PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 [180] 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228
  1. heads 4 FI
  2. sts kit (rust on the turbo)
  3. Good idea or bad, coating turbo from sts
  4. Anyone having trouble with their methanol pumps?
  5. Oil feed line restrictor
  6. how long should a open dp be?
  7. Please give me your opinion on this turbo...
  8. 9 second and faster turbo a3/a3 cars...
  9. soon to be FI LS1 owner
  10. Custom truck manifold hot parts for sale
  11. Looking for an oiling system for a custom rear mount set up, please help!!
  12. Would I see more rwhp - Gear change
  13. need help with 2 bar hardware
  14. Who has the advantage?
  15. What head gasket to go with for HIGH boost???
  16. Help me pick a mild blower cam
  17. Different Air Filter Set-Up for Vortech?
  18. Superchargers
  19. what comes with procharger kit
  20. homemade turbo system
  21. Lets say I wanted to push 12+ psi on my P-1....
  22. Just bought STS
  23. How to deal with oil coming out of driverside breather filter
  24. Piston compression height
  25. Part # For Procharger K&N Filter...
  26. guaging interest ATI P1sc stage 2 kit *NEW*
  27. LT1 Turbo Question
  28. merry christmas
  29. Pulleys for F1R
  30. How many guys running 396-398 CID?
  31. I Got Turbos For Christmas!!!!
  32. Max boost on a stock 5.3...
  33. 98 firebird v6 supercharger
  34. SLP flow pac (help a new member out)
  35. CAS bin file
  36. whats the max hp on a build but not exotic motor combo
  37. Compression height
  38. Heat shields
  39. STS issue! Please help!
  40. Higher ratio rockers w/ FI setup?
  41. Hot cam with turbocharger??
  42. What heads and cam on a Z06 with a blower
  43. Poweryne belt slipping, HELP!!
  44. Collector test fit pics
  45. First runs on the 408 /T88 combo
  46. Blower?
  47. What Blow off Valve is everyone using
  48. KAOS' Custom truck manifold turbo setup, pic inside
  49. Corvette vs. Truck manifolds...
  50. Big problems with Pro charger setup!
  51. ls6 pcv conver. and AMW can????????
  52. To all you motor heads!
  53. mechanical or electrical boost guage
  54. (STS Kit) Best Blow off valve for LS1
  55. Custom intercooler
  56. Headers
  57. Collectors are finished
  58. Rear Gearing for a turbo app.
  59. opinion on ls1 powerdyne 6psi system??
  60. Final pics
  61. POLL: TT kit for the F-Body
  62. where to find a 500 cubic inch small block ls2?
  63. turbo gauges
  64. alum intake elbows
  65. Boosting questions
  66. Requesting some help. How to shape oil dipstick tube around turbo?
  67. Procharger P1 on a stroker #'s????
  68. What Crank Pulley are you running with Procharger...
  69. Who makes a good single turbo kit?(non STS)
  70. D1SC and passing emissions?
  71. f13 112 and P1SC kit
  72. Now boosted!
  73. Is this for real?
  74. Vortech SC sound clip?
  75. Intake Question about new GMHT Mag.
  76. daily driver
  77. Looking for Pics!
  78. Where can I get a T6 turbo flange?
  79. All business...That's all I can say!!
  80. Super or Turbo?
  81. 398 iron block + turbos at 8.5 PSI + M6 = fun
  82. highest comp. for FI and 105 octane
  83. Leaky Vortech aftercooler
  84. What FMU should I use?
  85. Procharger, intercooled, 8 psi on STOCK A4 FBody : RWHP????
  86. My FI setup!
  87. STS Kit In Finally (need help)
  88. what changes would i need to make? STS
  89. Copying the Incon TT kit
  90. Truck Manifolds And Stock K Member?
  91. Can ANYONE Get Me An Incon Part #
  92. gas mileage with supercharger?
  93. I love Pic's like this.....
  94. bought shortblock instead of building myself
  95. C5 turbo manifolds??
  96. LS1 Kenne Belle ETA?
  97. Anybody make intake plate adapters for Superchargers?
  98. Installation of a EGT A/F Guage XD-1 Kit...
  99. Boosted M6 guys.
  100. Twin Scew on an F-body?
  101. twin kit ?s
  102. Phamspeed Install
  103. Radiator and Fans
  104. STS kit with out tune
  105. RANT: How come noone has made a QUALITY Stock Alternator relocation kit yet?
  106. 40X CID + ET heads + F1r...
  107. Need Sts Instructions
  108. max effort stock blown ls1 vs max effort stock ls1 w/150 shot ... what is faster?
  109. Nitrous or Turbo
  110. what size and where to find?
  111. Procharged 370
  112. whos got the gmr turbo kit
  113. Project Lightning...almost done!
  114. POR-15 the STS turbo housing???
  115. STS turbo kit
  116. Brain fart
  117. Sponsors who are Precision dealers???
  118. sooo close, twin turbo buildup
  119. how much psi can I run on stock bottom
  120. Pretty head repair
  121. gains witrh racegas?
  122. Maggie cam and differential gear ratio
  123. Latest Incon Dyno - 644/701
  124. Wastegate ????
  125. Please Discuss here: Does Oringing the Block/heads make an engine stronger?
  126. STC/Hi-Flo Street Force TT Vette - 692rwhp/660rwtq STOCK SHORTBLOCK!
  127. It runs
  128. anyone run f3 or f4 procharger..?
  129. What wastegate are you high hp guys using?
  130. Which Turbo?
  131. turbo cars at the track?
  132. need help guesstimating rwhp
  133. Holy Pressure ratio bat man... BW turbo maps
  134. What Kind of Exhaust are you running with Procharger/Turbo???
  135. Stock MAF with Procharger or Aftermarket...
  136. Look out HUGE breakthrough in turbo design..
  137. Hurst knob -- high boost switch for turbo
  138. Where is a good place to buy turbos.
  139. Will my 2 1/2" Exhuast Handel FI POWER?
  140. What size belt for 02 Powerdyne kit?????
  141. Attention W2W engine build customers
  142. Procharger install how-to?
  143. Blower belts?? 52" 8 rib?
  144. Predictions for HP on new setup...
  145. NEED Powerdynesupercharger Impeller
  146. Progress Pictures...
  147. Solid Roller Turbo Dyno sheets
  148. Gauges Needed with FI...
  149. Weld Ells vs U-bends
  150. Magnuson Mystery Part !!
  151. where to find reasonable 4 into 1 collectors
  152. anyone running a LT1 PTS turbo kit
  153. mild steel down pipe?
  154. "Roofer Dave's" engine lives!!
  155. Hi Flo website down for a few days for construction
  156. SIN 14 featuring Hi Flows TT vette
  157. Yeah, Another STS post.
  158. Folks with FI and Vacuum modulated trannies inside, please
  159. which makes more power?
  160. '05 C6 coming in today to begin installation of an ATI ProCharger
  161. Almost done with my 408 turbo truck!
  162. supercharged 402 or 408...
  163. ASP pulley has more slip than Vortech Pulley - Why?
  164. AFR with Turbos....
  165. Can I run a supercharger on a h/c/e ls1?
  166. NGK 3 and 4 Stage Colder Plugs...Good for FI?
  167. supercharger people, a little help if you would...
  168. LS6 intake manifold restriction?
  169. Finished up my truck manifold turbo set up..
  170. twin turbo 427
  171. Water cooled turbo here, need coolant feed/return (did search)
  172. Spark Plugs and Wires for FI...
  173. Zex spark plugs
  174. LS1 motor/ATI procharger/1970 Camaro
  175. Another Ohio Car, first pic release!
  176. Tial Wg?
  177. TR 227/224 114 good turbo cam?
  178. turbo kit do i want the ground zero log style
  179. Fuel Pump Question...
  180. Yet Another Turbo Ta Buildup
  181. Some updated pics
  182. Stenod White Formula...Motor, Turbo kit and fuel system for Sale!!
  183. Best plug for magnacharged 383 with meth
  184. best stock fuel rail setup?
  185. Turbo oil drain line size?
  186. New Edelbrock Intake
  187. STS system
  188. Turbo/component selection 347...
  189. 908rwhp 908rwtq Speed Inc. GT76 single turbo
  190. Cost to upgrade a P1 to a D1?
  191. What to do??????
  192. 1143rwhp, 1119rwtq Custom PTK set-up
  193. whats a quiet muffler for turbo app?
  194. PTK Turbo Kit set-ups, please check in!
  195. Guestimated RWHP???
  196. Turbo Exhaust Setup
  197. what am i missing?
  198. ATI aluminum damper with SC?
  199. Project Lightning...Big A$$ Intercooler pics!
  200. Finally got the engine running right but now.......
  201. What are the bolts sizes for the bolts that hold procharger to J bracket
  202. More questions for you STS experts
  203. ATI Super Damper with supercharger?
  204. first tuning session of new setup
  205. Truck manifold setup's
  206. Finally got to the dyno part 2
  207. sts exhaust
  208. AFR 225's, Stock Bore and Turbos?
  209. Best Meth kit
  210. Oil in down pipe
  211. Best material for tubular turbo headers
  212. Turbo Carnage (pics)
  213. STENOD Build-up Pt 4
  214. Any research on T3/T4 Hybrid vs T4 turbo flanges?
  215. Thinking ahead, need opinions. Which blower?
  216. looking for a Good daily-driver turbo setup
  217. Powerdyne missing Parts?????!?!!!
  218. SDCE guys in here
  219. How much BOOST with stock heads?????
  220. Our phone lines and a snow plow...
  221. Newbies with boost...
  222. Status on PTK install.
  223. how do u get oil to turbo?
  224. Clutch for FI guys?
  225. Comp 206/212 for turbo truck...
  226. E85 boosted setup
  227. My 05 GTO twin turbo kit arrived
  228. vacuum operated cutout for turbo setups?
  229. Turbo Cam for STS
  230. Incon car blowing smoke(oil) through exhaust, need help
  231. How well would u think this Motor would work with FI?
  232. STS guys
  233. 6.0 Manifolds
  234. turbo repeat
  235. Almost finished!
  236. what belt for 3.5 pulley
  237. getting ready to drill oil pan
  238. turbo quad question
  239. LS6 & 225cc or Carb & 205cc
  240. 150 passes + 14psi + graphite head gaskets + stock heads =
  241. Octane Question
  242. W2W Tecstar Rotrex?
  243. Building 408 for my D1 Procharger Setup...opinions!
  244. Chevy turbo kits
  245. need a mounting bracket for my supercharger
  246. tang or on center
  247. Bored of the 408 F2r.. What next?
  248. Problem with autometer A Pillar
  249. Waistegate Atmospheric Dump
  250. 222-216 reverse split cam with a supercharger?
