  208. Procharger?
  209. hi-flo website?
  210. overboost?
  211. What heads should i run with supercharger
  212. pulley size
  213. Strongest shelf forged piston for turbo 402"?
  214. Need Advise on Firebird FMIC
  215. IC or METH ?
  216. IC Spray
  217. tial WG & BOV
  218. Finally gonna be boosted!!!
  219. TR5, TR6 or which plug for Powerdyne blower.
  220. blow off valve to the atmo or tie back in
  221. what did you do to get to 650 or more HP?
  222. What DCR for 6# Supercharged?
  223. Supercharger!
  224. breaking up
  225. difficulty level of supercharger install?
  226. 600 Rwhp....
  227. Where to get 5 inc pipe from????
  228. car is almost done! not FI tho.
  229. turbo m6's, what gear do you run??
  230. MAF Output Choppy
  231. turbo and stock block..??
  232. Rear Turbo Pics
  233. best buy single turbo kit not remote mount?
  234. Motor Build
  235. Mufflex + twin turbo
  236. What TH400 torque converter with your turbo set up??
  237. Dyno results for twin T70 GTO
  238. Tuning
  239. About Cats and Forced Induction
  240. Which bearing for forced induction?
  241. 35 rwhp gain with mac midlengths over stock manifolds
  242. fuse box relocation bracket
  243. Oil ?
  244. Holdener F/I power calculation formula
  245. GMMG + twin turbo ?
  246. Less cubes > More cubes??? With a procharger at least?
  247. Muffler for high hp (>800 rwhp)
  248. guys running stock heads... what times/power?
  249. ATI belt pully change in vette (Godbless)
  250. Pics of the Bell IC mounted for the Incons.
