View Full Version : Forced Induction
- Supercharger help
- Can it be done?
- Compression Ratio Question
- Breaks with boost.
- To bypass near charger or plenum, that is the question ?
- 370 8.8cr
- Got my car back with 180 more hp and damn near 200 ft lb more Tq!
- MagnaCharged 2004 GTO
- Can't decide..304 or 321 for custom manifolds.
- heads/cam with 8 psi
- And so it begins
- Newbie To Fi Need Some Help
- Turbo motor questions.
- Intake Manifold thermal Isolation for Magnacharger
- What gauges to use?
- just got a racegate for my tti
- Update on the 8-turbo ls1
- Reading material on turbo / blower setups?
- Rear Mount Guys! Tell us your Turbo Specs
- Twin kit is 4-Sale
- F1 is here
- Where to buy fittings and pump for a turbo???
- Initial OBX FMIC/Vortech results
- NEED a comparitive LS1 Edit file!
- May end up selling my QMP turbo
- Intercooled by N.O.is this possible??
- what kinda gas mileage a4 guys?
- 12 PSI 93 OCT. 10 to 1 CR Stock motor?
- Turbo boost controllers: Apexi AVC-R
- Hobbs switch???
- LT-1 vortech dyno'd
- Anyone tried mafless tune with boost
- Truck manifold gaskets & flanges? (cat side)
- New to Ls1.. Have a 8rib question.
- Pics of some broke pistons.
- Intercooler help!!!
- Who is running non intercooler Vortech???
- 700 plus rwhp is great but I needed a new Daily Driver
- Procharger from my 89 Formula 350 TPI on my 98 Transam
- Very Confused about Turbo Sizing
- New Guy Quick Q
- Just need a last confirmation
- ATI Owners: is this right?
- what 1/8-1/4 mph gain for 10 sec cars?
- Sts dyno numbers
- Disable DTC P0101 Mass Air Flow (MAF) Sensor Performance?
- Procharger Times
- My TTi Race Kit Dyno
- Supercharging the Z06
- 5-liter-eater Clear out your Inbox
- Do I need to upgrade blower or bypass valve??
- bos....you've got mail!!
- It's Here!
- Got the I/C mounted.
- need help quick!!!!!!!!
- My block was cracked....
- Typical ATI/Vortech Intercooled vs. Ambient?
- leaded Vs. Unleaded
- FMIC's on LS1's..pics
- Sts Turbo Dyno #'s Inside
- best intake manifold and TB for FI
- Best supercharger???
- Single Turbo Z06 Track Results!:
- How much boost on a forged bottom end (10.2 CR)
- Car Cranking Longer Before Starting.
- How does everyone like there SDCE bracket?
- Incon Turbo Sizes
- ATI procharger parts list wanted
- Question about turbos and compression.
- Pics from my Mag install!
- Helical vs. Straight Cut impeller
- Another take on a FMIC install-pics
- Nitrous on top of a Mangnuson?
- help with spark blow out.
- Vortech Clockwise Rotation vs. CCW confirmation..
- catch can results
- Turbo Technologies Race Kit??
- What times are all of you running with the STS kit?
- ? about IAT's on 4.8 with whipple
- Just another day at the track??
- Questions on SDConcepts 8 rib LS1 kit.
- Well I dynoed again
- Tuneing problem with STS
- Eaton/Whipple question?
- Broke a hole in Incon exhaust manifold > help
- Re-installing Incon twin turbos > please help
- WTF, anyone loose alot of hp from ses light?
- who has the fastest s and t trim vortech cars lt1 or ls1
- Blower or more juice?
- Round about cost for a forged 347?
- Boost gauge, mechanical or electrical?
- Lingenfelter already has TT system for 05' vettes!
- Take a look at my heads...
- I've got an FI question
- FMIC Install Done
- Woot!! "overnight parts from Japan".
- 700rwhp Lt1?
- Anyone got a 3.0 hump hose connector and a 3.0 90 degree bend....
- Ls1 Aluminum Block For Turbo
- Twin turbo LT1 track results
- block is cracked
- T3-T04B on a mostly stock 4.8?
- I don't like the concept of a Single Turbo for our cars.. IS TWIN AVAILABLE?
- Vortech's GTO supercharger is available!
- Hey PSJ, why did you change your signature... and
- Need a vacuum source for you boost referenced stuff?
- tsp 231/237 & sts
- Pics of the new GT45.
- FS: (2) Dayco Polycog belts, 40.0 8-rib
- Anyone running a single fan?
- Injector options for a P1sc?
- Looking for pics of Turbo Tech Kit on cars
- anyone with a F1-R
- turbo kit questions
- P1SC parts
- New Toy and a ???? BOV
- What rings?
- turbo(s) or supercharger?
- I need 2 stock rods
- Turbo 403ci with hyd cam= 1329hp flywheel
- Wheres a good (cheap) place to get ATI compressors?
- Phone # for High Temp Silicone?
- Anyone using the newer gtr series turbos
- What Is On The Horizon?
- Attn: STS owners and supporters
- Starting turbo project soon, need opinions
- Just ordered my OBX intercooler.
- Can anyone help with my EVC 5 boost controller?
- For you vette peeps
- Heat soak issues with turbos?
- Head Suggestions for FI on Pump Gas
- Need some help gearing question.....
- 01 C5 450hp?
- sts replaces drivers side SFC! Are you serious
- twin turbo 372 vs tt383
- STS Efficiency
- LT1 ati procharger manual
- 346ci + forged internals + SC = how much power
- S-trim belt problem
- Where to get ATI Blower Crank pulley?
- What Turbos, I aint got no stinkin turbos
- Procharger Dyno'd
- Who makes the most reliable valve springs?
- Thinking of going FI again.
- How similar are Procharger kits on C5 and F-Body?
- How does the LS1 handle Boost? ***pics***
- Newbie need a turbo.
- Anyone tell me what parts i would need to build a rear mount setup
- TT kit for LS1 T/A???
- What psi which manifold?
- A quest. for all STS owners..
- Massive project to start next Saturday, need advice!
- question bout blower mods
- FI w/ Stock A4
- Going to a 2.75 Pully on my Vortech G-Trim, need tuning suggestions
- Intercooler types.
- Build or buy a turbo kit.
- FMIC going in.... *PIC'S*..
- CARTEK's 1016RWHP Twin-Turbo C5
- NA$TY-TA...customer of the month at AP!
- Soon I hope
- SC guys what's your rotating assembly
- GOD is not on ls1tech
- magnacharger
- Turbo Experts Question within
- Removing muffler on STS kit will do what?
- FMIC install on Z71 w/ STS Turbo
- Who all makes turbo kits.
- Will this vortech work ??????
- Boost retard LED not on under boost in 3rd gear...why?
- Mild turbo setup w/ a big shot of nitrous...
- Air/Water intercooler leaking internally.
- 99 camaro supercharger
- sts question
- Wanted: Opinion on bearings!
- Few pics of new custom kit.
- Qmp kit overboosting?
- roots style supercharger
- Blower on top of Heads/Cam...Feasible?
- under WOT check guage light comes on?
- Magnacharger
- Sts Meets Firebird Evolution Plus Intercooler
- Can I use the EVAP connector for bypass valve & boost gauge?
- icon turbo set up
- Need some advice on ATI.
- How far will stock valves take you?
- Questions on custom turbo kit fab..
- LS1 air consumptiom
- 427 block that will respond best to boost?
- Help needed ASAP!! Procharger install question
- Procharged vette over heating?
- Turbo Tech Kit
- Wanna be on Two Guys Garage?
- Upgrade to Vortech T trim from S trim
- would i blow up my car if...
- New Wastegate Here Tommorow
- Difference between vortec kits 98-00 vs 01-02.. need some help please
- Still looking for MMS crank pulley
- 372 vs 383
- Vortech Install Need Help Please!!
- One Last Piece Left 4 Fmic.
- OBX intercoolers ?? R they any good ??
- Front Mount Pics...
- Where can I get a crank pin kit?
- Methanol or intercooler
- TR-6 Plugs
- Front Mount for STS started
- intro - newbie incon tt owner
- ANyone see Ronnie Dukes new car?
- Opinion of Reichard Racing Pulleys?
- Blown and forged 347
- Incon owners oil system ?
- Y do you need Methanol
- Car update!
- Noise
- Downshifting and SC Belts
- MAF problem!!! Maybe.
- Griffen intercooler results.
- PY3400E Dyno
- Supercharger problems
- how much more can a mostly stock 6.0 take?
- Have a Whipple problem on my Silverado
- F.I guys with wideband
- intake tube connection question
- would this be a good cam for a vortech superchager with 14-16 psi
- ATI Inlet Hat Bigger Filter ???
- Need help with Procharger Bypass !
- Sts turbo
- STS Turbo Kit Q's...
- Dark Dragon Motorsports 1998 C5 1200RWHP
- If the MAF sensor is put in larger sample tube, will it read more (1000hp etc)??
- APE Shop Car Getting Closer
- Vortech Vs. Procharger
- Is a higher cfm head really better for turbo?
- How to set a bov?
- ??What's the torque spec for the pulley bolt on the D1SC??
- Need two measurements if anyone can check...
- New record....
- BOV question
- supercharger necessities?
- Turbo FAQ
- just add me to the tti owners list :)
- LS1 Turbo Kit
- Turbo guys, where should I mount a cutout?
- Livernois Motorsports Turbo Escalade Video
- ? on Incon Fuel Pressure Regulator
- For Sale: 42# SVO Greens, only used in Dyno Testing
- Belt Slip difference in the Rain?
- follow up
- FI heads and cam MUCH lower price
