- Just bought STS Kit, no bashing please
- Bullet muffler suggestions please??
- 1st time Procharger install, a couple of questions....
- running plumbing outside the engine bay
- 16" procharger Fan?
- Does anybody have a Really Quiet D1SC?
- Destroked 6.0 + T76 = Fun...
- turbo mounting bracket
- sts kaboom
- Will this turbo work?
- intercooler
- anyone heard of or use this alky inj kit
- Which FI set up?
- Boost/ HP limits for a STOCK LS1 shortblock?
- f body magna charger
- Why are most setups not run to their full potential?
- AEM uego wideband gauge?
- GMR SPEED TT engine bay pics....
- Sheetmetal intake for FI
- Help me build my setup
- well finally gonna dive into it.
- PTK vs. HI FLOW
- My friend is pretty busy....
- A project from last weekend...
- Oil Requirements
- Oil Requirements
- So who has an ATI + N2O?
- Injector size for 383 Lt1 sts
- injector size for 8-9psi STS kit
- OBX 3" FMIC
- Pics of 88mm GT47-88R
- just lookin for ballpark power figures
- leaning toward turbo
- Procharger Possibly For Sale
- Vortech YSi Help?
- supercharger choice
- BAP, which one? MDS or KB?
- Charge cooling (Magnacharger) where to start
- GMHTP Feb cover car
- Help with piping
- What if an LS7 met with...
- Belt size for 3.6" pulley D1-SC,
- downpipe ?s
- Procharger
- Enough BS,lets see dyno #s for ebay intercooled cars
- What is going on in this pic
- How much noise does a cogged belt add?
- More dyno #'s ,, 14.5 psi
- Problems with turbo kit STS need help
- Cam Suggestions Please
- Getting My T-trim Rebuilt
- Behind Pass. Seat Intercoolers
- 11.30 1/4 mile at 142mph - Our twin turbo C5 Z06
- D1SC vs T-Trim
- time for the next step. i need help picking out a turbo/turbos for 1600+fwhp
- what happened to HI-Flo?
- Sts Question
- BOV placement
- My new turbo is in the shop
- STS Question
- cleaned maf = running rich??
- How many are running a cooler Stat like 160/180 degree
- procharger guys with twin intercoolers/small IC fans
- my 3rd gen TT build
- anyone in ca to fab twin turbo headers
- c6 kit to c5
- Post up dyno numbers with stock motor and turbos.
- Help choosing new turbo...
- welding to the oil pan
- best bang for the buck for S.C.
- Any problems spraying meth through the MAF?
- Motor is finally done! Bling Bling pics...
- Temperature in headers VS crossover pipe
- STS turbocharged Heat Shield???
- T3 vs T4 (Turbine)
- new sts turbo kit
- SMIC possibility on trans am?
- caterham / super7 idea - few simple ls1 questions
- Need help...
- D1SC Belt problem too small?
- Wastegate or Pullies???
- What size injectors do i need for 8-13 psi???
- What is a safe amount of boost
- Silicone Vacuum Hose Diameter
- Turbo Oil Feed?
- How much Boost Before Belt Slip Occurs?
- another sts question regarding the exhaust
- need help w/sts kit (ls1)
- check out my shirt!
- surge valve for p1sc
- Engine test fit
- guys w/ alternator relocation.....
- Need pics of single turbo builds....
- Turboooooo
- Milling LQ9 heads?
- Parts for procharger
- STS Spool time
- Building my OWN Procharger KIT
- Which plugs to use and at what gap?
- Few questions on a D1SC..please help
- Cool turbo SS build-up at Icon Autosports..
- Hey, what do you guys think?
- All in one gauge you FI might be interested in
- Quick turbo selection question
- Ordering fans for powerdyne tmrw..couple questions
- Electric Fans HELP
- Supercharger maintenance?
- Phamspeed install after 8 months of waiting
- Turbonetics Suggestions...
- looking for turbo kits for c5
- upgrading fuel system
- Roots Type Blower
- Which first? H/C or SC
- Apexi avc-r boost controller help...
- Happy New Years To Fi
- PT 2, My truck manifold turbo set up is done and running!
- Injector size for turbo?
- Powerdyne belt slip, Help Again!!!!!
- Which Boost Controller To Buy for STS
- GMR or GroundZero kit?
- GMR SPEED TT pics inside
- CAR WONT IDLE! wtf ! Help PLZ!
- sts turbo what plugs to use?
- STS Turbos: Cat or no cat
- where to get threaded air temp sensor??
- question revisited...15psi doubles the N/A hp, right?
- Turbo Screens...who else runs one?
- 5.3 truck with custom GT42 results
- Air temp sensor on turbo
- Cheapest turbo kit
- quick tapping question
- 994rwhp 863rwtq
- What's better for FI LS1, Hi CC Low DCR or Low CC Hi DCR?
- Pros and cons of 2.5" crossover vs 3"
- Is anyone running aftermarket Fuel Rails with there FI setup?
- for the experienced sts lovers
- where do you buy rubber elbows?
- D1SC is it TOO much
- I love my LT1
- Which head( 241, 243, 035) for stock bottom end and 8-9 lb P1SC
- Which Procharger
- turbo oil line size?? dumb question?
- Who fabricates turbo manifolds?
- what to get
- Can I tap my oil pan here or not really?
- bs3 boost controller - any information?
- Twin Turbo LS1... What injectors?
- What AFR Target for FI + Nitrous?
- Boost Gauage Directions
- Any DIY'ers lookin for a turbo?
- The Lux-0-Barge from Down under
- Supercharger...Should I go with 2.5" or 3" TD's?
- Get rid of the PCV or not??
- can I reuse my Cometic gaskets?
- Low boost in lower gears
- STS rear turbo kit & Catback ???
- Need intercooler pics
- Is installing the Procharger also a good time to install a pulley?
- (Plugs for STS kit)
- install instructions for Incon twin turbo kit...
- Question about setting up oil lines for custom rear mount single turbo.
- Another FI head question
- procharger boys running FMIC
- A&A vortech kit + 02 Z06?
- Turbo Header Fabrication
- Pros and Cons of these superchargers?
- Question regarding setup
- Has anyone made there own custom turbo setup ?
- 3.3 Whipple
- 851 rwhp mustang dyno vid
- what rear on a turbo car
- Turbo charger
- ~ 2006 Boosted List ~
- Turbo charger
- radiator? for a turbo car
- 6.0 manfold stud removal and bolt replacement
- Where to get turbine parts??
- What Fuel Filter with a Supercharger?
- What type oil are you using?
- heads 4 FI
- sts kit (rust on the turbo)
- Good idea or bad, coating turbo from sts
- Anyone having trouble with their methanol pumps?
- Oil feed line restrictor
- how long should a open dp be?
- Please give me your opinion on this turbo...
- 9 second and faster turbo a3/a3 cars...
- soon to be FI LS1 owner
- Custom truck manifold hot parts for sale
- Looking for an oiling system for a custom rear mount set up, please help!!
- Would I see more rwhp - Gear change
- need help with 2 bar hardware
- Who has the advantage?
- What head gasket to go with for HIGH boost???
- Help me pick a mild blower cam
- Different Air Filter Set-Up for Vortech?
- Superchargers
- what comes with procharger kit
- homemade turbo system
- Lets say I wanted to push 12+ psi on my P-1....
- Just bought STS
- How to deal with oil coming out of driverside breather filter
- Piston compression height
- Part # For Procharger K&N Filter...
- guaging interest ATI P1sc stage 2 kit *NEW*
- LT1 Turbo Question
- merry christmas
- Pulleys for F1R
- How many guys running 396-398 CID?
- I Got Turbos For Christmas!!!!
- Max boost on a stock 5.3...
- 98 firebird v6 supercharger
- SLP flow pac (help a new member out)
- CAS bin file
- whats the max hp on a build but not exotic motor combo
- Compression height
- Heat shields
- STS issue! Please help!
- Higher ratio rockers w/ FI setup?
- Hot cam with turbocharger??
- What heads and cam on a Z06 with a blower
- Poweryne belt slipping, HELP!!
- Collector test fit pics
- First runs on the 408 /T88 combo
- Blower?
- What Blow off Valve is everyone using
- KAOS' Custom truck manifold turbo setup, pic inside
- Corvette vs. Truck manifolds...
- Big problems with Pro charger setup!
- ls6 pcv conver. and AMW can????????
- To all you motor heads!
- mechanical or electrical boost guage
- (STS Kit) Best Blow off valve for LS1
- Custom intercooler
- Headers
- Collectors are finished
- Rear Gearing for a turbo app.
- opinion on ls1 powerdyne 6psi system??
- Final pics
- POLL: TT kit for the F-Body
- where to find a 500 cubic inch small block ls2?
- turbo gauges
- alum intake elbows
- Boosting questions
- Requesting some help. How to shape oil dipstick tube around turbo?
- Procharger P1 on a stroker #'s????
- What Crank Pulley are you running with Procharger...
- Who makes a good single turbo kit?(non STS)
- D1SC and passing emissions?
