View Full Version : Forced Induction
- Lq4 lasted 3 days
- Gen IV 4.8/5.3 Still Boost Friendly?
- Seeking recommendations for rearmount camshaft
- ProCharger Corvette Direct Drive
- Monster Turbo Engine Porn
- what to expect s10 6.0 s400
- Optimising the Completed Build
- Need Expert input on boosted build
- Turbo choice and exhaust sizing help LS Datsun 240z
- Opinion on this setup
- 408 turbo size question
- 317 cnc heads
- GT4202 on LQ4? 1.15 or 1.25?
- 990hp,s484 dyno video!
- SBE LS3 S480 C5Z 5.6@125 1/8 mile
- [VR] Camaro ZL1 - Nitrous Outlet fed VR Stage V Package - Pics/Video/Results
- 6061 gasket question on 91mm 408
- Does anyone let their radiator fan(s) run 24/7
- Procharger for ls powered g body
- horizontally mounted intercooler?
- Have a few unanswered APS TT questions
- Novi 2200 sl
- Sidemount whipple supercharger
- Enough Vacuum???
- Looking MaggieTVS2300 Peak effieciency, pulley size
- Oil everywhere under WOT
- E85 injector size for LS3 TT 800rwhp
- Tom Nelson Shout out to Denmah
- Procharger impellers
- On3 alternator relocation kit
- 370ci, twin 61s, T56 dyno/track results
- Adding Supercharger - Remove Adj Fuel Pressure Regulator?
- aftermarket rods for 4.8 with big pin
- Ported Polished 806 heads w/ turbo?
- Too many mile for an A&A??
- Procharger vs Turbo impeller size
- Rear Mount Setup, Lots of advice / clarification needed
- LS2 with LS3 Heads LSA supercharger
- Feeler on bringing back the Huron Speed V1 Truck Manifold Turbo Kit
- future build with ideas
- Good source for copper head gaskets?
- Track update
- Why should I purchase a Heartbeat?
- Transplant bracketed for D1
- Exhaust Manifold Bolts for Truck Manifold Turbo Setup
- Crank question
- Turbo build from "spare" parts
- School me on meth injection
- Intake to TB seal? (pics)
- the "gt45 ebay turbo"??
- What cam PT88/4.8?
- Iron l33,twin Holset hx35s,800whp???
- katech 243's or 317s for boost
- Question about half mile and mile racing - with forced induction lol
- Volvo 242 - The frog
- 05 cts v turbo possibilities?
- Anyone ever swap BOV springs?
- Wtb; Procharger Lsx swap kit
- Need detailed info on fbody STS rear turbo
- Meth Injection Without Tune Gains
- $400 China “S366”
- S480 408 turbo question
- 8.29@163 sbe 4.8 f.i. billet 76mm notch
- 2000 ws6 370" billet s480 th400 9in e85 build
- ProCharger 1GU204-SCI CORVETTE C7 Z06 TUNER KIT P-1SC-1/F-2
- single or dual cutout for turbo setup
- How's my set up look so far? TT C5Z
- Use my converter from my bbc 454 on my LS turbo or trash it?
- Gain in swapping to headers for my application.
- Who knows innovate widebands? Can somebody guide me thru a problem with it?
- Supercharger and valve job
- Check Valve For PCV?
- What's better for small boost app 6.0 or 6.2
- Disappointing dyno numbers...were my expectations too high?
- Bosch 160 high Z
- Low Boost Issue
- Need the turbo cam gurus!
- Fast 92 or 102 for boost?
- bunch of turbo questions for build
- Procharged trans am front mount with stock fog light location possible?
- GT4094R twins?
- 370 + S484 + RPM T56 Build Thread
- Hotrod package 2.9L Whipple vs Magnuson TVS2300
- 81 Regal 5.3 PT7675 build-9.94@138.5mph
- Tiny Single Turbo?
- I hate it when......
- Where to buy old STS "PCV Solenoid Challupa"
- Boost leash?
- Boost spike, now noise/oil pressure problems).
- Boost LS1 Ford Crown Victoria
- installation pictures of mighty mouse catch can wanted.
- Fully stock + Turbo. want some input for springs and studs
- Turbo upgrade! TC70 to 6766 to small?
- went to the track and did'nt get shut down.
- 4l80e guys
- 71 Nova TT 6.0
- Huron Speed WEEKLY 98-02 Kit Bundle Specials
- Internal wastegate adapter?
- hotside close to hood?
- Twin turbo Chevelle - Forward and down truck manifolds with all accessories?
- Aisin Amr500 supercharger on a 5.3
- Bolt in MAF mount
- LS2 Turbo questions.
- Diamond 11510 pistons?
- LS3 max bore ???
- Car did much better at the track this time
- Any advantages to 110?
- 2013 LS + Turbo... What MAF?
- 3800lb/on3-76/e85/5.3 10s !!!!
- Pressure drop across FMIC
- First turbo build, advice appreciated
- GEN III limitations
- Went to the track, need some help (new time 10-10)
- Help with power hitting a brick wall???
- Wastegates not effective?
- Intercoolers plumbing finished
- any real world comparison between a fast 92/92 and victor jr?
- help with supercharger pulley
- Hot pipe !!
- New PB with Precision PT8285 CEA
- Manifold pics
- What's the highest mileage shortblock you have boosted
- Twin charged 6.2 cam question..
- Anybody have an Aster Bracket for sale ?
- Questions with first turbo build
- Change a/r housing - difference?
- Wastegate placement Question
- Destroked 6.0 and 76mm turbo.. Has anyone actually built one
- Anything to gain if I upgrade s480 & run same psi?
- Turbo LS for Time Attack Racing
- TBSS AWD dyno video
- Justin's truck makes 1068rwhp video!!!
- Any High Compression Setups???
- Need advice 88mm 408" LS3
- Does my iat sensor have to be before my meth nozzle?
- Wastegate Trim flare
- Question: New DI LT1 E98 turbo? can it be done?
- ls3 procharger tips
- Congrats to Silver_82 Drag Week Winner
- WANT budget build 800rwhp......engine who?
- Finally progress and traction 9.39@144.48
- No intercooler....
- 1000+hp 5.3
- What dual pusher fans for turbo ls1?
- Questions on ON3 Kit
- Headstuds with engine in car
- Is it a Turbo sin to use silicone elbows?
- Anyone running nitrous with boosting a sbe LS???
- abnormaly high intake temperatures with meth
- JE Forged 5.3 Pistons anyone?
- 4.8 build - source for rods & pistons
- WhiteLTone in action
- Spark Plug Coloring
- Most hp made with stock L96/LY6 6.0L ?
- LSX B-8 VS LS3 VS LY6 for Procharger build
- Truck or LS3 Manifold for (Hot side) turbo setup
- Supercharged on 87 Octane
- does MBC make turbo spool faster?
- Options for Mean/Ultra street legal 76mm's?
- SBE Turbo LS2 - Please Come Inside
- Cxracing AC retaining hotside
- stock bottom lq9 and t7875 results
- 427 LSX CADILLAC CTS-V WAGON (Pics Inside)
- PCV FI Routing
- Single turbo 4.8L Dyno Results
- no boost what to check ?
- LSA supercharger Build need advise engine size how much boost
- Intercooler piping question
- Road course - looking for fast spool
- BP7EFS plugs
- alloy 5.7 block, high comp and boost
- turbo motor runs great until vacuum lines are hooked up
- GT500 M122 on a cathedral head build in a Grand Prix 2+2
- TC78 Replacement
- Turbo setup for a 70 C10 SWB
- SBE L33 Huron speed V1 pt78/75 23.5psi 5.75@119.90 1.25 60'
- need help finding a good cam
- VVT turbo cam or just keep the stock?
- Who has an oil cooler?
- High Mileage LQ4 Boosting?
- Thoughts on new setup
- Sizing up a new turbo
- Stock LS1 Block - Max HP
- Anyone currently running VVT and boost?
- Question for LJMS/Forcedinductions/anyone that can help
- 2005 Monte Carlo SS -LS4 - 4T80E - S475-
- kenne bell 3.6 throttle body
- Just an FYI My Dart Billet block is for sale
- Dual vs single catch can with Procharger LS1?
- SBE 6.0 power levels
- Whipple build please help!!
- Stand up rad single shrouded 14" fan? Front mount turbo guys
- Fitting a C5 Procharger on an LS1 with F-Body Accessories
- What causes a turbo that didn't smoke to suddenly smoke?
- tipot single turbo C5 build LS7 S480 :)
- Fuel question
- Cracked a cylinder sleeve on my 2004 ls1
- Diesel Turbo Difference from gas
- Turbo oil feed
- NA Cam Turbo Build
- turbo lubrification
- What power level is needed in an F-body to beat a 1000cc bike?
- Jumped on the band wagon..
- Jy 5.3 with slight pitting in #5
- On3 supporting mods?
- *sigh* Not again....
- divided scroll, single bank wastegate? ?
- Need help please
- 2000 Z28 6.0 LY6 7875 Turbo Build
- 5.3 or 6.0
- Launching on 2 step with nitrous
- September is TWIN Kit month at Huron Speed - 10% off!
- 365"|SXE Billet S366's|Glide|Holley EFI
- a little assistance spec'ing S366's
- Measuring pre i/c pressure
- What solid roller lifters?
- High flow cats need some info. how to make exhaust quieter
- 76 corvette - Twin turbo lsx street car
- 91mm LSx 1966 Chevy II 315 DR
- Tick Turbo Cam, which stage.
- Boost controller/boost build up question
- Who has done a custom low mount twin turbo ls1?
- Switching from nitrous to a turbo, advice please
- Guesstimate of whp I'll make?
- How should this setup do in 79 Coupe Mustang.???
- LSA Supercharger adapter plate options
- Best location for heat exchangers on a mid-engine TT car?
- 02 transam partial ac removal?
- LM7 vs LC9/L33 Exhaust Manifolds for Turbo?
- need help with turbo issue
- Well....time for a new iron block I guess...low oil pressure
- Please school me on blowers and the reason for a camshaft
- Questions for Huron Speed customers and passing emissions
- LSA Supercharger Adapters?
- PT88 Who uses it & whats your combo?
- PT76 LS1 Turbo Kit by Turbo Joe
- Boost Calculations on LS1
- 7.70 @ 178! New LSX Real Street Record!
- Big Cam users - Timing?
- 2 bar map reading low
- Crank shaft drawings
- dual 2.5 downpipes enough for twin 6766s
- Bov and wastegate suggestions
- New SBE record 8.19@167
- Intercooler and converter question.. not your typical application.
- Very little space for turbo filter...any suggestions?
- Derale fan trigger wire quick question
- Stranded with bad map with sd tuned 99 ls1
- GM 376 for boost?
