View Full Version : Forced Induction
- Supercharger with and XER 228/228
- Please Help Me!
- Will not idle..
- Cam Motion's Cam recommendation...
- only 2 days left for gp
- 9:1 pistons and boost ?
- Best all round?
- shooting flames?
- Recent dyno sheet for my car (YSi-Trim)
- strange miss after head and cam install
- Changing headers and wondering If I would loose or gain with my STS?
- Vortech YS install pics.
- How much boost on stock lower end is to much?
- TTi Log Manifold Vs. TTi Race headers?
- How do i read the #'s stamped to the front of a turbo?
- Hardcore Motorsports Spring Open
- Procharger Tuner Kit
- boost on stock intake??
- please help me!!! vortech parts missing???
- I do believe I've been challenged
- valve spring float
- Need Help! Asap!!! Pleeaassee!!!
- Anybody use Accel 375+ with boost retard???
- short vid of ATP cutouts
- Turbo-fuel system question...please help
- Ring gaps and boost?
- MMS pulley with ASP underdrive crank pulley
- How low would you go with CR
- Best Spark plugs for forced induction App?
- Weird turbo noise???
- its a dog?????
- Turbo hot parts... one vs the other?
- ATI Procharger first ... any regrets?
- forced induction tuning
- Closest and best shop for me for tuning FI.
- sts boost question
- Any of you seen this?
- Paging FRCEFED and BOS.
- power difference between log tubular turbo manifolds?
- Another Question thanks for the help
- Stock 2004 gto on procharger ho
- Question on Supercharging
- expanding intake pipe!
- What Fuel Pressure???
- Merry Christmas all!!!
- STS turbo question
- What is the dynamic compression ratio on your FI motor?
- F1R Procharger with dry sump
- sdce belt lengths?
- running 10psi...?
- The Truth About Hardcore Motorsports
- Checking C/R on LS1?
- i have the option to control 2 sets of injectors, hmm, got some ideas
- PurEvl - Got a Q for ya?
- which supercharger
- Super
- 13lbs of Boost made 781 hp to the wheels
- 72cc or 68cc with Vortech 9#?
- need help choosing pulley size!!!
- Aquamist WI system, who is using it?
- Can you run low-mid boost on 10.3:1 comp?
- Recommend an ATI set up for me
- Waste Gates Which one so many to choose
- Ptk?
- How Many More Boost W/ 6.0L Heads?
- what would you do
- Where to get TORCO
- Oil cooler for FI
- Speed Inc.'s opinion
- Calling SSnakeKiller
- Turbo or Supercharger
- yo z8's that 4" stuff looks good
- Would this work
- Pulley change = How much more boost?
- Pics of my intercooler mounted
- Plug Selection???
- If you have a huge engine bay, why STS?
- ATI pulley Size/Pressure/Elevation/RPM/MODs
- Jay Leno's LS7 Twin Turbo is on Rides TLC
- STS 1/4 mile times seem slow?
- Anyone got H/C with STS...and maybe some hp/tq numbers?
- STS Patent
- F/I vs. N/a
- STS turbo pics
- where to buy a garrett t4 exhaust flange
- Looking for pics
- which boost controller is better?
- Stock Heads for FI
- Tony and John…pls : 3rd gen magna!
- tensioner GP's...send in your brackets!
- check out what I found on ebay...
- Blow through MAF or not????
- is there much hp to be gained by fine tuning the timing and fuel?
- 15lbs extra weight from thick material up-pipe.... would you care???
- boost, compression....etc
- Best turbo for money??
- Bleed off valve for sc applications?
- now for something really funny..
- Quench & Fi eng
- Guys running 15+ psi i have questions about your engine
- Exhaust Question for FI Setup..
- PSJ Or someone else..
- Turbo with Borla question
- Opinions on Intercooler Sprayers
- My 66's are forsale
- 703 RWHP 4x4 6.0L
- Max Power On Stainless Valves??
- Gauging cost on QMP kit- Will I even like it?
- Head Gasket Selection?
- Afr 11.1
- STS ground clearance
- Braking Under Boost???
- How are the Fast LT1's
- Low CR + Boost+ pump gas
- Almost got the motor in.
- Question for people with Griffen FMIC on a Camaro
- Would a T91 work on a Speed Inc T88 kit?
- my 9 sec 787rw 346" for sale
- incon car on ebay
- Alternator bracket
- magnacharger
- twins and plug wires=not good
- Boost And NOS???
- Strange problem here....
- Turbo whine?
- MMS Pulley Problems
- Oppinions on the LS6 cam for blown car?
- How much is 1psi equal to in terms of power?
- 11lbs of STS Boost + New OPTI = COil Over system I guess?
- Diamond pistons
- Olsd School D3 procharger project
- Here is broken piece in my tranny
- Please Help me Select an LT1 Blower Cam!!!
- Boost Question
- electric smog pump subbing for a vaccuum pump?
- Compressor map for Super T-76 turbonetics
- S/C or Turbo?
- Hell fire rings
- Magnacharger with LG Motorsports G5X-B hits 512 RWHP!!!
- Eaton M90 Supercharger on a 3.8L 99 firebird!
- GP deep discount has been met!
- New Ls1 Record 8.11@169
- STS Sponsors
- TTI T-66 kit and fans...
- Only getting 2 to 3 PSI from Stock STS lit?
- Turbine housing size vs RPM
- Pipe shape between turbo and IC
- STS Meth system is screwing up? HELP please!
- Need you SC savvy guys to help me out
- Who is making good power while passing emissions?
- STS on a 2004 GTO almost done
- Effective Compression Question
- Questions about Supercharging
- Need help picking wastegate!
- Harmonic Blaancer Problem
- LT1 FI Supercharger guys/gals
- What kind of cam for forced induction?
- ifr for 60# at 54psi base fp??
- What would you do?
- ? For Those W/ Around 500 rwhp Stock Block 346's
- STS turbo questions.
- took the car for a drive today...SDCE people in here please
- LS1 Fuel Rail GP inside!!
- Any FI guys care to show me your Spark Advance table?
- sdce spring tensioner orders
- Procharger oil?
- One more time -- Cam Motion cam FS
- Where can I find some good turbo kits?
- Opinions on a good blower stall
- STS featured in CHP!
- Bigger ATI air filter guys in here
- Efficiency of the OBX FMIC?
- who has the best meth injection.
- Kissing the Blower Goodbye
- GTQ76 Turbo
- Customized STS Twins
- Pondering the Future
- How much power from these Turbos?
- exhaust on sts
- Were do I get a smaller pully for my Vortech?
- CAS Regulator Owners...
- all those with forced induction
- Larger Turbo Question
- Supercharger or Turbo
- STS and hotcam?
- Pics of amacgt 2000 C5 rear mount turbo
- CAS guys inside
- What Size Intercooler to use for a Front Mount?
- 04 GTO- options for obtaining around 500rwhp..
- How Much low Boost with STS set up and 8.5 to 1 Comp?
- Update on my car,(major diet)
- ATI Balancer users... belt length?
- Crank Pinning
- Pics of the new turbo car
- Turbo EGT
- Willing to trade 3.3, or 3.4 ATI pulley for bigger than 4
- Blitz SBC i-D III (need help fast,,please)
- Turbo Question.........
- Next Level Perf Installed Intercooled Vortech Base Package $6995 thru 12/15
- turbo oiling question..??
- Question for the STS peoples.
- can anyone help out an N/A guy???
- Oil all over
- what do u think?
- 2000silverbullet is dead.
- what after market damper , with STS turbo system.
- Yella Terra rockers With STS Turbo kit
- ATI Guys, what pcv setup you running?
- What happened to all the turbo'd C5's?
- STS turbos and ATI superchargers on sale!
- twin turbo 350
- Extending O2 wired on the AEM UEGO gauge?
- Turbo + pcv sys = ???
- Anyone know anything about the New GT55 turbo?
- To much boost?
- Got a FMU on a STS system question?
- Fawk I think I hurt my motor...:(
- Qmp Owners... Inside
- sic viper
- Need to find a boost only source no vacuum..
- New toys!!
- what i think about you forced induction guys.....
- Exhaust leakfound
- just put a rear mount on a 2000 c5
- Belt Size
- STS turbo system Part sub fram connector?
- Project Turb Hoe
- Another Magnacharger in the 10s tonight!
- Few boost accessories FS
- FS LM-1 Wide band
- Which wastegates
- Need help with gates belt part number
- Anyone know where I can buy a 4 inch cutout?
- STS Turbo with wideband O2
- Pro Turbo Kits > Christmas Sale!
- need some input
- TR224 114..... decent SC cam or should I swap?
- How much boosted RWHP can a stock bottom end handle?
- Choosing the proper turbo
- Finally got on the dyno, what do ya think?
- Need help figuring out how to mount a 10 rib crank pulley
- AMW catch can in FI setup.
- custom turbo kit parts???
- Who said D-1SC can't make crazy power?
- FS: Reichard Racing ultra grip pulley
- Joining the boosted family- buying nasty's kit
- check this out
- what size CI motor are yall running?
- Digital Boost gauges...
- Installing STS mon.
