View Full Version : Forced Induction
- My LS1 GT-47 240sx
- Finished Turbo crossover pipe - single or twin 44mm gates??
- best combo for a D1SC Z06 vette
- Engine swap question.
- Vortec
- Finally made some 2007 hits, 9.44@144 and 1.35 on DR's
- building my own CAI
- Who running DARTS with their single behive PSI springs on boosted application?
- STS Experts advice needed!!
- Who sells nice flex sections for turbo app.
- TRT Intercooler for STS kit Installation
- procharger d1sc oil problems?
- Quick boost referanced regulator ????
- Looking for head/intake suggestions for D1SC
- S88 turbo
- is it true ?????
- oil pan/bellhousing integrity.
- EPP Banner Contest $50 gift certificate
- Any TT sts F-body guys?
- Suspension
- what mass air meter should i use?
- My own '99 Hugger Orange Z28 is finally getting put back together!
- STS and Cats
- New turbocar out and testing...
- procharger ?
- Cant find 4" to 3" silicon 90 for turbo inlet.
- COMP 232/240 .595/.608 115LSA RPM Range?
- polished p1sc for corvette for sale cheap!
- use my ported ls1 heads or go stock 317's
- head gaskets?????
- Head Gasket - 370ci, O-Ringed 317 heads
- Times and RWHP. Big build
- Dyno Pegged @ TTI
- EST 1/4 mile
- Need better T-bolts. Spring loaded? "Constant-Torque"?
- Waste gate vlv
- twin gt42 76mm
- Iron 420", Dart 225, D1
- 317 heads any good or go w/ aftermarket?
- LS1 Turbo Kit on a LT1??
- LS2 or LS6 intake?
- SPEED INC. @ drag week
- Thoughts on a PT91 vs. GT47-88?
- The Red Rocket is ALIVE!!
- Max boost for a stock MAP sensor
- Charged and Stroked
- Oh yes. It's my turn, PCV + STS + No Oil Pan tapping
- Need Help??? Remote mount turbo leaking oil out exhaust?
- Question... Twin Turbo truck manifold kit with AC.... thinking...
- Procharger+Roadracing?
- F2 Procharger C5 L92 and E85= 1000+
- Pegged the Dyno.
- Ohio Boys Record Breaking Video!
- Would changing my exhaust effect my tube (A/F)?
- D1SC,....Loosing Boost at 4K rpm.
- Ohio Boys in the 7's and another Win!!!!
- 750 WHP LS1 Turbo LS1 build
- STS Turbo kit near gas tank???
- Paxton S/C Severe Whining??? Help
- whats a good gap for 10 psi on TR6s
- Lt1/4 Fi
- ordering oil feed lines right now... have couple questions
- Intercooler HELP!
- New Dyno numbers @ 8.5 psi
- pyrometer gauge or EGT
- Vacuum Boost Manifold?
- Threaded IAT pt #?
- Idler Pulley for D1SC and Service
- Dead MAP?
- 88 Degrees 4200DA shakedown run with the Speed Inc street kit on the Hawk.
- what do you think
- Will this be a good setup?
- Looking for a Specific Boost Piston
- E Boost 2, help fast
- Boost Leak Pressure Tester 2.5
- Ohio Boys! Damn!!!
- Epp Rocks!!
- Meth blockage
- Who's pushing big power & low ETs w/ 6.0L heads?
- An early Friday treat
- 3 bar map bolt on
- F1 procharger on LT1
- Magnuson Question
- A2W or A2A for ls1 turbo street car?
- boost keeps falling!?!?!
- Should I?
- DP size ? on 408 CI with S91
- compression ?
- New Synapse BOV adapter flange
- New BMR K-member
- ATI Performance Products 10 rib wide ProCharger Upgrade Kits?
- Biggest CI for a D1SC??
- LS9 Supercharger
- 8.0to1 CR on a 370 and your thoughts please!!
- Sts Problem!!!
- Phase 1!!!
- Procharger Pulley question?
- Need recommendation for H/C for D1SC
- Any known breakage of DART PSI beehive springs on BLOWER applicaions or good enough?
- Procharger Belt Help?
- Dyno results in!!! STS kit
- TTi 60-1 street kit potential
- Picked up 75rwhp by removing intake, help.
- Single Turbo Guys, what do you do with the O2 Sensors?
- Help with 382 turbo cam
- What about this cam?
- What about mild steel headers and downpipe?
- Video thread! LT cars with Forced Induction?
- Please Guess RWHP & RWTQ
- Power steering problems with an old QMP turbo kit.
- max boost on bone stock motor???
- S88 Compared to a Large Frame GT47 88MM turbo
- ATTN: PA k member with out manual rack and 4' dwnpipe
- need piping
- 642hp/ 577tq :)
- Unpressurized cooling system for high hp race cars?
- GMHTP Mag 35th Aniversary SS Vert - questions
- tranny help!!!!
- Stock LS2 2005 GTO with ATI ProCharger D-1SC and Kooks Headers runs 11.58@122.24.
- Hey Guys!!!
- which heads
- Sleeper Project
- Nitrous or Methanol
- Idler pulley question?
- OIL restrictor// How small is too small???
- Guys with synergy motorsports AST 2-Step... Questions...
- exactly what height to tap for oil return
- Broke into the 9's with my partners Z06
- Got my STS in
- 408 or 427 LSX block questions.
- Clutch question for FI only.
- questions....
- Supercharger Compression Question
- fueling problem please help
- Correct FI cam for 366ci LS2 with LS3 heads?
- Old phamspeed power potential?
- ice box install
- Exoticperformanceplus phishing emails? Anyone else get one?
- New motor is in and running..Dialup beware
- sts/cat delete
- Which is better for my 355, D1SC OR F1A
- SDCE LS1 Tensioner Tool
- Anybody know where to get incon WG actuators?
- Snow Performance Methanol Injection Help
- 408 with GTS-76 rear mount turbo video
- t-4 for sale
- Eboost-2 questions
- What Turbo?
- Financing For STS kits!!!!! Through GE Money!
- 800HP Project
- STS Turbo and Severe BUCKING under boost!
- Whipple & F-Bodies
- APS TT Forged Numbers.
- Procharger ?
- s/c dress up
- Truck Manifolds on a GBODY
- Hobbs switch psi settings
- New best 1/8 mile MPH last night - at 5000' DA
- To boost, or not, on my AFR 402?
- So what's the difference if I switch to YSI from T-Trim?
- MAF and BOV placement
- Question about LS7 gasket on a Ls1 block?
- New driveline for my ProCharged C5
- gen tt and a 4l80e
- Gains from timing with boost?
- werid question...(meth kit related)
- Big Procharger??
- MPG gain with a Blower or Turbo kit?
- I need your opinions on a turbo setup...
- 408ci Twin Master Power T70 turbo's
- Intake set up for big single turbo?
- APS TT Setup in F-Body, All input is welcome!
- Anyone have some old QMP turbo kit instructions or pictures?
- Compression Experts-What's comp with stock LS6 heads and -2cc Diamond Pistons 347 LS6
- Dumb ?
- Gen-TT on a cam only car??
- Magnuson dyno question
- best head studs?
- What kind of TB???
- Official STS Thread
- Turbo help needed
- STS ?'s
- Well the motor is here.
- which supercharger for my lt1
- Procharger guys what radiator are you using?
- can head studs be used over and over again?
- Belt Slipping......
- F1 is on!
- Need knowledge on Rapid Motorsports ability to build quality 346 forged LS6 motor!
- How are Diamond Piston Rings and Scat Rods for 700rwhp blown D1SC LS6?
- Damaged oem crank nose from blower drive?
- dissapointed with 2.8 kenne belle on 408
- Which single Turbo for 6.0L iron. S88 or smaller?
- Need opinion for D1SC cam for 402ci
- how fast has a STOCK lsx been FI
- turbo/procharger with a carb ?
- turbo auto vs 6 speed DAILY DRIVER guys
- Best price for Wilson cast elbow
- No, No, No, No, NO!
- Ordered my first turbo today! GT-K 850 What you think?
- how well would an sts turbo work in a single front mount
- PCV Hardware and Routing for Supercharged C5 - Will This Setup Be Effective?
- F/I Cam experts-Stick with LS6 cam or 224/230, 114 lsa for 346 forged LS6 D1Sc motor
- Supercharged Lt1
- Mti Clear Lid W/ Powerdyne
- Blower Belt PN
- 8s with a 347??
- 14-15psi...D1SC or F1A??
- what piston would you guys recomend for <18 >8 psi
- need fmic for sts firebird
- and now for somethimg completely different..... OFI install!
- Anyone making Novi 2000 brackets yet?
- Oil Issues HELP!
- should i coat the pistons or not?
- vortec supercharger
- Just a bought a 2.8L Kenne Bell
- Need ProCharged LSX Help (cam and boost)
- Not everyday you see one of these!
- How do you increase boost on a turbo???
- Procharger Bypass Valve Question
- Can some of you procharger guys help me out...?
- New Updates at KY Turbo and Performance.
- Which balancer are the big turbo guys using?
- stock motor need help
- Procharger Problems...STILL!
- seeing knock, poping head gaskets, tried many things, need help, 1000+rwhp
- STS guys running straight spring
- Opinions on these spark plugs please
- What will make a big cam work?
- Whats happend to gen tt f body guys?
- Finally hit >10# of boost on my T-trim from S-trim Upgrade
- Custom 76mm Turbo GTO setup
- Anyone Have Any Experience with a GT4202?
- Where are you making full boost?
- 797 RWHP APS Twin Turbo GTO Hits the Rollers
- New toy
- 4.38" to 3.9" pulley?
- Is S the designation
- Can I get away with an internal WG?
- best alternator relocation bracket for turbo setup
- Piston question?
- Did Synergy go under?
- Does anyone know if the Procharger F1A fits on the F Body with the Be Cool Radiator?
- Synergy twin kit, 717 hp...
- Supercharger for my '01 Z28 Camaro
- Anyone have any idea how much to fix turbo?
- help with magnacharger
- Knock under boost when ECT higher than 215F
- need .81 turbo housing! i have .96
- meth or intercooler or both
