- HR Built Procharged 2002 Camaro SS: Cam/D1SC/Exhaust
- gt55 turbo and a 5.3
- Turbo Build Ideas!!! Opinions and suggestions Please!!!!
- turbo leaking oil externally. not feed or retun. ????
- Wtb 7/8 sec single turbo camaro or cobra
- D1SC on a 383 with 10lb - joke!
- Anyone used Probe forged pistons for high hp?
- Whipple Supercharger for the Gen 4 F-body
- oil cooler block off plate
- new to turbos few questions
- Wastegates dumped? Anybody got a sound clip?
- If I were to turbo the Z06..
- blown 454 lsx ?
- riddle me this
- Turbo kit
- Converting Ebay hotside kit to T6?
- What turbo for forged 5.3 with AFR 205's, cam motions turbo cam, ls6 intake ported tb
- procharger inlet options
- Will I have a problem with valvesprings ?
- procharged silverado vs lt1 trans am on spray
- 5.3 turbo bilud
- APS Twin Turbo Kit install help
- What is a slip discharge?
- twin 88s or 106mm or 118mm turbo
- PT76 Stock bottom end LS1 717/720 12.5lbs
- 100MM MAF guys - please reply
- chinese turbo track times
- oil pan drain for turbo... think i fugged up
- 408 and pt-88 ???
- Turbo peeps, step inside...
- Your thoughts/warnings on this set up
- precision vs turbonetics? anybody done a comparison on the dyno
- LQ4 or LQ9
- Holy $hit, Twin turbo, Trans brake vids.
- STS possible exhaust leak???....video inside. UPDATED with P0300 and ex man temp scan
- I need a .055 thick head gasket
- Want a Free Tick Performance Shirt? Guess the RWHP of our latest ProCharger Install!
- Hps 2012 Twin 88 LSX Drag Radial Racecar!!!!!!!!
- p1sc going from stock 75mm maf to 85mm 5 wire questions
- Hell yeah!
- some pics of my progress. D1SC, Big Red, FMIC...ect.**More pics/vids Added!!**
- looking for a new intake manifold
- 406ci will this turbo work
- TC76 rear a/r sizing on stock 346?
- anyone running a Lingenfelter 100mm MAF?
- For the very few...
- 402 F1 Firehawk Start Up
- High compression and Boost question
- combo help?
- exhaust on 427 + TVS2300
- Stock vs. Forged Shortblock
- some pics of my engine bay
- DC Power Engineering 185 amp alternator work with procharger
- tvs for my 5.3 in 67 Chevelle
- Twin 70mm or 76mm spool on 5.3 on the street?
- Front Mount build thread. Stock Shortblock, TC78, 6spd. Numbers/Vid on Page 3!
- good low boost bov?
- best stock block platform?
- Hoosier drag radials
- Why not to buy cheap BOV's
- FI on M6 or A4, whats better & safer..?
- selling my 05 vette procharger setup
- front mount t76 346 ,what convter?
- SC a reverse-intake LS7?
- Rear Mount Oil Leak
- Attention all stock shortblock players!
- which turbo set up should help me
- Damage in turbo sts
- Just a farmtruck... nothing to see here :)
- Plan on taking out some fast imports next year.
- 317 vs 243's for a 5.3L TC78 setup
- PT7875 times finally, 10.01@144mph
- turbo or procharger on 5.3?
- Lets talk turbine wheels and "trim,"have some questions.
- trying to down size turbo, need some help with physical sizing
- Boost Spike/Drop
- 370 what turbo?
- turbo engine build
- Could it be? Finally an 8 second pass?
- Im after your opinions on a Turbo for stock 346
- FMIC Procharger help
- Keep 241s or go 317 heads
- Air Filters.
- What piping kits are you using?
- Procharged LT1 - Dyno results
- A year ago today I took the stock shortblock record...
- High HP guys with 4L80's come help me out!!!
- SuperCharger
- Water to Air Intercooler @ -100F
- magnuson supercharger parts?
- Should I run meth?
- Single or twins
- **Corvette with custom 3.6L Kenne Bell By Late Model Racecraft**
- turbo cam question
- kpa to boost chart
- 5.3 t70 KYTP build thread front mount
- Has anyone actually run a comp turbo on an lsx?
- 05 corvette procharger
- How much boost on a 13:1 408??
- What spark plugs for Procharger
- street use/ok to run turbo out nose?
- D1SC auto guys, what stall are you running? Heres my situation after baseline passes
- looking for pics or tips on turbo oil drain and valve cover venting
- Version 2.0 H/C/I to Procharged D1sc?
- Best Heads for turbo 5.3l D.D ?
- Problems with T4 Gt91??? wont make more than 6psi!!
- APS twin or STS singal turbo on stock internals?
- Lt1 diy turbo build....yes another one
- how i ran my line for my electronic boost gauge.
- Where to find Tial 44mm wastegate flanges - mild steel?
- 5.3 turbo questions
- Blower choice
- F-body Twin Turbo Rear Mount...
- FI-98X....question
- what rings/bearings for my motor
- Quik Question on 2011 Edelbrock Blown Camaro
- Keep my 76gts or go bigger?
- help I have ls1 turbo borgwarner.what is AR Appropriate for my ls1?
- S480? too big for a 6.0L??
- 1990 Mazda RX-7 Street Car (turbo LSx, Powerglide, 8.8")
- 1000hp kenne bell ls3 for rpo
- Anyone Run 8s with an F1 Procharger??
- T56 vs.4L80 @650RWHP Who's had both?
- Need turbo/motor build advice.
- cheapest 5.3 turbo setup possible
- 408ci T76 Setup Question PLEASE HELP!!
- LS9 cam ok for single plane EFI intake/remote turbo?
- General thread for Modular Turbo kit builds.......
- cheapest meth pump..............just need a pump
- Help me hit 1000 hp (turbo & fuel help)
- Considering doing a rear mount on my stock LS1. Opinions?
- aps/incon coolant adapter??
- Discontinued Vortec Supercharger?
- turbo/blower
- Boost reference
- ARH/Farks Supercars 2010 camaro runs 9.42 @ 150mph!!!
- Need help with turbo 5.3 in a 2003 silverado
- VACUUM issue
- Will a 2.5 in intercooler be To restrictive ?
- Rear main seal - install forward or backwards?
- 402ci,TFS 225, APS W/LG turbos and 4L80
- Silvolite hypers... have some questions
- Injectors in intake pipe...
- *intercooler piping size?*
- kinda of in a pickle
- Will I overspool this setup?
- APS guys what exhaust are you running?
- 408 - pt88 SS Camaro vs Cam, Stall + full bolt ons + 125 shot Trans Am
- need advice on my build
- 1991 S10 with 72MM
- magnacharger or new car ?
- Hows this for forced induction...
- Check My Drain Placement
- Finally ready to dyno ,big thanks ...
- 370 ci forged pistons. what brand and gap of rings?
- Looking for BS3 initial setup help
- on3 turbo
- 370ci / PT7875 / 4L80e / Stock Heads / 706rwhp / E85
- spark plug? for 383LT1 DISC 10psi 8.5:1
- Rear mount or Nitrous?
- 11-1 compression + boost = boom?
- Gear ratio help
- This is gonna hunt all yall down!
- The Burkhart shop car is ALIVE!
- What set-up will go 5.30s in the 1/8th mile?
- My replacement for a Vic Jr and an Elbow...
- Any experience low hp due to dented in dp?
- s472 or s475 on 6.0
- Turbo question
- 6psi on stock injectors?
- 92 Z28 LS1 Front Mount Build/Resto
- What exhaust wrap?
- UPDATE:HPS Rear Mount-746rwhp-600rwtq
- The twin turbo Z06 build from Hell finally done!!
- 370CI T6 or T4 Turbo
- Pro charger Pin kit for rent?
- I think my Transbrake is too slow...
- '69 Nova Track Numbers - 4.8L W/ TC76
- 99 Z28 "stock" ls1 +76mm A2W ebay build
- need to change the rear seal on tvs 2300
- hellpppp,,,i got a misfire only in boost!
- who has built a fm truck manifold kit and kept sway bar
- 408 tc78 build question
- i need a blower pulley!
- My long term project-672" BBC twin 94's
- assembling -20an lines help
- is this turbo or crank case problem...?
- thoughts on cam choice
- Questions regarding my 408 F1-A setup! ***Updated 10/18! MORE ?s on Post #16***
- sts and keeping catabck?
- whats the user name for the guy who works at Speed Inc?
- What i planned on using as restrictor plate
- Turbostive kicking butt in 2011 hot rod drag week!!
- intake/tb worth any significant gains on my fi setup?
- vrx5 & 5.3
- Bad truboost solenoid?
- Lq4+Turbo capabillities
- LS7 for boost w/good internals, would the material between the cylinder be the issue?
- Help me with my check valves (PCV and Brake Booster)
- inlet hat
- My video build of my car with some driving!!
- just bought a low oil pressure engine need help with rebuild
- PCV Issues.. Need some input
- Turbo + Nitrous nozzle or DP?
- Finally a vid...
- New C5 Corvette
- lq4 with 2 gt3582rs
- Non Braided Flex joint
- Which 2 step?
- Bypass Valve Blow Off Valve.....Please Clarify!!!
- Need some suggestions on winter project.
- AES 390-D1SC-3.4 pulley~10lbs of boost
- twin turbo garret t04z
- GT55 Turbo & Cooling Issues!
- 2 Bar replacement for OEM gm map sensor 16212460
- How much is this LS2 long block worth?
- New personal best. Vid link added.
- Rocker Arms
- Questions on gate placement: PICS inside
- Which plug wires for boost?
- Did anyone come up with a good fix for the SDCE bracket on a iron block?
- Power Steering pump in the way?
- Boost spike question
- Forged 347 or 383 with S400-HP88
- 5.3 turbo build help...
- Turbo size for twin 347
- Would it even spool?
- Pulled the trigger on the FMIC Treadstone TRV259O **Updated** more pics. 11-14-11
- What's the best pusher e-fan setup?
- 341 rwhp... i was expecting more
- Turbo Drain
- truck mani guys how did u route the dp? stock k member and motor mt
- Supercharger vs Turbo
- Goal 700+rwhp/tq w/ KB 3.6L Stroked 6.0L or LS3?
- not making sense anymore.. help
- Ughh another 243 head thread.. to use or not..turbo
- Best turbo and cam recommendation for 71 chevy shortbed LQ4
- s475 too small for 410" stroker???
- -10AN turbo return in pan 1/2-14 tap. drill size?
- Catch can rounting for procharger...
- supercharger hepl
- supercharger hepl
- About to start my front mount turbo build
- Boost referenced Propane fueling
- c6 manifolds
- anyone making big power on holley intake?
- Only getting 11 psi,comp 8079,370 ci
- Conventional or Synthetic Oil
- "Things you wish you did prior to reinstalling your FI engine"
