View Full Version : Forced Induction
  1. Using 2 stock GN turbos...
  2. turbo sizing question for an LS1 street car
  3. Building a motor for FI
  4. Lt1 STS turbo kit questions?
  5. Some new pics of my Twin Turbo chevelle!!
  6. Using a AIR pump to help relieve crankcase pressure?
  7. Help with Turbo and Intercooler Sizing on 370ci
  8. boost on stock injectors?
  9. tti street kit crossover
  10. My STS Setup tuning results and STS review
  11. 12 Rib Pulley Question: Procharger
  12. Which 6.0 manifolds
  13. Thinking FI
  14. What kind of horsepower/torque should I expect??
  15. supercharger or turbo
  16. OK so ive got this miss..........
  17. '04 GTO automatic with ATI ProCharger
  18. i need some help
  19. turbo kit what do i want help me please
  20. simple question
  21. in case anyone is interested in Speed inc fuel rails...pics etc
  22. Can I remove this?
  23. boost.... how much???
  24. How many people running low 10's/high 9's on M6?
  25. twin turbo boost levels
  26. Some dyno numbers from GroundZero's turbo kit
  27. need help on turbo sizing
  28. More progress, 9.1 @151
  29. anybody tried a blanket on there STS turbo?
  30. oil pan pics
  31. Any info on Flat mount FMIC?
  32. My Twin Turbo Terror goes deeper into 8s
  33. Two WG springs which to use??
  34. intercooler ?
  35. Who is running STS
  36. Sizing a BOV and WG
  37. Any updates from Hi-Flo??
  38. Supercharger Talk?!?!?!?!
  39. Forced induction for road racing
  40. turbo kits?
  41. cost of fi setup?
  42. Yet another blower cam query.
  43. Turbo size / cubic inch?
  44. Building custom STS turbo system
  45. *engine pics*...when you play with fire...
  46. STS Turbo Car up on ebay
  47. Turbo guys- Your cams overlap?
  48. good spark plugs for fi?
  49. To gasket or not? What do you guys think about exhaust gaskets on turbo setups?
  50. planning FI...... recommendations?
  51. Supercharging a v6
  52. What next, FI or 402 stroker? Help me weigh my options please
  53. Anyone looking for an alternato relocation bracket...
  54. Those of you using the 8 rib setup.
  55. Anyone tried to fit an alternator with truck manifolds?
  56. Procharger Pulley Specs?
  57. Another STS in the 11's
  58. OBX intercoolers
  59. GTO twin turbo system pic - C6 twin turbo system in the pipe line
  60. What is the limit of the stock PCM?
  61. what size engine and turbo?
  62. Single Gt42 Truck Manifold Build...(pics)
  63. When is the aluminum block
  64. I know this has been discussed a lot but what is the best PCV method?
  65. Car breaking up on top end
  66. 16 Spal or LT1 Radiator?
  67. 600 RWHP with a magnacharger possible
  68. DIY turbo kits(whos doing them?)
  69. TTI Kit oil return problem?????
  70. exhaust charge pipe and outlet size.
  71. 8:1 procharger high boost cam specs?
  72. Are you happy with your Turbo/Supercharged setup?
  73. procharger seals
  74. a few quick pics
  75. Finally put all up pics up in a gallery
  76. Finally went 9's with vid
  77. Latest Track Times for TTi T-76
  78. how much boost and power will my 6.0 hold ?
  79. Turbo or not??
  80. i am positive i wil be chewed out for such a dumb question
  81. 408 compression
  82. STS dyno @8.8psi, 100 octane, 140,000 stock motor
  83. custom turbo kit
  84. Reroute of STS thru K-member
  85. Boost control INSTALL???????
  86. My Twins are finally up and running!!
  87. Innovate Wide Band With Gauge --- $249!!!!!
  88. Bigger piping on a STS
  89. How much boost can the 6.0
  90. need some advice
  91. Twin Turbo Z28 runs 6.9 in 1/8th at 117mph
  92. Magnacharger vs Whipple
  93. Racegate installation?
  94. T04R Question
  95. My C5 Twin Turbo kit for sale!!
  96. Need expert opinion on twin turbo LT1 plans!
  97. Ready, Set, Ignition
  98. where can I find out more about trims
  99. Procharger question for 120k mile ls1
  100. MAF (+ piping) rubbing pulleys/rad. fan.. any suggestion?
  101. TTI Kit. Lots of smoke out the exhaust HELP
  102. Procharger fitment
  103. Redline Motorsports Turbo
  104. Which Bottom End for Boost?
  105. Spending lots of $$$ on turbo, Some advice would be GREAT
  106. just placed an order for PTK hot parts.
  107. Intercooling question for TA's
  108. Vortech pulley change
  109. Powerdyne on a 408??
  110. procharger radiator support
  111. Do you have to cut the hood for a Vortech aftercooled S/C??
  112. Who has the biggest Twin Turbos?
  113. 11.2:1 too much compression for boost?
  114. Supercharger differences
  115. what size twins for 370?
  116. Help picking a turbo
  117. Has anyone ran more then 30 lbs of boost?
  118. How much boost?
  119. help me pick another cam
  120. A & A or SDCE Which one is better?
  121. FFHP T76 single turbo Corvette kit
  122. Help finding Coupler
  123. How to do FMIC mounting of firebirds??
  124. updated pics of my twinturbo build
  125. Anyone have an ATI 16" shroud?
  126. Should the coating on my pistons be burning off???
  127. Received my sheetmetal intake
  128. Meziere & SDCE
  129. compcams suggested this cam for turbo...doesnt seem right?
  130. FI safe tune
  131. Z06 cam with 6lb boost??
  132. over boost
  133. ATTENTION: Hurricane Rita & LS1TECH
  134. BOB at Exotic Performance Plus
  135. help/info on ATI 8-rib LS1 setup need instructions or PIC's
  136. Wideband O2 sensor placement on STS turbo car
  137. Speed Inc. shop car video
  138. Supercharger vs Stall
  139. My STS install pics so far....
  140. SDCE and Shims
  141. A/F problem with F.I
  142. 6.0 block for FI applications
  143. I didn't even know how to search for this one!
  144. Guys running Carb intake or plan on running
  145. A2W guys, what size thank, what kind of pump, and what kind of heat exchanger
  146. Alternative to Thunder Shootout --- Need Input
  147. edlebrock shorty's
  148. Sweet, made the cover of High Performance Pontiac
  149. 370 or 408
  150. Methanol Injection with a supercharger
  151. Finally started my project!
  152. Possible or not??
  153. STS Turbo on Camaro SS being installed at Exotic Performance Plus
  154. Where to get AN Lines?
  155. g-body supercharger help
  156. 408 and twin T04's ?
  157. What block for supercharger?
  158. What does "forged" mean?
  159. pusher fan help?
  160. Questions about possible STS setup..
  161. STS kit questions
  162. ATI Damper and belts
  163. Hi-Flo Turbo Strip Killer Progress Pics
  164. Opinions on painting intercooler.
  165. 8 rib belts
  166. New best last night, 9.78 @ 137.6
  167. magnacharger/nitrous
  168. STS guys with FMIC HELP
  169. NEW COMPLETE STS kits found.. Too good to be true??
  170. Dual Exhaust STS
  171. Pic: GM's TT Vortec 4200 I-6
  172. Check out these Vortech T trim numbers
  173. STS dyno on my stock 140,000 motor yesterday
  174. fresh short block or no
  175. hotparts done, ready to install
  176. Would these headers work/last with a big single (shortie headers -vs- cast manifolds)
  177. who all has made their own alky/meth kits?
  178. Meth/alcohol idea
  179. Did i smoke a ring or something else???
  180. D1SC on C6 8 pounds of boost
  181. Header Materials for Turbos
  182. Build up advice for STS TURBO
  183. Vacuum line question
  184. 10's Finally!
  185. Question About STS set-up
  186. New goodies go on next month
  187. Need advice on engine build up for lt1 -sts kit
  188. Stenod car won X/M at MIR LS1Tech race?
  189. Sts Turbo Instal Pics
  190. Got it running good then.......
  191. D1 cam
  192. biggest cam with d1 procharger
  193. Help me choose a cam
  194. Update on PTK kit
  195. Another ATI Super Damper question
  196. PTK, how stable are they?
  197. Flushing a FMIC
  198. New worst times today, yay!! not
  199. mbc
  200. Bore Vs. Stroke?
  201. Finished the PTK install
  202. Bypass Q
  203. T04r Hp?
  204. Everything for FI
  205. Retain Power steering with flipped truck manifolds?
  206. Turbo 6 Domestics allowed in Nopi......
  207. Vortech WHAT
  208. ATI, Vortech and Magnuson Supercharger Specials!
  209. Maybe someone will make a single GTO kit?
  210. lt1 turbo
  211. ATI damper question
  212. how about a PUBLIC vote, me in Extreme Mod
  213. Good cam for S/C
  214. Anybody up for some grudge matches at the EFI Nats?
  215. Alcohol pro's con's?????
  216. Why did my A/F spike?
  217. Hi Flo Turbo system becomes Precision Turbo dealer
  218. Low compression STS 408 with 10lbs with a problem
  219. o2 and maf confusion
  220. What compression
  221. car not making boost ??
  222. LS2 valve springs under boost?
  223. Meth Reservoir... where?
  224. 4.8L Kenny Bell supercharger
  225. Breaking in my engine...info please
  226. how critical is honing w/torque plates on FI engines? vs stock block machining?
  227. PVC and FI
  228. Turbo news 9/15
  229. Picture of GroundZero Motorsports new turbo kits
  230. supercharger or turbo?
  231. Today's September 15th...
  232. Harrop M112 supercharger kit testing results.
  233. sts guys exhaust setup?
  234. Turbo Timers
  235. who carries aluminum piping for fab work?
  236. What size pulley?
  237. Which turbo are you guys using?
  238. Gt42-76 Turbo Came
  239. Which single turbo for 650HP?
  240. STS Owners who have Dynoed ====>
  241. 6.0 heads
  242. critique my set up
  243. Part number for 1/2'' Ls1 headstuds
  244. SCE Titan head gaskets are in stock again
  245. New Boost Controller Question?
  246. Wormboy pix from Clash
  247. D-1SC guys
  248. Air-to-Water Coolers
  249. STS Turbo on stock Silverado 5.3L
  250. will my TR230/236 bleed too much boost?
