- cam recommendation
- What would this turbo be best for?
- Air to Air intercoolers questions
- Twin setup for my stroker
- BOV turning/rotating
- Need for tune or just bolt on? - C5 throttle body 78mm to a newer (01-) 85mm.
- Epp cam on stock 98 motor
- Water/Meth injection - who has the deals?
- Full Ceramic Ball Bearing Garrett Turbo Cage
- Stock GM ECU tuning
- D1sc procharger with straight cut gears
- Boosted C6Z06 at Texas Mile
- Remote (Trans cooler/fan) for (water/air intercooler)
- CX Racing liquid ic pressure drop
- Frankenstein Low-Pro Billet Manifold
- Lightweight clutch/flywheels and turbo(s).
- D1sc procharged ls1
- Lsx 261: v1ti convert tt
- Opinions on first turbo build
- Air to Water IC Share Engine Radiator?!
- drive pressure with vsr billet 7875
- 4" round vs. 4" oval exhaust back pressure issues?
- East Coast Supercharging is on point!!
- 5.3 turbo build
- Biggest AR exhaust housing for a PTE 76/75 ?
- Best water to air pump
- Too cold IAT??
- New wg spring stiffness?
- Morel 4708 lifters oil w/turbos
- 4th gen vs. 5th gen turbo placement
- What 10k ohm resistor are you guys using for the holley ethanol sensor?
- Guys with ls1 pan and stock pickup tube. How many quarts of oil do you run
- Cam
- Sooo about that 77/83 turbo.
- First time procharger!
- Should I be able to pour oil in to prelube s480, before firing up for the first time?
- Is 102mm TB to big for single turbo?
- Confused with boost signal and Vacumm
- 98 Camaro 408 S488 Huron speed v3 t6 hotside kit.
- What spring with scg-1 boost controller?
- The Baddest Built 6.0l for FI on pumpgas...
- Stock 6.0 LQ9 Exhaust Manifolds
- Post pics of custom Procharger F series filter setups
- Single BW s366 (Step in)
- help with old turbonetics meth inj
- Anyone know the limits of the STS turbo system on 4th gen Fbody cars?
- GT 4584 BIG Turbo
- Powerdyne prices
- 7665 or 7675 Turbo for my build?
- cutting out in boost
- Junkyard LS and 22lbs of boost give this sleeper Colorado 800hp
- turbo truck -AN fuel lines
- 370 F1A setups... what's the latest and greatest?
- Help with a build
- Custom blow through intake design??
- Iat sensor this close to bov
- [VR] 1,230rwhp Twin Turbo Camaro ZL1 1/2 Mile Build!!
- PWR/C&R Ice intercooler anyone used these???
- Microsquirt people needs some help
- Hey Everyone 2001 5.3L Single Ideas
- FEL-1160 .041 MLS head gaskets?
- Very confused about FPR and Turbo set ups
- Which heads for LSA S/C using adapters on 5.7. 243/241 or 317. Compression question?
- I did a thing..
- 3 bar Map FOR MSD 6012
- Opinions on intercooler pipe route
- S400 V2 race cover Dimensionals
- bw matchbot
- Holley 534-209 on a truck intake
- Stand up radiator vertical...complete kit.......On3
- Threads and gasket for s480 oil drain?
- twin turbo fox body fuel system and efi help
- What rpm are you shifting turbo cars at?
- Looking for Lil John
- Piecing together procharger kit
- O2 sensor location
- 1/2" head BOLTS
- Best shop/vendor for turbo build
- Anyone from the FI section going to TX2K?
- Starting a turbo build
- [VR] C7 Z06 F1X + Nitrous - Full Polished/LME Intake/Custom Engine Bay
- Port for Hobbs switch
- boosting a sbe ls1 with a ms3?
- DYNO! Highest hp 6.0 record PERIOD
- NA cam, High Compression, and now turbo?
- Procharger and racing
- Garrett TV6502 worth installing?
- Next step/help in 1000 rwhp build?
- Blowthru intercooler question
- Just a simple where would u put my wastegates
- Ebay turbo kit builders come inside
- Turbo Build Almost Done!
- Junk yard engines-cam bearings
- TFS/Jegs 228/230 Cam Turbo Results?
- Build me an 1100fwhp SINGLE turbo setup using a 5.3, 5.7, or 6.0.
- Turbo build
- LS9 Supercharger Lid Dimensions?
- cam advice
- Forward facing header accessories
- Engine machining specifics for boost
- Decisions Decisions......
- Trying to decide on cam and see what the pros think.
- Bw s400sx 75mm
- Ls6 intake worth it?
- Need help with Alt relocation on turbo camino
- A/C idea for boosted set ups.........opinions
- Weapon X Motorsports NW "Boosted 102" TB
- Co2 on wastegate
- Torque Converter selection for a4 turbo gto?
- Roots or centrifugal supercharger to replace nitrous for 406 build?
- 240sx Hood won't fit after 5.3 install need suggestions
- Loose procharger pulley. Video inside.
- First FI Build
- 5.7 sbe with 78/75... what cam?
- A2A and A2W inline setup
- 417 Motorsports 1500hp Hi-Ram Intercooler: The Data
- TT & intake combo question
- Help everyone pick a turbo for my drag 5.3l camaro
- Quite the dilemma!! Need advice on which motor to run in a 2005 gto?
- Taurus fan dimensions
- (Picture attached) Is this the correct routing of vacuum lines?
- Crankshaft help
- Turbo LM7 Dyno guesstimate
- 750hp ls1 combo? Critique
- Newby question
- Why are oil return fittings not measured my inside diameter?
- FI ring gap
- Hp limits with fmic
- Help with knock above 10lbs of boost
- FB RX7 5.3 S475 Glide 8.8
- Quick video - 67 Firebird 4.8L of fury
- 72 Lemans with 5.3 and ChinEasy T76
- Oil pressure at idle
- Huron speed turbo kit question
- Anyone here do hot sides for LS stuff in foxbody's
- pics of my latest hot pipes.
- Has anyone run a t4 s480 on a Huron speed ac kit
- Differences in 5.3 block castings
- 12:1 compression/ High Boost / E85
- Magnasun 2300 VS Procharger F1
- Block all clean and ready to assemble...Damn Billet is pretty...lol
- 11 blade vs 6 blade?
- *NEW* Huron Speed T6 S400 Turbos with 106/112 Turbine Wheel ! BILLET 88/112 S400
- 5.3L w/ 317?
- Novi Supercharger Question
- Custom built turbos
- My 98 z28 turbo build thread
- Dyno graph inside Why is my boost falling off on the big end?
- Fittings for boost gauge
- PT88 down pipe
- Whipplecharger Help
- Need some Help please
- What dual gates should I run?
- E-boost street boost controller acting odd?
- LSX Tall Deck Advice
- P1SC1 Intake suggestions
- Looking for real world dimensions for treadstone TRTTC9
- Help me spec a Motor For my twin turbo setup
- What 3bar map sensor?
- Back pressure data on a 4.8 with an 1.32 T6 S4XX?
- How cam choice affects engine heating with supercharger?
- How much power to expect?
- Forged 347 – F1A @ 13psi – Only 490 whp…
- What plugs for turbo ls1 14-16 psi?
- Any Colorado residents with FI cars?
- Sbe 5.3l rcsb 4wd; 10.91 @ 124.65
- 3.97@184 LSX Power!!!
- Turbo oil feed... another one
- Max boost/hp for 5.3 forged rods and pistons
- 68 Chevelle twin turbo 6.0l build
- LS1 w/ twins upgrade advice
- Installing new unpinned balancer question
- Building a twin setup from MILD steel?
- 1.00 to 1.40 GT55 turbine housing swap...how will it affect fueling?
- Switch to forced induction
- Th400 First drive impression.
- gm-8 turbo size and pressure limits
- 5.3 or 5.7 for a 871 supercharger
- Project Wrong Way Regal Wagon build
- Need to make a decision on forged boost engine, what would you do?
- cam help
- What Crank with a F1A-94?
- Where can i get a Compressor wheel for Master Power T-76?
- What rear gear
- Max hp with my fuel system? Turbo ls1
- Head gaskets for a 4.8
- Any reason to upgrade the harmonic balancer on turbo car?
- Turbo Silverado
- 4.8 and s475/T6/1.32
- Opinion on ring gap
- VP110 fuel??
- AC Relocation Bracket + Turbo?
- My CTS-V/ZL1...truck build!
- V Bands
- Catch can with stock valve covers and no tig
- Need some help with my 98 turbo z28
- Make me feel good about this cam.BTR twin turbo cam in single turbo car
- Brake booster
- Speeduino vs microsquirt for e85 build?
- semi-reliable turbo 5.3 on a budget
- Basic setup, how much boost??
- Dart LS Next2 454 and Fi?
- One turbo blowing air OUT of suction side...
- F1 Procharger gear ratio question
- School Me On Meth Install
- Looking for Wheels and tires for 2006 GTO
- Belt Walking
- Sensor Question
- 2000 z28 4.8l turbo build
- Making the switch.... rear mount to front mount turbo.
- Does it ever end?
- Ls3 turbo compression?
- Boost Issues
- Boostaholic cam?
- supercharger
- Piston rings no longer available...
- Flex hone or not?
- Meziere race water pump with alt relocation
- Turbo Log Header ?s.
- What pistons should I go with?
- whats a good turbo for my 5.3
- Exhaust Design - Procharged LSA
- What makes one BOV better than than another BOV if same size?
- Timing gets pulled as soon as I build boost?
- Fuel Filter & Dual Pumps Manifold
- Chevrolet V8 turbo
- BOV question
- Wastegate on Mid turbo housing
- 81 fairmont -new project LSX turbo
- Turbo LS1 Engine Carnage Video!
- Tial wastegate spring question
- 2nd Pump Questions
- Ls 370cid turbo ideas?
- Stock 6.0l bottom end
- Paxton SC1500 on C5 ISSUES
- another turbo ls notch build
- How far can I take E70 fuel?
- wiring a boost cut relay
- Cx Racing turbo kit on hci ls2 questions
- TwinS 6266's
- MAGNUSON TVS2300 ls3 in a c5z
- To intercooler or no that is the question.
- Heartbeat or Whipple for Chevy SS Sedan?
- Video of twin-turbo Vette putting down 2000hp
- Northeast X275 now at NED and Lebanon Valley..
- High compression 408 6spd t56 with t6 hotside what turbo to run?
- What size cutout on downpipe?
- [VR] 2017 ZL1 Stage III Package + Meth/E85 Makes 760rwhp!
- Ever find a verdict for Fairmont 5?
