- Modular Turbo PS line kit installed.... on a PROCHARGED car... (pics)
- ported ls6 heads or different heads?
- Who sells Stainless T4 flange to 2.5" pipe assy?
- cheap procharger
- 5/16 or 3/8 Pushrods?
- Sc 1995 firebird
- LQ4 Procharger Build Question
- gusset plates or not?
- procharged f1 ls2 killed the thrust bearing
- My build thread - TC78/LS1/sedan from Aus
- got car back today, traction is an major issue
- C6 Edelbrock E-Force Supercharger Install
- d1 or Turbo?
- Questions about my turbo oil drain
- any pics of enclosed procharger race valve
- leaking oil
- LSX 427 radial RX3
- turbo 5.3
- maf confusion
- what 72cc factory head for my 402 on 15#'s max?
- LS6 vs LS9 cam for S475 turbo LQ9?
- Which IAT sensor for turbo setup?
- Has anybody done a roots blown LSx?
- who's the dickhead closing people threads for nothing?
- lowball me on what this set up might make
- TC78 fitting sizes
- Having tuning issues with vortech V1 setup
- Splitting the Intake Pipe
- 94 383 SBC to 5.3 PT76 Build Thread
- Adding an intake spacer for clearance?
- Looking for dual 4.5" IC's
- Thinking about using PRC LS3 heads for a moderate boost application (15-25 psi)
- Dual 38mm wastegate placement
- should i go boost or bolt on?
- fmic question
- Supercharger question
- Any "small" 5inch mufflers for downpipe?
- Using proportion valve on front brakes to build boost w/out t-brake?
- is a 600+ turbo car good for a DD?
- PCV drawing and question
- T4 or T6 Flanges
- purely out of curiosity.... 750rwhp...
- how much power are u making with only one ati side pin?
- D1? Or P1?
- CAM Selection what would be your choice?
- Opinions welcome - my turbo build
- Tell me if my parts list is good or not?
- Ball bearing or journal bearing? is it really worth it?
- Gm high-tech supercharger wastegate what do you think
- turbee or not turbee
- Turbo gears
- How much power on '05 LQ9 rod bolts
- Start with 10 PSI?
- Turbo and emissions?
- Stock Shortblock Shootout updates and competitors thread.
- Advantages of going 5.3 over LS1
- good heads for procharger?
- Our latest Turbo F-Body accessory
- Guys running LS7/9 head gaskets...
- A4 with STS build
- How much power will this fuel system handle?
- whats needed for tt build
- a few gear questions (2.75)
- Valvespring choice
- 408 PT88 Turbo SS Camaro vs 364 Procharged G8 GT
- Cool weather & boost !!
- Pushrod Question 5.3 w/stock heads
- 91 Octane vs/ E85
- FI and stock ecu, wiring in a swap?
- APS C5 Corvette System - Scavenge Pump Issues W Smoking
- Placement of BOV???? DILEMA
- My twin turbo vette went up in flames
- Whats the record for F1R LSX?
- guesstimate my HP
- Real Boost and Horsepower Limit of a Stock GM LS Engine
- Boost lt1
- ARP Head Studs/LS9 Gasket?
- 408 Pt88 Turbo SS Camaro vs 408 S85 Turbo SS Camaro
- how much power will I gain?
- I am bored...ummm now what?
- How much boost will 42 lb injectors hold
- What i need for a F1C procharger to fit.
- Tech: Wastegate position sensors
- A4 boosted cars in here please
- 9.46 with a tc78
- Ok do's and dont's. Replacing Procharged Ls1 with Ls3
- Should I run my master power t70 with an lq4
- Boost Controllers
- Who sells LS7 intake flanges?
- Procharger Fuel Management Unit Question
- LS6 intake to LSXr Intake what bumps in power have folks seen?
- Fan Combinations for FI Cars
- Help me with cold side piping size
- Turbo or stroker?
- 69 Chevelle Engine Mount bracket?
- lq9 procharged questions
- Pics of a CAS twin turbo
- What parts in my parts list here are overkill on a 15psi single 70mm 4.8 turbo truck?
- What head gasket?
- rebuilding car, what should be done with motor out
- Pics of my soon to be turbo'd LS1!
- should i ditch my procharger setup and go turbo?
- Is turbonetics 10975-bb too small for my setup??
- Autolite AR3911 plugs and 15psi+. Anyone using these?
- 317 issues
- 4.8 w/317's
- Looking good for a 2012 LSX Series...
- How much can a stock LQ4 take?
- Help me turbo my LS1 jet boat...
- Dual bov for twin turbo build?
- Oil how to
- Front mount turbo with a/c almost complete PICS
- 3" vs 2.5" crossover pipes....LETS LAY IT TO REST!!
- Whipple in a camaro
- max psi on stock heads?
- 5.3l turbo build
- Stock Bottom 5.3 Selection for 15-20 psi - mileage?
- question about garrett 76mm
- What are the Pro's and Con's of Water Cooled Turbos?
- ARH / Farks Supercars Wins the Gen 5 Class LSX Shootout
- procharger and tc
- 1500HP recipe drag only turbo build
- intercooler/cold side piping
- 2001 ss twin turbo build
- Who's going fast on 17inch or larger drag radial?
- spoiling twin t76s
- You guys are gonna shoot me: 95 Z28 V6 turbo swap
- change to turbo setup?
- Forced induction LSX need ignition box?
- Does Kenne Bell make a blower for the 98-02 Fbod?
- 9s with auto swap
- tial 44mm wastegate routing? help
- Shopping List for 2000 C5
- lq4 garret t76 need advice
- th400 converters
- So I picked up my CBR Twin kit this weekend...
- Ive out grown the bottle....
- Thinking of swapping out my Turbos for bigger ones.....
- Cam Selection Help
- So we DID NOT let out at 1100 feet
- Best place to Buy 2.90 Pulley?
- twin turbo and a 6 speed?
- procharger twin intercooler install
- where do I send my car for a custom turbo build???
- factory head choice, 15psi
- 799 head combustion chamber size
- Any one run a ball bearing turbo without water?
- procharger on stock rear?
- Uggh... Cam Help PLEASE !!!, LS3 Heads/410ci/m6/Twin 67mm turbos
- Need a decision...What would you do?
- Custom G8 GXP TT project
- Bearings bad?
- Blower Pulley
- Compund (series) turbocharging
- How to get LQ4 to 8000rpm semi reliably?
- Lack of power with ProCharger?
- which intercooler kit? help
- "Spool Vlaves"?? Lets talk about why and why not...
- maggie for 7-800 hp??
- Procharger kit from brute speed
- STS turbo for my setup? - Need to pass Cali Emissions
- cam for MP 122 maggie
- injector size
- **LMR TTG vs Hennessey TT Ford GT**
- What hp rating is the new turbonetic HP67's? how do they compare to the new precision
- What's the fastes stock cam and boost car
- Crane 224/224 .551/551 114LSA for turbo 5.3
- The results are in!!!! And I'm a VERY happy camper!! D1SC tuned! **Videos Uploaded!*
- APS TT C6 w/ upgrades
- Mixing E85 and pump gas thoughts
- BMR Turbo K-Member Group Purchase? Yes...
- Would this be a good upgrade for a 6.0?
- Question about mounting IAT Sensor, Depth. And why after meth?
- advice on two setups
- Stock zo6 procharged reliability?
- LS9 headgaskets ?
- Modular Turbo oil drain kicking my butt
- Hx55 questions
- Throttle body to fast 102mm
- Turbo questions on Trans Am
- 799/243
- Need CO2? Twin 6765's on 427 and AMS 500
- where to tap into for turbo oil feed line? steel pan not stock
- I may have High Exhaust Back Pressure Issues...
- carb or FI with TT setup
- Impressive A&A kit + Meth results
- Mass air flow Question
- Turbo MAF or MAFLESS
- turbo build questions, help, and advise
- Info on pinning/dowell the main caps for crank walk?
- help..another heads thread. aftermarket only!
- What heads to use for ls1 turbo build
- Wastegate help/advice
- tc78 vs st80 on a 370??
- STS or Custom??
- Anyone controlling meth with the eboost controller?
- What fuel should I use???
- Please help with injector size..
- AtomicFusion 2.0 Official Twin 88MM 2500+hp build Thread
- Draw through STS/remote mount turbo kit?
- Camaro s475 TURBO build.... LOTS OF PICS
- LS1 Turbo Build 69 Chevelle post your pics!
- turbo 5.3L fopxbody. post your pics
- Need help with parts for 370 turbo
- What cam for my turbo build? (List to choose from)
- PRC 227 Heads sell or use them?
- B/W S400-75 (1.10ar) T6 vs. MPT76 Q (.96ar) T4 for LQ9
- Check this out: Hose Candy
- FI guys, I need the "skinny" D1SC/LQ4
- Finally....getting a tune! D1SC. kinda nervous lol.
- Help needed- Procharger Air Inlet Hat
- is this kit worth it
- going to do rear mount turbo
- Lastls1-Speed Inc at LSX shoot out.
- ls1 350z turb0 feed help!!
- BOV no noise?
- Dose anyone have a part number for fan male connector ?
- Holset Ht60 turbo feed size?
- chasing a set of truck manifolds
- Front mount intercooler with AC
- Procharger/Vortech Maggy wanted!
- Coating combustion chamber and exhaust ports?
- Koolrayz Wild Ride
- Heads question.
- help me get hi figured out...trying to get a tune this week for my D1SC.. :(
- Any inexpensive T6 turbo's?
- ST80 347ci dyno number on 10psi !!!!
- BOV opens up as soon as I start the car
- So we let out about 1100 feet and hit the brakes
- Holset ht60 turbo. Any insight?
- Tried to put it on Kill (vid)
- C5Z with G5XB in n/a form
- 85mm maf to procharger inlet
- Need a 2.5 bar map
- lsx turbo sonoma track times
- Blown head gasket?
- Twin-Screw/Roots Superchargers
- 6Speed Boosted Guys....
- Twin Garrett T3/T4 .63ar 57trim turbos on a stock LQ9?
- Confused. Vented or sealed catch can?
- stock 5.3 F1A w/ brute speed cam. how much can it take?
- please help with turbo ls1 build
- Can i mount IAT Sensor in ls6 manifold? then meth nozzles in throttle body?
- Got it tonight!! 9.86@145.5 PT7875 Street Car
- log manifold question
- who here has maxed out an 88mm turbo t88?
- Supercharger wanted!! Vortech Procharger etc.
- Vengeance Racing Builds Synergy Green 2011 Camaro. Whipple/Cam/Fuel/Rear/Susp/Meth
- where did you buy your turbo from
