View Full Version : Forced Induction
  1. Cam Question for Turbo
  2. TC78 owners come in!
  3. help i need help with boost piston choice
  4. Going For Broke-n.....Twin Turbonetics T76 5.3
  5. Turbo guys....38mm or 44mm wastegate on 5.3 build?
  6. help with vortech supercharger setup
  7. Twin TC turbos?
  8. looking at twin turbo ss
  9. after market hypers vs stockers
  10. Precision PT88 & Turbonetics T88 spec questions
  11. MAGGIE VS WHIPPLE on LS3 camaro (want input)
  12. Is there anybody here running this pump, or even heard of this pump before?
  13. anybody running maf with over 650rwh and big cam
  14. EBay Hot side piping?
  15. Do I need a bigger fuel pump?
  16. Do I need a bigger fuel pump?
  17. Thoughts on removing the divider on a tc78 Ex housing?
  18. steam tube adapters
  19. Fuel Slut! AES 390 TT TC-70's AMC Javelin Build.
  20. dual 3.5 vs 3.0 tail pipes - spool difference?
  21. Yes. Another low oil pressure thread. UPDATE 7/28
  22. Is this true about e85 or just bs
  23. Is a forged crankshaft really needed?
  24. Godspeed kits any good?
  25. truck manifolds/turbo in an A body
  26. Oil pressure dropping under load after oil change...
  27. Driver side manifold glowing after an easy 5 mile drive.
  28. vortech supercharger shaft play?
  29. Anyone have any real world experience with the factory style 3.3 BAR MAP?
  30. True cost of running E85
  31. tr6 gap
  32. not building boost
  33. evap?
  34. Rearmount turbo selection help..(NEWBIE)
  35. trying to decide on a turbo...again
  36. rearend mounted turbo
  37. HRM's 1200HP 4.8 LS
  38. The most efficient supercharger ever...???
  39. Loudmouth Turbo v1.0.......
  40. What do I need for a 140+ mph car ?
  41. cam for FI stock bottom end
  42. Seriously unsure about single vs twins
  43. Same cid tall vrs short LSX for boost?
  44. which budget A2W and where to mount
  45. STS turbo need help making boost
  46. Quick question.. What BOV is this?
  47. Champion camaro ttix 848 rwhp
  48. could I run a S/C with my setup?
  49. St-80......:)
  50. Looking for some feedback on my ideas for a TT build.
  51. Anyone have experience with 6-71 blower on LS ??
  52. Precision 76GTS pictures with stock radiator
  53. Moroso Oil Filter Sandwich Adapter Turbo Feed/Return
  54. Custom procharger mounting (fbody)?
  55. KY-Turbo Build
  56. Idler Pulleys
  57. Leaks oil, can't understand where. Need help!
  58. turbo cam size
  59. which fuel injectors
  60. Can i re-use these heads?
  61. Where would I find these parts for my supercharger?
  62. ls6 intake or fast intake?
  63. Jax04--88'rx7---88mm---L33--PowerGlide---8.8"--v1.0
  64. Who is running FTI behind their turbo/blower cars?
  65. Leaking Procharger....
  66. breather?
  67. good read on block machining
  68. Best engine for a blown DD?
  69. to bore or not to bore? Cam choice
  70. Vacuu source for catch can/pcv on a tc78
  71. 600-650 rwhp goal. buy lq4 bottom end or rebuilt spun rod ls1?
  72. Those who run Alky Control Meth Kit
  73. If you've had a procharger and turbo car in here!
  74. Carbed turbo guys, I need some advice on a crazy project.
  75. Need turbo ideas
  76. rebuilt pt88 exhaust wheel failure, what possibly happened?
  77. Is this the ebay intercooler that all you guys use?
  78. safe afr?
  79. meth tank
  80. has anyone got the new hotrod magazine?
  81. heater hose questions/mods. answers please.
  82. Could not ask for better people
  83. 370 PT88 only making 3psi on dyno
  84. Turbo Questions.......
  85. TC78 W/ 1.15 ON 4.8 or 6.0???
  86. Are there any notable differences in these 2 PCV Catch Cans?
  87. Catch can or no catch can
  88. whipple on a f-body?
  89. need a good a/w intercooler
  90. return line question
  91. what should I change about my turbo system
  92. Aeromotive 13105 regulator enrichment, lol
  93. camaro ls1 turbo at dyno
  94. MAP Sensor advice needed.
  95. Supercharged 408 intake manifold
  96. 383 Lt1 F1-r Blower build
  97. forced induction doubt
  98. power steering question for ptk users
  99. turbo seals question
  100. Boost #'s changing?
  101. Need help with 408ci turbo build...
  102. My rear mount standalone oiling system, have a question
  103. Ohio Boys Racing Updates
  104. Thoughts of Holset HX40 paired with a 4.8?
  105. need help with pushing water
  106. Help out a newbie.
  107. AES 410c.i. LSX & KY-Turbo
  108. Pro flow Xt turbo LS2
  109. supercharger pulley
  110. Short intro video
  111. Dyno...what do you think?
  112. can i fill the water jackets in the heads?
  113. Question re: PCV system and forced induction
  114. Turbos to fit the following criteria
  115. Extra Thick MLS Head Gaskets
  116. Overheating with AC on with P1 now...
  117. Billet T76GTS Dyno Results on 19lbs and E85!
  118. vette 50mm cog drive used in F-body
  119. L76/LS3/L99 vented catch can setup?
  120. Stripped coolant sensor
  121. 1966 velle twin turbo 454 or LS ?
  122. opinions on piping?
  123. .68 or .81 a/r exhaust for rear mount
  124. Spool and power difference w/twins pt6765 vs tc76
  125. Gt4202r
  126. RPM, boost, and engine life
  127. 30" tires now working on my LSX Drag Radial Vette
  128. I better upgrade my fuel pumps asap lol.
  129. Boosting lsx376
  130. Copper Head Gasket O-rings
  131. 2-bar MAP sensor not reading above 105kpa
  132. Turbonetics T76
  133. those running 5.3's
  134. 408 Twin Precision 6765 V&P Racing LSX Pinto
  135. FAST and 2 step.
  136. ProCharger Video Challenge 1st place $5,000!
  137. 427 F1C build
  138. AN fitting question
  139. Signs of a bad Procharger?
  140. rear gear- boost- t56 ?
  141. your timing and A/F increments from 1lb-20lb of boost?
  142. ls2 rails on lq4 intake?
  143. Thinking about going FI
  144. What plugs for ls3 twin gt35s
  145. 6.0 lq4 turbo?
  146. Turbo Guys! Exhaust question
  147. which oil pump?
  148. i need mild steel colector flanges for ac mani build
  149. turbo ls2 in a 245" top dragster
  150. Which large frame turbo for a 5.3?
  151. Procharger Help!
  152. rear mount guys
  153. How'd you bend your PS lines to clear turbo plumbing
  154. Suggestions on build....
  155. Diesel vs gas engine?
  156. My Forged LS1 KYTP TC 78 Header build
  157. Best exhaust manifold bolts/gasket combo?
  158. 16" Zirgo pusher / griffen /160 therm keep me cool ?
  159. 150/160/220 natural gas injectors?
  160. LQ4 Tuning/Timing opinions wanted
  161. FAST LSXr vs LSXrt
  162. Got started on the 20psi tune last friday, dyno and video inside
  163. Wiring woes
  164. 02's stoped reading in HP tuners
  165. lets take a vote on turbo selection.
  166. building ls1 for boost.help
  167. need help bad
  168. gear ratio? for my 5.3boost camaro build.
  169. ran friday!
  170. help choosing a turbo
  171. Well car is running with the D1.
  172. I need clarification please
  173. Single or Twins and what size?
  174. Finally dyno'd my turbo LT1
  175. Holden WH Statesman, 390ci + S400 build
  176. Eboost2 setup help
  177. new record: stock longblock 4.8
  178. STS turbo
  179. Meth Troubleshooting Help Please...
  180. Brute Speed Blower Cam
  181. How much to forge my motor? Stock ls1+Twins
  182. Just my luck, D1 installed and now the alternator isn't working.
  183. The latest technology Turbo Charging!
  184. S91 Turbo Problems Again. Or I'm Wrong? I don't Even Know Anymore.
  185. help what springs should I get?
  186. Same WG,differant ci,turbo,cam,lower boost??
  187. Most power with a 5.3
  188. anyone here ever hurt an e85 engine?
  189. arp head bolts.
  190. Turbo ls1 Horsepower estimate?
  191. 99 Procharged ls1 with part throttle knock
  192. Rear mount turbo- Should I run a pre-turbo flex pipe? Do you run a flex pipe?
  193. methanol injection
  194. .120'' Head gasket for boost??
  195. Heading to Milan this weekend...
  196. O-ringed block for use with MLS gaskets
  197. sts turbo problem need advice:/
  198. 89 octane with meth
  199. truck manifold questions...
  200. Safe octane level/timing for 20 psi?
  201. Procharger with Wastegate
  202. Turbo craped out, so what size should I get now?
  203. My TT Vette 930/870
  204. best streetable twin turbo kit for C6 corvette
  205. coated intake?????
  206. 9.2 compression and ? Boost
  207. rearmount help
  208. yes the question again, what turbo to use??
  209. Magnacharger tvs 2300 or go with kenne bell???
  210. Turbo oil leak problem
  211. Twin Turbo's
  212. RHS 427-F2 Cog-Stock Susp C5 PICS...
  213. couldnt find the anser to this
  214. intercooler size question
  215. Procharger P600B Kit - Stock LT1
  216. True duals with a single turbo/Brutespeed cam questions
  217. procharger open race valve
  218. Magnum turbos going 9's again....
  219. Magnum t76 group buy
  220. Procharged 383 C5 ZO6 Build
  221. Get a procharger or go turbo, help?
  222. TVS 1900 09 Avalanche by AMS
  223. The Manifold is done!
  224. before procharger header?
  225. valve cover breathers ok?
  226. HELP! engine issues
  227. New look of AtomicFusion LSX Drag Radial Corvette
  228. 10.30-10.50 stock block no weight reduction convertible possible
  229. 02' Pewter Z-28 Get a Custom F1-A Kit Thrown in
  230. A LS Procharger hub that can take it.
  231. gts 76 vs tc78
  232. c5 sts turbo question
  233. What heads for forged Ls1 with 15lbs boost
  234. aster bracket
  235. smokinghawk alt relo.. what am i doin wrong?
  236. tuning a turbo 2006 gto 6sp. knock only in 4th?
  237. Pipe Sizing, Backpressure, Restrictions?
  238. I must know
  239. Nitrous guy to Boost guy. Spark plugs.
  240. head gasket thickness
  241. speed inc alt bracket, belt walking off crank
  242. need a different oil feed source for turbo
  243. How are magnuson tvs 2300???
  244. Best intake for forced induction...
  245. ?
  246. magnum turbo's
  247. intercooler install
  248. Remember me? I'm still alive...actually :)
  249. GMHTP - Standing Mile build (88mm, 370... 200+mph)
  250. Race vs standard plugs?
