View Full Version : Forced Induction
  1. Finally made GM High Tech and Cover!!!
  2. On3 Turbo guys.....
  3. GT91 or HP91 T4 .96 AR Garrett availability help please...
  4. Turbo Sizing Recomendations L33 Fox
  5. e3 plugs and boost... Anybody doing it?
  6. F1A procharged WS6 in GM HIGHTECH
  7. My LS1 finally dumped me
  8. MSD 8733 2-Step w/Turbo
  9. Who's boosting L92 heads?
  10. Any Fox Bodies Using C6 Exhaust Manifolds?
  11. LT1 Turbo went to the track tonight...
  12. aes 390, d1, someone help please
  13. Do I really need a mondo or big red bypass..
  14. TFS 220 heads
  15. 2005 lq4 crank bolt part number?
  16. Twin Turbo Oil-Less Rear Mount 2010 SS by Unleashed
  17. 63 Turbo LSX Nova Almost Done!!
  18. 92 Camaro turbo lsx build 51k original miles
  19. Any FI members going to Ocmd car show this weekend?
  20. MSD 7562 Programmable Boost Controller
  21. Does my turbo need to be rebuilt??
  22. Started on my twin turbo build. Pics inside.
  23. Which aluminum 3" vband are you using?
  24. **LMR TX Mile Corvette Pics**
  25. What's needed to piece together a D1SC kit?
  26. LS2 block VS 5.3 for boost.
  27. Inlet Hat Gains
  28. New Supercharger for an LS3
  29. New turbos and headers Pics added!!
  30. F1r tbss!!!
  31. How much boost LQ4 w/ 243's
  32. Boiling fuel or cavitation in boosted application?
  33. Pusher fan install question..
  34. mishimoto vs cxracing intercooler
  35. Overboosting, can't figure out why
  36. Supercharger efficiency?
  37. callies stroker ARP 2k rod bolts?
  38. LS 408 BUILD UP, Could use some input.
  39. 2 bar map sensor tweakin out?? wtf
  40. Update on my KY turbo build..since break in.
  41. Billet valve covers. Who has in stock and can send now?
  42. 2005/5.3 head bolts which arp's to use
  43. 02 Z06, 370, YSi, yadda yadda
  44. Ideal DCR / SCR for centrifugal setup
  45. Which valvesprings? S475, 5.3, z06 cam
  46. LS3 TT questions....
  47. Favorite BOV??
  48. 3 bar map thats fits in stock ls6 intake inside!
  49. 202.5 mph Standing Mile Run in my 1000+ Rwhp Turbo Camaro - Video inside!
  50. 370/F1A dyno results on pump gas
  51. Bypass valve mounting/install question
  52. 317 heads valve?
  53. Ford Alternator on a LS1 motor?
  54. Huron Speed Turbo Kit Spring Sale LAST CHANCE - Ends 5/13/12
  55. 1/2" heads studs question?
  56. WTF is wrong with my car
  57. For those that always ask will 317's make power. 1000+ inside w/ vid
  58. ls1 or lq9
  59. Boosted going to single 2200CFM shrouded fan... HPTuners.. what to set fans to?
  60. Cam Help
  61. ATI/Procharger rebuild help
  62. **LMR's ZL Stage II 675hp Package Video Inside with Track Results**
  63. Supercharger installed at one place.....
  64. Engine Damage at 16PSI
  65. 450" Topped with Mozez heads/Marcella and a 118mm: 1352rwhp-15# boost
  66. Build ideas for 450-500hp with single turbo?
  67. Magna Charger
  68. boost referenced regulator in the trunk ?
  69. Finally done, and slightly disappointed...
  70. 4.8 t6 s472....it's only the beginning....
  71. Help! Turbo sizing for 5.3 - Specs inside
  72. ebay t88
  73. to stroke or not to stroke, that is the question
  74. I need to buy a wire harness, need input
  75. 317 heads on turbo build
  76. Turbo oil feed?
  77. Procharger guys 1 7/8 headers or 2
  78. Precision Turbo went bad twice in 3 months....now what?
  79. standing up the radiator
  80. Best converter to help launch on T70's
  81. The classic 'will it hold!'
  82. Trying to figure out witch heads to use on a turbo 4.8
  83. Magnafuel 4303 feed it with -12 or -10 ?
  84. Stock ls1 turbo+ nitrous
  85. Sound performance T4 Quick spool valve
  86. LQ4 Turbo Build Thread
  87. question for who use the Griffin Rad.27.5x15.5x3
  88. New fuel system,2 bar MAP, and E85. Car starts but wont idle..
  89. Front cover oil drain with truck front accessories
  90. Turbo ltx guys= best head gasket
  91. Is anybody using Probe pistons in their FI engine?
  92. How much more power do y'all think I will make?
  93. Best head gasket for high boost application?
  94. 370 C6 Manifold A/C build Precison 7675 CEA
  95. Pics of intecoolers and piping for twins
  96. noob ????
  97. 65 chevelle drag car which 0n3 do i use?
  98. What is everyone running for a boost reference fuel reg?
  99. Opinions on cam grind...
  100. 76mm turbo 5.3 3rd gen TA WOT runs @ 5 psi
  101. Electronic boost controller
  102. SO, im going turbo and know nothing about it, come inside
  103. Boost guys to Atlanta!!
  104. LS9 gaskets with L92 heads?
  105. ***Late Model Racecrafts 650hp ZL Camaro Package Inside***
  106. ?s on Nitromethane with Methanol Injection
  107. AFR 245s in stock? Needed for ProCharger F1C build
  108. G-FORCE 427 LSX F-1R Procharged 2011 Camaro SS!!!
  109. Need advice: WTB boost motor...will this work?
  110. Homebrew Alt. Relocation Idea.....
  111. 5.0 Ford to 5.3 ls swap, can I break even.
  112. mbc ok to put in car?
  113. 5.3 (LH6), which ON3 for me?
  114. Pressure drop across intercooler
  115. Intercooler Help Please
  116. air to water intercoolers
  117. 76mm OIL-LESS Turbo LS1 Miata Track Video!
  118. Anyone use the Obx turbo headers?
  119. 2011 SS Auto, Sleeper Package 561rwhp. ZL1
  120. What a day!!
  121. powerloss between 30° and 100° intake temps?
  122. JY5.3+LS9cam+s475+22lbs of boost in a 88GT
  123. help me reach my goals
  124. G-Force 427 LSx F-1C Procharged C6
  125. Huron Speed, on3 turbo, and 5.3 dyno results with vid!
  126. Let's play, "What's that in my oil pan?"
  127. FI head/cam question
  128. AMS1000 and Map sensor wiring
  129. Looking for input on stock displacement ls1 m6? Anyone with a Huron Speed Turbo Kit?
  130. were to by borg warner turbos
  131. Just Another JY 5.3 Build......
  132. Moran injectors on E.85
  133. Need help...head gasket issue
  134. 71 Nova 5.3 PT7675 build (now PT88) 9.98 at 139.
  135. 1200 rwhp Dyno Vid and several runs at Texas Invitational
  136. drag radial turbo build thread
  137. Our LT1 Track Video...new project?
  138. ECU advice
  139. A few e85 turbo build questions
  140. Junkyard engine guys
  141. any new or majorly revised true street builds?
  142. 2 gt2871 ball bearing turbo set up for sale
  143. whos got the fatest turbo aluminum block LS motor
  144. Unleashed Stock Bottom End Turbo C5 - New Best...10.26
  145. Bolting on PRC 215s, Couple Questions :)
  146. Oil smell from catch can set up...
  147. turbo ltx guys-how r u standing up your
  148. Turbo cam
  149. Stock rear, how much can it take??
  150. Bill's 99 TA LSx/F3 procharger
  151. Avalanche 5.3 V2 Vortech kit on 2002 LS1 Camaro
  152. New spark plugs required for 7-8 lbs boost?
  153. Catch can vs breathers vs header evac for PCV on FI LT1. Discuss.
  154. Procharger on a high compression motor..
  155. F1-A/390/E85 *** Update 4-24-13
  156. Turbo Cam ???
  157. SLP supercharged 427?
  158. Hot idle with vertical radiator?
  159. Where to buy tc78
  160. FMIC Ques ?
  161. out with the rear in with the front
  162. A-body turbo mounting solutions?
  163. Virgin 99 ss looking to hit 500hp Ideas???
  164. Turbo with 12.5:1 compression
  165. Turbo Sizing Question.
  166. Huronspeed.com turbo kit special!
  167. LS2 blower manifold 6-71
  168. Who's running the holley coils?
  169. F1r procharger on high compression motor
  170. TPS Splice harness?
  171. turbo kit swapping truck manifolds for shorty headers
  172. Got a 364 9:1 shortblock. Do I use that or my 11:1 416 or sell it all and go AES 410?
  173. **ZL Camaro By Late Model Racecraft**
  174. Turbo Size questions
  175. Any LTx boosted guys on here?
  176. em i getting a good deal ??
  177. Largest Blower Pulley with Aster Bracket?
  178. Heads, Manifolds, Bottom End?
  179. How much can a stock bottom end LS1 take? What catch can to use?
  180. Head Stud and LS9 gasket question.
  181. twin turbo ls1
  182. New Shell race fuel on Boosted cars.
  183. **LMR TT Camaro 1303rwhp Dyno Vid**
  184. Procharger D1SC LS1 J-Bracket Pros and Cons?
  185. thoughts about the c6/truck manifold turbo kit...
  186. Supercharger and turbocharger combined?
  187. Flex Section or No Flex Section?
  188. Turbo build ideas
  189. Speed density?
  190. New CTS-V Stock Ported Blower Only Record
  191. Speed density: re-tune necessary after turbo swap? Tc78 to PT7675
  192. Which procharger for me?
  193. A/R size for 76mm turbo+4.8 Motor
  194. speedway ls1 alt. bracket
  195. What do I expect to pay for a used procharger?
  196. Compression & Boost ?'s
  197. Upgrade rod bolts or not
  198. boost controller?? whats everyone using?
  199. ls6 twin turbo
  200. Project Plain Jane 62 Chevy II TT
  201. Turbo launch and then Nitrous.
  202. Way to quiet my wastegate, any downside to running back to downpipe?
  203. Studs or bolts for exhaust manifolds?
  204. The concept of: less restriction lowers boost but makes more power
  205. Lysholm Twin Screw?
  206. One piece motor plate
  207. Compare Valvoline VR1 20W 50 and Liqui Moly Synthoil High Tech 5W 40
  208. Alt bracket for turbo setup
  209. Callie comprstars and gm crank
  210. Fuel issues
  211. Best factory head for a turbo 5.3?
  212. more boost!!!!
  213. ls oil return
  214. High mileage stock motor turbo
  215. stock rod bolts??
  216. Need help with my SS 304 turbo manifold
  217. Twin Turbo guys who kept a/c
  218. Little problem with the 370/F1A
  219. stock 317 head gasket problems
  220. Carb'd LS7 FI Style Intakes
  221. Which fuel? 92 oct or e85
  222. 4.8 JY build
  223. Mmm, its so shiny
  224. Procharger for a H/C/I car?
  225. Meth pump fittings
  226. Turbo 5.3 build...suggestions welcome
  227. Charge Pipe Size Question
  228. lsa cam
  229. Procharger Twin Intercooler Dimensions
  230. BIG boosted 5.3s: come In and list ur setup!
  231. Question for those with relocated alternators
  232. Turbocharging a nitrous motor, can I make it happen?
  233. Alternative to truck manifolds
  234. Procharger Plenum and Meth Injection?
  235. "Bloodline" 68 Camaro TT LS3
  236. ATI Race FMIC vs CXRacing FMIC vs ATI Twin 4.5 IC
  237. **Another Supercharged 5th gen by Late Model Racecraft**
  238. 98 ECM and EFILive for Turbo Build
  239. 5.7 heads on 5.3 block ?'s
  240. Quick Procharger Installation Question!
  241. help!!! rough machining marks on deck which gasket can i use (pics))
  242. LM7 turbo questions on alt/PS/tensioner
  243. Any 600+ hp guys running MAFs?
  244. Who knows how Meth injection affects AFR?
  245. twin turbonetics 11533 thoughts
  246. Blown lq4 how much can the block handle
  247. Having issues with car. Help wanted
  248. RMCR lowmount
  249. gto procharger fans
  250. Full boost on a TC78 or similar?
