- IAT retard causing problems on turbo setup
- Question
- iron or aluminum 408 for F-1r
- GT42 Turbo set up almost done.........:)
- 9.45 @ 148.89 Video
- 3.4 and 3.5 Pulleys For Sale
- How do ls1s with turbo kits sound? curious
- Turbo LS1 Nova construction pics
- Cheep turbo kit.
- What hp are my t3/t4's good for ?
- Not making full boost!
- at what point should you replace your stock valves?
- Alternate Mounting
- So we went racing saturday
- 9.45 @ 148.89- come on PSJ.
- 9.61 @ 144.67! Almost caught Mike Brown...
- Track Day! New Best.
- Radiator Support
- Turbo housing vacuum nipple question
- Help With Methanol
- do i need to get wideband AND EGT gauges?
- Finally got my car dyno tuned!!!!
- Is Speed Inc still making turbo setups?
- Want to spray ontop of the charger.....
- Ordered My PTK Yesterday
- Log boost cheap, if you dont have AC anyhow :)
- meth kit
- Just some questions...
- C5 Kenne Bell Info...
- Turbo rebuild help?
- Harlan 2-step + transbrake???
- Help Wanted 9sec car.
- powerdyne supercharger?
- Wiring harness available to run stock gauges/etc with aftermarket engine management
- 9.59 @ 146
- Thanks Steve (S_J_H) for the nice little vacuum manifold
- used procharger Question?
- hp calculators
- garrett intercoolers
- What is your raceweight FI guys
- anyone using a D1-R here?
- What part # for 2 bar map?
- STS boost controller/ misc. questions
- Any ATI Guys using SLP Smooth Bellows?
- Ford TB electronics with stock pcm?
- Tbyrne Motorsports North vs South Aug 6th!
- BOV recommendations?
- guess my boost....
- 231/231, .598"/.598 114 vs. 228/228, .538/.538 114
- Blew right through converter..which to get now
- noob needs help
- Which is the better buy?
- StealthWork's phone anyone.??
- BOV flange on STS kit (what kind of piping is it?)
- looking for a F-1R kit?
- Truck 6.0 shorty's...????
- 3 ply silicone on cold side of turbo?
- Knock sensor issues with new motor?
- TTI turbo Kit power limits?
- What are the fastest STS times out there?
- phamspeed or just a sham
- 408 with a magnacharger?
- porting headers
- Just A Few Q's
- Just some info on testing with Nitromethane injection
- Stenod Performance Single Turbo Project Update Pics
- 408 With F1
- 408 F-1 guys
- Vortech question about boost and pulley size
- water/meth=what a difference
- anyone tried e-brake launch?
- Dual channel wideband, and Maximizer 2 Monitoring screens.
- Will a D1 reach my goal of 700rwhp on pump gas?
- Edelbrock and WAR Manifold guys....
- STS for sale
- FS:FI heads ,cam,and piston combo
- Vortech kit using SLP MAF?
- Best turbo cam
- whos silver twin turbo camaro.....
- Electric Turbocharger
- high boost through short tube headers?
- Vacuum Source for D1SC Bypass Valve\Boost Gauge
- I can not build boost
- Finally up and running again!!!
- F.I. VS. Compression Ratio Question
- Cant seem to hold a blower belt!!
- Need Help. What is Required to Make Procharger D1SC Vette Kit work on a F-Body ?????
- Help with some electronics to go with my CAS twin turbo
- A few questions since i blew my head gasket?
- LT1 SS progress pics
- How much does a decent single turbo setup cost for everything?
- is it just me or are the blower guys making better times with less rwhp
- 408 with a F-1r?
- fmic painted?
- well the procharger just exploded last night!
- FMIC guys, have you sealed your IC to the bumper?
- Master power turbos any good?
- STS silicone coupler
- What size stall with a turbo setup?
- Help building boosted 408...
- How long should meth last?
- Where to order Mondo Bypass valve?
- at what rpm does the boost build in a sts setup?
- where can i buy my turbo's for a good price
- Nitrous + Supercharger
- Muffler Suggestions
- FS: Procharger D1SC Complete Kit
- ATI P1SC opinion please
- What should I see?
- Spectacle Solutions Lids
- bypass valve?
- getting down there, D1SC 2600' DA, 10.25 @ 135.5
- good a/f ratio with FI
- Z06 Supercharger
- waistegate q's
- Threaded fan spacer
- Need pics of Phamspeed kit...
- D-1SC users in here.
- Well its official I have joined the Darkside.
- silicone hose
- Intake Choice for future FI car.
- Got an issue that I can't figure out...
- Sts Problem.
- Bucking hard
- Noise Level
- WTF??? CAR 1 SEC Slower tonight at Track!
- Twin turbo update...Cas kit is a B*tch to install!!!
- my twin turbo project car is for sale
- Phamspeed Kit, here are the pictures of mine
- Best Forged piston for Forced Induction
- Adding a P-1SC
- 414 7500rpm solid roller vs D1SC stock motor dyno.
- fuel system with supercharger
- Understanding FI
- Need a 2 step
- Has anyone pressure tested their turbo set-up?
- Where to buy a supercharger?????????
- My car is alive!
- Where do I find 7.25" 8 rib crank pulley?
- tuning my procharger
- What do you guys do for air filters???
- Phamspeed Bov
- Thinking Question.?
- Dynoed Today.....
- Slight smoking?
- Anyone know a sponsor w/an F1?
- will my head and cam setup work on a supercharger
- CoolCharger
- how should i go??
- which blower should i get
- Incon wishlist....Previous owners come in
- ATI 5psi numbers wanted
- Need FI Tuner ASAP, Trenton NJ.
- C5 single turbo???
- Help W/ Phamspeed Build*
- compression ratio advantages/disadvantages with turbo...
- Our big move at PTK
- 408 with tubonetics 94mm inducer
- turbonator
- tti kit T-76 for sale
- "Spy pics" of the upcoming C5 STS Twin Turbo!
- BOOST and 4l60e
- supercharger or turbo
- Need help deciding which turbo kit to go with; would love your opinions!
- Timing for boost?
- Vortech Kit on 2004 GTO ... dynoed 424/408
- Guaging interest in single turbo kit demand for F body...
- phamspeed single turbo kit?
- Silicone Hose
- Would this 90* work on the suck side " blower"
- rocker arms and emissions
- Want to laugh?
- For you LT1 turbo guys
- any turbos hitting 5.50 and lower in the 8th?
- Dry Sump + Turbo
- someone tell me why the "Budget turbo kit" thread is locked so i cant read it...
- What's the proper way to drill/tap into oil pan?
- help with phantom kit
- Anything new on twinscrews/roots
- Kit Complete Oil problems
- What do people think of this catch can
- Updated intercooler pics, more parts also
- Stock LS1 with T-76 ?
- exhaust temps
- Wow!
- 8.3'S Secound time out with turbo setup!
- 101mm thumper kit FORSALE
- Turbo experience?
- Forced Induction Stuff 4 Sale
- Smoking at odd times!!
- Vortech questions
- Any TX guys want to barter for S/C install?
- Nice Carb intake for sale on ebay
- Trying to wire up boost controller...help!!!!
- what to use
- Help With Turbo Build
- part fitment issues on tti kit, anyone?
- 4L6?E or 4L80E on turbo setup??
- I am still learning about turbos
- adding ATI or Vortech to my N/A setup...thoughts!
- Plug wires...what Truck wires are the longest?
- Passing the sniffer with a turbo
- pic from blower uninstall
- Does one cylinder go before the rest?
- Twin turbo build from scratch, LT1 or LS1?
- Methanol or Not to methanol?
- My CAS kit is sold to 30th T/A time for ptk? phamspeed?
- Which FI sponsor can get TiAL BOV springs I need to buy..
- need novi1000 mounting bracket for lt1
- cam and valve suggestions for forged 383 DD
- procharger pulley
- Where to get flanges
- Wanting to go blown with C5 and looking
- Who can build TT for me?
- Supra vs. Camaro?
- Wanted:ATI 6-rib 4.10 or 4.20 pulley
- which is a better street cam for blower?
- have a question about air fuel ratio...
- Sucking water
- Notice anything different? Pic inside...
- Running Meth injection NEED HELP!!!
- PTK kit bought.
- Need turbo size help...
- STS owners want TT for Centerline exit
- SDCE Where are they? Number is disconnected
- clearance issues on tti street kit?
- check out my buildup
- Anyone got any pics of Harlans TT setup?
- New Superchargers for Gen III V8s by Joe Gibbs Performance
- Stenod Performance Twin Build-up...SOOO CLOSE!!!
- GM MLS or Cometic
- how important is heat in a turbo setup? (hot side, not compressor side)
- Procharger
- Procharger done...GTO
- Some new Pics Of ProCharger
- Mustang 5.0 shorty headers work on ls1's
- Need Advice on Turbo Kit and Procharger
- Monitoring Radix I/C and H/E temps
- OBX intercooler for sale, cheap
- LS1 turbo header idea?
- friends are telling me turbo are not the way to go....
- New personal best with MT DR's
- How you guys running PCV?
- ATI twin inter-coolers and rear mount turbo??
- First start up with turbo!
- Will timin change when boost heats up?
- TA w/ FMIC = !Fog Lights?
- Who to get my meth kit from?
- paging "forced inductions"
- Need ARP head bolts
