View Full Version : Forced Induction
- What happened to the Roots type for the F-body??
- CAS TT kit update...I got my new turbos!!!!
- Pulley Sizes and their Respective Boost Levels...?
- SLP 402 for a FI set-up
- Changing lobe separation
- Blower with dual electric cutouts...
- Could my current cam swing it for a turbo cam for awhile..
- sts instructions i need a copy
- Roto-master To4b
- more pics ... with some paint
- A Proud FI Owner at The Portland Rod & Custom Show...
- Since my new single setup isn't going to be ready for a few weeks...
- Turbo Sizeing
- why exhaust temp matters for turbos
- finally working on my sts install
- Will chrome hold up on Hot Parts?
- ALRIGHT!!!! time for FI!! Help me out here!
- ? about the 8 rib pulley setup for an ATI blower
- CR questions
- Quick question about STS
- Procharger/Cam
- Superchargers & l60e Trans good or bad?
- Whats the Top 20 cut off for the list?
- Turbo question any help?
- anyone have problems with thier vortech?
- Is there a 2005 Boosted List?
- know any thing about this kit?
- ? About Using Brake Booster Line for Boost Guage
- What do ya'll think about a twin turbo kit with GT30R's (ball bearing)?
- all bore + boost bad mix???
- Turbo Cam Questions?
- 8 turbos on one engine
- Wheel spin and boost ?
- Interesting Valve Train Question For Big Boost
- Progress Pictures
- Firebird frontmount?
- front mount install
- Check this out.
- P1SC help
- Head Unit for sale
- Thinking about an STS turbo on completely stock '04 A4 GTO
- Pics of Rides With Superchargers
- FMIC on a camaro! post ur pics
- procharger install....
- OBX works good, have autotap proof.
- Will My Car Like An Ati Blower?
- Big FI cam
- SMC alky guys inside please.
- Incon Turbos - Wire Only One Shut?
- ATI vs ESC vs A&A
- Mounting Turbo Upside Down
- who is running a t76 on a stock displacement motor and what kinda power?
- Sts Truck Kit On E-bay *no Reserve*
- New complete ATI 6 rib pullies for sale
- Smog Cert
- harlan 2step instructions
- Twins vs. single turbo....
- Looking for old pictures of the QMP turbo kit
- Looking For Specs
- Any good online places to order Dayco 8 rib belts?
- frozen, boiled, and then they run it over
- What Pistons & Rods
- Where to buy Dished pistons
- Intercooler pipes done, dropped off at the machine shop!
- Ever closed a spark plug gap with FI?
- High compression w/ low boost.
- Officially FI, TTi Street kit installed and running
- Phamspeed Twin turbo kits- $4500
- Need a cam suggestion to compliment S/C...
- Which is better, c16 or 110 oct?
- Ati D-1sc Vs Sts Turbo
- Request for Jim @ LS1 Speed
- Just got my High Temp Silicone Order
- How much more boost?
- How much power to go 150 MPH?
- need OBX FMIC installed pictures on a Camaro (ATI)
- Where to T the BOV off of?
- Launching a Turbo with a TH400
- Turbo 383 or 347??????????????????
- Need Help on Turbo Application.....for the experts!!!
- How much to jet-hot coat QMP turbo kit?
- Wideband sensor location for F/I
- head/cam swap OR supercharger???
- BOV sound
- where to buy procharger oil...
- Supercharger or Turbo? 98 Ls1 Vette 6spd
- Incon Guys Within Please!!
- Low CR guys . . . what is your timing before boost hits?
- Max boost? Stock everything 120 octane
- Vortech brackets??
- OK, rate my cam
- WTB LT1 Supercharger
- Turbo up and running
- Pics of Jay's 94 Camaro SBC Turbo Buildup
- wideband O2 sensor?
- Trap Speed/times?
- electric centrifugal supercharger kit question
- Remove MAF Screen?
- Turbo Piping Questions from a noob
- Blow off valve needed for 7-800rwhp.
- v band clamp
- Lingenfelter NEW limited Twin Turbo 427 C6 !
- 1st Dyno - APE 370ci, Incon Twin Turbo
- higher psi actuators for Incon
- STS guys, my oil alarm keeps going off under boost
- Turbo with no muffler, how loud
- IAT fluctuations
- welding beads around intercooler piping / tb
- ATI Procharger Parts, where to find
- any incon dyno sheets
- WTB: complete supercharger kit
- Anyone else do this?
- PROCHARGER: is anyone having pulley aligment problems or its just me?
- Anyone have directions and part list for log manifold TTi kit?
- Some questions about my turbo kit.
- can someone give me a straight answer??
- What Turbo for my goals (8s and 6 speed), other questions as well
- Mig welding stainless?
- Imos-ss dyno #'s..348 @ 7psi
- HPP Magazine- Calling all Firebirds
- nexus guages
- Turbo or Supercharger
- Cam suggestions for d-1sc
- Custom grind cam
- Race Season started today, got a new best..
- Jim Filipowski's 1993 Camaro Setup?
- Supercharger 4 Sale
- Exhaust for turbo
- Installing Boost and Fuel Pressure Gauges...
- Are there any 8rib pulley's for stock balancer?
- STS Turbo NIGHTMARE! Please help
- Looking for a good turbo kit.
- Just changed out the rear mount 67 for my 76
- d-1sc mounting bracket options
- Anyone need a 4.10'' Procharger Pulley?
- D-1SC Procharger
- Lunati 230/237 112lsa
- Anyone running a pair of GT30R's?
- intercooler pipe
- Upgraded STS Turbo Kit F/S
- Who is on ALKY
- All things being equal.....
- STS peeps. What other turbos are being used
- OIL-PCV-BREATHERS?What works?
- W2W turbo for Silverado?
- STS and nice 60 ft time
- Firehawk is SOLD......
- For some of you that asked, yes we can polish our manifolds:)
- F11 cam good for STS turbo?
- Water Alky Question???
- misslabeled waste gate springs?
- OBX Intercooler entanks
- ET calculator
- How much boost are the stock rods good for?
- How much boost?
- Should i cough up the cash for an engine, before mine breaks? or wait?
- Hardcore LS1/LT1 challenge at VMP
- Fuel Injection Management for 20+/- PSI
- Intake for 20+/- PSI
- 12 Rib Belts
- New Pro Turbo Products Video
- Oil pressure problems solved!
- Intercooler on a 94 Lt1 camaro
- still goin' ...
- wonderin about a cam
- Difference between ATI 8 rib and SDCE?
- T70 + LS1? Good turbo for a very conservative setup?
- Plug gap with met on STS
- Sts
- What Oil Pressure Is Normal??
- alcohol + carb + efi
- Clarification on QMP/LS1 turbo kit
- Intercooler for Sale!
- boost gauge question
- Supercharger Whine?
- truck turbo kit
- Exhaust port
- boost questions for boost experts...
- Need help fast (procharger d1sc)
- need a more serious blower..
- TWIN TURBO Kit
- What is the intercooler core size on the Incon TT
- Need Incon Part - Anybody Got It??
- Oil Pressure help!
- Add On Intercooler Setup for STS
- How do you keep the intercooler cool on a T/A?
- Pics of my 00' s-10 blazer
- whats a good cam to run with a supercharger???
- POLL-Help Me Decide!
- 5 psi sts turbo kit please advise!!!
- Forged Shortblocks
- boosting on recal. pcm
- Solid Roller and Boosted applications
- Highest power Twin turbo?
- fmic guys, need parts?
- Lsx Intake?
- Any Nice Single Turbo Kits Besides the STS Kit?
- Turbo For PSCA Limited Street
- Phamspeed is taking a beating on local forum
- Anyone here rebuilt a P600B before?
- 396 cubic inch lt1 with t76
- 427 or H/C & Blower 346?
- Wrong MAP connector?
- 6.0 head guys
- draggin my feet... some IC pipe pics
- Fired up the TT 408 last night!
- LS1 Intake manifolds capiable of mounting 16 injectors?
- FS:D1SC Head unit
- Bad sales pitch??
- Failed Smog after ATI Install and Tune...Help!
- SMC Alcohol Injection
- Supercharger
- High class Water/Alky injection
- SS J and U bends
- Has anyone run the IT "R" turbine wheel yet?
- Air Lid Sounding Like A Small Supercharger!
- So who has maxxed out 42lb injectors and what kinda power did you make?
- real quicky
- Blue Smoke, Cold Startup, Lasts 10 minutes
- ZZ9 with ATI
- Please help a newb out and fine tune my setup
- 5 psi STS ET's
- New Boosted List keeper for 2005!
- Q's on sts kit
- How much power from a cutout?
- running methanol
- supercharger installation
- Is this a good deal on a used D1-SC?
- SMC Alcohol Injection Kit GP
- 700bhp fiero. what will it take?
- Want more Torque
- Who makes the strongest 8 rib belt?
- STS guys seing OIL from Valve cover return line?
- Is it worth the money to... :)
- Fuel injector question
- magnacharger on a F-body
- 700rwhp+ Folks - What injectors etc?
- wow......Street Nationals Pics
- Most SC RWHP on a 6-Rib?
- d1sc wiring
- Dyno Fun
- Autos with FMIC....
- Please help diagnose this problem
- Intercooler
- T-Bolt Clamps
- How much boost will I gain when I change pulley's
- Better to lower CR with pistons or heads?
- Spark Plugs?
- Fastest Outlaw 10.5 car
- Advise: Anyone that has installed a STS turbo kit on there LS1 come in.
