View Full Version : Forced Induction
- Motor Build! With Pics!
- WTB 80MM to 96MM Turbo
- Changed wastegate springs, need some advice
- Sts
- COS 2bar, IAT & ECT multipliers
- Another OHIO BOYS Win!
- APS C6 ZO6 twin turbo system pics and install instructions
- im curious about some of your FI tunning rituals
- MAF-Keep it or ditch it! Explain why=>
- what do u guys mean by "spools by 3500rpm"?
- My APS TT Install Thread
- Pics of oil return off turbo into pan or timing cover??
- APS TT blow off valve
- Can i run my oil return for turbo to a valve cover?
- 402 twin turbo mistake ?HELP!!!!
- turbo tech worth??
- HCI vs. APS Twins
- Building the ultimate turbo LSX---head Q's
- For the love of god...can we make a turbo cam sticky?
- Turbo Cam
- d1sc on a torquer v3 cam car?
- Cat issue with STS?
- Using airconditioning as an air cooler?
- TT Truck Manifold Kit! (18psi)!
- Is bigger better?
- which cam to go with???
- Turbo guys suggestions please
- Forced Induction
- ofi radiator and overflow for sale
- HELP!! Cant rev my engine more than 5300rpm
- ati pinning kit
- Electronic boost controller recommendations
- APS TT Kit, Setup
- Turbo'd the wifes truck
- SX88 Dual Ball Bearing
- ditched my darts for l92
- Whats really needed in the FI world?
- any one using a ported fast 90 with a procharger?
- 350 whp from sts!?! thats all!?!?
- LS1 Magnasun Supercharger!
- Install Of Aps Twin Turbo!!! Kwikss
- lost low end
- Teaser video of Whipple 3.3L in C5 Z06
- oil return idea
- Who has 4" TB cast elbows? And some meth questions...
- performance products intake
- What size TB for carb intake w/elbow?
- YSi compressor map.
- Professional produvts intake and throttlebody
- New Best ET/MPH Worst 60 ft!!! 9.670/145.83
- meth vs nitrous
- S80 versus S88 on 408
- lt1 turbo ,can it be done
- New PB with F1A Procharger
- Need opinion on used D1SC Procharger
- IC for STS kit..mounting by air dam
- HPM TTiX 347 Dyno Results
- Superman09 track results
- APS f body install thread, tips,tricks,pics,etc.
- MAF problem!!!
- Reliable DD: P1SC vs. STS Help me decide
- Who has gone with a Custom Turbo??
- OIL + SMOKE out of DOWNPIPE= not cool
- How is everyone printing out the APS turbo Guide?
- Can I reuse intake and valve cover gaskets?
- Pro's and con's of running COgs on the street
- Saturation Intercooling
- F.i.???????
- Heads up on Hardcore....
- 50mm tial BOV what spring?
- Time to tune and boost my 98. What MAP? Still using MAF
- 3-bar map sensor
- STS Help...
- different prochargers???
- Which BOVs and WGs are preferred???
- Procharger Install Help
- Aps manifolds
- Why Am I Losing Boost - Incon Setup
- Finished! C5 vette single T4 turbo setup
- Those with the 8-Rib SDCE setup
- A2W intercooler help...
- Anyone using Trick Flow heads
- Going Turbo :D
- Pics of boost gauges/controller in dash vents,T/A
- Turbo Spooling #'s!!
- Now is the time!!! It wont be any cheaper!!
- Piston Rings Boosted?
- after catchcan runs like sh@$%
- Turbo specific engine build ?
- gt45 on stock motor...any comment!!
- Turbo Needed
- low oil pressure, is my ls1 on the way out
- sp motorsports west coast killer
- Pick my cam for me
- crank pulley
- Prosport Gauges - Any experience or info
- Tt 04 Gto
- PT98/88 on a 347?
- what do you guys think
- Lq9 and Lq4 heads
- Stock Cube LS1, Which Turbo?
- ??? For you OFI owners
- Incon tt Stage 1turbos HC408 or LC364
- confirm my fear.....
- Looking for 2nd opinions.... Forced Induction camshaft selection...
- highest psi on stock springs
- Vortech T-trim upgrade from S-trim
- APS F-body kit is here (56k take a hike)
- 07 Suburban with a SC
- trans upgrades for sts ???
- All ATI P1 or D1 owners inside please
- got some dyno numbers on T67/403 mis-matched combo
- what to tune!?
- sts turbo kit, good or bad?
- Why Is This Slow!?!?
- How much more power
- INCON FP regulator help
- Cartek Aps Tt Forged 347 Final Numbers 907rwh
- Getting cold, fresh air into a maggied '06 GTO. any ideas?
- Which cam to go with for a D1SC
- I just inherited this!!
- Need some help...turbo troubles
- New Custom Y-pipe
- What would you consider a perfect daily driven FI car?
- TT GTO back again...
- Black dust inside procharger outlet & intercooler tubes... WTF?
- STS cam confusion...
- Which Supercharger?
- OHIO BOYS Video
- any FMIC kits that allow minimal work/mods to bumper?
- Help! Magnafuel pump blowing fuses!
- royal purple =sludge
- Total Seal AP Steel Ring Gap
- Red Rocket meets Sticker Dude!!
- Megasonic BOV with Video
- Power steering fluid boiling!
- how many 8/9sec. turbo cars run air filters?
- 100% Methanol or 50/50 Mix?
- Can you mount turbos vertically?
- Which Twin Turbo kit to buy for an F-Body? APS or Gen TT?
- LQ9 main caps srenth DO or DONT!!!
- And the fun begins
- Help building Turbo Motor
- Calculating Compression Ratio
- Gale Banks Turbos?
- need help installing synergy 2-step for an M6
- newbie to FI... help me!
- Cranking compression of a 8.5 to 1 motor?
- Effects of cam timing on a turbo motor
- Ok Turbo Cam Masters!!
- Twin turbos
- 408 Iron Block with what turbo??
- Maggie + H/C
- Stay D1 or go F1????????
- how much boost stock ls1
- video sticky
- Gen TT
- turbocharged c5
- STS F-Bodies in the 10's
- 3" or 4" intercooler???
- 8.6:1 347 with 14psi,any thoughts?
- MSD Timing twister? MAP sensor boost retard
- solid supercharger tensioner or spring loaded
- Hp Performance Turbo Kit V Sts
- IAT sensor leaking air through it?
- Finished My D1 Setup Sunday!
- Turbo Newbie Question
- Firehawk that we built an LS2 for last year is now going to get an APS twin turbo kit
- 423" stroker, Afr 225 heads, F1a Procharger w/front mount.
- Whats the best Oil feed line kit?
- AFR 227's and Procharger
- LM Speed Maggie Kit For F Body
- 408 with a d1sc?
- Looking for high quality digital boost gauge.
- Cannot get Procharger Belt on....Help
- Exhaust pressure gauge. Who makes a good one?
- Help with prepping a motor for Turbo
- Wideband gauge
- sts and a 75 shot
- Iron or Aluminum for me?
- Turbo and Tuning problems
- To stroke or not to stroke???
- Joy after Heartache!
- how many have a kenne bell sup up for a vette
- finally good pics of setup
- Anyoe interested in my old blower verter? TCT
- Why hasnt someone come up with an STS intercooler??
- vic jr intake worth it for a turbo setup?
- Questions about BOVs
- Aps Gto
- How important are cooler plugs?
- Congrats Ohio Boys 8.06 @ 182
- Can a non-intercooled Magnacharger fit a stock C5 hood?
- What boost are you getting with your pulleys?
- ATI balancer + Procharger Problem with pics!
- Snake Slayer is Back!
- Turbo Car overheating
- Front Mount Turbo or Procharger?
- -25cc dish to much w/ 71cc combustion chambers
- BigStuff3 Boost control
- overheating issues =(
- radix 122 model infor
- procharger fan help
- 36.5" Procharger Belt
- Procharger pulley Question
- Blower or Turbo with a motor plate
- Some turbo projects might actually end...
- project last head gaskets evarr!
- Head flow question, anyone have examples?
- F-1A 427 l92 heads 219 cam 858 RWHP
- Procharger/Turbo?
- What size intercooler tubing?
- 408 with Procharger??
- Dyno tune on Monday, want to guess RWHP and RWTQ?
- turbo cam higher lsa and exhust right?
- APS F body twin turbo system $5495 twin turbo deal extended to Oct 07
- Question about boost.....
- Average Procharger boost with 4.5 pulley?
- Just fired up my 3.3L Whipple on my C5 Z06
- Procharger Help
- Twin turbo F-body or vette vids?
- whats the progress or updates on your project?
- ATI ProCharger Clocking Guide
- My OFI kit Dyno results!
- Anyone running a S-trim?
- What block to use
- Procharger W/ Nos? How and How Much
- Procharger Air filter
- Any reputable shops that will work on a turbo LS1 in Alabama?
- Is Forced Induction Feasible With My Current Setup?
- Theory question on boost.
- ls6 vs Fast 90 for F/I
- NemesisC5: Customized and Supercharged
- Maggie Dyno Sheet
- shims in a BOV
- Maggie M122HH For L92 Heads?
- Building your budget stock block....
- Supercharger Plus Turbo
- looking for hot side vendor
- how much power and boost?
- LT1 turbo. best heads/intake?
- Broke alternator with a D1
- Twin turbo exhaust
- S88 408 Turbo build. What size head valves
- i have guys telling me not to run c16. need some experience here
- ATI pulley bolt, washer, and pin question
- catch can setup help please
- Turbo line questions
