View Full Version : Forced Induction
  1. Which head gasket for 76gts and forged bottom?
  2. New best ... 10's so close!!
  3. turbos
  4. C6 Magnuson installed with hood pics
  5. Who has the Fastest F-Body using a true STS?
  6. Mike Romain Signel Turbo Vette Pump Gas = 9.66
  7. What clutch are you guys running?
  8. Procharger whine.....anything I can do to quiet it down a little?
  9. supercharger recommendations
  10. LS1 Crankshaft Drill Kit Help?
  11. Blower belts
  12. stock pump
  13. What would it take to build your own meth Inj. Kit??
  14. All you Accufab and Wilson Tb users...
  15. Turbo cam comparison and dyno results
  16. huh, ever see a 4" obx type (xspower) intercooler like this?
  17. Finally, PRELIM numbers, home T76 kit.
  18. Where to find S/C belt
  19. Help needed...
  20. Vortech S Trim vs. ATI Procharger P-1SC
  21. 8 rib pulley for SDCE tensioner??
  22. Intake hat for the D1-SC
  23. Supercharger or Turbo for me???? Totally stumped
  24. HKS boost controller
  25. F1 pulley torque specs?
  26. Plastic Plenum
  27. Hi Flo's "Street Force" twin turbo system for C5 is up and running
  28. Who holds the record for highest 6 speed FI on pump gas?
  29. (THE OFFICAL)help noobies choose the right cam for application!!!
  30. Turbo guys - do you use a full dish or partial dish piston??
  31. Finally started my own LS1 camaro TTi race kit turbo project
  32. D1SC pulley swap! Glad I did it.
  33. Turbo for road race?
  34. best turbo kit
  35. single or twin turbo?
  36. Running A/F < 10 . . . Build Boost Or Not?
  37. Where to get a bypass valve
  38. turbooost
  39. Any reason NOT to use a BOV w/ my turbo?
  40. If you are looking for YSi stuff....
  41. Did BigTTPaul run a 8.5?
  42. MasterPower GT45 results
  43. Finally!! Got the tranny, motor, and twins installed!
  44. Any suggestions on a possible problem
  45. Blow off valve
  46. ls2 402 twin turbo VIDEO
  47. IAT relocate to EGR location. How?
  48. Turbo or Supercharger!!!
  49. GMR SPEED twin turbo ......
  50. Extreme FI Heads....
  51. Need help! Which turbo system to buy for emissions compatability?
  52. Turbo Stuff at SEMA 05
  53. Multi Level Boost controller
  54. Internal Wastegate - Downfalls?
  55. Need Sts Tuning Help In Il
  56. cam
  57. Weiand 144 Blower
  58. STS turbo size?
  59. Street Killer Dyno Numbers
  60. Cam for Powerdyne kit????
  61. Any pics of LS1SPEEDs "Eliminator" turbo kits?
  62. Turbos "Look Inside"
  63. Is it possible to buy everything but the head unit?
  64. Procharger needed
  65. CARTEK C6 Stage 1 Twin Turbo First Track Runs, 10.62 @ 130
  66. New to the Turbo... NEED HELP
  67. STS Doubters....
  68. LT1 Procharger 12 rib D1SC/P1SC 7.65 and 3.40 people inside!!!
  69. crank pulley problem
  70. SC's with ported & polished TB?
  71. Should I be OK with my 918s for the time being? *9psi and 6.0L heads*
  72. Need assistance on FI gauge selection
  73. ***Make Your Own Sale - Save Up To $400.00!***
  74. Roots type blower?
  75. Turbo guys inside (STS)
  76. boost gauge?
  77. Made a few 'street trim' passes this afternoon
  78. PTK is finally here!
  79. need advice on tt sbc project
  80. ATI Procharger 5-7 psi
  81. Design on FMIC... HELP!
  82. Post Pics of your Meth Setups
  83. Whipple Superchargers?
  84. Pic of turbo headers
  85. Anyway to stop the STS oiling of the engine?
  86. New STS Times
  87. Want to upgrade to an 8-rib
  88. 67 Camaro's 104MM Update
  89. Deeper in the 8's with CE
  90. ID of Precision turbos
  91. A/R ratio for 427ci twin turbo....
  92. Magnacharged LS1
  93. W2w
  94. advanced turbo tech
  95. TTi Stage X - Stock Bottom End - Corvette Dyno Numbers
  96. cam with super or turbo,good idea?
  97. D1sc kit on Ebay? Is this the old style D1?
  98. Rough Idle problem solved!
  99. Lrry93 finally good results from the STS
  100. Where to spray meth at?
  101. Where to spray meth at?
  102. DIY 6.0L truck manifold TT?
  103. part # for 8 rib belt from a/c to ati damper
  104. Precison released there own line of ball bearing turbos
  105. Did you know.........
  106. Newer Numbers
  107. Hi-Flo Horsepower Numbers
  108. procharger/LS1/1970 Camaro - has anyone done this?
  109. lQ9 heads??well im ordering a turbo and new heads and cam
  110. Bandwidth at EPP
  111. ?'s about stock ATI bypass valve...
  112. pt88 questions
  113. A2W intercooler fill.
  114. drive 3000 miles with an STS?
  115. twin 67's....or.....
  116. I need experienced opinions on the STS turbo setups
  117. Difference in meth/water/washer fluid ??
  118. Wtf Is Wrong!?!?!?!?!
  119. Rumor Has it 3 Hot chicks are working on my Turbo TA
  120. MY friend IS nuTS! 10 PSI ON A STOCK MOTOR!!
  121. low-end torque loss on turbo cam
  122. Can I drive without tune?
  123. Help me finish my SC setup.
  124. Any SLP shortblocks with FI
  125. Turbo Horsepower Numbers
  126. T56 w/ twin setup
  127. 10/27 Turbo Upgrades
  128. single gt35 on stock ls1?
  129. which way to go
  130. Futral Does FI Too! New Shortblock!
  131. Why do supercharged cars seem slow???
  132. LS1 pumping out 837 hp @ rear wheels!
  133. oil drain to oil level sensor hole?
  134. Cool Air plus Boost=mucho fun!
  135. Belt tension on a D1SC
  136. HOw many of you have saved your crank after spinning the balancer
  137. Boost on a D1SC
  138. 01 SS Supercharged complete
  139. coughing back thru intake, popping pipes loose
  140. Boost w/ F1 impeller RPM maxed out????
  141. A Different Boost Gauge Question
  142. Blew out my Jet-Hot Cats
  143. Ain't No Quitting at Hardcore!
  144. different crank pulley with procharger???
  145. What RPM should I see full boost at from a P-1SC?
  146. Has anyone attempted this?
  147. Need help choosing a cam
  148. sts abd AMW PCV catch can how to install it
  149. ATI Back Bracket
  150. Help w/ boost and some N20
  151. Fuel injector question
  152. Boost gauge question
  153. just got my STS Turbo
  154. Transgo kit for STS and 4000 stall
  155. twin turbo "kit" for fbod?
  156. some recomandations on wastegates and BOV
  157. Intercooling your turbo???
  158. Coming Soon... The Magnuson Experience!
  159. LS1 knock sensor vs LQ4 knock sensor
  160. Will this work on a sts set-up
  161. A few newbie FI question
  162. Budget Turbo Kit/Pre-fab Kit???
  163. DFI help please
  164. Preliminary Dyno numbers on "The Beast" Dyno graph inside
  165. Need help analysing this cam for my application
  166. Vac/Boost gague, where do you hook it up?
  167. Best combo for 5.3 heads
  168. what plugs for Vortech SC IC with H&C
  169. valve job for FI setup?
  170. Eastern Forced Induction meet.
  171. Magnuson's LS2 Dyno Numbers!
  172. Blow through carb turbo systems?
  173. 6.0 truck manifolds.
  174. How come turbos always have that rusted look?
  175. Cooling issues
  176. Twin 63 Turbos, how much power??
  177. CARTEK C6 Stage 1 Twin Turbo dyno results.
  178. whats this guy using to build boost?
  179. Recommended Stall for F/I setup?
  180. alt bracket
  181. Can I run a turbo or SC with a CC306 cam in a stroker LT1?
  182. big blower cams, do I need one ?
  183. Extending MAF wires
  184. Need Some Feedback on Setup (TT 04 GTO)
  185. does a gt47(88mm) really spool faster than a pt88?
  186. Some pictures of the Harlan's TT project and Derty's Outlaw 10.5 project are up....
  187. Metco breathers 1 or 2?
  188. MS3 cam D1SC, and Spray!
  189. Quick update on my 408 turbo setup...
  190. intercooler operation
  191. Replace pusher or add puller fan for ATI setup?
  192. most rwhp/rwtq with p1sc?
  193. supercharged
  194. F-1R placement?
  195. Budget turbo kit questions
  196. Good place to have a turbo freshened up?
  197. Questions by a Turbo Newbie!
  198. turbo kits for gto?
  199. Reworked STS intake piping
  200. 4500 lb sts truck in the 11s
  201. Bah, more issues!
  202. new best for me (street tires)
  203. The beginning of something...
  204. 370" turbo motor, what theoretical compression?
  205. What size reverse split cam 2 run for SC and Stock motor?
  206. 8-9 sec turbo cars what....
  207. Turbo Kits
  208. F-250 intercooler
  209. Pvc-pcv....
  210. New 1/8 Mile Times with STS
  211. My dyno numbers with P-1SC @ 6#
  212. What AFR's do you run?
  213. 99 Magnacharged Z28
  214. ***Garrett GT42 V-band clamp needed****
  215. How to choose P1 or D1?
  216. STS instructions
  217. TBYRNE Motorsports Is Now Taking C6 Magnuson Orders!
  218. Notice: Hi-Flo's Phone System may be unreachable today, 10/21
  219. New Best last night
  220. STS Turbo LS2 GTO...the details and graphs
  221. 2005 GTO Owners - Time To Order Your ATI Supercharger!!!
  222. T76 kit on ebay?
  223. How much out of a Forged 347 and a T-67?
  224. Orlando speedworld world street nationals.... ;)
  225. Turbocharger limitations
  226. procharger 6-rib d1sc???
  227. E-Boost 2 Guys
  228. stock 6.0 horsepower and compression
  229. '05 GTO ProCharger to be released November 15th
  230. 617rwhp on a Mustang Chassis Dyno with an STS!
  231. Magnacharger on a camaro/firebird?
  232. Say good night to the bad guy.....
  233. Million dollar question: manifolds -vs- headers
  234. Need help with cam choice.......Thanks
  235. Hi-Flo Turbo Systems - The final pic thread
  236. cutting hood for powerdyne???? WTF!?
  237. What RPM do you reach full boost at?
  238. whose turbo kit to buy?
  239. Twin Garret T03Bs?
  240. Need help with a procharged Z06
  241. flanges for 2003 silverado truck manifolds
  242. Turbo size for a 632 cubes
  243. New kind of Hybrid
  244. Twin Turbo- Single Wastgate
  245. Homemade ls1 turbo?
  246. turbo 6.0
  247. Stenod Performance Does it again......
  248. My LPE TT Hawk is in the new HPP...pics inside.
  249. 402/408 Plenum Volume for FI
  250. GM 6.5 Diesel Turbos on LS1
