View Full Version : Forced Induction
- is this right???
- New S88 lasted 10 miles [Pics]
- Truck Manifold guy's Inside????
- Best Place??
- Will this thing even start?
- Turbo boost and 4.10s
- Procharger head unit questions?
- I need pics for Intercooler piping
- LSX FI Intake
- Need Help On Deciding
- Looking for help on supercharging LS1 in 240sx...
- I got the spy hunter smoke screen mod now :(
- TTi Installs Forged APS Twin Kit
- what's the lowest oil/water temp that's safe to go WOT for MAX power?
- is a 31"x12"x3" IC to big for 8 psi
- Stock shortblock - 0, T76GTS - 1
- STS and Pipes
- My LSX build... from hell.....
- New 5 Layer GM Head Gasket's Result's!
- LSX block....LS7 heads or AFR for FI?
- Is 16psi all I am going to get?
- Break Boost on M6
- Ohio Forced Inductions Oct sale
- V-band vs Ball-Socket
- Turbo guys, what stall are you running..
- Adding more boost & meth kit, how important is new tuning?
- innovative turbo systems...........................
- Gen-tt On Holden Monaro Install ;)
- Intake......pop off valve?
- opening up 6.0 heads to lower comp. even more??
- has anyone cracked tens with under 600 hp?
- procharger + dry nitrous
- TTI BOV Issue/Leaking
- Almost Finished.....
- My last boost question
- Big Boost(25+psi) Big Power(900+rwhp) & 400+ci - What Cam?
- Just ordered a S91 from old S76.....
- Has anyone done a setup like this? (pic)
- Finished my exhaust system...and weighed the car...
- Is it worth spending $ to uprgrade my stock LS6 heads on forged D1SC 347 LS6?
- Need Help Now!!
- anyone ever crack an iron block cylinder wall?
- JGS Wastegates
- LQ9Heads on LS6 with Maggie
- Old phamspeed kit ?
- Belt driven scavanging pump system
- Boost vs timing
- Tc-76 Blew the Tranny!!
- Can I use this heads/cam with a SC?
- In-cylinder Video
- Two Short "Boosted" Vids
- ? about impeller speed
- will a procharger fit it.
- ls1 347 or ls2 364 for procharger?
- Lets hear it
- Parts list for s/c already have some stuff
- video - Mightymouse passes at RD on 9-28-07
- FI CAR STOLEN!!!!! HELP?!?! North of Dallas.
- gauge view video of a few pulls
- P1SC and Boost
- Pictures of EPP's FMIC
- Interested in Procharger but my compression is kinda high
- What size stall for a turbo/superchared car?
- Roller rockers and turbos
- need help finding turbo studs ASAP please
- Best place for the IAC
- L92 heads and intake
- My custom single turbo results.
- Need to make a heat shield
- Has anyone REALLY made BIG power with Dart 225's?
- TurboCharger Oil System
- AnyBody Here Try This?..Blown Short Stroke LS7
- roller rockers...
- Procharger D1 will this be OK
- How's this sound
- Front Mount Installed PICS
- Turbo car leaves like a n20 car leaving on 200 shot reverse progressive ramping
- Turbo customer request....
- TC-76 track results. with vid.
- 2 sets of stock injectors....
- Opinions on this kit
- My new turbo exhaust, and the neat old muffler
- What head gasket size do I need?????
- T76 Turbo dyno results in...HELP! Need a diagnosis...
- intake leaks...
- How long would one expect the head unit last on a Procharger D1SC
- Max Power of Stock 346 TTi
- should I go STS or Procharger?
- gt 47 88mm
- How much?
- The firechikn is alive, finally.
- Procharger P1SC
- RFI: Samples of cam overlap
- GT47-85 question
- Dyno tomorrow on T-trim 383. Any predictions?
- BOV,wastegate sizing help
- Sts
- Bad heat soaking on upper intake piping
- Anyone notice new 6.0/6.2 MLS gaskets are 5-layer??
- Kenne Bell f-body?
- FI motor without FI
- Procharged LT1 383, what injectors?
- Procharger rebuild(EPP)
- Help needed... cam and injectors for Turbo Project
- What are everyones thoughts on compound charging?
- high mileage boost?
- Need second opinions on BIG Whipple build
- deck thickness on heads
- Correct intercooler
- hay Bob @ EPP thanks!!!!!(pics)
- Pic's of Steve Verplank's Mazda RX7 from Superchevy at OPR/ATI booth this Summer
- restrictor plate on vortech, will seals live ?
- 8.5 psi D1sc results @ GaFBody Shootout
- need help and info on this turbo?asap
- Radical boost spike 41psi!!!
- BMR and UMI Please come in
- Fixed small leaks, and holy sh*t
- Procharger
- Twins location in an f-body. Starting to brainstorm new set up
- how does this sound?
- Intercooler install instructions??
- Got my 8's with the ttv6
- Single Digit Midget M6
- what goes where?
- Need some advise so I can make a decision
- Boost and lifting heads!?!?!?
- Home built Hot Parts Come on In!
- FI Newbie question
- Remote/low mount turbo oil pump
- Snow Performance Boost Cooler ?
- Horsepower gains from pounds of boost.Weird question
- STS Questions
- anyone want to guess what my car will make
- Boost Leak
- finally getting the hang of driving my car
- Crap...FP blowing fuses again....getting too hot I think...
- Silver Dollar Raceway "Results"
- How meth affects current tune? And how to fix boost spike?
- so i was bored today and fabbed up a different alternator bracket
- Those with a Vortech V-9 G-trim
- C5 procharger bracket?
- stainless steel vs mild steel vs aluminized
- Front O2's?
- Gen tt turbo kit
- TTi Street Kit question ?
- Supercharger rebuild?
- Shaft Play Question...
- questions on what i need for safe twin gt30's
- Need help with a seal on a procharger..
- building 383 forged ls6, what compresion?
- f1 procharger?
- Gauge Install pics on my 408/T88 Build
- PCM for turbo car
- anyone use a autometer 4376 boost gauge?
- Red Carpet Turbo Kit ????
- "Flex Joint" & Scav. Pump Q's
- who has experience with a whipple/kb on an ls1? not an fbody
- Really good Boost question.
- Boost Vs head gaskets or??
- Nitrous with turbo?
- Forced Induction and 76GTS Turbo!!!
- How to keep car cool with IC infront of condensor?
- some turbo Q's(turbo gurus welcome)
- How to attach 4" pipe to D1SC inlet?
- expansion joint
- Ran 9.3 at 144mph today at Bristol.
- Noob BOV Q?
- in-cabin intercooler
- I think Las Vegas is one of the worst drag racing facilities in the US
- *** Cartek Turbo Cam and AFR 225 Heads 4 Sale , Track Proven 9.3 at 149 ***
- *** Big-Bore Boost Pistons 4-Sale ***
- what's my compression & how long will this setup last?
- Ported heads and bigger cam or don't bother?
- procharger question
- EGT's on gas turbos
- Anyone port the head chambers to drop compression.
- GT47-88 vs GT55-91 question
- opinions on these turbos for a 408
- Anyone have their car feel slower after getting more traction?
- 450hp turbo ls1
- Kb Blower
- double keyed crank
- Turbo Oil Drain Back Question
- Fuel for FI
- Anyone heard of Q16 Fuel?
- Turbo Guys come on in!
- Decreasing spool time with tuning
- Two TT cars + 3800da + bad track prep =
- Radiator Cap Question
- Why do superchargers give positive displacement?
- STS Turbo Tuck
- supercharging a stocker
- Couple FI questions.....
- hoow much boost should i run with this combo
- quick question
- Ideas on how to change current tune when adding Alky?
- water-to-air leakage problem
- Regret
- New Product: GT45F and GT45FX Non-ball bearing now available
- Need Manual Boost Controller Directions. (Turbonetics)
- FI kit for 496 (8.1L)?
- Vortech SQ trim users inside please
- anyone know a place that sells or has done hot parts for large frame turbo C5 kits?
- Electric Turbo?wtf
- Looking to get a TT system
- Testing our GTO Gen-TTR Intercooled Twin Turbo System
- MSBC-1 user help
- Explanation for oil line restrictor?
- Screened inlet hat pics on a F1R?
- Aftermarket heads worth it?
- 918s hold moderate boost levels?
- Need some help on a NASTY project
- Cam Selection
- Newbie turbo questions
- S91 408 TH400.. Need new cam specs..Or do I?
- Winning streak broken,but new best e.t.
- Some H/C Rear Mount Turbo dyno results FINALLY...
- Accessory belt rubbing with ATI
- So who has the fastest...
- latest progress on my Magnuson MP122HH setup
- O-Ringed Block: Head Question
- ETP Canted Valve Heads and Billet Intake
- 2XXX hp LSX Build Pics
- Does this concern anyone else?
- Old School car/ new technology
- I need your opinions guys
- Anyone NOT running an IC?
- Hit 140 MPH today, TTi Race kit
- High static compression and forced induction
- Need Incon Install help please
- Everyone Welcome - NA$TY-TA JR!!!
- STS without downpipe ok?
- New motor and turbo kit,blowing smoke during decel.
- turbo ls1 advice
- Thanks Canada !
- Innovative Turbo stole our turbo!
- Possible causes of leaning out?
- STS Owners with wrapped exhaust, 2 questions
- Large Turbo > Thermostat Housing
- Base Tune For A F1a 402 Setup W/bigstuff 3
- T76 Turbo. Stock LS1
- Sts Instant Rebate?
- Twin A2W intercoolers Vs 1 Big A2W
- low boost...lag...general bs to pass the time
- Any pics of T6 Thumper setups with truck manis?
- what springs for sts kit?
- MP T70 power rating? Can't find them anywhere?
- Help with supercharged plug gaps!!!
- Flex piping for turbos?
- Does anyone know where to get alt bracket
