- STS owners in or near Pittsburgh PA...
- Tial 44mm wastegate flange and clamp
- what's the quickest anyone has gone in the 1/8th on 12psi???
- High or Low compression?
- Video footage of my car
- procharger or sts?
- Will the ATI 6-rib crank pulley work with a UD pulley?
- belt breakers
- boost options
- Special thanks to Mike at Next Level Performance
- Diff. in AFR from no Meth to Meth on boost?
- lt1 turbo question
- STS (F-bod)guys, What kind of ETs are you seeing?
- E Boost2 Guys...MM, Cablebandit.......
- turbo catback?
- Big Flames from exhaust on Procharged C5
- Which sounds better
- Very Odd Idea
- Turbo Headers? Cost and who
- which cam for turbo?
- STS kit what else?
- Question about installing A/F gauge
- how much will my FMIC block the radiator?
- 2-3" cutouts or 1-4" cutout for turbo setup
- Snow performance GM maf kit?
- Flipping exhaust manifolds
- STS runs and issues....please help
- Alternator & Downpipes
- What pulley sizes for F1R?
- a4 turbo blow off?
- Vortech guys - balancer issue here.
- Got some Motor/Turbo pictures!
- STS set up?
- GTP blower? Not the question you think it is....
- quick FI question #2
- GREDDY boost controller problem-STS kit
- Procharger inline pump... specs?
- 9sec 93 octane setup?
- Belt shredding problems
- anybod have any 3" 90's -pipe not couplers- left over to sell?
- |Congrats to Speed inc and hugger orange!!!!
- Intercooler for a PT91..
- Is 600rwhp realistic for my setup?
- quick FI and N20?
- Catch Can With A Vortech??
- Thoes with a turbo/supercharger and an Automatic in here
- Turbo Differences
- Pin kit for a 6 rib P1SC?
- SDCE set up with ATI damper
- Bad O2s = Lean??
- some turbo ???'s
- GTO/ Light Truck turbo system inquiry
- can I dump turbo oil into the valley of the motor???
- F1/F2 Procharger question
- Built a dual nozzle alcohol system
- How much did you spend?!
- LEAKING Under Boost?
- Its finally here
- Where to buy ATI procharger
- a lil help here getting started guys
- Where is the fluid plug?
- relocating filter on ati is possible.
- STS IAT location?
- Headers Wanted!!!!!!!!!!!!!
- Belt came off!!
- High RPM torque on truck intake manifold
- 157 MPH in a turbo car!
- Undecided on gauges
- Need help deciding on how to go
- oil feed fitting.
- supercharger and stock bottom
- OBX users
- Where to buy STS turbo kit in NJ PA
- Which turbo kit?
- Going Forced
- still learnin n need help
- Pulley change?
- what kind of pumps are being used for scavenge??
- !!!!!!!!!!!!new Part Coming!!!!!!!!!!!!!!!!!!!
- Pro-M MAF
- STS guys, have you switched from manifolds to LT's or vice versa? What difference?
- downfalls to low compression?
- Anyone going to...
- TA Nats Drags
- Any Recomendations on Piston COaters?
- Will I need a different MAP sensor?
- Nasty Performance Sheet Metal intakes
- This is stupid
- A few Procharger ?'s
- phamspeed/GZM factory manifold kit.
- Your opinion on this T4 flange...
- 402 Twin Turbo
- BOV open at idle
- Low compression 408 break in..
- ? about difference in Prochargers from different years
- launching a turbo car off of a transbrake...2-step or not???
- what is needed with Forced ind..:low compression heads ,fuelpump ect...
- Will a 160 thermostat lower iats at all?
- Vortech Superchargers On Sale! Plus You Could Win $250.00!!!
- 2 blown C6's
- How much Hp will I gain?
- Upright radiators anyone?
- Turbo news 8/22
- got a problem with my vortech...
- MM here is that PTE88 race kit forsale on ebay
- Did anyone get valve float with PR dual springs.
- My thoughts on rear mounts...
- Trade for FMIC?
- Turbo or N/A w/Nitrous
- Is there a 2.5 bar map sensor??
- G5X3 with D1SC? Opinions needed....
- SES light Blinks then stays on Help.
- ATI 4 WS6:Help Please!!
- White Firehawk on boost for sale on EBAY
- What do ya think???
- look whats going in the car tomorrow
- Some Phamspeed install pics
- CAS TT update....fab work is nearly finished! Pics!
- WHY are heads not as "important" with FI?
- My 625 dyno graph
- what torque for head bolts?
- LS6 SSR with radix kit
- Looking at getting a charger have cam question
- NEED STS Wiring info quick!!!
- Banks?!!
- Best Magnacharger Cam
- suggestions on water temp gauge?
- New Ic Mounted
- ugh... I need a new wastegate
- Cracked manifold
- Is this setup looking alright?
- Trying to clean out extras...
- Turbo cam selection 101
- ATI Guys: Are you running your air pump?
- Power difference bt 71mm&76mm Hi Flow
- My New Ic... Will This Hurt Anything
- Belt question
- Advantages of a upgraded BOV???
- Turbo my 383 FWD! All welcome.
- lt1 roots type superchager
- Poll: Heads/Cam or Supercharger
- phamspeed guys here!
- Boost cooler?
- Ballpark cost for Single Turbo in Fox Mustang LS1
- Phamspeed budget kit?
- Dont Be Scared
- Are there any single turbo kits out for a stock gto?
- I think hardcore needs to update their web page
- New D1sc Bad Oil Leak
- Maggie I/C pump flow ?too much?
- Photos from W2W open house
- Cars done! Video and dyno #'s inside
- Magcharge/Nitrous
- Anyone got FI on a F13 cam car?
- the right turbo cam
- Boost Creep Bad?
- Thinking of making some changes to my setup, tell me what you think
- Vortech help??
- Anybody know anything about HP Performance?
- Stainless braided power steering lines
- Turbo 101 changes
- taping turbos for boost nipple
- JohnsonRacing-Turbo camaro
- looking for vortech and intercooler pics
- Stenod Single Turbo Project Update Pics Round IV
- ATI big intercooler questions
- How did the old "Q M P" Turbo Intercooler mount?
- Hi-Flo Turbo "Street Killer" Preliminary Pics
- which one should i get?
- Anyone running a vacuum pump??
- Recommended turbo upgrade for rear mount for 402
- D1sc tuned VE
- Where to Tap in & run Boost Gauge Line Through Firewall?
- turbo and auto trans.. need boost quicker
- FAL fans question
- Procharger D1SC tuner guys in here please.......
- T70 vs. T76... when to use which one?
- Has anyone built a ????
- T76 rear mounted setup at 14 psi dyno
- Anyone have a stock ATI bypass valve for sale?
- Anyone relocated your stock fans to the front of the radiator?
- D1SC:mail order tune/predator/HPTuners
- 15-20psi w/LS6 egr plugged?
- Area under the curve on stock cube vs. Larger motors...
- what front shocks and springs should i run need to rasie up
- What brand wastegates are these?
- Boost a Daily driver?
- Guys, this isn't a CLASSIFIEDS forum...
- Boost difference between 2.95 and 2.75 vortech pulley
- VP C16 versus Sunoco 117?
- turbo book??
- How does PCV effect detonation
- ls1 sts guys
- 38 lb injectors enough for powerdyne?
- need advice from people with Vortech exp
- max psi with just a front mount intercooler...
- can you beef the 346 enough?
- where to buy flexible hose for ati intake?
- ATI owners: opinions please..
- procharger front mount intercooler piping
- SDCE 6rib
- roots type
- Nitrous with supercharger?
- For Sale: Intercoolers & plumbing & stuff
- help which blow off valve to use with D1sc ati
- FMU needed with tune
- Video of car at N v S!!!
- Any FI guys coming to the MIR event on the 17th????
- Pics of truck STS front mount, we don't need no stinkin' lower valance cover
- Puzzling Turbo problem.
- Gauges ??
- Need a larger crank pulley for my SDCE 8rib setup
- IC plate thickness
- Casper is now there!!!!
- How hot should i be?
- pics of new ati bracket?
- Any ATi Procharger Fbody's out there??
- do i need to upgrade to twin 57mm turbos
- Building the boosted LSx
- valve springs for high boost? what aftermarket heads are on the shelf ready to ship?
- Time To Orders Your ATI C6 Supercharger!
- quick cam question
- FMIC Guys... Questions for you.
- A question for some of you?
- Supercharger ??'s - Whipple
- Big boost guys inside please!
- Snow performance boost cooler mounting
- Rear mounted T76 R Trim at 13 psi is fun
- Boost reference Fuel Pressure Regulators
- more video of the street car
- Where can i get tubing for STS?
- Phamspeed Dyno #'s
- Which companies
- Kenne Bell For LS1!
- ***MAKE A MBC FOR <$12***
- Casper-Not quite there yet...
- Would like to go from Procharger to Turbo...tips?
- Baddest turbo "vehicle" ever?
- Is Phamspeed still doing buisness?
- ssautochrome t70 turbo's
- Anyone need a boost/vac gauge?
- tti street kit help..low volts
- ATI Guys Belt issues?
- special front and rear seals for boosted applications
- Shakedown passes with the turbo setup
- FMU selection help....
- Boost on a 427 darton?
- turbo piping
- Help with Pro-Charger
- Blown Head Gasket
