View Full Version : Forced Induction
- turbo tuning opinions
- Spool time
- AN size drain line with scavange pump
- Worth It or Wait???
- what converter
- look at this cam.....give input
- What do you think about this LT1 turbo cam.
- How to remove EVAP system - does it hurt anything?
- Safe boost??
- Will a small cam increase your IAT on a turbo setup?
- AllPro FI head guys... what plugs are you running?
- Truck manifold peepz q's within...
- PCV Z06 Catch Vent $10!
- how much of a restriction would a 90* angle coming of the turbo be?!?
- Well I think it popped. You tell me....
- new t-70 but no v-band
- ~Custom Turbo Kit~
- Guys, I need some input
- sts dyno graph?
- TurboLS1SS, I'm almost ready for ya...
- Opinions???
- How much power can you be robbing by running dirty air filters?
- What does a dying turbo sound like?
- what pistons is everyone using
- What compression for sts
- what intercooler is everyone using
- Gathering correct parts for my build... few questions
- guys check out this cam
- new to the s/c world and need help
- The Real Price of Forced Induction
- ~Help me build something FAST~
- Cant stop the smoking
- Having great results with Procharger on C6 Corvettes
- Procharger question
- My two best friends.....
- Twin gt40's or single GT55 (91mm)
- Need help with O2 sensors
- The "Some Hi-Flo shiznit came in today" POST IS NOW A STICKY
- Pics of Camaro front end w/ FMIC
- Can you guys post some pics of your fmic/airdam setups please?
- Mustang S.c.
- HELP NEEDED!!!! Oil remote pump
- Can a/c condensor be used as cooler for A2W setup?
- What would make more power and throttle response?
- ls1 missing at high rpms help?
- silicone elbow blew with only 10lb.
- sts rear mount #'s on a stock car
- Source for Garrett parts
- Turbo question (please dont laugh)
- Procharger Bracket flex
- Header recommendation
- Made a new inlet hat for my Procharger (Warning!! alot of pics)
- Dream car with a nightmare!
- What does a turbo rebuild cost?
- Porting the throttle body.
- New Filter?
- Questions about turbos
- Vortech users come in
- is there a way ti keep the AC
- Looking for an Incon turbo or compressor housing.
- Power differences between truck manifolds and headers
- Duke goes 7.51 @ 186MPH!
- wire diogram for sts setup
- What kind of difference in 1/4 mile times do you see from summer to cooler weather?
- STS Z06 PCV Vent!
- Vic Jr. Intake = hp??
- oil catch can questions
- Paxton for an LT1 ????
- Are there still any issues with the Procharger SC units?
- getting there w GT47-88, #'s inside...
- Ohio Forced Inductions Inc. F-body hot parts pics
- what r the day 2 day problems running FI
- What does this mean?
- What exhaust housing choices do I have with this turbo?
- Where to find this turbo?
- garrett or turbonetics???
- Supercharger or Turbo
- Need A TURBO or S/C ????
- Lt1 CAmaro front mount
- TTi log and spark plug wire clearance?
- Any tricks to drop the pan?
- 1000rwhp single turbo formula 'street car'
- 90° Intake Rubber Elbow
- New to FI-need help
- mondo blow off question
- Anyone using the Griffin radiator with the ATI shroud and A/C?
- V1 S-trim dual meth nozzle track results
- Any problems with a MBC?
- Optimum turbo for a 6 speed LT1 355(with 10's in mind)
- my question ???????
- Well... 9.90 @ 139 and still problems... help!
- Optimum Turbo Street 6 speed Setup?
- how do you run oil lines?
- Talk about a long day at the track..
- What do you guys think of my new shortblock?
- How to launch with an STS.
- sts turbo
- Noob question about STS
- My PCV Setup PT II
- Low CR 402 n/a numbers...
- OK to use port on intake manifold for boost/vac reference
- are mahle pistons and rods good for 700 rwhp?
- Need some advice from Vets!
- where to muffle an STS
- can i put a performance muffler on a stock cat back?
- new intercooler pics
- STS problem
- getting closer !!
- ? about cutting bumper for FMIC, TA
- what happend to my proturbo post?
- build help
- Boosted LQ4
- 6L Block Iron/Aluminum
- Dumbest question, or Hardest??
- Help with my setup
- Is Magna Charger worth it??
- Universal Intercooler Piping
- whos got a turbo lt1
- Is there a better fan to use on my ATI kit than what they gave me?
- PP Stage 2 or Stage 3 heads for Turbo app?
- Instructions on godzilla BOV
- 383 stroker,D1SC,14 psi!!!!
- power steering delete
- sts turbo oil problem, please help
- Added another fan, still running hot, now what?
- TT LSX 59 Impala nearly complete...finally
- what BOV is this
- Futral F9
- Will race fuel help me on a street tune.
- Aftercooled Vortech LS1. You like it? #'s?
- Turbos on the way!!!
- Ported throttle body, does it help much?
- Some STS Help
- which would be easier...
- LS7 SS build up with a Procharger
- Looking for General Remote Turbo information
- Turbo Dimensions
- Should I buy QTP long tube headers if i get a turbo system?
- Whats a good exhaust A/R....
- f1 help
- Tuner for LT1(stock PCM)??-t-76 10psi pump/14psi race
- t4 inlet and exhaust gaskets
- T76gts cold side inlet flange question!!!
- Where Could I Get Some Check Valves?
- Odd question about STS
- What about this
- T-3 or T-4
- what paint for FMIC and IC piping?
- mass air question?
- another short update
- AFR 205 or Ported 6.0
- New track videos from Chitown RSD
- Track Pictures by 1320Video.com of My SS
- New TT Z project.. not what you might be thinking..should be FUN!
- Pics of your turbo support.
- can you guys take a stock c6 z06
- Supercharger for LS4 5.3 v8?
- Eaton M112 Supercharger
- 98 ls1 edit files for supercharger?? needed
- Just bought my Vortech Supercharger kit
- Anyone run twin turbo?
- Vortech T-trim head unit???
- ground clearance with sts
- How hard would it be to make a homemade sts style turbo kit?
- intake manifold question
- head flow velocity
- turbo size ?
- anyone running 10 pounds with a T76gts on stock bottom end??
- what is keeping a Fbody from mounting a procharger to the heads?
- Sts Turbo
- pics of install roots blowers
- Has Anyone Lost His Engine to 8 PSI?
- Compression on built block for a D1sc?
- What is my rwhp?
- Could I be losing boost somewhere?
- 304 SS VS Aluminized SS for INtercooler tubing
- question on what exhaust to run.
- Making my own crossover - questions on WG and flex section
- 1000-1200 hp air-air
- First time to the track!
- So I was looking into getting a turbo.....
- First track runs with DIY turbo
- F1 Procharger for a 346 F-body?
- Wastegate size. Stock o2 location...
- New Track Times for my Twin 67's; 9.16 at 146.197
- Custom Rear Mounted Turbo Hits The Track
- 6.0 manifolds wanted! NO SMOG FITTINGS
- Victor Junior fitment issues ?
- should i still get a converter?
- Stock Ls1 And P1-sc Procharger
- 90mm Trottle Body And Elbow
- pcv idea
- FS:25.2 camaro roller
- Twin Turbonetics 60-1 HiFi, on center exhaust housing .96
- magna 122
- Who has the best price on wiseco pistons?
- Procharger people: Do you ever...
- Going +1 on STS
- Fun at the track. Now I need some help.
- T60 freshen up costs
- So who has actully done a 3bar tune?
- 370 c.i Iron block with vortech ????
- I am ordering a KB supercharger kit for a 03 z06/What else might I need?
- Differances between Methonal and Denatured Alcohol
- Anyone have pics of their 98+ TA with front mount?
- Most rwhp on a D1 on pump gas?
- Cam selection
- Alittle Issue after the dyNo today...need HELP asap!!!!
- The lil ole LT1 Dyno #'s
- update on my crank reference problem
- FMU should raise fuel pressure correct?
- Compression ratio???
- what do you think about these numbers...
- People who have FMIC IN!!
- First steps towards BOOSTED
- corvette boosted tune and 3 bar map sensor ???
- tuning..........turbos
- List of truck manifold part numbers?
- I did my homework and want your opinion
- shop forgot bov on sts turbon help
- Looking for a 3.5 x 3.5 elbow. 90
- 2004 C5 346 ci with D-1SC at 14 psi - 700+ rwhp on our Mustang Chassis Dyno
- two stage fuel systems
- need help
- Turbo oiling idea
- I like 'em THICK!!!!!!
- Sts Owners Help
- Best twin/single set up?
- WTF??? Need crossover help
- how much boost?
- ls1 1000 hp
- cam?
- Thats it, I am worried.....
- Boost my car?
- So what is "the" solution to the ATI overheating issue?
- Bill/Hiflo tracking #
- what catch can do you have???
- Why is the ATI fan shroud like this?
- Innovative turbos
- GT47-88 Build pictures (1998 Formula) ---->
- another 1000rwhp tt burnout
- North vs. South Shootout
- What is the preferred brand of piston
- T76 rear mount track results from tonight
- Flex pipe??11?!?!??/?11??
- turbo
- 1000 hp burnout!
- What are the best heads to use with a kenne bell on a 346?
- 6.0 manifold question, flanges?
- What do you think
