- 4 inch stroker crank vs stock crank...FI application pros and cons???
- Please help - advise me on my build...
- Fabricating a GTO Vortech for a WS6
- STS turbo lag video...
- SDCE tensioner Blew up
- Which stall convertor for big boost???
- Anybody have sts instructions?
- how much boost
- supercharger compressor map reading vs pulley size
- Valve Seals
- how much diff will twin logs flow over tubular headers?
- Meth injection suggestions?
- how much HP capable with 91 octane w/ std meth injection ?
- took the car out tonight and....
- anybody running a 60-1???
- Procharged (D1) M6 Track Times?
- safe boost?
- are truck manifolds different from side to side?
- 67mm single turbo - losing boost in upper rpms
- best turbo mods for stock motor
- In the situation again of either procharger d1 or 76mm turbo
- oil spitting out the back w/ sts
- corvette procharger kit
- F1-C c6 Water Pump
- Procharger p1sc mounting question
- 370 turbo cam ????????
- Will a STS turbo work with this exhaust?
- Prochargers and Exhaust??
- Most power out of a stock block..
- Exhaust sound, weak?
- AEM boost controller??
- AC compatible LS1 tubular headers with merge collector- OFI style
- ls1 heads on a 5.3l... good for boost?
- Max CR on forged pistons?
- FI help have some ???'s need help
- Turbo's???
- how much power are the boosted 6.0s making?
- Quick cam question
- Procharger Race Valve
- pics of flipped truck manifolds facing up
- Turbo ID? (scammer?)
- Truck manifolds
- puttin the sts on.
- step up ratio vortech V5 ?
- p1 procharger kit on my car
- Cam overlap and Boost
- Turbo upgrade coming for the Undead Sled
- 160lb injectors and a injector driver box
- Twin Turbo LS1 Skyline.
- Requesting help from turbo and procharger guru's!
- turbo damaged worried?
- Anyone had to replace bearings in the Procharger idler on the bracket?
- 78GTS vs. PT88 Dyno overlay inside on same motor
- APS Spool
- Rear mount guys: Header wrap?
- turbo rebuild question
- boost ref. fuel pressure regulator
- twin 94's
- LS7 gaskets not good for iron block and boost
- Aluminum vs. Iron
- Question for Procharger Guy who have added a second fan
- just simple question
- Rear mount turbo question!!
- Did ur insurance company send an agent to check mods?
- oil line fittings...brass or AN?
- How about this cam profile for turbo app
- What Catch Can???
- Please help me find a downpipe for a 1989 Turbo T/a
- how much power?????
- Lt1 sts q...
- X or H-pipe after turbo?
- Need Input ASAP!
- 2010 Camaro w/ T76 anyone?
- difference between
- Trans selection for turbo.
- Which headers for supercharger?
- supercharger timing?
- Boosts problems need some help!!!!!
- manifold gaskets?
- Check out this Corvette.
- procharger HELP!!!!
- LS9 supercharger
- Help with New Cam
- OMG another which turbo thread!
- 383 turbo build??
- catch can question
- Procharger
- Who makes this C5 kit??
- looking for a 5" velocity stack
- Big TVS blower on my LS3
- L19 Head studs
- F1A on a 347?
- Turbo PCV options
- Hellfire rings in Metric sizes?
- Turbo ?'s
- need opinons from forced induction vets.
- anyone boosted a high mileage motor?
- Winter project... We like it cold (pics inside)
- SDCE bracket or COG set up for F1A 6spd street car?
- have some questions on turbo build on what parts
- Ofi
- magnacharger or procharger for 500rwhp
- ls2 pistons in a 6.0
- Using a 5.3 block for a 347
- need answers please
- What Fuel Pump and Gears
- Some build pics from today!
- FMIC Guys Come in!!!! ASAP
- Recommendations???
- Dropped the car off at Dallas Performance
- LS3/L76 intake VS L92 truck intake boosted
- your opinion on my set u..HELP?
- Another D1SC or F1C? Thread
- How much boost can stock headbolts handle?
- Gas Turbine JET engine Turbo wanted!
- GM High Tech Perf Down for the Count?
- once turbo seals start to leak is it too late?
- Max boost with a LS GM casting head?
- Have you ever seen this!!!
- STS rear mount turbo
- Truck Manifold walk trhough?
- Who do you recommend to build my FI short block?
- need help with IAT sensor
- TURBO CAM for L92 6.0....hows this?
- Engine having issues at low boost
- Rod bearing clearance
- PT88 ok to add oil restrictor?
- Powerdyne??
- ls3 and boost
- Ls9 supercharger
- Anyone bearing a steering knuckle for APS?
- Stock Bottom & Boost - Reliability List
- boost gauge install
- Final #s from TTi/402 A6 C6 Inside
- MP T76 news...
- Centri Superchargers... max psi?
- DIY Turbo Gurus Come in and Help Out With a Turbo Build Idea
- Some pics on my updated build.
- How many of you dowl or pin your mains?
- My new c6/6.0 mani a/c setup came in pics!
- Aps twin turbo upgrade c5 zo6
- Anyone looking for a large A2A?
- Running a hotchis front stab bar with APS?
- Bumper cover for FMIC??
- LS2 GTO procharger on LS1 f-car
- 6 bolt head question
- 954rwhp c6z!!!
- New to FI ??
- Which block? How many cubes?
- faster spool with same power
- 842rwhp @13.5psi Another APS TT C6 ZO6 by Speed Inc.
- Truck manifolds and steering?
- forged 347
- Debating on d1-sc or t72 turbo...
- how cheap have you turboed something part 2
- what are these procharger parts worth new?
- Low budget turbo questions
- turbo build
- Gonna try something new this year-a Vortech YSi!
- Anyone know anything about the T-netic's gtk turbo's
- 408/F1-C Vette
- Oil Pressure port.
- Difference Between D1 and D1SC Prochargers
- turbo with TH400
- ATI Pin Kit, ATI Dampner Help.
- LMR in Doha Qatar!!
- 16psi w/ Fast 92mm Intake pics inside
- Ideal Procharger Exhaust
- FI cam question
- check valve behind LS6 manifold
- Motor is out: How much $ to convert to low compression for turbo setup?
- LTx hangin in there :) New dyno vid and numbers!
- where to find 4" + ID silicone connector hoses?
- What oil to run??
- Timing Set Question
- STS guys please chime in!!!
- how much boost can a F.A.S.T plastic intake can Handle
- 13 psi on a 11:1 engine pump gas or e85????
- heads for turbo ls1????
- Ayone running AEM tru-boost?
- Converter on mild FI
- tvs 2300
- Cant buy OFi so i made my own !!!
- 5.3 pistons
- Are LQ9 heads any good?
- h/c for supercharger set up
- STS - separate turbo oil system Qs
- Few quick q's about meth
- surge valve too loud
- EPP's Cog Drive Assembly for F Body ProCharger now available!
- TVS 2300.....out with the old, in with the new!
- Carburated supercharged LS1?
- Long COG Belt?
- Which gate?
- Rear mount turbo setup, oil return pump suggestions?
- Just Completed 2000 TA Maggie Install!! Dyno numbers!!
- Hey what are you TT guys running for exhaust
- curiousity question..............
- Spray meth before the intercooler?
- Belt Needed?
- Gen-ttr turboI got a qu
- NEW FORGED MOTOR ..... TWIN TURBO Experts COme in!!
- Procharger Question!
- ls1 with sts turbo
- Another blower belt question
- Wideband not working
- PolyTech cog belts
- sts questions and concerns
- What headers can be fipped/modded for twin turbo use?
- tell me what you guys think about my new "blower" cam???
- 5.3 turbo build????
- Best 16 injector intake.
- Where to position methanol nozzlel, maf, and IAT sensor
- So am I the first one to blow up an LS6 manifold?
- How come there are so little F.I. bin files?
- New intake going on
- Wanting a rearmount, help me get it started.
- STS Problems
- Hey guys, Twin screw questions
- cruise control question
- Wastegate spring... maxxing out at 13psi!?!?
- my LQ4/4L80E tc78 build
- New Dyno Numbers: 700rwhp+ LS1 Stock Bottom A&A Vortech V2 S-Trim System
- Procharged C6Z?
- 8 sec Nitrous guy going FI??
- ??? P1SC to D1SC ???
- LS1 to LS6 need help please with supercharger!
- Simple question
- to much power
- Procharger+ nitrous?
- Need some help, GT42 turbo
- Looking to go turbo with stock motor. few ?'s
- APS turbo questions
- cutting out front grill
- l76 intake 2bar map part number
- whats the biggest cam i can go with on a turbo setup?
- How much power is too much for dd...
- Can a stock LS1 be built to handle more boost?
- Pullying Down... guesstimate on boost/power?
- Port or not.
- D1sc impeller damage.
- 38mm wastegate to small for 80mm
- STS Rear Mount or..
- too much meth?
- Autometer electrical boost gauge wiring
- Put forged rods/pistons in my stock LS2 or buy a shortblock?
- cobra s/c on ls1??
- 347ci 900-1000hp turbo build questions
- 403 Kene Bell
- I wanna go turbo
