View Full Version : Forced Induction
- Happy Thanksgiving
- procharger crank pinning tool parts needed
- external wastegate location
- Greddy EBC & Tial Sport Wastegates - Need Installation Instructions
- FG-WGATE-50 springs
- FMIC pics on lt1 T/A?
- Twin or Single turbo system for a 427 or 454ci
- stock motor and turbo questions??
- How much power did you lose going TH400?
- turbo build question
- truck turbo kit(new company)
- Looking for 600+whp with ls1
- need to see dyno out comes of APS on
- FPR too close to blow off?
- Is it worth swapping to an LS6 intake?
- AirFuelRatio question
- Heat soak question
- real help for modified sts
- Rings...
- Of the three, what intake would you use
- Catch can
- Question w/a Magna Charger TVS1900 on a M6 Car
- magnacharger 112
- 2 step on t56 logged data
- supercharging a stock LT1
- Say Good Bye to the Red Rocket
- Carb'd turbo setup
- anyone use this?
- diesel turbo
- Radiator caps?
- Which Blower for Road Racing?
- Heads for boost
- Last Minute Turbo change?...build almost finished...help?!?!
- calculating boost with a twincharge setup
- How long with a MP T70 Live?
- 59cc chamber head.. would you still boost?
- Comp map for the TC-76 and 78...
- New Truck Manifold crossover Fbody turbo crossovers now available on ebay?
- Have a few questions
- Turbo build
- Twin Turbo recomendation please!
- All Custom Rear Mount Setups In HERE!!!
- holset turbos
- 454 LSX w/106mm - Lots of Pictures & Videos
- thinking about going turbo?
- Idea for PCV System / Turbo Oil Return...
- OfI 4" Exhaust clearance pictures
- I was looking for some answers. non LS1
- well its about time (vid inside)
- Forcing my LS1 upgraded AMC..
- Plug Reading
- More turbos???
- Ditching the MAF
- A4 turbo gearing
- All sts users
- 800-1000rwhp turbo cars what exhaust.
- Paxton SN2000
- What would you do.....
- 346 v 364/370 for tc78
- What kind of gains should I expect?
- budget build s10
- Sdce ?
- Machining a Block for more Sc brackets
- HPT for boost?
- Replacing Head Gaskets this morning. Question though....
- ls3 Pro charged in a 69 Camaro ?
- Boost 406 noise like lifter
- Fuel setup advice please
- Some more low 10's from my track outing and got it weighed at the track scale.
- Pulley size vs. rpm
- Blown vs. Turbod? (Biased views welcomed lol)
- Is it me, or is my car getting quieter...
- Equal length header tubes on a Turbo build?
- Convert to SD and catch can ?s
- Cog belt brand question- Goodyear, Gates, Dayco
- L92 GT-47-88 Startup video!!!!
- How good is a Ebay kit
- 5.3L vortec, 89 Caprice Classic, Turbo - oil feed line
- oil pressure and a turbo....
- Crankcase scavenging mandatory?
- need help identifying a turbo GT42?
- Twin Turbo G8 goes 11.00
- TTi Street Kit Installation Istructions
- SD vs. MAF Tune
- F1-C F-body installation problem ! help
- Early Christmas present to myself...
- 09 CTS-V 6.2 SuperCharger
- I have the ultimate SC setup!
- Question on spring loaded tensioners
- New Build - LS7 - D1SC - A/W - N2O
- turbo protection
- turbo build cost?
- weird supercharger problem...
- Turbo flow: inlet reducer vs changing compressor
- AR help,
- Which turbo for Autocross?
- Cheap blow off valve??
- high hp motor which poweradder
- Turbo Build Suggestions
- *** I DID IT !! Smashed the 8-second Zone today ***
- Why would a throttle body be ON the turbo inlet?
- My New Turbo Build!!!!!!
- Turbo kits
- need a cam
- Cool dyno vid....91X on a BMW
- 2003 Z06 with A&A vortech kit
- Lets see some results for the TC-78...
- Now imagine this technology once it hits mainstream turbos..
- anyone have plans for one of these
- Cheap Ebay Turbo Kit?
- Best heads for Turbo ls1?
- mocal scavenger pump
- Patriot Dual Spring Failure
- belt driven scavenger pump
- how do i wire a scavenge pump and alky pump?
- New turbo on order
- Turbo, supercharged,or nos
- Block recommendation for street/track car
- Are ARP head bolts enough?
- Newbi help stock botom
- 402 ls2 with d1 /m6 GTO
- Truck manifolds
- Fuel system question.
- single turbo blowin through a carb
- Couple questions on finishing up my build
- Screen or No Screen FMIC???
- Forced induction head gaskets
- cross over length? is it important?
- Reliable intake setup for boost
- Pillar pod paint matching.
- Eboost 2 got one coming install questions tips and tricks..
- Procharger F1-C pls help me ????
- diesel turbo
- will i need it re-tuned
- magnacharger mp112
- Turbo hotside from ebay what you think ?
- after-turbo exhaust dumps, can we see some pics?
- carb style intake question
- Finally Got Some Dyno #s For the 408 & F1
- Is anyone using any Knock Off Wastegates or BOVs?
- LSX or Iron Block
- 2-step?????
- Dope style with a ram air twist Trans cooler
- Incon Wastegate Actuator Questions
- LS2 block cylinder walls max boot psi/hp/start to balloon Any info on dry sleeves to?
- Stock car (Turbo or Supercharger)
- Good info maybe even should be stickied.Concerning smoking or oil burning from turbo.
- Its Back?!? 218/228 Hot Chili Cam + BOOST?
- My custom FMIC setup thread
- Procharger tensioner bearing seizing!
- Conpression of 347
- Quench question
- what size wastegate and bov?
- Turbo Size sugestions
- master power turbos
- eboost2 on twin turbo..do I kneed two solenoids?
- JDM Ebay Turbo....who has them???
- Help a Honda buddy pick a turbo?
- is a kenne bell in f body possible??
- Quench with a Supercharger
- Bypass valve questions
- T4
- 6-71 looking blower for ls1?
- Question regarding loss of coolant on my Turbo car...
- 2000 vette 5.7L(head gasket?)
- Fuel system
- Procharger pulley size
- LSX Block's!!
- spool time
- Our cog drive with reinforcement brackets
- Opinions or experiences with this intercooler?
- T3 turbo rebuild
- Cam for Magnacharger build...
- CAST PTK TopMount manifolds
- timing chain.
- Procharger VS Turbo Dyno Graphs
- turbo kits ?
- good streetable cam for supercharged 408
- 2 turbo questions. Turbo size and manifold
- Blower, Cam, and not HEADERS??
- Turbo swap on 91 Syclone with pics
- what valve springs you guys recommend?
- APS guys number eight plug and wire changing?
- S400 Too Big?
- How to Mount an Intercooler
- oil feed question
- these kits any good ?
- help getting 2bar
- Anyone using the Speed Inc Alternator Relocation Kit? Need feedback =)
- Turbonetics TNX-122
- Edelbrock Supercharger???
- Turbo feed/drain question
- New turbo
- Boost refrenced Fuel PSI Regulator for Turbo
- Procharger exchange?
- too low of compression..7.9 to 1
- Problem solved!
- procharged 490bbc lost oil pressure
- A1000 or A100 platinum???
- New APS track results (stock shortblock)
- any destroked builds out there
- Oil Pan Recomendation???
- Blown Motor caused by OIL STARVATION!!
- 440ci Z06, Ebay "PTK" kit; some results, some questions.
- JGS Wastegate and BOV
- Car running better with new PCV setup..
- cat-back on TT 427
- what kind of power u guys making
- At what point is a 4" Downpipe a noticable restriction
- Finally got into it.
- LS1 Forced Induction Hall of Shame
- Finally made it to the track with my A&A C5Z
- Open Down Pipes Bad???
- Need turbo recommendation LQ4/9 6.0
- 06 GTO - SC M6 vs TC A4? FI Gurus Talk To Me Please
- Mild Steel Manifold Flanges?
- need help!!!
- Bov placement question?
- will these work and big enough?
- ls1 turbo build
- Coolant hoses
- Dual oil coolers?
- Sold off the Formula
- Burkhart Radiator setup for FI
- Finally ... My nine second six speed.
- What should i do? Pulled the ARP Head Stud out of block.
- Whats the best year ls6 cam to go with?
- Manifold differences....
- Best for my application?aps twin turbo or procharger
- Truck Manifolds?
- sts turbo set up
- Where to go next?
- clutch problems
- should I upgrade my fuel system
- need help (PETER APS)
- Front mount swap how much hp gains
- I finally took the FI route...
- APS KIT/ TTI @ 1000rwhp possible????
- .224/.232 114 lsa good cam for forced induction with l92 heads?
- 2 bar MAP?
- Last runs of the season: Car goes 170+ mph
- Adapter, Tial 38mm to 50mm Jgs Wastegate
- t3 manifold change to t4?
- ProCharger Pulleys, Where to buy..?
- Good cam for 383 LT1 supercharged
- what cam for 408 t-trim supercharged!!
- diesel turbo?
- front bumper
- How can I get a fail safe MAP signal?
