View Full Version : Forced Induction
  1. To all you motor heads!
  2. mechanical or electrical boost guage
  3. (STS Kit) Best Blow off valve for LS1
  4. Custom intercooler
  5. Headers
  6. Collectors are finished
  7. Rear Gearing for a turbo app.
  8. opinion on ls1 powerdyne 6psi system??
  9. Final pics
  10. POLL: TT kit for the F-Body
  11. where to find a 500 cubic inch small block ls2?
  12. turbo gauges
  13. alum intake elbows
  14. Boosting questions
  15. Requesting some help. How to shape oil dipstick tube around turbo?
  16. Procharger P1 on a stroker #'s????
  17. What Crank Pulley are you running with Procharger...
  18. Who makes a good single turbo kit?(non STS)
  19. D1SC and passing emissions?
  20. f13 112 and P1SC kit
  21. Now boosted!
  22. Is this for real?
  23. Vortech SC sound clip?
  24. Intake Question about new GMHT Mag.
  25. daily driver
  26. Looking for Pics!
  27. Where can I get a T6 turbo flange?
  28. All business...That's all I can say!!
  29. Super or Turbo?
  30. 398 iron block + turbos at 8.5 PSI + M6 = fun
  31. highest comp. for FI and 105 octane
  32. Leaky Vortech aftercooler
  33. What FMU should I use?
  34. Procharger, intercooled, 8 psi on STOCK A4 FBody : RWHP????
  35. My FI setup!
  36. STS Kit In Finally (need help)
  37. what changes would i need to make? STS
  38. Copying the Incon TT kit
  39. Truck Manifolds And Stock K Member?
  40. Can ANYONE Get Me An Incon Part #
  41. gas mileage with supercharger?
  42. I love Pic's like this.....
  43. bought shortblock instead of building myself
  44. C5 turbo manifolds??
  45. LS1 Kenne Belle ETA?
  46. Anybody make intake plate adapters for Superchargers?
  47. Installation of a EGT A/F Guage XD-1 Kit...
  48. Boosted M6 guys.
  49. Twin Scew on an F-body?
  50. twin kit ?s
  51. Phamspeed Install
  52. Radiator and Fans
  53. STS kit with out tune
  54. RANT: How come noone has made a QUALITY Stock Alternator relocation kit yet?
  55. 40X CID + ET heads + F1r...
  56. Need Sts Instructions
  57. max effort stock blown ls1 vs max effort stock ls1 w/150 shot ... what is faster?
  58. Nitrous or Turbo
  59. what size and where to find?
  60. Procharged 370
  61. whos got the gmr turbo kit
  62. Project Lightning...almost done!
  63. POR-15 the STS turbo housing???
  64. STS turbo kit
  65. Brain fart
  66. Sponsors who are Precision dealers???
  67. sooo close, twin turbo buildup
  68. how much psi can I run on stock bottom
  69. Pretty head repair
  70. gains witrh racegas?
  71. Maggie cam and differential gear ratio
  72. Latest Incon Dyno - 644/701
  73. Wastegate ????
  74. Please Discuss here: Does Oringing the Block/heads make an engine stronger?
  75. STC/Hi-Flo Street Force TT Vette - 692rwhp/660rwtq STOCK SHORTBLOCK!
  76. It runs
  77. anyone run f3 or f4 procharger..?
  78. What wastegate are you high hp guys using?
  79. Which Turbo?
  80. turbo cars at the track?
  81. need help guesstimating rwhp
  82. Holy Pressure ratio bat man... BW turbo maps
  83. What Kind of Exhaust are you running with Procharger/Turbo???
  84. Stock MAF with Procharger or Aftermarket...
  85. Look out HUGE breakthrough in turbo design..
  86. Hurst knob -- high boost switch for turbo
  87. Where is a good place to buy turbos.
  88. Will my 2 1/2" Exhuast Handel FI POWER?
  89. What size belt for 02 Powerdyne kit?????
  90. Attention W2W engine build customers
  91. Procharger install how-to?
  92. Blower belts?? 52" 8 rib?
  93. Predictions for HP on new setup...
  94. NEED Powerdynesupercharger Impeller
  95. Progress Pictures...
  96. Solid Roller Turbo Dyno sheets
  97. Gauges Needed with FI...
  98. Weld Ells vs U-bends
  99. Magnuson Mystery Part !!
  100. where to find reasonable 4 into 1 collectors
  101. anyone running a LT1 PTS turbo kit
  102. mild steel down pipe?
  103. "Roofer Dave's" engine lives!!
  104. Hi Flo website down for a few days for construction
  105. SIN 14 featuring Hi Flows TT vette
  106. Yeah, Another STS post.
  107. Folks with FI and Vacuum modulated trannies inside, please
  108. which makes more power?
  109. '05 C6 coming in today to begin installation of an ATI ProCharger
  110. Almost done with my 408 turbo truck!
  111. supercharged 402 or 408...
  112. ASP pulley has more slip than Vortech Pulley - Why?
  113. AFR with Turbos....
  114. Can I run a supercharger on a h/c/e ls1?
  115. NGK 3 and 4 Stage Colder Plugs...Good for FI?
  116. supercharger people, a little help if you would...
  117. LS6 intake manifold restriction?
  118. Finished up my truck manifold turbo set up..
  119. twin turbo 427
  120. Water cooled turbo here, need coolant feed/return (did search)
  121. Spark Plugs and Wires for FI...
  122. Zex spark plugs
  123. LS1 motor/ATI procharger/1970 Camaro
  124. Another Ohio Car, first pic release!
  125. Tial Wg?
  126. TR 227/224 114 good turbo cam?
  127. turbo kit do i want the ground zero log style
  128. Fuel Pump Question...
  129. Yet Another Turbo Ta Buildup
  130. Some updated pics
  131. Stenod White Formula...Motor, Turbo kit and fuel system for Sale!!
  132. Best plug for magnacharged 383 with meth
  133. best stock fuel rail setup?
  134. Turbo oil drain line size?
  135. New Edelbrock Intake
  136. STS system
  137. Turbo/component selection 347...
  138. 908rwhp 908rwtq Speed Inc. GT76 single turbo
  139. Cost to upgrade a P1 to a D1?
  140. What to do??????
  141. 1143rwhp, 1119rwtq Custom PTK set-up
  142. whats a quiet muffler for turbo app?
  143. PTK Turbo Kit set-ups, please check in!
  144. Guestimated RWHP???
  145. Turbo Exhaust Setup
  146. what am i missing?
  147. ATI aluminum damper with SC?
  148. Project Lightning...Big A$$ Intercooler pics!
  149. Finally got the engine running right but now.......
  150. What are the bolts sizes for the bolts that hold procharger to J bracket
  151. More questions for you STS experts
  152. ATI Super Damper with supercharger?
  153. first tuning session of new setup
  154. Truck manifold setup's
  155. Finally got to the dyno part 2
  156. sts exhaust
  157. AFR 225's, Stock Bore and Turbos?
  158. Best Meth kit
  159. Oil in down pipe
  160. Best material for tubular turbo headers
  161. Turbo Carnage (pics)
  162. STENOD Build-up Pt 4
  163. Any research on T3/T4 Hybrid vs T4 turbo flanges?
  164. Thinking ahead, need opinions. Which blower?
  165. looking for a Good daily-driver turbo setup
  166. Powerdyne missing Parts?????!?!!!
  167. SDCE guys in here
  168. How much BOOST with stock heads?????
  169. Our phone lines and a snow plow...
  170. Newbies with boost...
  171. Status on PTK install.
  172. how do u get oil to turbo?
  173. Clutch for FI guys?
  174. Comp 206/212 for turbo truck...
  175. E85 boosted setup
  176. My 05 GTO twin turbo kit arrived
  177. vacuum operated cutout for turbo setups?
  178. Turbo Cam for STS
  179. Incon car blowing smoke(oil) through exhaust, need help
  180. How well would u think this Motor would work with FI?
  181. STS guys
  182. 6.0 Manifolds
  183. turbo repeat
  184. Almost finished!
  185. what belt for 3.5 pulley
  186. getting ready to drill oil pan
  187. turbo quad question
  188. LS6 & 225cc or Carb & 205cc
  189. 150 passes + 14psi + graphite head gaskets + stock heads =
  190. Octane Question
  191. W2W Tecstar Rotrex?
  192. Building 408 for my D1 Procharger Setup...opinions!
  193. Chevy turbo kits
  194. need a mounting bracket for my supercharger
  195. tang or on center
  196. Bored of the 408 F2r.. What next?
  197. Problem with autometer A Pillar
  198. Waistegate Atmospheric Dump
  199. 222-216 reverse split cam with a supercharger?
  200. 2 step explanation?
  201. STS owners?
  202. ffhp's single turbo for corvette
  203. The new setup!
  204. Might be picking up a 98 Z28 w/ turbo and blown tranny...need tranny advice (A4)
  205. IAT sensor mounting...
  206. waste gates and blow off valves
  207. ati twin intercoolers on an sts kit??
  208. turbo or pro charger
  209. help me decide on setup
  210. Hi Flo Twin Turbo
  211. jethot 2000 for turbo manifolds?
  212. LS2 Compression ratio for a blower?
  213. gage pod and boost controller pics
  214. Would you build a 408ci TT or purchase a Viper and TT it?
  215. 98 ss with powerdyne. having problems
  216. 224/224 and procharger
  217. STS leaking oil on exuaust pipe
  218. Anyone have any HI FLO TURBO DYNO # YET????
  219. FI Question
  220. STS turbo for $3500 (new) a good deal?
  221. First trip to track w/ new ATI setup
  222. check this out!! twin whipple
  223. Vaccume pumps and dry sump oiling...
  224. So i had a fun sunday did everyone else?
  225. Tell me why the turbo guys don't use shorty headers?
  226. Best electronic boost control
  227. Do I need a vacum pump?
  228. OMG!! Not another "what turbo" thread...
  229. Best Oil Catch Can/tank?????
  230. F.I. SCR issue (request advice)
  231. Compression ratio too low?
  232. STS SoCal
  233. i have a question about heads. help
  234. O2 placement for STS turbo answer
  235. Anyone running PRC Dual Springs with Boost?
  236. Performance Racing Industry 2005 Photos!
  237. Professionally Installed
  238. 363 versus 383 cid with a T-76GTS
  239. best compression for whipple charged 408?
  240. PTK mock-up
  241. Where does your combo make peak torque?
  242. question about turbo lag
  243. Vortech TA & C5
  244. T3 with .84 a/r or T4 w .81 ar
  245. not ls1 but double your hp at 8psi?
  246. Sts T60 A/r???
  247. H/C D1 Question
  248. Turbo kits For BBC
  249. Time to lose the tubular turbo manifolds..
  250. I got the SDCE setup, but i have a question.
