View Full Version : Forced Induction
  1. clearance issues on tti street kit?
  2. check out my buildup
  3. Anyone got any pics of Harlans TT setup?
  4. New Superchargers for Gen III V8s by Joe Gibbs Performance
  5. Stenod Performance Twin Build-up...SOOO CLOSE!!!
  6. GM MLS or Cometic
  7. how important is heat in a turbo setup? (hot side, not compressor side)
  8. Procharger
  9. Procharger done...GTO
  10. Some new Pics Of ProCharger
  11. Mustang 5.0 shorty headers work on ls1's
  12. Need Advice on Turbo Kit and Procharger
  13. Monitoring Radix I/C and H/E temps
  14. OBX intercooler for sale, cheap
  15. LS1 turbo header idea?
  16. friends are telling me turbo are not the way to go....
  17. New personal best with MT DR's
  18. How you guys running PCV?
  19. ATI twin inter-coolers and rear mount turbo??
  20. First start up with turbo!
  21. Will timin change when boost heats up?
  22. TA w/ FMIC = !Fog Lights?
  23. Who to get my meth kit from?
  24. paging "forced inductions"
  25. Need ARP head bolts
  26. Picture request of turbo system built by Rob
  27. Air to Water Intercooler cores
  28. F/S custom LT1 blower cam
  29. 408 w/TT or F1?
  30. Getting pro charger. will current cam work?
  31. Crankcase pressure = leaky turbo?
  32. Z Angel, Brian... Any New News on the Turbo Project??
  33. Any one tried an F1 with stock intercoolers?
  34. Turbo Fabbing...
  35. Took "Casper" out again with trans trouble...
  36. Incon turbos, how many bolts in the turbine outlet.
  37. Holy SES Codes Batman!
  38. Everybodys posting pictures, here are some of mine
  39. estimate on numbers
  40. Intercooler outlet size?
  41. Meth on a Stock Bottom End
  42. Procharger Fan Wiring Diagram?
  43. Custom LT1 Blower Cam F/S
  44. Spray the D1SC?
  45. Question on D1SC blower pullies?
  46. anyone wanting to sell there Vortech kit????
  47. 12 rib Procharger belt help...
  48. Threaded IAT sensor Part # or application??
  49. M6 guys what clutch do you perfer.
  50. FMIC tubing pics
  51. quick question
  52. TH400 loss over 6spd from PTK 88 car.
  53. D-1SC Pulley Question
  54. where do you go to buy intercoolers?
  55. 1st Gen LS1 twin turbo?
  56. Goodbye OBX, welcome back H20/Alky
  57. any huge hp difference between a turboed 402/408 or 347
  58. Turbo cam from COMP. Does this seem too small??
  59. PTK pics needed and pricing!
  60. To the ground with A/C & Power Steering?
  61. What size downpipe correction.
  62. The E-boost 2 GP
  63. ATI damper
  64. What size downpipes?
  65. God... what a mess
  66. Any one done an air to water intercooler with supercharger?
  67. need help measuring my twin turbos.
  68. Can't make over 750rwhp - why?
  69. Phamspeed/ARE intercooler set up w/pics
  70. Phamspeed dyno results!!!!!
  71. HELP - trying to Figure out CR of my mish match of parts for MY Tubo Build?
  72. Gt42?
  73. Availability of LSx and what upgrades needed for boost?
  74. TT,T, or SC??
  75. procharger questions
  76. sdce 8 rib GP
  77. changing compression w/LQ4 heads??
  78. Can this qualify for car pooling?
  79. Aluminum tensioner pulley for G-trim(homemade)
  80. Megasquirt for sale
  81. new to T/C... help me build...
  82. another sts question: what can i do now and upgrade later?
  83. Megasquirt for sale
  84. Clamps
  85. Ran the car on new setup. How did I do?
  86. Oil in the downpipe, turbo freaks I need your help
  87. A quick question?
  88. LS1 turbo kit for sale
  89. 16-gauge tubing
  90. Dual Spal fan setup and D1SC... need help!!
  91. what CI for 700+rwhp and what turbo kit?
  92. PTK Question
  93. apex avc type r boost controller
  94. this should put my tt power to the ground
  95. ATI owners-Catch can and Blow-off Valve?
  96. Gauging Interest in SDCE 8-Rib Coversion Kit Group Purchase
  97. Knock retard after shift....help needed!
  98. Who makes the best proven turbo kits?
  99. Any information on sequential turbos?
  100. Main cap walk with aluminum block
  101. PTK kit came in monday
  102. F.S. STS with extras
  103. 6.68 @ 104 1/8 at 3200' DA yesterday
  104. LS1 Blower question, n00b here
  105. Cooling fan specs?
  106. Adventure at the dyno...
  107. Does this price seem right?
  108. Procharger-WS6-dual intercoolers cooling air flow???
  109. Anyone remember the post that showed 2 intank pump Install
  110. just finished a 2002 ss 810 rwhp trick setup
  111. Front end support for more room? *PIC*
  112. Turbo Technology Kit
  113. Need an aftermarket radiator that works
  114. SC'd Fuel Systems (650rwhp+)
  115. What would cause A/F to rise?
  116. anything wrong with this oil return?
  117. compression ratio and it's effect
  118. My PTK PTE88 SS
  119. CC 918 springs question
  120. turbo spool vs rpm
  121. WTB 3.2 Procharger Pulley
  122. sts and 918's
  123. Accessories needed with STS turbo kit
  124. Wastegate?
  125. it's alive... IT'S ALIVE!!!
  126. Looking For Turbo PiX
  127. Calling out Phamspeed owners
  128. Good BOV?
  129. pro charger belt/pulley
  130. 383 Stroker - Cam & Injectors
  131. progress pics on the small turbo build
  132. FS. PTK LT1 gen 2 kit
  133. Bran New CUstom set of ROSS FI pistons For Sale *pics*
  134. cali leagal FI or shortblock
  135. Turbo worth the xpense over Procharger?
  136. how to install guages and wiring
  137. LQ9 (6.0 Ltr) heads for sale!!!!
  138. Racegate Question
  139. F/S Custom Blower cam LT1
  140. Stang 4.6 2valve FI question
  141. Procharger? Twin Turbo? What 2 Do
  142. F-body STS and Dyno Strapping Ques...
  143. P-1sc-1 Price ?
  144. .581 cam with STS Questions.
  145. Is this a good blower cam???
  146. fuel pump for vortech v9...
  147. Corvette Over-Radiator Intake Pipe, how much boost?
  148. need to order part quick. but where?
  149. What ever happend with my old kit???????????
  150. upgrade advice after turbo
  151. Procharger 3.5 Pulley For Sale
  152. What Turbo?
  153. Going to the track soon what will my car run?
  154. STS with or without cat's and headers?
  155. What plugs to run?
  156. Wanted: Sheet metal intake
  157. Some more progress on Stenod Performance Twin Build-up!
  158. Block ????
  159. cooling ?
  160. Front mount Pro charged issues D1SC
  161. vortech to stock...
  162. headers for twin or single LS1 in a 1st gen
  163. procharger and fuel management
  164. Solid Roller Specs
  165. DIY Alky Injection Kit
  166. Good shop in north east for install of blower
  167. Procharger HP Problems on a 99 Z28
  168. nedd help with my next mod
  169. Any FI cars running in the heat?
  170. OK, so who has the fastest FI track time on pump gas?
  171. Link to the "Do it your self meth kit"
  172. Moving the stock radiator pics.
  173. EGT question...
  174. SOME Turbo Kit progress Pics...
  175. Vortec Superchargers
  176. Heads:casting #873
  177. Homemade turbo lt1's on budget
  178. Turbo tires - just read it!!
  179. temperature
  180. Who saw STS on TRUCKS??? anyone anyone?
  181. Twin or Single turbo,whats the big difference
  182. Turbo guys,in here.!!
  183. Timing with 6 PSI
  184. Who here tunes there own car.
  185. T72 got full boost at 3000rpms with Phamspeed kit
  186. maxing out a D-1SC
  187. Another "what turbo do i want" Thread.
  188. Where to find an MMS crank pulley?
  189. Boost brainiacs........got a question
  190. ? for high horsepower fi cars
  191. Next project
  192. Kooks 1 3/4" or 1 7/8"??????
  193. PTK kit
  194. what cylinder head specs for a turbo application?
  195. Best sounding exhaust for Twin Turbo SS
  196. 409L stainless steel 16 Ga for turbo headers
  197. what plugs should i run w/ my turbo setup?
  198. Oil cooling a water cooled turbo. Will it work?
  199. Intercooler Almost Done...
  200. Best Check valve for oil drain back line??
  201. Injector Size for Vortec Supercharger
  202. looking for pics and pinfo on turbo custom
  203. How many are using billet main caps?
  204. What way to control ECU for boost?
  205. whipple twin screw??
  206. Got SS back, now have a few turbo questions
  207. Super Charger Lesson
  208. which turbo for me???
  209. good daily setup?
  210. Anyone tried an INTRACOOLER
  211. ATI, SDCE guys, changing oil ?
  212. header flanges
  213. Oil Pan Drain Plug.......What size?
  214. tti kit
  215. Looking for some power
  216. i need a 2 step!
  217. A little Video enjoyment
  218. Who makes the best alternator relocation bracketing?
  219. What machine work did you have done to your FI Motor?
  220. LS1 setups, post whatcha got
  221. Another 11 second STS car
  222. taking Opinions
  223. Vaccum questions (bov/wastegate)
  224. tti oil pan alternative tap location! quick!!!
  225. Vortech MAF relocation (pictures).
  226. Advice on a Vortech V9 aftercooled?
  227. Keep my 918s or grab some Patriot Duals?
  228. Safe boost level
  229. 02 2500HD Running now Roadtest time.
  230. intercooler fan?
  231. Who makes a good 2-step?
  232. Getting a New Engine
  233. CryO²™ - INTERCOOLER SPRAYER
  234. Random Poll, Post Your Choice!!!
  235. optimal turbo for 347
  236. Why is this such a slug without the spray?
  237. bosch part number for LSU4.2 o2 sensor
  238. turbine interchange??
  239. supporting mods???
  240. Whats the best stroker (cubic inches) to build for boost
  241. Blown car FS in the classified section
  242. twin turbo lt1 project
  243. Speed Inc. 348 Short Block
  244. Ideal Radix A/F ratio?
  245. MDMC Twin turbo kit
  246. Max Boost on Pump Gas
  247. need 3.75" ID x 6" long, black, silicone hose
  248. guages
  249. John Pham
  250. Where to get pressurized oil?????
