View Full Version : Forced Induction
- V band inlet exhaust housings???
- Does this sound right?
- Procharger guy's inside
- Questions for the turbo dudes!
- ic mounting location?
- LT1 Procharger on a LS1
- Tracking down exhaust leaks
- Power gain going from 93 to 100 octane
- i need help with this setup? (wastegate)
- i need a bov!
- line connected to passenger side of TB...?
- How restrictive is it to run stock manifolds?
- strength...
- How loud are open downpipes
- Looking for advice on Stall...
- can anyone explain these Z06 dyno numbers....
- What causes some turbos to be loud and others to be quiet?
- Boost.
- LT1 2nd Gen RX7 Looking For Boost :)!
- faster @ 1/2 to 3/4 throttle than @ full need help
- Cometic .120's
- best palce to buy fi forged shortblock
- T76 front mount
- Supplies?
- Compund og BI Turbocharging
- 1/2 inch head studs fo boost 900+
- ATI SC users with Larger Filter setups in here
- Looking for the magic 500RWHP w/Vortech.
- How to:
- Need some fans.... Twin Pushers, questions!
- Trt Fmic
- Difference in units
- Anyone running a KB twin screw on a LS1? (Vette guys I guess)
- Belt Slippage?
- When it comes to a front mount turbo, what is the best way to go with headers?
- poll on stock ls1, sc or sts setup
- 8:1 or 9:1 comp
- How loud can P1SC be????
- gonna get BLOWN
- twin gt28rs...what do you think?
- Qyestions about methanol injection(boost cooler)
- crank
- quick pcv question
- Turbo Blazer Pics And Vid :d
- Ran the TT Chevelle on Tuesday.
- magnacharger
- New 1/8 mile best Friday night
- OFI Single f-body kit with a 80mm T6
- Anyone own GMR twin kit
- PCV/crankcase Evac with Drawings, need Help
- Getting ATI crank pulley off balancer?
- Streetable long term turbo setup?
- Forged LS2 Bottom/L92 Top w/ D1sc?
- worth it to reduce exhaust to 2.5"?
- New Dyno Numbers!
- So I am installing my PTK
- Help me with what Im not getting?
- Formula? Boost vs HP gain??
- Critique my FI rotating assembly
- Could the AC be used to cool the water in a air/water IC?
- not sure what this sts part is???
- Rear mount turbo goes 10's :)
- Zombie ss finally went 10's...
- Does anyone make a crossover for truck manifolds?
- well, im getting blown!
- ATI shroud/Spal 9" 30100452
- Lowest psi springs for Racegates? Anyone have any laying around??
- Finally!!!!! in the 10's!!!!!
- Turbo Car Restrictive Exhaust
- t74 build ???
- How finicky are wastegates?
- Hp ?
- Define "useable boost"
- need to buy Pulley and Belt, need info
- Need help - Boost or H/C paclage
- Where's Parish?
- what crank pulley are you FI guys using??
- Pics/Built Specs Of LT1s Stroker with Superchargers
- Hmm...Help me decide...Blown/Turbo guys..Come on in!!
- prelim dyno numbers for twins
- Well I decided to just sell the turbo kit for now
- Fi ?
- can i put my oil return bung here
- What belt do I need????
- limit of twin ati intercoolers
- ATI procharger with dual intercoolers...
- Turbo timing...
- OFI GTO times and more pics
- lowering compression for a turbo
- Procharger intercooler questions
- Where can I get this spark plug?
- How safe? and how?
- pics of your rearmount turbo
- Need to replace ATI Procharger Anti-surge (bypass valve) what to get???
- Darton strokers and boost??
- Black Smoke issues
- Where to buy truck manifold flanges?
- polished intake elbow, pic
- Better to part out or sell as complete turnkey?
- Wastegate: Dump to atmosphere or back to exhaust?
- Harlan Two step??
- Those interested in Magnuson kits for F-body, step inside
- Plug suggestion for big BOOST
- SLP 402 with ATI ProCharger D-1SC at 16 psi of boost = 757 rwhp on Mustang Dyno!
- transam FI custom bumper
- Too leave the dynatechs on or not
- whats the best intercooler?
- Meth Kit Or Intercooler
- wrap this up fooooo!!! question
- I got a Tial 50mm BOV and a Rattle snake
- T-Bolt clamps... CHEAPEST price anywhere
- Which low CR heads?
- Anyone seen this video of MIke's Turbo CE
- Stock..Sts...yes??
- What's an acceptable amount of shaft endplay?
- Compression for Turbo Setup???
- quick ?
- FMIC finally on, thanks TRT Billy.
- D1sc?
- LS2 stock boost
- whos car is this?
- Should I or Shouldn't I??
- What do you guys think?
- I Love Boost :d!!!@!@%@#$%
- Vortech S-trim
- Oil restrictor size
- Powder Coating IC's? How much?
- New best
- Questions about the P-1SC system
- What would you rather have?
- Turbo 6m cars
- Need to find a 3.5" to 3" 90 degree elbow ASAP
- intake runner length affecting fuel distribution?
- New Bests
- Videos - my turbo trans am
- Has anyone ever had any issues with their alternators while under boost?
- Will it fit?
- 02 ls1 procharger part#
- LT1 procharged question
- New numbers with the Meth!
- Wrapping hot parts
- spider intake
- Look At What Im Wanna Do To The K Member
- FM Turbo Location high or low pics inside
- Wot Afr ?
- Hp/Cid ect..
- daily driver reliability
- Exhaust Restriction
- Switching from 3.73s to 3.42s worth it to load the turbo?
- Maf before or after turbo????
- Starting FI from Scratch
- Am I doing this right?
- vortech guys , need help
- General FI question
- New Best ET 8.66@140 mph!!
- Has anyone kaboom'd driveline on the dyno?
- T60, T67, or T76 on Daily Driver ??
- What Wideband do you use?
- To AC or Not to AC
- Anybody running a roots style on their LS1?
- Limits of stock ls1 intake on FI setup
- 38mm wastegate?
- STS Droptop with SFC Pics 56k warning
- WooHoo! New best Time tonight...
- cheater cam from TR
- I need your help about LS engines.
- T76 to T88 spool difference with an auto?
- Which heads, any gains ???
- procharger help
- Wooo woooo - is that an IC in his trunk ???
- IC Pic's?
- Twin Turbo guys fuse box relocate
- stroked turbo setup, why 6.0L block?
- New Turbo Project
- Single Turbo Project!
- Its has begun!!!! T76 build PICS!!!!
- sts w/ subframe connectors
- Opinions needed. Which combo?
- 2.73s for an M6/ boosted 383?
- STS question again
- Simple boosting question
- i just found out what meth really is!
- Torque?
- H2o2 / ASC Methanol / Nitromethane blend - for water/alcohol injection systems
- Digital gauges for A-Piller What brand is the BEST?
- STS CC Pics
- Question with FI tune
- meth users, what size injectors are you using??
- Calling all 383 LT1 vortech supercharger guys!
- Bigger Airl filter????
- STS questions
- AZPS New part for F/I applications
- boost valvesprings....
- hey guys
- [Speed Inc] Streetable 'Race' Twin Turbo System
- Alt relo bracket and aftermarket fuel rails?
- Vortech MD Results 589 RWHP 486 RWTQ!
- Setup Help...
- Meth users: Where did you mount the tank and pump?
- MIGHTYMOUSE 'help' FUND HERE:
- Head gaskets good or bad? (pics inside)
- larger filter for turbo setup!?!
- LS6 cam good for turbo setup on a LS1
- How to break in FI Stroker
- Ohio forced induction inc single turbo numbers GTO/f-body
- turbonetics BOV
- t60 or t67?
- How loud is the blower whine on a P1SC?
- Argggh, my car is eating belts
- how much boost
- Wormy and Roofer Dave in GMHTP
- Will this cam play nice with a Procharger?
- Forced Induction and Electric Water Pump
- Stall
- What size is your front mount Intercooler?
- Larger Air Filter for procharger setup
- C5 or Firebird
- I think I just found a way to get a free 50 rwhp!!!
- What is the happy medium between timing and boost?
- Final round of mods, I think thats about it lol
- What makes engine oil "turbo approved"
- What kind of turbo?
- Carburetor + blower on LS1?
- Video from Weekend of September 16th
- Where to buy SS header flanges?
- Anyone running a G5X3 112 LSA with boost? OPINIONS WANTED.
- Magnuson MP122H install
- Best prep for an LSX boost motor...
- Well She's Finally Back Together
- Turbo setup
- Turbo Timer Install help..
- how long will this last????
- Finally! >650 rwhp with TTi Street Kit!
- superchargers pro&cons
- How to bring your IAT's down, pics inside
- Magnacharger
- ARP rod bolts allow more boost???
- is anyone runninga a blowthrew carb turbo set up
- Track vid
- My projected setup for next year...what would it be good for?
- turbo
- Pulley change questions
- 408's With PT88 Come In
- 6.0 LQ9 Heads on 347 F1A setup?
- PCV suggestions w/pics
- Dyno Battle Results
- LS6 valley cover on LS1... PCV question
- Can someone explain this to me
- 20 cases of ProCharger oil in stock at Exotic Performance Plus!
- sts + lowered = good/bad idea??
