View Full Version : Forced Induction
  1. To blow or not to blow, that is the question....
  2. Chris@Diamond is now Chris@AP-Engineering
  3. How much HP will 60-1 hifi support?
  4. Harlan, Pro M 90 MM MAF?
  5. John Ryan - Please check your pm's
  6. PSJ I'm coming for you (on they dyno that is)
  7. PCV to Checkvalve
  8. Thank you Vortech!!!!!!!!!!!!
  9. Help with new fuel system.
  10. Survey says (dyno session #4)... 719.5rwhp!!!!!!
  11. High compression and boost
  12. Max Gasket Thickness for "O" Ringed Heads??
  13. Pre-Blower #'s
  14. 90mm LSX+Supercharger
  15. MIGHTYMOUSE 2004 Preview vid!
  16. Turbo 400 users - Inside Please!
  17. Low compression cam ?
  18. Blowby Fix?
  19. whats the max hp for 50# injectors????
  20. Tell me how much power I can make out of this.
  21. I Need HELP
  22. Survey says... 705rwhp!!!!!!!!!!!!!!!!!!!!!!!!!
  23. Venting ATI
  24. What do you guys think about my new project?
  25. Oil Question?
  26. F1R install
  27. ATI Surge Valve Question
  28. 224/224 581 on 112 LSA with 1.8:1 rockers with FI
  29. blow off valve question
  30. rob raymer
  31. Ported Heads with FI?
  32. Intercooler cores cheap
  33. Looking for actuators (sp?) for incon kit
  34. More info on the Vortech V9 that I can't get to work right
  35. Speed Inc and Pro Stock John, Im comin for you!!!
  36. Are there any quiet FI systems out there
  37. Volumetric Efficiency (VE), How do we calculate it???
  38. D1SC Cam?
  39. What exhaust are you running with your Turbo
  40. F/S ACCEL 48lb Injectors
  41. Got a quick question....
  42. Modified G-trim progress->
  43. Who here has the SMC Water/Alky Kit?
  44. Head gaskets for boost and 4.030 bore?
  45. Race gas question
  46. Heads
  47. Superchargers for sale?
  48. Identify these wastegates....
  49. Anyone been lifting heads?
  50. questions to ask when shopping for an intercooler???
  51. FI people please help me
  52. saying thanks
  53. dynoed tonight
  54. Help with T-76 specs
  55. Evaluate the MTI Stealth cams on their suitability for a TT car:
  56. blower bracket bolts
  57. 800 FlyWHP
  58. 1200 RWHP boosted LS6 motor...............
  59. Modifying a Turbo Tech kit?
  60. Please comment on some details of my Twin turbo LS-1.
  61. Question for Racetronix
  62. Good supercharger for a good price
  63. D1SC vs F1
  64. Where to start?
  65. DP + Boost ???
  66. paging harlan
  67. RICE ETR - Inside
  68. Mass Air location on Turbo setup
  69. lq9 / lq4 ?
  70. Nitrous/Intercooler?
  71. Paging Twntrboce
  72. Locked vs unlocked dyno numbers for turbo and sc cars?
  73. Boost with higher compression
  74. PT88 is here!!!!!!!!!
  75. limits on boost with ls1 edit
  76. COG pulleys have been ordered!
  77. Highest RWHP w/Stock Engine and Boost?
  78. What Mass air meter on turbo car?
  79. real world gains with alkey injection??
  80. Large Diesel turbo on 5.3?
  81. Installing tighter converter, then redynoing
  82. Boosed cars, stock internals?
  83. what problems might a too small of waste gate cause?
  84. Egr
  85. Want suggestions for a Vortech blown 382 stroker...
  86. LS1 Edit?
  87. 2 Intercooler Questions
  88. Ported Magnacharger?
  89. D1SC Is On The Way
  90. Bought my dream tow vehicle
  91. need wastegate info for big turbo setup
  92. Paging TrboBuick6 from A P E!!
  93. Please assist me pick cam...(Guys from the "Turbocharger Cam Specs..." thread)
  94. Frcefed98, any cog updates......?
  95. turbo ls1 edit files
  96. xb-1a up and running
  97. Oil cooler location?
  98. Maintenance and Longevity of QMP, or similar Turboed Car..
  99. 12psi on a stock block?
  100. Hows a supercharged LS1 feel?
  101. its alive
  102. 760rwhp 777rwtq
  103. Thicker Head Gaskets with Hi Boost applications
  104. Possilbe 15,000 LS1 Race May 2004
  105. high boost - custom cogs or 12 rib setup
  106. intercooler question
  107. Venting the bypass??
  108. qmp gurus plase help
  109. HKS SSQV Blow off valve F/S
  110. FI Worth It??
  111. anyone wanna drive to oklahoma and fix my piece of crap? :)
  112. qmp turbo kit update
  113. 631rwhp/700rwtq QMP Project Formula
  114. MMS 6 rib Crank Pulley For Sale
  115. Back pressure stops 1.000 hp
  116. 2004 and 2003 Forced Induction Lists
  117. Simple: ATI or Vortech
  118. Petition Thread : Magnachager for the F-Body
  119. Getting ready to start project 9 sec TT
  120. rob raymer
  121. Any News on the STS turbo kit?
  122. anyone with qmp turbo experiance
  123. Paging Rob Raymer ... Intercooler Question
  124. FI Guys: When does your track re-open for 2004?
  125. TWS slides into Home with 11.71 @ 121 MPH!
  126. TB location
  127. Single turbo on passanger side
  128. Turbo Cams
  129. someone please help(att. rob raymer)
  130. What are your goals for the new year?
  131. Turbo manifold design.
  132. Supercharger suggestions: '00 SS
  133. bov and wastegate.help
  134. Will A Magna Charger Fit A 2000 Ta Ls1
  135. I have nitrous motor 11.1:1 CR can I drop near 8.5:1 just pistons?
  136. convertor ?s on turbo setup
  137. Holiday Supercharger Sale ending soon!
  138. Turbo Questions abound...(Lots and long)
  139. Supercharger for 385
  140. best K member for incon or incon style turbo setup.
  141. Procharger wont trade up!!!
  142. I need a little help.....
  143. YS Trim Update 12/29/03
  144. Can I magna-charge my 8.1 liter truck?
  145. Congrats to Noyzee his article in GMHTP finally came out
  146. What cam are you guys running and what HP/TQ and ET's are you getting?
  147. T400 peepz what converter are you running?
  148. Oooohhhh Boyy!!!!!!
  149. P1sc-D1sc swap ???
  150. Would a LSX 90mm help in a turbo application?
  151. Any performance shops in Orlando?
  152. Start with LS1 or LS6 engine if blower planned ?
  153. Blew Something.
  154. Selling my Stuff
  155. Lingenfelter Burial Monday - Many will miss him
  156. need shortblock advice
  157. ati inlet hat, what diameter is it?
  158. Twin Screw already out for the GTO???
  159. Formula for calculating impeller speed?
  160. Wastegate location?
  161. Turbolocity Twin Kit for LS1?
  162. FI vs NA power - Decision has to be made - Help
  163. Vortech w/aftercooler any good?
  164. Reichard Racing 8-rib setup?
  165. What Sponsor for Custom Cams?
  166. pics of powerdyne bracket?
  167. Anyone Know If A Rksport Lt1 Supercharger Setup Will Fit A 2000 Ls1
  168. everyone please read!!!
  169. Pic's of Harlan's old motor?
  170. Turbocharger cam specs....
  171. D1 - Keying Crank?
  172. Does Kenne Bell make a Vette LS1 blower?
  173. Procharger + cam guys
  174. 304stainless vs 316? for headers
  175. Best way to lower compression on motor
  176. Pics of the 91.5mm setup
  177. P1 vs D1 Why do most think they need a D1 when most will never max out the P1?
  178. Interesting backpressure #'s
  179. TurboSmart Boost Controllers Now In Stock
  180. QMP Single Turbo kit for sale!
  181. Im In!!!yha Hooooo
  182. TTi driving impressions
  183. The setup....
  184. need help with vortech problem..
  185. xb1a almost done
  186. Incon TT for sale
  187. How much boost can the ls1 computer handle?
  188. Vortech G-trim compressor map inside
  189. Rob, do you have the Dyno Graphs for the C5 TT kit?
  190. Half-Assed Racing Custom ATI Install Progress...
  191. Paging nbm00WS6
  192. Cartek Blower Motor and F1 procharger set up FOR SALE!!!!!
  193. High coolant temp after ATI blower
  194. Fuel question on 383 blower car
  195. paging rob raymer important
  196. FS: MMS crank pulley
  197. What gap and plugs to run under boost?
  198. Is this possible?
  199. Anyone know turbo cam designer
  200. MMS 427 is FINALLY Running!
  201. What size pulley to get 7 psi?
  202. oooppppppppsssssssss
  203. how much would it cost???
  204. High Boost....getting Backfire at top of RPM
  205. Turbine trim ?
  206. Smoke coming out of breathers?
  207. emissions in your state?
  208. What size wastegate do I need?
  209. ATI Cog set up is here!
  210. Max Intercooler CFM
  211. Psj?
  212. How often to change NGK TR6 Plugs?
  213. how cold of plugs for 10-15psi?
  214. What are you doing about crank case ventalation
  215. Latest electric supercharger attempt(NOT LS1)...
  216. building a turbo header
  217. ATI now with tuning>>?
  218. f-n-g to this forum also oil pump ?
  219. new Waldon fuel pump for sale
  220. Paging "Chicken" Raymer!
  221. Moving HP & TQ curves in Turbo applications
  222. f 1 or d1sc?
  223. The cost of boost for the LS1.
  224. ati blower pulley install question
  225. Getting 550rwhp To the Ground on Street(Turbo)
  226. 3.5" down pipe?
  227. F-Body/ Magnuson supercharger thoughts
  228. Complete kits from ATI with programming available!
  229. lb/min vs cfm before and after turbo
  230. MTI Stealth Cams and Supercharging
  231. Water/Alky???????
  232. Fuel System for D1
  233. Looking for Alternate location for Boost Gage???
  234. paging rob raymer
  235. QMP Project Car Updates: C5 TT, Turbo Formula, and '81 Trans Am TT
  236. 700 rwhp plus w/ this set up? can it be done?
  237. Water/alky injection and freezing?
  238. STS does a turbo for the new GTO! (pic)
  239. WTB ATI Inlet Hat
  240. Procharger on stock motor what boost??
  241. Cog Updates????!?!?!?!?
  242. maf question
  243. Paging harlan...
  244. Optimal A/F Ratio 11.5, 12.1, 12.5 ??
  245. Help me out!
  246. boost controler?
  247. Any input on how these turbos will perform?
  248. MMS crank pulley and 3.7" SC pulley for P-1SC
  249. Powerdyne people in here (old and new)
  250. Which Head Unit for 700+rwhp?
