- low maf freg?
- Ice in water resevoir
- Parasitic Power loss with SC..what is it???
- Back on the road!
- Crankcase Pressure and valve nubs...
- is 100 low lead oct ok to use on turbo setups?
- Mufflex GP... 1 more order needed!
- Oiling for a PTK kit
- took the phamspeed plunge :)
- where to get a Turbo header??
- question about the tt kit from Phamspeed
- Bottom end LS-1.....what can it take?
- How fast are you FI induction guys??
- stupid question about slicks on Turbo'd F Bodys?
- My install ...finished
- Tapping into boost/vac line... Setup done but have ?'s
- Procharger and cali smog ques
- What internals to replace with turbo?
- Bov
- Where to get Part#'s for Procharger Parts?
- air lid on d-1sc
- PHAMSPEED Maf Sensor Location
- This little 306ci Ford setup ROCKS!!!
- if i built my own turbo kit would it pass smog?
- smog legal turbo kits?
- Rebuilt motor and more mods = 100rwtq and 50 rwhp LOSS
- How important are heads with high power FI setups?
- Single Turbo LS1 C5?
- where can i get stainless collector flanges?
- Phamspeed Turbo Pipes
- How can you check a Tial BOV off the car?
- Need Help/Advice on a 97 LT1 M6 FI Car (Long Read)
- NON-projected Tip Spark Plugs? Anyone use them?
- How important is Quench and intake runner volume
- OBX with dent FS
- max safe TQ on a 427 TT
- Whos making the most power with STS turbo?
- Hp 2 Bar Or Ls1edit?
- Looking for Turbo kits and installation in Texas?
- Dose anyone have sounds of the ATI race ready valve?
- questions for phamspeed
- Any reason to go with a TTi kit? over phamspeed?
- What kind of BSFC #'s do you FI guys see?
- Question
- New BOV installed with ATI...
- Safe Boost
- ProchargedWS6 FOR SALE!
- tti turbo sizing
- Radix on ZL402? What do you think?
- New STS Dealer in So.Cal.!!
- Oil pressure help!
- ATT George at Turbotech! INSIDE!
- Forced Induction Extravaganza!
- 10 bolt survives a few more passes, still alive!
- Rear end recommendations...
- ATI W Cam Videos
- Ati 8rib?
- Anyone with a running Phamspeed kit, please come in
- p1sc-1 cam suggestions
- 1.5 years, $15,000., Countless Hours, 1st and only 12.0 sec Pass> Boom POP Spit Broke
- STS concern...
- water cool intercooler?
- Redline Motorsports
- Will 8.1 injectors work for only 6-8 lbs. on a 5.3?
- Can you special order an extra whiney Procharger?
- Timing for 8lbs off Boost with 8.5to1 comp?? & who to tune in Now Orleans Area?
- Few more D1SC/SDCE/FMIC progress pics
- Procharger video?
- If anyone's interested, SDCE 8rib tensioner GP
- Phamspeed GT42 Kit PROBLEM(S)..JOHN@PHAMSPEED HELP
- Is it possible to upgrade from a p-1 to a d-1?
- Post Your Turbo Set Up Pics
- 700rwhp...full drag car..loud!!!
- Dropped Valve on 6.0 Radix
- Which gaskets to use???
- stock internals and s/c
- Tell me about your turbo setup
- where to get aluminum 4" elbows
- ATI twins to FMIC: parts needed?
- Piggyback computer
- Help with High Boost? Only getting an extra pound?
- What for rest of setup?
- Phamspeed questions
- Safe Lt1 Boost
- Question for Mightymouse
- basic forced induction tech questions
- my turbo cam experience
- Head Question
- Which kit should i get
- What about a Stealth II cam for FI
- Porsche KKK K26 Compressor Map?
- Anyone have a set of 6.0 MLS gaskets?
- Price of TTi kit.
- Can a stock tranny and rear hold up to the STS turbo
- have a problem under boost?
- This Turbo Okay?
- What turbo system to help me get 700rwhp and put me in the 9's?
- PT67? psi stock sb
- RPM's Drop and car stalls
- ASP, stock, or 3.60" pulley on Procharger ?
- Lowest maintenance block?
- "Sound" advice
- FMIC kit with Griffin?
- Supercharger
- Got into a debate with a Ford guy today about high compression and boost..
- which one to choose??
- Do stalls and turbos mix?
- o2 placement on turbo system
- max boost, power with sts t60-1
- Turbo headers
- Procharger Experts help! Belt problems.
- And you thought the GT42 looks big, hehehe
- So What Turbos For Twins, 600 RWHP
- Intercooler placement. opnions!!!
- Your thoughts on Precision Turbos.
- Stock oil pump on 02 LS1 turbo?
- Min/Max angle for turbo oil drain?
- How hard to install myself?
- MAF.... blow through or pull from??
- Tt Sbc 327
- Mount BOV after/before intercooler?
- Sweet turbo Kit on a LS1 Sand Rail:
- EBAY turbos....Guys please read
- dyno with new cam
- 99 Trans AM WS6 with Incon TT kit for Sale
- Non f-body turbo question
- Max HP&TQ w/ stock pcm & forged 346alum block?
- asking about a cam?
- TT installer
- Modifying intercooler questions...
- X trim ?'s
- CAS intercooler installers I need Help.
- california leagal fi system?
- turbo headers ???
- Turbo Intall -- more updates
- Turbo
- So, which FI cars will be at the Commerce Race in three weeks?
- belt size
- 6.0L Truck Heads on stock motor Q's
- Compression of pistons, and rods.
- Crank Case Pressure, Catch Cans and Breathers
- Procharger D1SC or P1SC?
- can someone please help my NA/FI problems?
- Boost And Fuel Lines
- W2W 408 Dynoed today.....
- Piston Oil Squirters
- Help, need advice on gauges and pod
- M10 and M24 TT
- Should I Powder Coat or No??
- Blowby & Oil out Breathers...
- 6psi to 8psi how much more power
- Ebay Turbo Kits
- Anyone got a 2.25" coupler there not usin?
- Spark Plug damage > Opinions? * Pics *
- boost and fuel presure gauges?
- So the term "aftercooelr" only applies to superchargers?
- Video ......
- Add an intercooler = how much more psi?
- AWD and boost question
- Anyone w/ a PT70? HP est. 5-10#psi
- Help... Cobalt boost gauge purple wire came out...
- Started Mounting the Intercooler
- controlling boost
- Any pics of a GT67 turbo?
- Boostaholic's Top Gun FI List
- compression decrease to boost increase ratio?
- Stenod Performance is starting another project car...
- WTF STS?! Look at this...
- Multi Boost Levels?
- Max boost w/ motron 60s?
- TRUE STREET - At the Year One Experience Apr 22-24
- Missing Boost Where It Counts....
- Turbo filter
- What's the cupon code for HTS?
- Updated pics of GT55 Turbo build up
- how much boost can i run
- Price wise, what would I be looking for a D1 and bracket?
- Latest Round Of Buildup Pics
- Few progress pics, D1SC/FMIC
- PTK LT1 car finall made a track pass with T88
- Spark plug gap?
- Who has made over 1000rwhp with FI and an LSx motor...THE LIST
- Lower price for my blower!!!!
- Will a Corvette Procharger work on an F-body?
- Identify this exhaust housing!
- vortech and nos??
- I NEED some HTS STuff!
- New radiator/fans necessary?
- Turbo AND Nitrous
- electric supercharger on ebay
- .69 A/R Exhaust housing on STS to help with stock stall
- Anyone Know Anything About This Turbo Kit
- Ken's STS/Cartek GTO running 10.68@122MPH
- Help!! Car Wont Idle
- Compressor surge?
- cam
- Meth or N2O
- Whats the fastest FI ET record on 17inDRs?
- map sensor question
- How much boost can I run???
- best compression for twin turbo
- whats the highest Hp turbo/blower setup seen to date.
- Twin Turbo LS1 **of a different color**
- Incon Guys - Replace FPR - What Size Connection??
- head gaskets??
- Turbo 347"..... What part GM # MLS head gasket??
- I need some advice!!!
- How deep do you drill when pinning crank?
- Turbo VS SC
- Anybody here running a CoolingMist system?
- FI Engine Break In?
- supercharger rating system?
- Procharger???
- Phamspeeds budget turbo kit
- Update Pics-Procharged W2W 408 Installed
- Turbo Accessories
- help, i have a 408 with t76, what mod next?
- Turbo or supercharger??
- Phamspeeds's new kit - is it worth the $$$?
- S/C queestion
- Overboost = 906rwhp/975rwtq
- New Banks Power Twin Turbo
- How to trigger fuel pump?
- Turbo or Blower
- More updates on the project
- Help with procharger kit
- FI newbie, got some ?s on procharger setup?
- Bryan Wilkinson Pics of your radiator
- 98 MAF Max
- HKS BOV question with ATI kit
- Not exactly forced induction related but...
- Sdce Fmic
- TTi LS1 turbo kit help
- Whats the fastest FI GTO so far?
- weiand roots type superchargers
- turbo 4.3l questions...?
- Synergy Production FMIC kit....
- ProTurbo has released a new line of turbo kits....hehe
- STS Oil pump Problem * HELP * ?!?!?!?
- D1SC Kit: Where/what to buy?
- STS Turbo Installation w/ 3" to 4" IC
- orange hose off the D1, Dyno last night, results inside.
- Cost of Building Forged 346 vs 408 for FI?
- Anyone blown a Forged Piston or cracked a Ringland?
- Procharger Help
- Custom turbo on STS
- Corteco Gaskets - Anyone heard of them???
- what turbo???
- 42 Or 60lbs Injectors
- LS1 with 6.0 heads - What gasket?
