View Full Version : Forced Induction
- intercooler position?
- Is a supercharger without headers worth it?
- Biggest turbo/turbos for C5
- Need the best FI cam I can get
- Check out this intercooler. Perfect size for Camaro grill opening
- Innovative Mounting
- tried the .96 housing on my car, some interesting results
- Has anyone ever used this turbo kit?
- sts wont boost
- Guess HP
- LS2 vs L92/LS3(07 Cady Escalade) GM longblock for my turbo project. Expert opinions?
- Where to put the turbo...any ideas?
- Got car back from LS1SpeedInc...
- Thoughts on this combo...
- ct26 turbos ??? anyone???
- Break in the new motor?
- 6.0l heads
- fastest stock bottom end turbo or supercharged cars?post your times!
- 98 block safe for boost
- Exhaust question for the FI guys
- NHRA Pro Mod rules regarding turbochargers
- PT88 Nossle kit, 408, more pics of the camaro
- Mandrel Bent Piping for FMIC...is it really that important???
- Mufflers
- Anyone thought to extrude hone a 6.0l manifold?
- Help with crank pining
- Magnacharged F-body track videos inside
- Anyone ever tried one of these for a cog setup?
- Winter Mods (cam, meth, heads) HELP NEEDED
- Turbo guys: Tell me about your timing and CR
- Lt1 Sts 383 preliminary dyno numbers
- 122 ci Magnacharger ???
- Headgaskets
- STS Turbo/Daily Driver/Low Boost, is it worth it?
- APS GTO Phase 2 twin turbo system - one time deal - $5695 delivered to your door
- Spark plug?
- P1SC build with stock exhaust
- 07 C6 with D1SC Video!
- Hardline vs braided stainless pros and cons
- oil drain question
- How much boost on forged 10:1 compression motor?
- How many 1000 hp dreamers have had over 500 rwhp?
- Too much compression?
- will a Procharger LT1 set up work on a LS1 car?
- another is this a good turbo cam thread?
- M6=more fun than auto?
- mixing turbo parts???
- Changing Main Serpentine Belt w/ Procharger Set up
- sts installation booklet
- Ring gapping questions
- twin turbo outboard boat engine
- twin turbos + nos pics.
- need timing help ASAP!!
- STS Owners - What did you do with your IAT Sensor
- What is the limit of boost 02 35th LS-1
- spark plugs and FI
- New Site
- turbo questions
- OFI single LT1 dyno numbers
- exhaust
- Looking For Inside Mounted Air To Water Intercooler Pics
- sts return oil pump
- STS Mufflers III!
- Downpipe. to step, or not to step
- Info or pics on Turbo Zone Kit.
- Best Procharger for Street Setup?
- My 402 D1 vs Stock bottom #s
- SuperCharged Ls1- Question
- will this cam work with a blower?
- PTK owners with the NEW alt arrangement
- Looking for that T unit for brake booster to hook up turbo stuff...
- D1 402 numbers
- Ideas for bumper cover support on 98+ TA?
- Procharged guys...
- So Masterpower sucks right? Now what? I need a turbo.
- Guys With 6.0 Iron Blocks Come In
- Leak Down Test?
- charger vs turbo?
- Buying a D-1 from EPP
- Oil drain setup.
- Has anyone put together a complete DIY turbo guide?
- Exhaust temps STS
- Back pressure... help an ignorant fool here please.
- 2006 C6 Z06 Twin Turbo with Pictures and Dyno Graphs
- 88 single on 346, spooling questions
- some loose ends for my Hiflo install, need help
- Took a Sunday Cruise in my 8 sec IRS C5 Corvette Street Car [VIDEO]
- few pics of my system
- Top ring to use for forced induction?
- Twin Turbo Dyno Video
- leaky exhaust for sts
- Eboost2
- Need help with this SDCE pulley.
- TT Viper 7.98@183
- New valve springs with Turbo Setup?
- oil drain and feed fittings
- Got a TSB today (STS owners read)
- what size housings for a tt 427?
- 2 ques. on turbo
- how are you routing all your wires for gauges
- TTI car in classifieds
- for turbo apps why carb style intakes
- d1sc prochargers
- you guys that are looking for hoses and NPT fittings
- meth
- Turbo knowledge
- 6.0 Heads+LS6 cam+STS
- Look, its an entire Sound Performance turbo kit! A.K.A Hi-flo kit
- Heads Lifting....
- Gains from stroking with a turbo car
- low/high boost fuel cell idea...
- Will EBoost2 retain settings if battery is disconnected?
- Truck manifold pipe gaskets? Where to get them?
- turbo or supercharger???????????
- Turbo Help
- Procharger A4 guys, what stall?
- Why isnt this room on fire with lsx block talk
- self contained supercharger
- external oil filter
- magnacharger owners come on in
- what cam should i use with my turbo set up?
- Procharger kit for ls1 fbody with ls2 engine?
- Vortech YSi versus Paxton Novi versus ATI D1SC or F1R
- Plenty of Room for my Turbo now!!
- Anyone have any extra WG springs lying around for Tial 38mm?
- Single Turbo on stock LS-1. NEED HELP!!!!!
- STS gurus inside please
- Cooling a FI F-Body
- Any one know about this SC???
- Will this turbo work?
- Muah Hahahahah...!
- dart pro 1 turbo set up
- Boosting a LS1 RX7- Have some ??
- Oh Boy! QTP for us Turbo Fbodies...
- T76GTS or TC76
- Intercooler quality and prices
- this look interesting
- STS Turbo question
- Price of Turbo install???
- Powerdyne
- Cheap Truck turbo setup
- Thinking of getting a TT kit for the C6....
- Single turbo piping size to turbo?
- Fmic
- Good pic of truck manifold setup with K-member notched?
- Who runs a big cam with their FI?
- Can't Decide......
- What REAL gain w/ported TB and ditching the [screened] MAF?
- Anybody put a Rotrex in an F body yet?
- LS6 Intake
- need ur help everyone with turbo manifolds
- Cam Selection???
- What best compliments my vortech??
- cam specs for a 403LS2 w/ s80...
- New 1/8 mile best, last time out for the year (really this time lol)
- Best CR on a FI engine
- Max Boost to Max MAF or PCM
- Post pics of your turbo setup.
- Boosted Stock Bottom End guys IN HERE!
- Info about the Rotrex Supercharger (W2W on NMRA TV) Video Link
- STS twin turbo or Procharger D1SC
- Any sponsors sell individual ARP head studs?
- 10.206 @133 stock bottom end rear mount
- 408 Tt
- Can someone give me a measurement?
- What turbo would you recommend for a 364?
- Sanity check my PCV and vacuum lines.
- Help adjusting incon wastegates!!!!!!!
- new roots type supercharger smog legal?
- The Kenne Bell 2.8 is in and running!
- Show me your engine bay
- Dropping Oil Pressure under Boost
- LS1 with LS6, heads,cam,intake, and 8-12Lbs blower am i safe
- Finally Ordered my New Turbo (pics)
- LS1 02' Camaro SS STS only <4k?!?!
- Which Turbo Cam and Why?
- Ok, So im starting my Custom turbo kit.
- Kenne Bell, any reports of it causing false knock retard?
- Need an oil tank to be bought or fabricated
- Upgrade Valvetrain or not
- Stock crank or Forged crank???
- gt3076s TURBO kit on ebay
- What can my 370 hold?
- LS1 RX7 Looking to run about 6Psi? Turbo or Charger?
- Help. Low numbers, Newb Turbo questions?
- PSI ona stock motor
- which of the Two will hold heat better?
- I'm looking to trade my 60# inj for some 42# inj.
- where to cut for large frame turbo?
- choosing a wastegate...
- 370 turbo cam?
- Just bought a D-1 Kit. Now I need some info on cam and such
- cheap turbo to support 650rwhp?
- STS Cats!
- quetions on used s-trim
- whats your guys vacuum at idle?
- S/C or turbo for stroker LSx
- Kicking it old school
- forced induction on a third gen
- Any TURBO ZONE results out there??
- A2W Intercooler In A Daily Driver?
- can I make 700hp on a forged 346 and a d1sc with twin 4.5 intercoolers
- Has anyone ever considered using Shorty 5.0 mustang headers turned around?
- who makes the fastest spooling turbos?
- CR with BOOST!!!!
- Anyone have video of their car spooling?
- Wideband gurus: will LM-1 setup do this?
- M6 shifting and supercharger
- STS Guru's
- Anybody seen a C5 Kenne Bell at the track???
- how to read a compressor map for tt application?
- Video of my TT LS1 Volvo Wagon!!!
- Kenne bell few questions
- Procharger Q's
- Forged Street... CHime IN
- Procharger D-1SC is here!
- Any single turbo kits that keep a/c (front mount)
- bought a 76gts, but what about a pt88?
- internal waste gates and boost controllers?
- More effecient - 1 FMIC or 2 A2W Coolers
- Bunch of Supercharger Pulley Questions
- Its Gt80 X-trim?
- where/how/what do you guys buy for your Meth?
- Rear mounted PT88, more info
- TRT Stage 3 kit or Procharger D-1SC "tuner kit"?
- Ported fast more prone to cracking under boost?
- TwinTurbo..........................C6 Corvette
- 346 turbos garrett ???
- Alternatives to a FMIC?
- Magnuson F-body - new dyno results
- Twin Turbo System available.
- Need Turbo Help
- what would you do
- (In-Car ) VIDEO C5 VETTE SINGLE TURBO
- HP estimate please!!
- LT1 Turbo Build PT.2 S400 Turbo 396ci's....
- Thinking of FI my stroker.
- What do yall think about this Blower setup
- help GMPP intake
- 2-Step Rev Limiter
- Fluiddampr and Procharger pulley???
- Vortech on a LT1 car
- going to wrap my exhaust for my sts - best bang for the buck?
- pulls hard.. then ~4200 rpm - POP!
- 11psi tahoe
- Does your car have really bad fumes in your COCKPIT?
- oil feed and return
- thunder blower cam any good?
- Cracked block and broken piston..
- Where and what kind of turbo for rear mount?
