View Full Version : Forced Induction
- Angled Turbo Hose?
- what a/f do you get max power?
- Where to get Procharger oil?
- Hobbs? switch?
- Slight Oil Pressure drop with Vortech Oil System normal?
- Is some SC Belt Dust normal?
- Intercooler who??
- alky tuning
- Can I safely run a ProCharger on my setup?
- OBX TBX3000 intercooler
- has anyone used......
- Drawing through MAF instead of blowing through
- 2300ax whipple for a c5 corvette?
- Boost Help!!!!!!!!!!!!!
- Updade on the Car.
- heads and injectors FS
- Thinking of getting a ProCharger
- Maxing the MAF
- Please post your radiator info!
- Questions on Snow Methanol Inj. Kit
- new use for my alky kit--not tech related
- Turbo (T76) question for the experts :)
- where to get turbo head unit ?
- Land and Sea Dyno Question
- Incon TT Car for sale
- Has anyone experienced this code?
- Alky Injection question
- S/C vs. NA
- ATI Procharger or leave stock?
- how much timing and timing at diferent rpm's?
- I regret getting this FMIC...
- Gears with turbos...
- Belt size selection for ATI?
- Right bank LTRIMS acting weird on startup...
- WTB: P1SC or V-2 SQ or other supercharger Head Unit
- Fuel Pressure Drop at WOT
- What do you guys think of the STS Turbo KIt
- Anyone use Stainless Works?
- This can't be for real!!!
- haha it's the little things that keep me from racing
- ? for CA supercharger install
- STS Tailpipe Question
- An easy way to prevent a lean condition??
- ATI Twin Intercooler Talk
- Tranny is in
- Intercooler has arrived......
- Eviltwins.... YSi?
- Anybody Looking for Dave Inall / INCON ???
- Turbo Oil Question
- Turbo? SC?
- where to buy whipple supercharger
- 1.23 a/r exhaust housing
- Muahaha...sure lets race for money, you can look under my hood...
- Intercooling A Turbo truck
- 688RWHP - Stock PCM - Speed Inc NEW ATI Front Mount Upgrade
- Got my car all torn apart...
- So whats the symptoms of belt slip on a 4th gear wot punch
- One way check valve? Where?
- MAF acting weird....
- Belt and pulley problems? Need Help!
- STS fins????
- turbo setup/custom
- down pipe doesnt fit???
- turbo on a v6 3.8L
- Rumor has it.........
- AutoTap Dyno Numbers...
- What brand belts are you SC peepz running?
- which cam for turbo?
- Any Good FI Tuners in the NJ area??
- Tuning changes for more boost
- Need some RWHP numbers
- Has anyone thought of remote oil tank for a rear mounted turbo?
- any one seen this 900+ rwhp turbo camaro??
- turbo manifold
- can anyone identify these turbos?
- Who is using the stock maf?
- Which ATI damper ?
- logs vs. headers
- Which is better single or twins?
- How do I get ahold of Rob Raymer?
- Wastegate Is Off......
- TBI Whipple HELP!!!
- Noisy steering pump after Vortech install
- PCV w/ turbo?
- Where the Intake pipe runs on an STS
- My alky system
- SC Belt Wear, normal vs. abnormal + pics, Cogged Serpentine?
- STS oil return pump?
- STS users! You running cats or no cats?
- I'm gonna intercool my STS
- How much boost on pump gas?
- You ATI guys know about fans and radiators right? couple questions
- Turbo is on...
- Need FMIC info?
- TT question
- Trying to get in contact with chris@ap-engineering
- Maf Placement On My Car Good Or Bad??
- F.I. cm question
- Stock 98 SS with turbo, what mod next?
- Is anyone running a FMS cam with a blower?
- what should i go with
- New pb and new dyno numbers
- Still Over Boosting....help!!!!
- Turbo oiling system question regarding remote mount filter...
- Toothed SC setups
- Map sensor questions
- Car dynoed low numbers whats wrong?
- cog belts...
- good heads for 98 C5 magnuson
- from ls1 to ls6 heads/cam
- Blower Cam for LT1
- horsepowertv today.
- Question about STS Turbo
- best heads for boost?
- MMS crank pulley
- Newbie Question
- Anyone have SC HP Power Loss #'s for ATI or Vortech?
- Boost Creep - What causes it?
- Why can't I get my QMP kit to finally work?
- supercharged dyno #'s...
- Turbo going on Sunday, need tuning advise...
- Anyone using Non-Stock Tensioner for their SC??
- Intercooler questions .
- Will my combo make my 600rwhp goal?
- Chipping away...
- Yet Another STS Thread
- Think the car was hurt today....
- SMC solenoid? I need one.
- just got off the phone with PTK
- Incon Turbo Hose? Tom Porter?
- Boost Controller with a Centrifugal SC
- MAF placement
- Turbo'd...or Procharged...that is the question
- Ready to buy my turbo, now where?
- Verify this vendor please
- Vortech V9 aftercooler on 98 LS1/SAS problems
- N20 to TURBO 2!
- where to buy methanol?
- Were to buy Mandrel 90's online??
- STS Featured
- Largest Blower experience with Vortech Aftercooler?
- maxed maf idea
- turbo fuel system help
- STS news flash
- Too much boost and Pump Gas Not Good! Meth/Wide Band!
- Fs: Cammotion Turbo Cam
- 5psi on a stock F-body
- LS2 not FI bound?
- Fuel system help
- Anyone who installed a Procharger
- what set up???
- lookin for a turbo kit..
- STS and Z06?
- question for the big HP guys...
- mls 6.0 head gasket set p/n
- Fm13 And D1sc
- What's the max effective CR your motor can handle?
- How much boost before pump gas will not work?
- WTB: ATI idler pulley
- 1500 HP go cart? can that be real
- Low boost in LS1's
- Updates to Boosted List - Help me with Info
- Ordered a few things today
- Would high ratio rockers do much for me?
- STS for a Vette
- Couple things for sale if anyone is interested
- STS / jlturbo.com kit on my 408?
- STS Questions for the DYIer
- Borla XR-1 or Dynomax Bullet for turbo car?
- Good/bad day at the track...
- pics of my custom twin intercooler piping
- A/F & timing with supercharger???
- STS owners, before and after times/#'s Please
- re dynoed today
- Over Boost.... Need Help
- Car is now at QMP.
- Why isn't a Boost-A-Pump or MSD more popular here?
- Intercooler Idea
- pre TB intercooler piping, 3.0, 3.5 or 4.0?
- big power pcv- 3x power = ?
- CC'd my #317 heads. Strange results.
- sts kit pics (not installed)
- turbos don't need lotsa gear
- What size injectors?
- Well I think my luck has run out..
- Going FI
- ATI race ready Bypass or HKS SSQV BOV ?
- STS Dyno Numbers *Complete*
- humm, installed fuel pressure gauge and this is weird...
- turo timer for LS1
- Incon Owners - Reroute Intake Tubing Into Turbo?
- Turbo vs Super charger????
- very, very nice turbo setup on camaro
- For a SC which is better.....
- FMIC went to the track
- FS:ATI Intercoolers, piping, and Polished Plenum
- T-Trim + V2 SQ Hybrid
- blower cam
- ho hum....
- Started project TT (Pics)
- Big MPH, Little guy.
- ATI tuned and dynoed moved up a little more
- Project Update - D1SC Home Kit
- Some changes........
- Help - Fluidampr Problems?
- LS1 turbos extinct???
- TTI Race Kit on the road!!!
- Technical Help: Bleeding Boost
- Vids of my car 5.04
- Vortech Pulley and LS6 Ported Oil pump?
- which setup is a better choice??
- replacement for vortech water pump
- Pro-M questions
- Thinking of selling my turbotech T76 kit
- N20 to TURBO!
- Head unit and changes in cubes
- Wow! Cudos to the Admins!
- sts exhaust
- Which TR55 for blown 5.3L?
- Dynoed the T76.
- Did some logging with the FMIC...few questions..
- hi i want to know some thing ?
- turbo hot parts???
- boost drop again
- STS Turbo Owners - Please Respond
- vortech question
- P1sc guys running 7lb crank...3.2 blower?? belt slippage?
- ati guys 500+ inside
- Stall Speeds N/A vs. FI
- Which Blow off valve is this (vid inside)
- AP Engineering Shop Car Update
- video of shakedown runs...
- what would be better, turbo or supercharger?
- spercharger options
- supercharger sounds
- Anybody have problems with their Autometer guages?
- Difference between Bypass valve and BOV
- anyone w/ vortech have an ultra z hood?
- Who got the highest boost readings from a D-1SC?
- need knowledgeable opinions on forced induction!!
- pcv/breather q's again
- Bigger intercooler results!
- More updates
- Initial SDCE Tensioner Results
- Jet pump, For Scavange on remote turbo?
- biggest cam for 6-7lbs boost?
- drama race angle 2 part 2.
- need turbo help please
- oil pressure for a turbo, Jose, Rob, anyone???
- installed radix
