View Full Version : Forced Induction
- F body Procharger users--relocate alternator?
- Twin Turbo 403 LS2 on the way
- Turbo cam recomendation from Cam Motion
- becool part number
- New Build for the 67
- BOV Comparison...
- D1 vs F1 drivebility
- How much money for diy turbo?
- general timing question
- Turbo pics
- Swaping heads for FI will this work with my setup?
- How good will this cam be?
- 2,300 HP...454ci TT...daily driver, 950 rpm idle, A/C, all accessories.
- adjust mondo bypass valve?
- Something New to Help the Twins
- difference between stock and STS pcv?
- Supercharger HELP!!!
- are these any good?
- Got my little air filter for my GT47 turbo
- How many are on 113lsa cams with F/I???
- Kenne Bell supercharger?
- Is my vacum low?
- If you ever wondered.... Hi Flo hot parts
- Boost Pistons
- need pictures of sts intercooler set up
- Looking for the final say on a Procharger
- magna charged F-body
- Garrett turbo question.
- How much more timing are you adding with Methanol?
- Twins + E85?
- Gen-TT G8 Development Complete and Shipping
- Traveling with Meth
- what do you guys think?
- Underhood Temps. Is there a Fix?
- Eye Candy
- Those using nitrous jets for restrictors come in!
- wastegate pressure connection
- Official STS help thread
- Complete new ProCharger 4.5" intercooler assembly - $850.00 shipped at EPP!
- LT1 procharger pics
- Highest HP TT Z06
- Any sponsors sell carb'd procharger kits?
- 2.65 or 2.75
- Ninetres's new forged 364 build thread
- Turbo's are here!!!!
- Please help can't pass emissions in colorado?
- Looking to lower my compression ratio?
- new toys :D ( pics )
- 9seconds or faster running drag radials?
- sts guys, how much oil do you use?
- Opinions on "turbo cam" vs Z06 cam in a 408
- 6.0L heads part number
- Innovative or AMS 1000 Boost Controller
- ignition & PSI & Power
- Open Down Pipe?
- Problem with missing/bogging above 6 psi
- routing intercooler plumbing...
- 67 TT camaro Build
- Procharger IAT's
- Help me decide
- Whats easier to install? Turbo or charger
- modified TTi street kit ( is it possible)
- Good Blower Cam
- FP and Octane
- will you be ordering one of the first aps TT kits
- Turbo choice for true street class....
- Turbo Oiling
- F-Body D1SC Head Unit Problem/Question
- anyone have a parts list of a homemade rear turbo?
- How much is my car worth?
- Guess Dyno #
- help!!!!! i need to drop the comp.what is the stock combustion size of a ls1 head
- The Truth about Traction
- I'm Baaaaack
- More problems
- Newbee at Turbos. Will this work?
- supercharger cam
- Pusher Fans
- LT1 Boost?
- procharged Z06 track times with vids
- 1 7/8 turbo headers?
- What coating companies have you guys used for turbo hot parts?
- 224/236/114LSA blower cam?
- Boost controller for supercharger
- Turbo compressor surge causes MAF reading fluctuations?
- What gears for a procharged car?
- Noob Water/Methanol injection Question
- Procharger Question
- 2 bar map and adapter part #s
- TA's with STS kit....POST PICS!!!
- Need help with turbo setup
- Remote oil filter??
- Those with scavenge pumps come in!
- AIT's What is more Effective
- STS Gurus I need some help.
- C5 Turbo Exhaust advice...
- MAF in front of turbo or after???
- Incon kit for sale for $3,800
- wideband location on a TT
- Intake elbow keeps collapseing (STS Kit)
- Sometimes when you have too much Boost... This Might Happen...
- Superman09's Twin Turbo Build Thread Part 2
- Let's talk about blower cams.......long!
- Where to put a MAF??????
- Blowby...
- P1SC Sound/Video
- Gen-TT Twin Turbo Fbody 800rwhp system $4995 including free delivery
- paging PSJ...
- I've been screwed by scrapmetal!
- F2r Mounts
- Totaled out my rig into a huge deer,
- Turbo cars in rain....
- Where to go from here?
- who sells the sts kit for the least $$
- Cuttingout and bareley spooling up!?!? whats the deal?
- 13 psi, 408, pt88, 91 octane still few issues dyno sheet
- Rear vs Front Mount?
- Trying to make 600rwhp..
- Any trades?
- cheap turbo kit.
- Size of stock TT incon turbos?
- Do I have the completly wrong cam?
- Real Price of BS3
- Supercharger on a v6?
- A/F ratio to lean to race?
- Help Need Closest Istaller For Ati
- Keep my 347 or get a ls2 402?
- Turbo guys, do you park in your garage?
- Head Selection & clamping ability
- My turbo setup is for sale
- fuel system questions ??
- 427 LS2 and boost boost boost?
- new sts kit ???
- Who make's this!!!!
- What mods for 2000 Trans Am to stay with 1971 Vette (454)?
- Quieter Procharger??
- Custom twin turbo system we're working on
- Turbo 6.0L 87 Buick GN
- Some truck build up pics
- F1 Prochargers...
- Will this TURBO work?
- Turbo help needed!!!
- Spot for Oil return into Oil pan
- Low Vacum?
- XFI Cam + Boost? Will it work?
- Eboost Vs Eboost2
- vortech v9 kit for sale
- What would be a good turbo for this?
- Turbo frame question
- specs on this car please
- 557" BBC w/ F3 Procharger
- APS C6 ZO6 twin intercooled twin turbo system - first pics
- Rear turbo oil return pump recomendations
- Mounting Oil pump for rear turbo need help?
- Reverse Split Cam for Turbo
- Input on a turbo build for 04 C5Z
- LT1 Supercharger Question
- opinions on a turbo/supercharger set up
- I am having Twin's
- Couple LT1 turbo questions
- Procharger Questions
- ProCharger C5 StageII Belt/Pulley matrix
- ball-bearing vs. non-ball bearing
- Valve springs for my mild cam turbo?
- Launching a turbo car
- warhawk vs. gm lsx block FI builds?
- Is a Turbo setup for me?
- FI Vette owners, How did you do your fuel system?
- planned mods for FI, help please!
- Is this too much boost?
- 5.3L Block (LS4?) bore to 5.7L for FI?
- Stock Top End + Turbo
- Spun Rod Bearing - Thinking Boost - Questions!
- stock bottom & FI? 500rwhp possible? pushrod install?
- 00' z28 A4 Boosted?
- anyone running the performance products intake, what do you think?
- Turbo high mileage?
- LS2 402 with ATI D1SC
- WOT woes
- i need help quick procharger p1sc 9#
- Twin Turbo!!
- Innovative boost controller
- polished pipe?
- Magnuson supercharger throwing the belt
- Twin Turbo 8 sec video
- What size piping for a rear mounted turbo
- True Street Turbo
- Twins Vs Single (wastegates)
- can you do this?
- How much $$$ do you have in your car..
- Turbo Guys
- Sponsors: Are you a Vortech Dealer?
- 3" to bigger piping hurt things?
- STS Problem Need Help ASAP
- Black TA & FMIC
- PTK/PTS owners with tubular K-members inside please
- VNT Turbo + Megasquirt
- Turbo guys: How do I solve exhaust leaks!?
- P1SC Vs D1SC
- Coating Turbine Housings..Worth it for drag race only?
- Turbo size for this setup
- Turbo Shootout
- Do you need a magnavolt for a Maggie?
- Turbo setup o2 before or after
- Wastegate vacuum placement. STS.
- 1st pass before the track got shutdown due to snow :(
- 4/7 swap?
- Turbo Motor For Lt1
- Valve event timing for L76 Turbocharged app
- exhaust side of turbo
- what do i do
- best multi-task gauge?
- 500 RWHP Help
- anyone tried these heads?
- Eboost2 hookup question
- NEW BEST!! pics and video*
- Victor Jr. is on along with the gemini twin plate
- O.F.I New website
- Ordered a S80 today !
- My 91mm Turbo Project So Far...
- turbo kits
- Need some help please look and advise fueling ?
- Boosted 6 speed 60ft's
- What can you do?
- Check out my new CB trim blower!
- G2-3 Cam + Turbo?
- Why no Rotrex's on F-bodys?
- STS pressure drop
- armagendon is coming.....
- F Body intercooled twin turbo system - preliminary pricing $5495 inc free delvery
- WTB PT-88 but where
- Wastegate Question
- Any LT1's running EPP's front mount?
- Bad Ass Turbo Car
- What fluid to use?
- Got new setup in and goin take a look leave some thoughts
- any one here not use there IAC motor?
- custom polished stainless intake piping...
- FI Valves....
- LT1 Impala Turbo Kits?
- Incon TT kit
- give me sound/videoclips of your turbocar...
- JGS Wastegate Selection
- Quick help on front bumper removal
- Using Volant CAI for vortech Sc?
- Supercharged Vette hits the roadcourse! (Video)
- Victor Jr vs. GMPP
- Anybody sell bracket for F1R?
- Cheapest TT Package Ever
- vic jr vs ls6 this sat, more testing to come soon
