View Full Version : Forced Induction
- Borg Warner S480 Standard vs Compact Cover
- Holley High ram in first gen camaro
- pulling the trigger, need advise
- 2004 cts V 80mm cx racing turbo build
- MS3 Pro setup on twin s366 build
- Procharged 64 cutlass question
- another boost by gear thread
- Rod bolts
- Blow-thru e85 5.3 timing..........
- Procharged Header opinions
- s475 fittment to ON3 kit
- Get Turbo'd CHEAP! ~Huron Speed V1 Truck Manifold Kit
- Making big power with stock truck rails?
- 3800-4000 fti stall and boost
- MM Catch Can Question
- S10 turbo - forward headers
- pics of co2 set ups and what size line?
- Insane NOS ls/vette build: Runs 4.30's in 1/8 and street drives it
- 700 whp Procharged ls3 Trans am - in the 10s
- S475 346ci Turbo Bird
- Supercharger vs Turbo.... OFFICIAL ARGUMENT THREAD.
- Manual boost controller 20psi Max?
- Do NOT post turbo vs supercharger threads.
- Cleaning spark plugs
- Help needed... cant figure out lazy leave. Datalog inside
- Huron Speed V2 TWIN Turbo Hot-side Blow-out Sale!
- Boost/Timing 91 Octane only
- What type of oil pump on boosted 408
- When to go solid roller?
- plug n play coil
- precision turbo 88
- Turbo ls1 w/ or without cutout & straight exhaust?
- NEED more powaaa
- Twin Turbo Lq9- compression help
- Need advice on what motor to turbo
- STS kit or stay bolt ons ?
- Pro charger oil around head, reason to worry????
- ERL Superdeck
- Boost issues
- Turbo opinion
- Newb boost controller questions
- 1998 Trans am turbo build
- Vacuum Routing help
- Knockoff Tial gates and you! Tips at bottom apply to all wastegates!
- Procharger vs Turbo from those who have had both
- Let's see your fender/hood exit exhaust/wastegate
- Forced induction cam
- Huron Speed V2 T6 kit downpipe ?
- Forced induction
- comp engineering motor plate
- Boost Labs BL375R Turbo
- What radiator are you using?
- New speed master cathedral port dual carb supercharger
- AEM Meth Flow gauge or IAT gauge?
- Increasing base pressure decreases flow?
- Smoke coming from oil fill cap
- O2 location on on3 turbo ls1 kit
- Turbo selection suggestions needed
- Silicone Coupler PT88
- Thoughts on Comp Turbo
- help me pick!!! 364 vs 408 procharged
- Does anyone know the difference?
- Need pn# inline pcv check
- Need a little advice on some engine internals.
- A2W cooler blanket
- [VR] 1,035rwhp No Expense Spared Build - RHS/A&A/RPM/DSS/B&B and more!
- [VR] 1,064rwhp F1X Powered C7 Z06!!! - Stage IV Package + Procharger
- Help With EFISource GM-Style 3-bar MAP Sensor
- Automatic Trans for Turbo Question
- Twin Derale 16925 Wiring Question
- CXRacing TT Conversion - Electronic Throttle Control
- Borg Warner S475 shaft broke in half. Has anyone else seen this?
- Need a cam
- Scavenge pump
- Snow Performance Customer Service
- Need help on my joe gibbs silverado
- Ms1 tune
- 70' Monte carlo, the gentlemans junkyard build
- Aster bracket and turn one power steering pump
- what sparkplugs are you using?
- E85 and no intercooler
- 98-02 trans am ls1 twin turbo
- Street tires that hook
- D1 Procharged 347 Build
- Turbo hotside question
- Dyno time- made 721/697, mustang dyno, eBay turbos
- Compressor Wheel Radial Play
- Methanol spray before or after iat sensor
- S480 LQ4 build
- Lsa blower pulley tool
- New to the turbo world
- Brake Booster Port Plug
- Supercharger hood clearance issue
- Huron Speed T4 Scavenge pump location????
- Compressor map question...
- 2010 Colorado ZQ8 Build
- 6.0 with 241 heads
- Single 3 inch exhaust 76mm turbo 810/875rw.
- RPM Suggestions - LS6 Cammed 4.8
- Boosted 4.8
- Converter help
- need some help (boosted noob questions)
- Turbo for DD LY6 suggestions
- Turbo selection advise requested
- My first turbo ls
- Great N/A - Now want boost
- Best place for mail order tune for turbo kit?
- Looking to re-ring my lq4 for boost. Suggestions?
- Heavy Sedan + Manual trans + turbo 5.3... Can it work?
- PVC mods for turbo ls1
- Anyone using the "new" silver electrode plugs?
- Where is a good place to buy a tank for methanol?
- 93 octane to E85 tune
- L33 turbo build help needed
- 88 Cavalier Turbo Build
- L92 supercharger?
- Help needed for a beginner wanting to go turbo
- newbie to boost 80mm turbo
- Bad 44mm Chinese Wastegate
- Piston dish for boost? Poor cam choice?
- LS6 vs PAC1218 vs Isky beehives
- PS relocation bracket
- stock ls2 twin turbo build what do i need?
- lq4 questions
- Question For Those With A BOV
- Just Ordered Speed Engineering Turbo Headers
- Spooling time 5.3 LM7 - S475 T6 1.32AR
- E85 best spark plugs?
- Questions on which engine for future turbo setup
- Rocker bolt backing out
- Turbo Cam. Who do I believe?
- Pure meth, IAT's and 2 step
- Max hp on latest LSX block vs previous generation block
- options for PS delete and Huron T6 kit.
- 4.8 crank in a 6.2 block
- Threw Out The LT1 Went LS (TURBO BUILD)
- Synapse Wastegate question
- 4l80
- Tick Turbo Cam (Supporting Mod Advice)
- bmr k member help please!!!!
- Eldelbrock Eforce charger flow test
- Advice needed, Turbo or Supercharger with Billett Specialties Tru-Track Top mount
- What am I doing wrong?
- Injector testing
- Have no clue what I'm doing
- Reichard Racing?
- EBC Solenoid Options
- Less than ideal oil drain line angles
- teach me about scavenge pumps
- Turbo building question
- S10 turbo
- Full race to street car
- Supercharger compatibility question
- looking for a way to make this work--steam vent lines
- Opinions please Comp Turbo CT43X 7875 .96
- 2300 supercharger max rotor speed
- On3 WG and Scavenge pumps
- JGS Wastegate spring question
- Valve spring choices, PAC1218, or GM Performance?
- Comp Turbo Oiling Help
- Fbody P1SC
- Turbocharger trim is calculated how?
- 1986 Ford LTD/L92/BW S-480/Holley EFI Street Car
- Leak test hotside
- F1X-12R 4th gen F-body Camaro 1500hp
- Procharged LS1 breater tank setups
- Need help choosing heads for my procharged setup
- Turbo Manifolds
- How Reliable is Your Turbo Setup?
- th400 questions.
- OBS ls swap turbo questions
- Question about using 5.3 truck fuel rails with turbo setup
- Turbo CTSV gen1 tuning
- HP guesses
- Top or bottom of wastegate for boost control
- How well will a 7675 on3 single turbo work with my current setup?
- What size primaries for LSA exhaust?
- Flywheel problem (help)
- Maximum boost on pump gas L96
- Budget build help needed
- e85 timing table.
- Guys running prochargers on their fbodys chime in! HOW FAST ARE YOU?
- Coolant line question
- Boost Ramp Vs Tune
- After many years
- Turbo Cars? What rear gear are you guys using with a th400? What mph? hook street?
- Considering Procharger, Do it or hold off?
- Th350 kickdown bracket
- when should i expect to run out of fuel??
- Whats better two vented catch cans or two blow off valves
- Cam selection on a turbo application
- 2 Step vs Trans brake or Both
- Microsquirt LSx Firmware - Tunerstudio Setup Tutorial Video
- P1sc Procharger upgrade
- Question about heads for a 408
- #charliebangas 1600whp f1x z06.
- Holley Hydra Mat 98-02 FBody Fuel Tanks
- Catch can question for procharged setup
- I know, I know, another turbo size question...
- manifold hot side
- Please Help w/ hobbs & relay wiring.
- Tuning with pure meth injection (Track Results)
- 6.2 turbo stock rods and bearing will survived?
- Turbo build gauges?
- How big should I open up the Turbo oil feed.???
- Mail order tuning with boost?
- 4.8 lr4 boosted setup
- procharger pulley size questions
- Microsquirt NOT RPM SYNCED
- A&A 09 C6 questions
- HP guesses...
- DIY dry decked heads.
- Dyno Results - 1998 Z28 w/ 408 (LQ9) w/ T76 @ ~7lbs
- denmah mega squirt challenge
- 86 k5 with a 6.0 lsa swap
- turbo for low rpm boost
- 99 turbo ta mostly china build
- Looking for ls1 turbo kit
- Plug recommendation? 76mm Turbo Silverado 5.3 10.5:1 E85 flex fuel tune 10-12psi
- Turbo sizing for single turbo stockish 5.3
- What turbo size???
- Passenger side turbo manifold 5.3
- PT7675 smoking like a train!!
- Vacuum Block Routing Help
- Best head gaskets for 800rwhp boost?
- problem loading first tune in a mircosquirt.
- ls2 rod strength?
- The time has come. TT-FRC tune time.
- LS9 heads on an LQ9 block with stock sized ARP head studs...will it work.....?
- Ls1 Turbo top end setup questions
- Cruising AFR
- poor mans ERL 6 bolt solution / 1/2 head studs
- How much more power vortech pulley change
- Anyone use a Lsa charger?
- MAP sensor
- Turbo sbe 5.3
- Building twin turbo LM7
- TC78 stock bottom build thread
- 403+2x7665+417 intercooler+glide ford notch, cam swap mo-power 888whp 8.50s@157mph
- lumpy cam?
- Holley fuel pressure regulator
- ls1 turbo kit or procharger kit
- Turbo drain hose length ??
- CX Racing turbo kit?
- What rod to choose???
- front bumper exhaust loudness...turbo car
- Need plug verification for my turbo...
- s362 vs gt35r
- Possible 2000 LS6 boost?
