View Full Version : Forced Induction
- Anyone here installed ATI twin I/C P1SC on a C5?
- "Get Blown." T-shirt now available
- Boost-A-Pump Warning!!
- NEED TO REACH y2khawk ASAP!
- Procharger CARB #
- Ram air or Cold air???
- Help with new FI Set Up
- Looking for a 4'' Pulley
- Paging BIGBOS
- KAOS is born
- tuning with edit for supercharger
- Weights of FI "kits"
- Turbo stuff on ebay!!
- Ati D1SC setup
- bov question
- Boost gains, any gains from LS1 intake to LS6?
- STS Turbo
- Have some ?'s about turboing a LS1
- qmp turbo kit =bad news
- Incon guys - what did you do with your power steering lines?
- newbie to LS1/V8 FI - starting point questions help request
- HPP Article on Ronnie Duke's T/A
- All Incon Kits come with intank fuel pump??
- Im feeling the FI blues!!!!
- TTi guys with 3" DP
- Welcome smokinhawk as moderator
- Breathless shoot out videos
- Extending MAF with MAFT good or bad idea?
- 2001 Suburban 5.3 W/ Magnacharger
- QMP 728rwhp Formula vs DLM 921rwhp Viper GTS
- Pics of my turbo LS1 67 Camaro
- whats the best turbo fuel out of these choices?
- FI Consensus Questions
- Cog Update 4-20-04...
- Race gas question
- Nordskog Digital Boost Gauge/ Lucas 38# injectors F/S
- Install Vortech ya or no?
- Potential Power with current fuel setup.....
- Question about vortech?
- Anyone spray an ATI with a 5177 kit?
- How many of you guys have your boost gauge here?
- Pickin a super?
- The Future Turbo Life of my LS1
- How are you guys achieving 8.5:1 with a 3.905 bore?
- Need Help Picking Guages!
- Supercharger Upgrades
- Do intercoolers add power directly?
- 8 Turboed LS1
- Reichard Racing pulleys
- Best Way To Achieve Desired CR?
- best place to tap in for boost gauge?
- How much boost?
- Procharger
- what you guys run fuel pressure?
- What heads and cam for vortec ?
- New best on regular $50.00 radials :)
- how to build more boost on the launch with auto
- turbo truck runs good first trip to the track
- H/C setup or ATI Procharger?
- TT questions...
- Cam choice / turbo choice for solid roller 409CI max effort
- ProCharger Dyno numbers
- Turbo Sizing/cam selection Confusion
- Results with SD-concepts pulley set up.
- C5r + T101
- Forged 6.0 iron block buildup
- Boost vs. Compression.
- GP on SD-Concepts Spring Tensioner Kit
- Long time no talk....Turbo Formula Update
- Procharger Questions
- STS Turbo
- Update on my APE Motor and Fuel system PICS
- Blower Belt
- Supercharger and a Auto
- Car Dead, Plz Confirm - Autometer Elec FP Gauge
- Need a question answered
- Pro Stock John
- My Custom ATI buildup - Update
- Track Times
- Larger Incon CHRAs for Sale
- how much can I squeeze out...
- Tuning with STS
- adventures with a turbo
- Sold a procharger to Buck Owens
- Where to buy turbo kit?
- Question about on CR and turbocharging
- Turbo on SS
- Looking for a couple electronics parts. :)
- Boost with High Compression
- more boost or timing?
- what to do next...
- Optimal Compression?
- Cam or rockers?
- Thanks Might Mouse and Turbo Tech!
- Procharged returnless fuel system problems on H2 hummer kit
- Where to buy a weld up header kit?
- Emissions Legal Turbo
- Supercharger on EBay
- Paging NBM00WS6
- Installing ATI: damper question
- ATI Crank Pulley backed out
- What size pulley do I need?
- gap on plugs?
- What to do now?
- ??Question about SD Concepts idler tensioner for ATI??
- Rear turbo???
- incon users
- need ideas on supercharger and pics of differant ones installed...
- procharger F1 bracket questions .
- my turbo set up
- 02 ls6 cam-cheap blower cam?
- Charged Air 15psi Dyno results....
- Calling out Harlan!
- 6 Speed Guy's with 500 plus RWHP....
- ATI Super Dampener Question
- Copper Head Gaskets
- Harlan, question on vette fpr
- 10.96 video from last weekend
- LPE 6 speed 427 TT goes 9.4 at 151.87mph
- Pics of my FMIC ATI Procharger Setup
- pump gas goal accomplished tonight.
- Ws6rufus
- FI Motor for sale
- FREE ARP head bolts.....
- Easy solution for D1's and cruise bucking
- What type S/c For almost stock?
- D1-SC, 348cid + 6-Rib hits 9's @ 142mph - No juice
- Blowed it up last night :(
- Boost Change
- turbo experiance
- My results of 408 stroker ( Thanks for everyones help)
- Any turbo guys wish they had gone with a blower, or vice versa?
- Which Turbo Headunit would be better???
- Twin Turbo Guys Inside please. Need pictures and turbo sizing
- ASP Cogs V. Spring Tensioned 8 Rib
- Selling my turbo kit
- Ati P1Sc Belt Part number
- got my car dynoed
- Where to spend my money....opinions?
- Cam Motion Turbo Cam for Sale
- N20 to FI
- P1SC Twin intercooler or single FMIC
- Pilgrim's Progress (by author)
- Automotion Steel Brkt.
- Which MAF should I use for FI Tuning??
- need vortech v9 gtrim head unit
- should I get a supercharger?
- Rear Mounted Turbo Setup
- TT 427 Projexct
- ASP Cogs?
- HELP with torque converter for my supercharged vette
- z06 with d1sc ran 9.82@ 142
- how did this turbo launch happen?
- dyno #s
- Need help with fuel system
- new #'s for p1
- I need help picking a cam
- PTK has released some pricing and info on the LS1 F-body kit.
- Twin Turbo Setup
- Paging ATI owners...help with ATI crank bolt ASAP!
- Need opinions ASAP please.
- Ordered my Steel ATI Bracket
- Harmonic balancer pin kit needed.
- Forced Induction Cam up for grabs!
- I need some help with my ATI belt tensioner...
- DFI gen7 questions .
- disassembled my engine last week. rings.
- Vortech Question
- opinions on cam
- Which pulleys with no belt slip on ATI?
- which plugs/gap with ATI
- Finally got in the tens :)
- Unleaded Turbo Blue at the pump Cincinnati/Dayton
- Help identify this turbo?
- New setup what do you think
- My new toy
- STS Gtech 0-60
- Head swap.
- How do I figure out which turbos are which?
- 10.77 @ 138.86
- Newbie,How long to install 7# ATI?
- 78mm FAST Intake & ATI Results
- Can someone explain compressor maps?
- STS 2psi Et's
- What is the dyno record on pump gas?
- Automotion Steel ATI bracket showed up...
- T-76 guys, What size wastegates are you using?
- FI head flow
- New numbers...
- qmp kit
- Turbo Kit?
- Iron Heads on the QMP Turbo Formula
- ??How much is the procharger/magnuson crank pinning kit..??
- pics of ATI crank pulley installed?
- Procharger guys,ATI+GM Warranty??
- How are your cars idling with the Mototron 60's?
- 8.7:1 or 9:1 - Help Me Decide
- ATI Procharger decals
- vortech supercharger repair help needed
- ** Do Turbos Care If????
- Best oil weight?
- over 1 year no CAS TT
- Electric Supercharger
- Selling the Procharger . FI change
- got a leaky head gasket, help with options
- Procharger guys (Interesting read)
- Another FI Fuel question...
- help please
- rob raymer
- spraying nitrogen on intercooler?
- a little different fuel setup
- what turbo for a ls6 camaro?
- Anyone have a ATI(s/c company) crank pinning kit I can rent?
- Holy Crap!! LS1 STS Is Installed
- Cam Choice, Twins ... Poll
- Cog Pulley Update 3/30/04
- Turbo Pics Please
- Ford newbie has questions
- MAF location with multiple turbos
- Progress on my car...
- Worth swapping out stock cam for 216/220?
- Just ordered the new D-1SC 8-rib setup
- 6-Rib D1-SC and 10 Sec Times
- TurboTech wastegate question
- 1/4 mile times w/ turbo
- Aftermarket MAF or MAF Ends with SC?
- dyno vid from sunday
- Front mount intercooler for Vortech?
- Sat in PSJ'S car today.
- FI Survey - What size injectors and power level
- DIY water to air intercooler
- Advice for a 600rwhp turbo setup?
- HP inline pump vs. intank hp pump
- QMP Turbo Formula....LOT's of Interesting Stuff...
- Anyone running a FAST intake with their blower?
- Stuttering at part throttle...
- External Fuel system help ??
- read and heed
- fi vs big ci
- F'ing ATI
- what's a good head and cam package for ls1 turbo
- How much boost
- How are these numbers for stock motor, 6 psi?
- Any turbo technology knowledge?
- need pro charger information.
- Supercharged Throttle Body.
- Waiting Part II
- cam selection
- run this by the FI guys..
