View Full Version : Forced Induction
  1. I got a kick out of this video
  2. Should i sell my tt t/a?
  3. Tc 78 vs. Pt7675
  4. GMC Syclone build up
  5. Help needed for choosing trans for new build
  6. some basic FI q's
  7. 2005 LQ4 boost ?
  8. What fuel pump for stock LS1 with D1SC?
  9. Need Advice on E-85 and Pump Gas setup
  10. Ran the car need help sorting torque converter,gear ratio & tire dia.
  11. Guess whats bigger than a can of coke ??
  12. need pro charger for ls1
  13. Good cheap reliable heads for boost.
  14. My 5.3 build is almost completed, want your opinions!
  15. Quick vid of a buddies 88mm T/A!!!
  16. Can I buy just one head stud?
  17. car wont go passed 5lbs!
  18. "limit" of boost on Pump gas
  19. quick heads question
  20. Front mount turbo guys post pics of downpipe/exhaust.
  21. 1999 2000 Camaro Exhaust Maniflods needed!
  22. Head gasket failure - opinion?
  23. I am tired of seeing all these damn 5.3s going so fast..
  24. Catch Can Setup
  25. Spraying Meth before or After the IAT sensor?
  26. Ethanol levels changing in winter? really.....
  27. Weighed some blocks this morning
  28. E85 and back pressure
  29. Filtered or un-filtered oil source?
  30. Procharger P1200 parts
  31. Help Please
  32. Question about BOV
  33. Twin Wastegates
  34. Woke up and found this in my driveway...
  35. Master power T3/T4 super 60 twin 6.0 lq4 ??
  36. E85 poll...should i or should i not? Closest station 17.4 miles.
  37. Vacuum Line
  38. Turbo leaking oil on turbine side.
  39. truck manis vs some stainless shorties
  40. Boost reference location for waste gate.. what is the final answer?
  41. Turbo cam help!
  42. Blower cam advice
  43. How long should ls1 engine last on 8lbs of boost?
  44. Race Proven Motorsports New Shop!!!
  45. How far can you "safely" push pump gas + meth? (20psi/800+rw/9:1 forged 370ci)?
  46. High mileage 317's for FI?
  47. What % of methanol gives the best protection of KR?
  48. Is a meth/water injection kit worth it?
  49. Racetronix pump hp numbers come in
  50. Max seat and open pressure w/ stock lifters
  51. lt1 turbo questions
  52. lt1 turbo questions\
  53. 69 LS2 Firebird twin turbo question
  54. Trying header evac PCV... what to do with stock PCV (LT1)
  55. Filling D1SC Head Unit
  56. New Motor Dyno 974hp Vortech YSI 23lbs
  57. turbo suggestions
  58. Out with the D1SC in goes the F1A
  59. Simplest catch can setup
  60. Procharger blowing oil on less than 3,000 mile rebuild
  61. Dropping compression from 10:1 to 9:1 require a larger turbo?
  62. Turbocharge of procharge?
  63. Good stock crank boosted bearings? Clevite "P" work good?
  64. catch can setup question?
  65. Camshaft help with 112 Maggie LS2
  66. 99 Trans am build thread
  67. Turbo Set up
  68. dual turbo size question
  69. cracked piston some advise needed
  70. What # wastegate spring?
  71. what size is the sts oil pump fittings?
  72. anyone with eboost2 setup for gear based mapping?
  73. Atomicfusion 7.85@185 video
  74. turbo routing
  75. Is a t4 76mm .96 too small for a street driven 6.0
  76. STS Z06 dropping boost
  77. 240sx crate LS1 ebay GT45 build thread... I'm probably going to kill myself.
  78. Is -16an big enough for rad lines?
  79. Crank pulley without a/c pulley??
  80. Looking for 90* silicone bend
  81. Cam's Gt91 2002 T/A Keeping the Ac budget build **Fire up 7/21**
  82. 8 rib no dampener Procharger
  83. Kenny Bell supercharger 01 ws6
  84. 1969 Chevelle 5.3 Twin Turbo TNT Results
  85. PT 7675 guys lets see your numbers
  86. Rear Mounted, Oil-less, Comp Turbo Fbody?
  87. Best external fuel pump for high hp E-85 cars?
  88. how much more boost can you run befor you have to retune?
  89. xer281hr cam in my 4.8 Camaro
  90. Norris catch can or moroso with dual inlets & breather...or both?? OR RX Perf can?
  91. please estimate my hp
  92. Pulley Size Question
  93. Where to look for a quality low cost supercharger
  94. FI LS3 cam help
  95. trubo heads
  96. Turbo header build question
  97. Newb to boost build few ?s
  98. Manley Forged 2618 with boost
  99. A2A or A2W intercooler, my situation
  100. ls2 intake good for boost? searched didnt find much
  101. Rear mount turbo
  102. can someone ID this turbo?
  103. Intake runner size
  104. stock cube cam help
  105. building a boosted motor, few questions
  106. 1981 Turbo T/A vs New 5.0
  107. Camaro lean at idle
  108. Need some advice on my junk
  109. Your thoughts/Criticism -and a question on engine build with D-1SC
  110. LUNATI cams advice
  111. F-1X camshaft advise
  112. Modular Turbo kit and ON3 turbo #s stock motor
  113. 408 turbo guys in here
  114. help please!!
  115. big boost on stock LY6 pistons?
  116. is a 30 micron inline oil filter good for a Ball bearing turbo ?
  117. Any LS Turbo Tuners in PA or MD?
  118. Procharger D1SC 34000 rpm impeller speed to low?
  119. Madre di Dio! whose stock crank turbo car is this?
  120. how much will a stock crank hold procharged.??
  121. piping question
  122. twin turbo ls1 question
  123. Made it to dyno today! D1 on 10lbs 416 CID
  124. Boost in action... maiden voyage... 140mph.
  125. Congrats Mike Brown on the Atlanta win!
  126. 317 heads on 5.3?
  127. what does valve float feel like?
  128. BOV and wastegate
  129. 317 heads
  130. what do you guys think of this noise
  131. Has anyone tried this LOW MOUNT PASSENGER side ALT Bracket made for truck mani kits?
  132. rear turbo chatge pipe routes
  133. Would this cam work in a 5.3L 72mm turbo?
  134. Best "reasonably priced" ring set for boosted 4.020 build?
  135. -12an oil drain flange...where to buy???
  136. 05 GTO DIY Turbo, Cage, Mini Tub build
  137. Timing gear/chain?
  138. Help with gear selection
  139. Wastegate Mounting Position
  140. '98 Camaro S475 build just started.
  141. Keep 317s or Not?
  142. how much rwd power you think i have
  143. Need to plug a -10 AN oil return
  144. water to air intercooler????
  145. Holset HX55
  146. procharged and exhaust i want more what next
  147. lt1 guys what throttle body you using
  148. Single intercooler set up
  149. 5.3 700hp build advice needed!
  150. how much boost should i expect to make?
  151. adding e85 to pump anybody doing it?
  152. 600 RWHP LQ4 Turbo
  153. one nasty sounding mid 8 second dragster!
  154. What turbos to use
  155. Race Proven Motorsports 25.3 C6Z06
  156. supercharging high mileage
  157. LS-6 valley cover/catch can how to route lines
  158. supercharging high mileage
  159. tips and tricks for lighting a turbo 4.8 car
  160. twin turbo post
  161. Procharger install manual
  162. Heating issues with front mount setup.
  163. ugh 8.1l problems
  164. Pt76gts, run an oil restrictor?
  165. How much power can this iron short block hold?
  166. 4.070 lq9 block will be ok on boost?
  167. J/y 5.3 - tc76 vs pte 7675
  168. Anyone make a plug and play pusher fan set-up?
  169. which intake for my boosted application?
  170. Piping Kit
  171. ARH Monthly Newsletter
  172. Lingenfelter 2 Step Installed and Bent Rods
  173. How much area for a air to air intercooler for a vortech ysi?
  174. Smallest Radiator/Fan combo that will cool
  175. **LMR TTV Dyno Vid Inside**
  176. ? Re: Boost Leak Tests and Turbo systems
  177. magnum t76 ball bearing oil restrictor?
  178. Does anyone other than ATI make sprag blower pullies?
  179. Can i achive 750rwhp with a s475 in a Lq9???
  180. s400 turbo questions
  181. 6.0 vs 5.3 Is it worth the extra $$$
  182. 08' 5.3 magnum76 17lbs video Chevelle
  183. How big of a Procharger with aster bracket
  184. 408 CID what turbo
  185. **Late Model Racecraft 5 Year Anniversary Special Inside on Packages**
  186. 347 76gts Dyno Results
  187. Procharged Daily Drivers in here!
  188. P1-SC Procharger for sale
  189. Single intercooler set up for trans am
  190. Procharger install Horn relocation
  191. on3performance 44mm wastegate springs???
  192. Gauges needed for turbo addition
  193. Forged 347/TC76/T56 Build Thread
  194. So I bought a "Roller".... x275 soon to be!
  195. Need some advice on IATs
  196. taking too long to build boost on t-brake re-stall converter?
  197. 6 bolt / cylinder head guys please step inside
  198. hobbs switch psi recommendation
  199. opinions needed....is this enough clearance for my fans??
  200. Signal hose came off Manual boost controller. 19psi!
  201. E-Boost2 HELP!
  202. Hotside/exhaust questions.. Twin 6265's (Prostreet)
  203. need a custom flange made
  204. F1C Forged 347 Build. DYno tonight 9/10 NUMBERS Finally
  205. Relationship between dropping compression and raising boost
  206. woohoo !
  207. question:5.3 with top mount s/c
  208. Any pics of windsheild washer resevoir used for methanol injection?
  209. how much boost in a diesel KIA
  210. Need Help with cooling issue F1A and iron 408
  211. Turbo E85 heads versus compression help.
  212. Thinking about going rear mount
  213. e85 and fi guys come in
  214. GT 91 v band outlet
  215. whats the best thing to add to a WtA intercooler to keep it cold??
  216. something i learned today
  217. Boosted 5.3s What rwhp are yall making with what setup?
  218. Help - Not showing boost
  219. Planning a Turbo Monster Truck - Need opinions/advice!
  220. Fuel Pump Recommendation Changes
  221. Will this turbo work for RM?
  222. 460" Gear driven F1 procharger ....
  223. F-Body Instruction Manual for "Ebay" Turbo Kits!
  224. Any turbo guys with 4000 stall TH350 here?
  225. Reducing compression, do it with heads or pistons?
  226. Anybody Use Emachineshop.com for CNC?
  227. Which t6 turbo for lq4
  228. 3.70 or 3.55 for Turbo LT1
  229. dumb questions for a noob to real racing
  230. Where to buy TC78? Which sponsor?
  231. new to turbos lots of?s
  232. 700hp ls1 hybrid
  233. What spring do I need for my 50mm tial bov
  234. CXRacing Intercooler. Who is Running these and Power?????
  235. stock shortblock+E85; how much timing?
  236. Question about BOV and STS Turbo Kits
  237. Vacuum/Boost plumbing
  238. how good of a boost cam is this
  239. exhaust size and no muffler post videos
  240. need to order two turbos asap. who has them?
  241. MAP sensor question
  242. Flashing SES code scanner not pulling code
  243. TC 67 vs TC 76
  244. Throttle body slams shut
  245. Lets talk faster spool
  246. Boost loss due to improved exhaust.
  247. Got my Daily into the 9's Build Thread
  248. Thinking about adding a wastegate to my setup. D1SC...
  249. F1A Who is using 4" IC piping?
  250. rear turbo guidance
