- Where can you buy OBX FMIC's????
- Motor blew at 8,000 miles, what do i do next??
- questions about high mileage superchargers
- What psi is the wastegate spring that comes with the phamspeed budget kit?
- 11,000mi on the stock shortblock and boom.
- is this calculation accurate?
- WideBand O2 Sensor?
- Header Upgrade, What power gain to expect??
- what turbo do i need to hit 500 rwhp
- LC-1 and wide band sensor placement
- spec stage V is dead. Turbo camaro = 0 clutches = 4
- Hit 9s today at BG.
- may add a blower,have some ?????
- Need help from people w/2 step
- I have my factory ECU working as a 2 step
- More new pics of twin turbo buildup, getting close!!
- Main girdle???
- 27"x7"x3" IC core support 800hp?
- I need a bigger turbo! Help me pick!
- List of my current mods
- Which Block?
- Anyone Interested in my Meth Kit?
- H/C or Turbo
- 600-850rwhp guys... Trap speed vs. rwhp vs. total weight
- P-1SC 7psi procharger
- My turbo project
- gas problem in my city tuning and octane question
- Max bore LS2 with short stroke
- Procharger P-1SC install ?s
- A procharger on a 346...
- What would you think max safe boost is?
- need quick response! 6.0 turbo size
- Extreme rich and misfiring?
- New custom TCI converter t400/ls1 for a turbo motor for sale link.
- MAF question on FI cars
- stock 98' CAM for CAS setup???HELP
- Oil pressure point question!!!!!!!
- New D1sc What Kind Of Numbers To Expect
- need to get a blow out valuve which one
- oil return line
- Turbo # help
- STS Help with numbers
- Harlan.... In a Mustang????
- What Car to Buy to BOOST??
- Stenod Performance Single Turbo Project Update Pics Round II
- Making another set of turbo kits, you can order them now
- STS turbo loud as heck
- question about boost controller install
- FUGGIN RAIN! Now I have to pull all my i/c piping.
- Compression Calculator
- mutliple spark?
- My procharger kit is only making 5psi. of boost
- Phamspeed kit here
- comp ratio for FI setup
- Reminder
- new blower pulley and new numbers
- Anyone seen this head gasket
- Best place to Find a GMPP intake
- My turbo & other goodies for sale
- sts turbo oil leak
- Why is TQ so inconsistant in FI setups?
- procharger and CheaTR cam?
- Happiness is being Stroked AND Blown
- 2-step instructions
- can you figure this out?
- How bad would this cam be for FI?
- Turbo FAQ -Overlap Error-
- Group Purchase SuperStore
- Where can i purchase a 3.9" 6 rib pulley?
- custom single PTE88, truck manafold, air to water turbo set up about 20% done
- AEM for LS1 FI???
- Turbocharged C3 Corvette
- meth injection
- Twin turbo Chevelle update!
- is a boost gauge necessary?
- Phamspeed Budget Kit
- Question on F/I, C/R, forged pistons vs cast
- Sts kit question...do gutted cats help the turbo boost quicker?
- Help with running A/C lines around my turbo
- Injector/ fuel delivery requirements (request assistance)
- cutting front bumper for FMIC
- Wet or Dry Nitrous with Supercharger?
- '69 camaro TT
- Phamspeed Budget Kit + My Setup? I want in the FI club!
- Where to buy a cell to hold ice water?
- Help calculating wheel trim...
- vortech rebuild...
- change oil before or after STS install
- need some sound clips of phamspeed budget kit
- Custom turbo?
- what converter when running a turbo..
- anyone have a medium frame to try?
- Stenod Performance Single Turbo pics
- Vortech Blower w/ Aftercooler Question
- TT327 FI intake
- LS1 Z28 DIY Build - Pics
- twin turbo
- SBC Twin Turbo recomendation
- HELP! Power loss after 5k.
- Silicone Hose Question
- My Dyno #'s
- Boost sensor location
- How much timing for stock power?
- Electronic boost gauge from MAP sensor
- Where to get FI tuning around Midwest
- More newbie qestions
- Twin Turbo Fabrication on F-Body
- D-1SC head unit $$ ??
- install time for vortech
- Custom made intercooler, who makes them???
- 6.0l / Gt-42?
- STS problem. Please help.
- Questions about STS set-up
- Help W/ S/C timing....
- STS with 87/89 octane?
- how much HP should i have?
- sts kit: gt67 vs base turbo(T60?)
- Large Griffin Intercooler For Sale
- Concerned about clearance with sts on my sts.
- Coming out with twin turbo kits for C5's
- MY BLOWER WAS STOLEN by camaro99ss427!!!
- ls1 turbo pistons and rods
- Immediate help needed, air filter placement, on my turbo bird
- need procharger 8lb. pulley specs
- STS Idle problem?
- Two Weeks Until North Vs. South >>>>>
- Not making any boost ?!?!
- Alternative to Intercooling
- Does anyone currently make a TT kit for us?
- cross over pipe fitment Q
- shops near nashville
- Ordered the 3.7 pulley
- Anyone running nitrous AND turbo?
- electronic boost controller 4sale
- what i need
- GM 5.3L Turbo Dyno Results
- Lots of bent pushrods
- What kind of HP and Et's to expect from stock engine with STS?
- Please help
- Does ls1 edit or hp tuners have a 2 step function?
- what size twins for 346?
- Wanting Cog Belt Drive for F1R
- My link bout procharger or turbos.. help please!
- Looking to forge LS1 engine for future turbo/SC. Where to start?
- Need to know: for Vortech owners
- how much power on a procharged stock heads/block ls1??
- vortech help
- Rear mount (STS) Dyno graph at 10 psi
- Info for newbie
- Whats the biggest turbo used on an F body?
- Nitrous or Meth for Procharger
- who has the best prices on sts for f-body?
- Plan-B 2-bar, speed density Aussie tuning done on STS Yukon
- Oil Pooling In My Turbo (STS) Question...
- Alternative underhood mounting locations
- Nitrous vs Alki for Turbo.
- 78 PSI Fuel pressure
- round pipe to square pipe for turbine inlet flange? how do you do it?
- Why not to buy STS part 2
- Is there a way to run bigger injectors then 60lbs with a turbo making 900+rwhp?
- How much are the twin ICs worth?
- Turbo Placement Decided
- GT42 for sale cheap....
- Big Cheap Lid for Air/Water Reservoir
- Need help .. car wont start
- 2 step question...
- Need some help on a Cam for my STS KIT
- cam specs
- car died!
- Supercharger Tuning help
- can someone help me determine the RWHP limits of my turbos
- Heat and turbos....
- ATI guys with Trans cooler
- Installed kit pics
- Brand new T76GTS for sale
- power without intercooler?
- 228-228 600-600 113?
- Anyone running cats on a front mount turbo?
- Boost controller
- sts guys...what exhaust do you have
- 500+ HP stock bottom end Turbo.
- Anyone using a 4" FMIC?
- 3.8 L superchargers
- diy meth kit
- Innovate Wide Band Controller Sale!!!!
- Why Not To Get STS?
- Livernois turbo truck vs S/C Escalade race??
- T-70BB/347/T56 buildup for road racing? Input please
- Fi Cam
- STS guys, or anyone! Low Low voltage???
- FMIC or meth water for STS turbo?
- Race-Prep Tune, 6psi, STS, NO Meth, Stock longblock+cam, Stock manifolds = 450RWHP!
- Eboost and turbo forsale
- C5r heads and FI
- ported heads with a Turbo
- Some turbo shakedown runs
- Brake line interference
- Boost Gauges Reading Wrong
- 99 camaro powerdyne
- other options
- FI and after market fans
- A guess on HP
- Which Cam?
- BOV/WG selection
- Rear mount turbo guys
- Best route for FI on pretty stock DD?
- vortec sc question
- compression? 6.0 Heads on 5.7 block
- Turbo cams.
- Turbo test
- what kind of turbo????
- Need pics of fmic on LS1
- building a car for the track. will barely see the steet
- more pics of the buildup ...dual walbro pump pics
- How much boost can I run before I lift a head on stock head bolts?
- I keep ruining belts!!!!
- How many miles is alot of miles for a sc?
- Help with 85mm MAF and turbo.
- important spark plug info
- 11.01:1 work with FI?
- Copper Headgaskets
- Tappin oil pan on lt1 for sc/ any alternatives
- Question on Eboost 2
- Fs: Turbosmart E-boost2
- F/S Silicone HTS, T Bolts Clamps, couplers, elbows...$100
- forged 370+mag+nos...
- What size oil restrictor?
- ARP Main studs
- TURBO people w/ stock topend...what were your dyno numbers??
- "New to turbo's" install question
- Can you gradually get into forced induction? (turbo)
- Turbos & Towing
- Pics of custom rearmount
- Phamspeed Done!!!
- forged 346 or 408 for boost?
- Stenod Performance Twin Turbo Car....DONE!!!
- HPP shootout vid from yesterday
- My turbo SS is going in GMHTP
- LS1 with turbo sounds like this ^^^
- Vortech vs ProCharger
- looking for installed phamspeed budget kit pics again!
- Good sites for purchasing procharger
- In & out fitting, Vortech ques?
- Alternator Bracket for Phamspeed.
- Procharger aluminum piping?
- Step Up ratio for T Trim?
- 02 2500HD Running now Roadtest time.
- anyone here have 1/2" head and main studs?
- Question about wastgates???
- Aussie's took the record back!!
