View Full Version : Forced Induction
- Will this work on a sts set-up
- A few newbie FI question
- Budget Turbo Kit/Pre-fab Kit???
- DFI help please
- Preliminary Dyno numbers on "The Beast" Dyno graph inside
- Need help analysing this cam for my application
- Vac/Boost gague, where do you hook it up?
- Best combo for 5.3 heads
- what plugs for Vortech SC IC with H&C
- valve job for FI setup?
- Eastern Forced Induction meet.
- Magnuson's LS2 Dyno Numbers!
- Blow through carb turbo systems?
- 6.0 truck manifolds.
- How come turbos always have that rusted look?
- Cooling issues
- Twin 63 Turbos, how much power??
- CARTEK C6 Stage 1 Twin Turbo dyno results.
- whats this guy using to build boost?
- Recommended Stall for F/I setup?
- alt bracket
- Can I run a turbo or SC with a CC306 cam in a stroker LT1?
- big blower cams, do I need one ?
- Extending MAF wires
- Need Some Feedback on Setup (TT 04 GTO)
- does a gt47(88mm) really spool faster than a pt88?
- Some pictures of the Harlan's TT project and Derty's Outlaw 10.5 project are up....
- Metco breathers 1 or 2?
- MS3 cam D1SC, and Spray!
- Quick update on my 408 turbo setup...
- intercooler operation
- Replace pusher or add puller fan for ATI setup?
- most rwhp/rwtq with p1sc?
- supercharged
- F-1R placement?
- Budget turbo kit questions
- Good place to have a turbo freshened up?
- Questions by a Turbo Newbie!
- turbo kits for gto?
- Reworked STS intake piping
- 4500 lb sts truck in the 11s
- Bah, more issues!
- new best for me (street tires)
- The beginning of something...
- 370" turbo motor, what theoretical compression?
- What size reverse split cam 2 run for SC and Stock motor?
- 8-9 sec turbo cars what....
- Turbo Kits
- F-250 intercooler
- Pvc-pcv....
- New 1/8 Mile Times with STS
- My dyno numbers with P-1SC @ 6#
- What AFR's do you run?
- 99 Magnacharged Z28
- ***Garrett GT42 V-band clamp needed****
- How to choose P1 or D1?
- STS instructions
- TBYRNE Motorsports Is Now Taking C6 Magnuson Orders!
- Notice: Hi-Flo's Phone System may be unreachable today, 10/21
- New Best last night
- STS Turbo LS2 GTO...the details and graphs
- 2005 GTO Owners - Time To Order Your ATI Supercharger!!!
- T76 kit on ebay?
- How much out of a Forged 347 and a T-67?
- Orlando speedworld world street nationals.... ;)
- Turbocharger limitations
- procharger 6-rib d1sc???
- E-Boost 2 Guys
- stock 6.0 horsepower and compression
- '05 GTO ProCharger to be released November 15th
- 617rwhp on a Mustang Chassis Dyno with an STS!
- Magnacharger on a camaro/firebird?
- Say good night to the bad guy.....
- Million dollar question: manifolds -vs- headers
- Need help with cam choice.......Thanks
- Hi-Flo Turbo Systems - The final pic thread
- cutting hood for powerdyne???? WTF!?
- What RPM do you reach full boost at?
- whose turbo kit to buy?
- Twin Garret T03Bs?
- Need help with a procharged Z06
- flanges for 2003 silverado truck manifolds
- Turbo size for a 632 cubes
- New kind of Hybrid
- Twin Turbo- Single Wastgate
- Homemade ls1 turbo?
- turbo 6.0
- Stenod Performance Does it again......
- My LPE TT Hawk is in the new HPP...pics inside.
- 402/408 Plenum Volume for FI
- GM 6.5 Diesel Turbos on LS1
- 6.0 piston info needed.........
- Best FI piston's
- sts Turbo
- Turbo setup, LS6 cam, what springs??
- Wish me luck
- Ideas as to what happened?
- Phamspeed/Groundzero Turbo Kit
- Gauging Interest - Custom ARP L19 Head Stud Kit
- You all out FI guys may be interested in this...
- Dyno boost?
- Learn me something...tubular manifolds vs ??????
- CE goes 8's
- Vortech cooler proper drain and fill
- Cam for Procharger?
- anyone here using a 9th injector?
- Forged 347, supercharger?, and nitrous?
- incon intercooler is leaking..no wwhat
- What to do?
- Found oversized crank pulley (Procharger)
- Info on the STS rear mount...
- Pulley down!? ATI D1 kit...
- need some pics.
- Hi-Flo Turbo : Final Cold Side Pics, Underhood
- SuperCharger OR Turbo, which one fits my needs best?
- Dyno sheet (05 SSR 6 Speed) Magnuson Products
- MY custom GT42 turbo kit is done!!VID
- pressure tested my sts setup, boy was it worth it!
- STS Turbos On Sale!
- P1SC only goes into boost some of the time
- LT1 question
- 3 options Boost 5.7 or build and boost a 6.0 or 6.2
- 222/222 versus 226/226 cam (old was 224/236)
- newbie
- Adding LQ9 Heads-How Much Boost Loss
- High HP dyno charts?
- 471 HP 560 TQ PTK kit at 7.5 psi stock engine
- Stenod Performance Weekend Race Report - Oct 15 2005
- Is it possible to reach 600rwhp with t67
- Congrats to the Stenod guys for winning the quick 16 at M10
- F/I options
- Initial tune complete , dyno within
- Ran my 98 Formula at World Street Nationals
- SDCE & Belt Slip
- supercharger or nitrous
- Turbo camshaft 4 sts
- I'M IN...10's and 130+
- Finally went to the strip, 15 psi on pump!
- Procharger headers
- I have an Idea to reduce turbo lag!!!!
- 427 Tt
- I give up, the 6spd is coming out, I'm going auto.
- Autometer Electric Boost Gauge- MAP Sensor
- 3"-3.25" Silicone reducer needed please help
- ?? about boost & stock LT1
- 640 Rwhp, 640 Rwtq
- How to Test for Vacuum or Induction Leaks
- Meth pressure switch/ Cheater cam
- Uh Oh... My house is a mess now!
- Boost And Some Juice ?
- tell me if this is a bad idea
- My crate just arrived from Texas Speed!
- what intercooler whould you recomend?
- where is good plce to buy mild steel bends?
- Saw the Hardcore Black TA convertible last night
- E boost 2 problem STS
- Blown C6 question
- whats a step up from a t-76
- PCV. r u guys setting them up.
- STS problems...
- Meth Kit installed...now what?
- Hi-Flo Turbo Systems: "Street Killer" Intercooler Pics
- PCV revisited (searched and now confused)
- Spun my pinned crank pulley
- Seen the new HOT ROD?
- procharger
- F.I. on lt1
- Methanol vs Torco
- Relieving Crank Pressure
- Cam selection for forged 402 twin turbo
- F.I. Guys I think I have a lean problem
- about power output of a sts kit(yes i searched)
- pics and dyno numbers from my turbo set up
- powerdyne s/c
- 515rwhp and 540rwtq from PTK kit
- Turbo for my 3.8l v6??
- Estimated cost of TT kit for LT1 car?
- 6.0 FI block Prep
- Lower mounted Turbo guys, got question.
- Should the bypass valve be open?
- Does ASP make procharger pullies for the LT1?
- FINALLY- its alive!!
- ptk 03 c5 vert rocks
- Vortech Mondo bypass...0-10psi???
- blow off valve/bypass valve
- flood damage
- Stenod Performance Cold Weather Testing with the Glide!!
- Arghhh... comparing my 9.40 and my 9.51 slips (bummed out)
- IAT Sensor Thread size???
- FJO water/meth info.
- i could use some advice
- Incon Car - Smokes Blue When Cold On Decel
- 12 rib procharger set up
- This Things Pissin Me Off!!!!
- Help me guys. New to turbos and I'm going to build my system.
- is it possible-blower questions
- Big HP guys what cooling system?
- 456 RWHP 509 RWTQ 3800 camaro
- Stenod Performance Open House
- Top radiator support
- Almost another 8 sec car
- ATI twin intercoolers and STS system
- Turbo or Not?
- SDCE 8 rib
- 4000 CFM fan setup...pics inside
- boost controller , who makes a good one?
- Texas Race - might be cancelled soon
- My STS project
- e-boost experts - questions on settings and boost dropping off
- Procharger Questions????????????????????
- First track results D-1SC
- How can i git 15PSI in D1SC ?
- Having trouble deciding which heads...HELP!!!
- Beautiful display of fabrication
- Upgrading to Vortech T-trim
- Oil blowing out pcv valve
- questions about LQ9
- Lingenfelter "Radix" LS2
- Two time valve seat dropper, what's up???
- harmonic dampener vs normal pulley
- TURBO or SUPERCHARGER
- rain storm in ri car wont start
- Turbo sizing and hp production
- finally broke into the 9's!
- Did a little better: 9.40@143.74
- need help.... boosted tune... anyone
- Another what 370, 408, or 427 for boost thread
- STS Results as promised....
- Spark blowout??
- has anyone twin turboed a built 454
- STS Kit questions...
- tensioner pulley bolt
- Lingenfelter 1,000 RWHP C6 - video inside!
- Opinions on what supercharger to look at for truck?
- Phamspeed finally done!!!!
- Sold my stang ready FI!!!
- F1 Clearance question
- I think we may see a new best
- So am i an idiot or are my wastegates not functioning properly?
- Twin 58MM Turbos equal one 112MM Turbo?
- small cam for boost
- Knock Sensor with Block Filler - any change?
- G5X4 and boost?
- Any ideas why I'm running lean?
- how much boost can I run
- Changing heads, cam, blower set-up
- spm single turbo killer pics
- ? installing autometer gauges
- Turbo sizing for 402?
- More than 17psi?
