View Full Version : Forced Induction
- tip for new incon users
- Vortech non intercooled: still happy?
- Twin Turbo Super Sport Z-28
- i need help on turbo .
- Found some boost leaks.
- thinking about a turbo. need some info
- Power Request from Posters
- Procharger Dyno
- Anybody seen this 8 Turbo Setup LS1?
- How dependable?
- Need Your Input on my Boost Fluctuations
- vortech bypass valve options.
- oil from breather hose on d1-sc???
- p-isc.. new fuel pump??
- You FI guys need to see this
- 2 Weeks Left on Street Pro Electric Cutout Sale
- Who has done over 700rwhp? 800rwhp?
- chrged guys
- Supercharger for the LS1
- can i get some help reading these plugs
- What do you guys think about this turbo kit for under $4000?
- Do any of you guys have ls1s w/ reversed intake manifolds?
- Filter sock...
- As you all know the WS6 is SOLD
- Granatelli MAF
- Just got Vortech
- SDCE stuff arrived
- Where to get D1SC?
- pulley tensioner 4 supercharger
- Price BreakDown ATI Kit
- Base Fuel Pressure change and A/F relation
- SC choices?
- Some pics of my TT LT1 SS
- Woohooooo...
- ati bypass valve ?
- Using Iridium plugs on a FI motor?
- Hey guys, help me with my fuel pressure please
- Powerdyne SC
- Tl Bov
- ATTN: SDCE LS1 tensioner guys...info from Scott
- powerdyne SC installing manual??
- What FI guys are going to the north & south shoot out next week?
- Need professional's opinions.
- 13 lbs of boost is missing is part of the problem!
- is this spark blowout?
- Who's turbo kit is Lingenfelter using?
- Alky injection through MAF?
- When installing an intercooler setup...??
- Crank Pulley Needed
- STS dyno #s on my truck.
- Boost, KR and Torco results....
- ATI superdampener, help needed, bolt size
- Need help Reading Vac/Boost Gauge
- Does your car run hot?
- hooking up boost gauge and boost controller
- My project .
- WTF is up with magnacharger-they have kits for the GTO and SSR
- what pistons and rods for turbo?
- Bad Ass Supra!
- intercooler pipe ?
- Turbo info
- IAT temps...
- You thought your turbo setup was badass!!?!?
- crank pulley???
- Vortech crank pulley q
- New to FI
- SDCE Spring Tensioner Update
- Need to check engine timing... help?
- good blower Cam?
- Selling My heads!
- I have to say Good Bye!!!
- Info
- Opinions on my new setup....
- ATI P1SC-1: Multi misfire code
- MMS Pulley, Belt Snapped
- What motor oil for turbo car?
- T-bar style clamps??
- have you guys seen this.
- I have a question about calculating compression ratios under forced induction.
- Didnt get my 1.4x 60' with the nitrous :(
- Major Problems with car!
- frcefed98 any updates
- another day another dyno
- TT-99C5 car cutting out @ 4,500 RPM
- symptoms of lifting head?
- What Emission cam for D1-SC
- FI Heads from Absolute
- ATI Pulley Conversion to MMS Pulley
- Issues to resolve before play-time!
- vortech owners ahve ???'s
- Boosted List updated!
- Hopefully the weather holds and I can try the nitrous tonight.
- boost with stock notched pistons
- heads/cam/blower
- new clutch for turbo
- Boost readings........
- cam for TEA heads and D1SC
- ATI Steel Brack just received
- who is this/info?
- First Pass This Year
- Trade 3.4" ATI pulley for 2.75-3" pulley?
- Break down of turbo sizes?
- what flowrate should the oil scavage pump run?
- QMP turbo customers inside...
- new thread, new video
- Here are pictures of some of the Master Power turbos
- bypass valve or BOV?
- frcefed 98 (Jeremy) Any Dyno Results??
- Picked the car up from FLP today, numbers inside
- Major ground clearance problems with incon install
- How much boost?
- Do i need bigger injectors? Need Advice
- Need crank pin tool
- Anyone want to buy my set up??
- Garrett GT35R w/1.06 AR on the Turbine Side
- twin-turbo or super?
- Where can I found used s/c?
- Supercharger and Nitrous
- what pistons to use
- 1999 Trans-Am QMP Turbo Kit for sale on Ebay
- Hi Im new, also going with FI
- How much timing initially....
- Good source for simple electronic boost controller?
- What is ATI P1SC step up ratio? Also..
- Belt Slip or Boost Leak? Dyno Graph Inside
- Built a Silencer for my Open Bypass this Weekend.
- Bailing Out
- SDCE bracket guys, what's the verdict?
- How do I change my D1SC Oil?
- Worked on some math for pulley sizes for the SDCE guys
- Need help choosing cam
- I have a confession to make..
- Fuel Pressure still dropping
- FAST E-dist and Crank Trigger box?
- How would a t-70 work for me?
- heads/cam procharger guys....what power are you making?
- What size injectors...
- Procharger: 0 Boost
- FI Blues........
- MMS 218/228 cam
- props to ls1speed
- new best short time & et.
- Extreme-G '69 Camaro updates!
- LQ9 6.0 heads?
- Turbo impeller rpm...
- Cast iron manifolds for a turbo?
- d1-sc crank pulley sitting flush????
- question
- Want a supercharger, have questions?
- Help Tuning SC, LS1 Edit or HPTuner
- Powerdyne supercharger
- Found someone crazier than Harlan - 8 turbos?
- Whipple Indicator Light and Service Engine Soon Light
- SDCE Track testing within......
- Kyle (NASTY-TA) dyno?
- Going standalone FAST for the blower setup
- SDCE PEEPS, Question before I hit the track...
- Heads for FI
- Looking For A Turbo
- T trim in place of S trim Vortech?
- 725RWHP - Stock PCM
- 895.3 Rwhp 347ci .......
- best turbo kit with pics
- Oil coming out of the discharge on my D1sc?
- vortech heat exchanger questions.
- fi new motor break in ?
- STS turbo pipes
- Coolant overflow?
- Anybody got LS1 S/C BOV sound clips?
- best setup for mild mod car
- t76 exhaust flange question
- Difference between P1SC and D1SC
- Qmp 623 Hp Z06.
- Turbo INFO PLEASE!!!!!
- qmp users inside
- best way to sell ati intercoolers/plenum
- Anyone know anything about the turbo depot kit?
- progress pics for my FI buddies 5.25.04
- Front mount intercooler
- Question for the Turbo guru's...
- Pully changes need some input
- paging frcefed98
- Vortech 8-rib Pullies
- 623hp w/ 7psi
- Turbo setup question
- I'm joining the FI club
- Help an WS6 Guy
- Prep for procharger?
- H vs. X pipe w/ Forced Induction
- Turbo headers
- Turbo + Nitrous
- turbo or supercharger
- CAS Regulator (FI Stroker)... where do I start?
- 1969 Dodge Charger
- Question about SC
- The RICE ETER Special... Almost done
- Need help with turbo cam
- FMS Blower Cam for sale
- The sound of FI
- Custom ATI 3" hard pipes
- ATI or Vortech?
- Or I will sell entire car $19,500
- FAST system FOR SALE
- ATI F1 with ATI race valve and FMIC for sale
- Notes, Pics And Info On Our Tensioner
- FAST users ... timing
- ASP Cogs???
- Forced Induction Parts for sale
- big problem
- Need advice on blower cam
- help with valve springs
- Still looking for a MMS Pulley
- Anyone have a 3.8 ATI pulley for sale?
- VORTECH Owners Where is your IAT Sensor?
- Supercharger sale at TBYRNE Motorsports!
- recently ordered head/cams - now adding turbo on top
- SDCE finished....
- Turbo guru help needed - leaking coolant!
- MMS Crank Pulley Going Rates
- Going full standalone FAST, have some gauge q's...
- dynoed sts kit today
- So You've Heard Of Corky Bell, Right?
- S/C with 112 cam
- What exhaust to run to reduce back pressure.
- where is your wideband?
- SQ g trim failures?
- blow off valve for vortech system?
- Procharger Dyno #'s
- 10lb - 15lbs on Ttrim instead of D1 ATI
- Turbo truck Dyno numbers
- What should i run?
- Incon car going into shop, need help with details...
- How much boost should i be able to make??
- PIc's For You Guys
- Just Ordered My Forged Shortblock!!!
- Centrifugal superchargers?
- Vortech G-Trim SQ version LOCKED UP!
- revolutionary ESC™ 400 Electric Supercharger
- Is the D1SC generally louder than the P1SC ?
- Heads for F.I.
- FMIC Questions????
- Turbo experts please.
- heads up
- FAST/Gen7/BS3 Users, jump in here....
- pulley wobbles??? what do i do?
- kyle F...need your.mil addy again...
- we now return to our regularly scheduled programming
- sts dyno #'s ???
- Belt for ATI doesnt fit
- Boost Controllers?
