- best block choice
- No vacuum on my procharger setup
- How much timing w/93 octane and 12lbs of boost?
- fi head suggestions
- Need alittle help pro charged s10
- max boost on cobalt 2 bar map sensor?
- Needin some help
- Where does everyone mount their trans coolers?
- Throttle Sticking under boost
- Speed Inc. tweaking the build to better my 7.52
- trying to figure out this precision wastegate with no controller
- any high hp ls3 block guys?
- Procharger camshaft
- New Engine/Supercharger Setup, Thanks Unleashed Performance!!
- Garrett gt4202 on lq4 be a good option?
- 4150 intake w/elbow vs fast/OE HP#s ?
- Cam question
- PT76gts to small?
- quest for power with mpg's
- Kenne bell
- METH users...how much boost/timing are you running? shooting for for 19psi here
- need help picking turbo parts
- water methonal questions
- ls9 head gaskets/how good for 900rwhp ?
- Vortech Belt replacement.
- limits of the ls6 block
- Build For 2012! Project Angry Bird 408/F1A Procharger
- max boost with 10.1 to 1 compression
- 2000hp steel rod build what stroke?
- who has successfully welded extra head bolt mounts to an iron block?
- turbo my ls3 or sell?
- I'm thinking this spark plug gap is a little too tight???
- Delivery time Callies ultra billet crank?
- 370 w/ Glide, what turbo and cam?
- Champion edelbrock e-force 621rwhp dyno
- RPM Built 1020RWHP TTIX C6Z
- anyone try running a pair of these derale push/pull fans? Amp draw too much?
- Getting a little impatient .. My soon to be build
- input on my fuel system please....stock return ok for this fuel supply?
- Not flipping the manifolds?
- Meth Kit?
- spark plug wires for flipped manifolds
- in need of help here
- turbo with internal wastegate for budget 5.3 build
- Best aftermarket heads for a 5.3?
- 67 chevy II LS 2 twin turbo build
- Compression limits on E85 and turbos? ways to band aid?
- ALT relocation question
- help me decide
- ***turbo headers for my LS2...
- LQ9 thought to be turbed..
- VHT on the street
- Has anyone changed combustion chamber size on their turbo setup?
- Best exhaust system for procharged camaro? 4'' exhaust ?'s...
- K-member for turbo.. can UMI k be used?
- intake manifolds
- 5.3 block strength
- Electric Superchargers
- Where Are The Twin Screw Blower Guys?
- front mount install write up??
- Belt size?
- this a good cam?
- Upping The Boost
- A little daytime street race LS2Formula vs BonnarLS1
- Ls6 Cam
- Need a little help to get to my expectations
- LQ4 Rods vs LQ9 Rods
- E85 vs 93+methanol on a procharged car
- Does anyone make a belt that has a "grip surface" on the smooth side of the belt?
- Recommend me a turbo please 408 iron block Ls3 heads
- greddy turbo timer wireing
- AN lines for radiator hoses
- LT1 12.1 CR Boost??
- couple enigne boost questions???
- 4150 TB with hat or elbow and 90 with Vic Jr
- A little Help Please Vortec G-Trim
- Tips on making a stock crank live
- Filter on turbo vs cold air intake? Any back to back test?
- FelPro Stopper gaskets
- What heads for a 370 ??
- l98 (416 ci) turbo 491
- RX performance dual valve catch can - any experience??
- post up picts.of turbo motor bays!
- 317 Heads
- opinions wanted for a turbo set up
- Beck intake on 390 F1A build; benefits over FAST 92mm?
- What carb style intake?
- ssoooo what if???? high Cr and boost?
- 427 TT setup for a 73 Vette
- purchased sts kit, what size turbo for my 04 GTO?
- my 76mm Turbo LS1 Miata ***Lots of Pictures***
- will rear mount set up have less power than na at low rpms?
- 383 with a d1sc
- 441ci LSX Twin Turbo new #'s Precision 67 CEA vs Turbonetics TC70
- Pushing water damage?
- Need alittle help
- Are stronger rod bolts necessary?
- 5.3 or 5.7??
- Centering Supercharger Crank Pulley
- Radiator hp rating question.
- my next big upgrade purchase
- Gt4788
- Silicone Couplers & Adapters ** D1SC Truck Intake
- Vengeance built Twin Turbo C6 Z06 goes 1343/1229... Graph/Video/Info Inside
- where are the pulleys??
- Need input on this custom cam for turbo
- breakin in new motor with procharger?
- Gaskets for truck manifold / crossover connection
- 2011 Whipple Camaro
- Putting together my 35th LE car to drive around town and X275/ lots of pics
- Instant spool twin turbo???
- d1sc dimensions
- What kind of sealer for turbo exhaust flange?
- Boosted 347 LS's
- STS Turbo Questions
- Balance and Blueprinting for TT kit
- would like imput on turbo and waste gate size
- short street bursts, 76mm/17 psi/93 octane
- Dyno tuners suggestions-ohio
- New build...what peak rpm are you running on the street?
- Truck manifold wastegate sources
- ati procharger install
- Master Power Guru's what is This turbo?
- Starting my Turbo build...finally
- PT7675, PT7675 CEA (Billet), PT7875 or Other
- Am I making the right decision? Forged motor or suspension/rear?
- whats the budget FI SHORT BLOCK set up....for 800 RWHP.........
- Ideal pump gas turbo PE ratio
- Best clutch for F1-A 408 car? Aster bracket/pulley setup..
- Input wanted to get to 9's on turbo setup.
- Unleashed Performance - 810RWHP, Stock Engine, Oil-less Rear Mount, and E85
- Need help arp head studs or keep arp head bolts? Ls9 head gasket install
- What turbo manifolds to retain a/c?
- What type of manifolds are the best for turbos
- 2012 FASTEST FI LSx 1/8 MILE LIST
- New Comp 80mm,17psi,370ci, auto,777whp!DYNO SHEET ADDED!
- map question
- Turbo engine build Question ?
- Ls1 turbo gt4788 a/r 1.08
- 2012 FASTEST FI LSx 1/4 MILE LIST
- Our Latest Contribution to the 2010 + Camaro
- New S10 project
- Best place to get 4" pipe for down pipe
- Supercharger Crank Pulley..Help
- Working on the 370/S480 silverado finally!
- Injector size?
- Twin Screw Blowers
- ls3 camaro Manifolds would they work.
- precision vs borg warner turbo experts come in!!!
- Intercooler discussion - Twins, FMIC, A2W
- Fuel sys suggestions LQ4/s400sx3
- would a Master Powers T70 be "good enough"
- 383 lt1 ( 11.5:1)able to boost safely?
- Turbo LQ9 breaking up under boost (3.5-4krpm) (long, but please read)
- Is anyone running a turbo on stock bottom end? Lets here about some set ups
- any custom procharger duel intercooler setups out there?
- 2002 Z28 LS3 91mm build
- Disassembled: Emusa 38mm wastegate and 50mm BOV
- ever heard of this 2.5 bar map?
- 317 heads, whats the limits on cam size?
- '68 Lemans Turbo build
- oil feed and drain
- Is it worth to upgrade from LS6 intake to a FAST Intake?
- Airstrip Attack: Private Runway Shootout in February,Rolling Side by Side Competition
- Keeping A/C, Turbo Location
- Turbo rebuild kit
- Building your headers and need AWESOME flanges?
- GM LSX 377 or 454 Boosted help
- Anyone using LS9 head gaskets on a LS1/6?
- what kind of FI do you recomend
- Congress ends corn ethanol subsidy
- On the fence procharger or turbo
- E85 Street Centrifugals or Turbos Numbers
- scavenge pump mounting and drain line help
- Procharger Crank Pulley
- E85 with IC or E85 with Meth for 50lb break?
- stock long block times
- Lloyd Elliot finished my TFS heads.
- Powerdyne LT1 install questions
- procharger bypass
- looking for intake input
- Who owns this Camaro??
- 2002 Camaro FMIC D1 build pics vids and dyno within! UPDATED BOTTOM OF 1ST POST!!!
- Maggie, Meth or N2O
- LSA/LS9 heads??
- Harmonic Balancer
- Intake manifold.. ls2, vic jr?
- Ported manifold and boost?
- Can you run a D-1SC with a 6 rib
- Starting my turbo build
- Thinking About Going F/I route with a bigger cam yes or no
- suggestions for cylinder heads
- Boost gauge placement?
- any vendors have a air to water intercooler kit
- Lq4 or ly6??
- I need a vendor to sell me an STS turbo kit
- Tru-Boost Boost Controller
- New to FI. Looking at forged pistons. Any suggestions?
- elbow question for those with NW T'Body.....
- looking for twins!! help!
- turbo guys making BIG power on pump gas? lets see the combos and tune..
- Wastegate failure protection circuit
- t76 vs s475
- Help me build the fastest spooling T6 Merge
- Procharger Questions
- What's the trick?
- 5.3 with BW475?
- looking for opinions on camshaft
- twin turbos using 1 air filter
- E85 Guys...what are you gapping plugs at?
- turbo with air conditioning
- Turbo Experts - Plan my build......69 Camaro LS
- New Dyno 402, Novi 1500, 12.5PSI
- cooling fan help
- stock fuel rails
- any ideas for 600 wheel horse with 6.0 mp122
- What widebands allow you to have a alarm?
- "Stock" Engine Ideas for New Project
- custom water to air intercooler
- Procharging...rebuild blown motor or buy new?
- Quick change pulley ?
- gasket help
- Simple boost/compression ratio Question..
- Random turbo questions.. help please
- twin 68mm ?
- What all Would i need for to turbo my 00 ss
- Headers with turbos?
- My 275 turbo car, first start!
- what plugs?
- I need help with A/R and Wastegate size
- Shift points and peak power on 6.0/pt88 combo?
- 850-900 rwhp front mount truck manifold 78mm turbo
- need info on my turbo 5.3 build. experienced people please help
- what pistons for a boosted ltx block
- few questions about a low boost turbo setup
- anyone used an EMUSA wastegate?
- Project: Stang' Bang: New Edge Turbo Build... class? Track?
- Edit: Brute speed procharger in my future
- quick wastegate question
- 370ci AFR 225's, APS w/ Kandos, Pro-flo XT Build (56K die)
- Opinions on LS FI build
- Help me build a bottom end
- Anyone have luck with a PT94 CEA
- Picking a Compression Ratio for a TT 402
- Intake manifold for forced induction?
- What cam setup for a turbo with rectangular port heads?
- LQ4 Turbo Recipe good for 8's!!!
- new setup? possibly more boost?
- need a procharger
- procharger cog drive on street car??!!
