View Full Version : Forced Induction
- s362 vs gt35r
- Possible 2000 LS6 boost?
- Need a good cheap Boost hobbs style switch
- please help getting this boat out of the hole!
- Turbo 346ci 76mm single turbo TB sizes heeeeelp 800-1000hp target
- Wastegate size suggestions, Please Help
- late model DOD conversion on 5.3 alum block
- Tc78 347 fuel system changes
- LS1 76mm single turbo, target 800+rwhp! Pistons, Rods Advice
- Holley hi ram intake intercooler
- Cone filter vacuum line nipple
- Where to tap oil pan for turbo drain
- Exhaust muffler that's really good for turbocharged engines
- Billet S482
- How much can the T/A bumper be trimmed for IC?
- Professional Products Typhoon 96mm intake manifold w/ 76mm turbo
- Building V8 350z 76mm single turbo application. please help
- Manual trans with high hp/tq no.
- Procharger guys using truck alternator? or?
- Turbo Size and CR Suggestions
- Questions for all you 1500+ HP guys...
- MAF or not to MAF with 10psi or SD?!
- ls2 block
- Turbo drain lines
- S/10 build
- Piping/ wastegate ?
- Easy EFI?
- Cheap 10 micron ethanol compatible fuel filters.
- current turbo and what should i get next
- Project Miscellaneous Expense - 1972 Nova 5.3 turbo
- Fuel Rails
- Back to the dyno for some better numbers. How'd I do?
- 900+rwhp procharged f-bodies?
- Pro Flo XT and Holley Fuel Rails
- Weird stuttering and lean condition at low boost.
- Need help mounting derale pusher fans on ac condenser with Huron Speed v2 kit
- 20k
- 4.25 vs 3.70 Pulley D1 belt
- E38 ECM flex fuel question...
- Building NA LS2 with potential for turbo in the future?
- Any advice?
- DGR Performance
- MAF Help
- Turbo piping
- Fueling Question for a 68 Chevelle build
- Driving impression with a smaller AR
- Twin Turbo C3 Vette build in progress
- Water Spray Question
- what do i really need..?
- What oil and weight to run
- Griffin part number
- Any running a S484 ETR /w V2 Cover?
- MS3-Pro Engine Management System.......anyone use it...?
- lq4 belt length
- which cam
- In search of a larger throttle body options
- DCR revelation !
- How much boost for me?
- Ethanol Content and actual results
- Crankcase to Exhaust Question
- Twin Turbo LS Boat Engine
- Intake question
- 900-1200WHP Boost help, 333CID
- Anyone weld their WG directly to the turbine?
- Huron Speed twin turbo preliminary numbers
- T4 s400 408
- Help with Turbo 5.3L Build
- S10 Beater/Sleeper Build 5.3 Twin Hx35s
- Ran out of fuel pump??? Does this sound right?
- Factory Parts Combo for Low Compression Setup(s)
- MSD6012 box ?
- 5.3 stroker
- LT1 procharger F1-R wanting to up the power
- dash and wiring going back in.. motor updates done in 2 weeks
- Setting up 2 step
- blow-through carb turbo set-up..starting timing and plug selection?
- Noob Forced Induction questions.
- Turbo the goat time!!
- LSA heads...can the chambers be opened up...?
- Boosted 5.3/706 heads - Truck intake or TBSS?
- Different Turbo LS build
- Blower gears/stall with turbos
- Whats everyone using for V bands on their hotside?
- Twin Turbo 5.3 240sx. What size hotside?
- Intake tubing thickness?
- pcv and puke tanks
- Tax time turbo kits?
- New short block for F1A
- F series prochargers
- Help! Oil leak at hotpipe/wastegate
- Power Valve Delete for Drag Race
- Dual pumps and fuel lines? Best prices?
- Vs Racing 77/83
- Tuning info
- Victor JR
- Any experience with a gt4202 on 5.3???
- broken procharger head units,,,,
- How long do your plugs last?
- Critique my planned turbo build
- Measuring back pressure with 38 lbs of boost.
- Car has the sniffles
- cant get my 160lbs injectors to run right. please help!
- Project LSXpress pt 2
- Turbine inlet flange size?
- Afr for e85
- '99 HOZ Twin Turbo 370 build
- Denmah gt45 kit t4 divided flange questions
- pulley issue
- Finishing up my 65 Buick winter rebuild
- 5.3 blew pcv piece out drivers side valve cover
- Turbonetics Hurricane twin 7668 too small or too big
- Which stall to get .........
- Truck intake hp numbers with 6.0 turbo anyone? ?
- Water intercooler radiator and pump input sought
- 81' malibu classic LQ4,80mm turbo build
- Extrude Hone eforce superchager
- Possible forced induction build
- turbo help
- ls9 style gasket for small bore
- Huron speed v2 kit, swaybar fitment
- Help me choose a turbo for rear mount
- Two intakes for turbo build. Which is better??
- Which turbo
- Ls7 Intake recommendations for boost application?
- Water cooled turbos
- Running Pump or E85?
- Check out these T4 flanges I had made
- Those of you running Aftermarket intake manifolds
- Wiring harness and computer help for lsx
- Info Please
- Ebay turbo headers
- pt88/pt8847 questions
- FMIC bumper inlet cover...Trans Am......where to buy this? (Picture)
- 2005 GTO LQ9 Procharger Build
- WTB Heat Exchanger and reservior upgrades
- fuel pump(s) set up w/diagram
- turbo hot side coating
- D1 with aster kit? Or buy kit whole!
- Need help with turbo and injector sizing
- bulding a 83 c10 with 5.3 turbo, have questions
- Installed lsx motor with ls2 conversion, no start condition
- Turbos running out of steam
- Cxracing turbo kit reviews
- OBX turbo kit
- Best Cam For Turbo LS1
- Scavenge pump wiring question
- S366 twin turbo?
- Edlebrock pro flow intake and turbos
- This an ok cam for boost?
- Need help!! Please and thank you!
- Blown head gasket
- a few boost questions
- Best Heat exchanger ?
- Turbo scavenge pumps...
- Crossover pipe sizing (600hp)
- Boosted 5.3 lm7 with notched heads help!!
- Radiator and fan question
- Anyone running on3 turbo
- turbo dimensions
- 317 or 821 heads for 6.0 E85 Blow Thru
- Are 1/2 head bolts needed with 6 bolt heads?
- Are these the Correct Injectors?
- Does this sound like a 1000rwhp Capable Setup?
- Idler and pulley questions
- water meth
- Progressive meth controller or eboost
- Tuning
- Oil in Cylinder (? valve seals ?)
- Balloon plate converters
- What should I do with my converter? 600whp to 900whp
- Turbo Cam
- Twin Turbo 65 Mustang new PB 4/1 5.82@120
- Trans cooler locations
- Experience & Opinions needed: can a 3.6L Kenne Bell support a 454cui pump gas LS7?
- Truck procharger on lq9 based car?
- Exhaust Decision for 370 D-ISC PROCHARGER
- What turbo to get?
- Mesh trans am front bird for I/C
- Ebay turbo
- 03 6.0 or 05+ 5.3
- twin turbo truck rear mount radiator
- Running str8 meth with no intercooler doable ???
- 2015 silverado turbo ?s
- Centrifugal SC for truck accessory drive
- Buying used d1, what should I look out for?
- Ls3/ly6 valves
- e85 switch
- Ring Gap
- Pt7675 vs turbonetics 7575 billet
- Average hp for lsa swaps on 6.0's
- rear/mid mount turbo questions
- GT35x2 vs On388x1-Best China turbo(s) for 1001whp?
- Ls3 with forged pistons and stock rods
- Which Stall converter with a D1SC
- Should i gap my rings 6.0 with lsa blower
- Where to find a small, thick radiator for 750whp
- 2014+ Truck Twin Turbo Systems Now Available!!!
- Plugs needed for boost
- 3 bar map for truck intake
- WPC surface treatment (anyone using this for turbos?)
- LS1 Supercharged Emblems
- Looking for guidance on new 5.3 setup
- Injector Question
- What happens to a top mount SC when sprayed
- L59 Head question on E85?
- Who makes a good cutout that lasts?
- Ideal placement for dual wastegates (help)
- Looking for spool time on ON3 76mm turbos
- UPP Turbo now on LS1Tech!
- Anyone have a ls6 cam for sale?
- foxbody turbo build help
- Ls turbo help
- Turbo 5.3 injectors upgrade
- Chevy II 6.2 turbo need cam help!!!
- Whipple build
- Truck intake question?
- Engine bearings
- stock motor/E85. intercooler vs no intercooler
- Rear mount turbo setup, how they work.
- What gears for Turbo and 4l80e
- LS1Tech Forced Induction Shootout
- Project "Street Taco!"
- 04 GTO pulley setup, and F-Body pulley setup
- Machine a V band out of flange on truck manifold
- New Mid-Frame turbo
- Profec ? Customer Car
- 2 or 2.5 piping for twins?
- Top end for 370 twin setup
- Alternator relocation question
- Home built front engine longtravel buggy ls1 turbo build
- Anyone use this sheet metal intake?
- Twins or single?? LY6 600hp goal
- 4 port over 3 port How much more boost ??
- Pump gas and Meth vs. straight e85
- Vortech v1 got some questions
- Kenne Bell Injectors
- Water/Meth will probably save your engine.
- quick head stud question
- LQ4 SBE Prep
- Cam choice for boost......whos the guru.....?
- t76 81AR which cam triple12 vs 216/220
- Just wanted to say thank you to some people for help with this build.
- ERL 427 F1A combo guesstimation
- Twin Turbo Gurus....Need help with sizing for 402
- Go to dark side? D1 for Turbos?
- squash fuel setup question
- 2015 Camaro SS "SingleT" Build
- 5.3 blow thru turbo setup
- 3bar map vac line T? Good read after T?
- truck manifolds 'egr'
