View Full Version : Forced Induction
- belt length
- clutch?
- front bumper cut out pics?
- Getting a STS car off the line.
- Iron 370 or Aluminum 347????
- Air Filter Restriction vs Boost On FI
- Need Some Help.....
- Testing Results
- 346ci FI vs 408ci FI
- Melling High Volume Oil pump w/Rollmaster Double Roller
- boost on a 3 bar fast unit ?
- vortech help
- making more room for turbo setup
- Trouble with my motor head gasket?
- Cam & stall recomendation, 6.0, Blower, and bolt ons
- my PT88 car *vids*
- APS TT GTO Dyno Video 16PSI
- Slick turbo plug wire pic
- The real story behind Phamspeed's Budget kits... (Read Me)
- Am I leaving streetable power on the table with my current cam?
- D1SC on 383LT1
- Procharger on stock ls1
- Anyone using FJO Racing's Water/Methanol Injection Setup?
- STS Dyno Number Low
- Not a F body but a cool FI project!
- Will these turbo spec work with an ls1 or lQ9
- When are the IATs to high for FI??
- FAST 3bar MAP install
- is this bs or reliable?
- Shall i do a pic by pic write up on LS1 vortech install
- Check Out Andy's "Secret Cam": Looks Like He Is On To Something
- how much more money do i have to spend!
- turbocharged problem with brakes!
- Will this pcv system work?? PICS!!
- who does work like this...
- Dyno #'s @ 5500 RPM
- 2 or 3 BAR MAP for hpt & interceptor gauge
- forged motor
- Anybody using an EBoost2 with two external gates and one solenoid?
- Updated Pictures of my SS
- What thermostat for 346 twin turbo?
- Synergy Twin dyno results....two dynos
- An STS Trailblazer SS is Born
- Boost piping.
- Carb# California
- school me for boosting on transbrake
- Any boost numbers for 403/F1A with this pulley combo?
- low CR fuel economy...
- TT vs Big Single Turbo
- dumb question - pt76 turbine v-band flange, what size?
- Turbo cam recommendation
- Fluttering past 6K rpms?
- Possibly purchasing s-trim/ need advice from vortech guys!
- Meth options
- Hi-Flo "Street Killer" Install pics
- Sputtering in boost...HELP!!
- pics of a/c compatible turbo setups ?
- what is a safe afr for low boost?
- tonight 1265 hp and lost a tire...
- How to remove the blower pulley on maggie?
- 347 F1R dyno video
- LT1 Manifolds
- LS1 sts on a Lt1?
- 3 bar wiring
- Forged Motor Build In Progress
- DCR's turbo engines?
- ms3 with fi??
- Anyone use a powerglide in thier turbo setup?
- 7" Velocity Stack
- Anybody used LS2 plugwires on a LS1 for turbo pipe clearance?
- STS and driving in rain
- 408 with single Turbo T76??
- Alky Control Kit Install ?'s
- 946 hp street tune
- Anyone Got one!
- 796 Rwhp 720 Rwtq 347cid C5 Auto F1r
- is it ok to spray lube in wastegate to prevent it sticking open?
- MSBC-1. where to buy?
- IS this turbo capable of 800whp?
- Who has/uses a Bead Form?
- new 403 in and running
- only 5ps1 help1
- ProCharger belt length rule of thumb?
- New Car New Build PART 2
- more boost with restricted exhaust?
- Supercharger Surging @ Idle
- Fireball FI98x Turbo Build
- My STS turbo 383 build **PICS**
- Twin Turbo Vette. Anyone know this guy?
- cam shaft for 6L with f1 procharger
- my first new car pass little video
- intercooler inlet
- Ls6 Intake Gain?? Worth the cost??
- Twin Turbo Manifold Kit(Coated Hot Parts)
- Final Twin Tirbo Kit Pic's
- Intake suggestions for my street Twin Turbo set-up
- basic FI questions
- Progress pics of twin turbo Firehawk
- procharger & exhaust
- Any one using greddy catch can for pcv system?
- need help, chance to buy headunit
- Physical Dimensions of the Procharger Red Race BOV?
- coolant recovery
- More power with higher octane same tune?
- Suction hose on Procharger
- turbo vs. supercharger(LT1)
- procharger systems(LT1)
- tuning software
- A&A procharger/LS2 throttle body fit?
- problem with snow progressive meth kit
- Boost drops off? I need a drink..anybody?
- BBC turbo headers
- wideband acting up...AFR 50+
- Turbo rebuilds
- HELP!!! Problem with BOV!!!!
- e85 instead of methanol injection
- Dyno numbers
- FMIC question
- FI+Shot on Stock bottom end
- Procharged A4 question
- mounting stock fans to radiator?
- Those who moved radiator up and verticle.... in here
- quick heat wrap question...front mount turbo
- turbo manifolds
- Where are my old kits?
- Testing S95 placement
- ATI F1A and No Intercooler on Pump Gas??
- scavenge pump for turbo...return to pan?
- Coolant temp drop from removing the condenser?
- Any ATI users ditch the fan shroud?
- Anyone using Zirgo fans?
- CR help??
- Heads on procharger???
- f1r
- Side mount magnacharger...any good?
- ETP 265's and Victor Jr manifold
- Lowering Swaybar
- A & A Progercharger 8 rib-stock idler pully?
- New D-1SC from EPP on NHRA Trans Am
- effing crank bolt...
- 83# inj and fuel system ??
- Underdrive Pulleys with a Procharger P-1SC-1
- TTiX Manifolds....
- Block?
- what should my max boost pressure be at max impeller speed?
- GT3582r
- I need a sensor or gauge to let me know my turbo is getting oil??
- Got a Speed Inc. Street Twin setup coming and have a few??
- Turbo Maintenance??
- Can I stand the stock radiator up if I modify the core support?
- exhaust housing q
- hp/boost ##
- Patriot Gold Valve Springs on a stock motor
- why is whats his name selling his twin turbo?
- boost????
- Who has BEST PRICE on F1C Procharger System?
- STS Rear Mount Maximum Boost?
- turbo headers
- Belt Alignment On A D!sc.
- TURBO or SUPERCHARGE?
- Home built D1-SC and fmic, finally got to start it (Vid & Pics)
- 2 step
- Whose running HV oil pumps?
- would supercharger from a lt1 work on an ls1
- Patriot duals: Gold or Gold Extreme?
- Anyone use Royal Purple?
- p1sc ls1 pully size q?
- Forged 347
- People w/a catch can is there a oil smell?
- 8.5 DCR OK for NA, what about supercharged 6#s???
- fuel cut 2 step
- PLX Wideband
- those with ams1000
- rad size 4 relocation
- What way to go suggestions wanted
- Had a good time at the Pinks all-out thing..
- I need help....1969 camaro LS series motor
- heads/cam for a procharged ls1
- 427 procharger F-1A l92 dyno numbers
- D1SC Bigger inlet hat/elbow???
- AEM tru-boost controller?
- 427 or 388 with S88 turbo? cam specs?
- header wrap affecting my AFR?
- doing supercharger install this weekend Vortech guys come inside!
- is it an issue?
- Stock ATI BOV.
- I'm almost there.
- Apexi AVC-R help
- Vortech Supercharged 2006 C6 Z06
- Heads poll for D1SC and stock 346
- Best head / intake combo for 427ci FI build
- quiet bov or bypass valves
- What size air filters are you guys using?
- Katech Tensioner
- going back to the dyno monday to finish 635 so far with fuel pump problem and no timi
- OIL restrictor starting place.
- Going FI, basic necessities?
- 106MM 347 in a GN build thread
- My new setup: P-1SC w/ forged 347 (632 RWHP)!!
- A few ?s guys
- 90degree silicone elbows OFF the intercooler?
- Zangel
- Little bit of progress on my GT47-88 project
- Turbo oil question????!!!
- So whats the status of all the Hi-Flo kits??
- DynoTune Boost Gauge Sending Unit ?
- oil return line location
- A2A intercooler
- LS6 Head and Cam and Vortech V9 Kit?
- sts and homemade rearmount guys pcv???
- New Dyno#'s - WTF is Going On?
- Auto=SC Manual=Turbo?
- 650rwhp help on ignition...
- Stock Bottom End, Stock Head A&A P1SC Dyno Numbers
- Mild DD turbo...questions.
- where to find boost-a-pumps
- Money Well Spent!! Procharged C5
- innovate gauge mounting
- Please help me choose a heads/cam/intake setup
- quick pics of pt88 build
- Started my car today and its running like crap?
- restricting oil to turbo?
- fabricate your own 8-Rib Balancer
- for u guys that want a supercharger on ur intake manifold
- Alkycontrol knob...?
- Air to Air intercooler efficiency
- Vortech Mondo and race bypass
- boost???
- Turbo or Nitrous
- LPE 100 mm MAF
- 408 shortblock build or buy???
- headers
- New S88 turbo hits the track.....
- SDCE kit question
- procharger d1sc
- Recent pics of my Turbo Formy...
- Who's running meth
- Tried search, looking for people with STS kits and dual exhaust
- Where to buy 3bar for a corvette
- Tial BOV 9psi or 11psi spring?
- Cleaning a intercooler??
- AEM Map Sensor
- My DIY 6.0L manifold build thread
- sts turbo vs. headers cams...
- turbo exhaust pics?
- alky injection kit installed finally, almost
- Balancer
- Thoughts& opinions on ATI D1
- d-1sc question
