View Full Version : Forced Induction
- 600rwhp & Boost to get it~
- Roots type supercharger conversion parts list
- Intercooler Coupler hold help
- anyone here live by straightline performance by Joliet Illinois
- Need waste gate and bov selection help
- foxbody 5.3 turbo help
- Wont go into boost?
- Supercharger Kit 2000 Formula
- first time out on fresh motor and have a few question on et,converter boost on 2 step
- LS9 Heads or AFR225 Heads for 408ci YSI Setup. HELP
- GT55 94mm GTR-HO Build - Engine Top End Suggestions Needed
- First passes on Gate pressure best of 5.80
- 862 heads with ls6 intake manifold
- Limitations of 3" Downpipe?
- Intercooler question
- cooling system problem need ideas
- targeted afr way off
- Brand new build... persistant skipping... help!
- What cam with a PT7675
- Thoughts on Turbo Drain
- The need for speed...
- Inverting the throttle body, thoughts?
- Procharger buddies please help . At a loss here.
- Any turbo gurus in here? My Precision turbos are smoking. Need help please!
- what's your guesstimate?
- Lq4 6.0 with Ls9 cam, 80lb injectors, microsquirt, and 76mm on3 turbo, safe boost?
- Need moar powa - turbo 5.3 turbo size recomendations
- Where to buy turbo vacuum lines?
- Be Sure to Use Anti-Sieze on Stainless Hardware
- Questionable cam bearing, opinions needed
- Cobra elbows
- Eboost2 w/on board air?
- Installing a Speed Inc TU1.5, leave it straight up?
- 15Psi boost nw tb issues tvs2300
- Can I reuse my stock valve spring retainers?
- Turbonetics Billet 7275 vs On3 7875 Comparison Pictures
- got back to the track
- Cleaning the Intercooler?
- NEED HELP with Huron V2 T4 W/ a/c install.
- Question about heat wrap for a turbo...
- Hood choice for 4th gen Camaro Boosted
- Crankshaft pin kit??
- procharger twins to fmic ?
- Will a 250 shot be very Inefficient on my set up.....
- Turbo lq4 blowing oil under boost
- 427+YSi+JamCam=1030 rwhp!!!
- Pusher fans
- Thoughts on these cam #'s: Experts please!!!
- Car Wont Start - Help!
- LS1, Magnuson 2300, AI 317 Heads
- Hoping for an easy 800+rwhp with these 2 goodies
- What's considered "high lift" on a blower cam these days?
- Motorcycle Radiator fans
- Turbo 5.3 for towing (gasp!)
- Worth Changing Brute Speed Blower Cam for a More Turbo Friendly Cam?
- Another Derale fuse holder failure
- Poor man's Variable turbo?
- Preventing getting hot with the A/C on
- ProCharger and LT1 radiator
- holley high rise or supervic
- No oil pressure please help
- Anyone get flex fuel to work on a 2 / 3 Bar P59 ECM?
- Air filter cover
- Turbo ?
- AIS vs Aquamist vs Alky Control vs AEM
- resonator causing STS TT not to spool?
- A little different kind of turbo build. Need input
- Boost a pump and boost.
- AEM Truboost. How does scramble boost work??
- 5.3 as backup to a 6.0
- Budget 4.8 turbo build.. Advise needed
- Turbocharger mounting angle
- 60# Siemens Deka Injectors & Turbo
- Where can you buy Methanol in Kansas City Mo?
- pt 91 pro mod turbo on 370
- Truck intake mods for turbo
- Opinions; Intakes for turbo
- GM 3 bar MAP sensor plug and play
- What boost level do you start using Meth?
- I have a sheet metal intake meant for old c5r heads. What port is close to that?
- Anyone with upgrade turbos on APS kit
- Looking for RDS blower plate info.
- Head question
- m6 lq4 with a cam, s475 too big?
- Planning 5.3 turbo build, what sensors to keep?
- TVS 2300 fuel filter/regulator questions
- Does this look like Valve Float to you?
- 2008 ly6 or 2004 6.0 for boost?
- Throttle body for a 88mm
- Super Vic not cut for O-rings, sealer or felpro?
- Benifit of a ball bearing vs journal bearing
- Trick t6 truck manifold,where to get replacement Ac line?
- Yoke engagement question
- Any problems running polly mounts on turbo car?
- Pro charger questions, P1SC, D1SC, D-1 Help
- Knock sensors
- 4.8 turbo suggestions and where to get the best deal
- Ls1 venting question
- Nick Williams 102mm DBW
- Variable speed fuel pump via holley(or any stand alone ems)
- Help with alternator wiring ??????
- Line from valve cover
- bent intercooler
- AMS-500 2 Stage Boost Controller Question
- newb trying to build boost with 2 step question
- Building my own meth tank. What do I need for the corrosion?
- 370ci / S484 / T56 Build Thread
- Lemons12- 370 S484 E85 Build thread
- Spark Plugs for LS1 Turbo
- Incresaing the pressure required to bypass oil filter?
- Turbo size for a 416
- Anyone here used the aquamist controller? looking for pcm pinout help
- LSXTV did a short little story on my car.. really cool
- New build, 2 door Zephyr
- Finally off to dyno! what should it make?
- Problems after 317 head swap
- Spark plug wire help
- Need help with overall dimensions of the BW S475.
- What to heat wrap on my Huron Speed V2 T4????
- twin fuel pumps
- Turbo 5.3 laggy spool
- Installing 3bar MAP in LS2 intake. Need advise.
- Megasquirt on a C5?
- Lsa blower fueling help ?
- What do I use the inputs/outputs plug on the holley efi ls main harness
- Procharger belt size?
- stock ls6 turbo...
- ok, here we go.
- 5k for turbo 5.3 and Trans??
- Identifying a procharger setup
- Turbo question, need a bigger exhaust side
- Worth checking out?
- Twin 255s not enough anymore, what should I go with for a pump?
- Project Geezer...Dead as a door nail...
- Please help
- 87 GN build planning could use your suggestions!
- turbo lm7 noob Qs
- Please don't flame the FI newb...
- twin PTE billet ball bearing turbo experience welcome inside.
- Burkhart Chassis Summer Sale
- ZL1/LSA/CTS Supercharger on a budget
- Fuel pressure regulator
- Low buck rods and pistons.
- New to Boost... Please Pick Apart my Plan
- Too much pressure at idle/venting/PCV/Catch Can???s
- Compression question
- LQ4 boost prepperation
- Power steering line recommendations..
- Aeroforce Interceptor Gauge Boost Add On
- Customers 01 Z28 S480 build
- 4.8 turbo c10
- 4.8 crank and rods forged pistons. reliabilty
- on3 76mm has arrived
- Kenny Bell Mammoth in a 2007 Zo6 questions???
- Can't seem to run WG pressure only
- Holley efi dominator & turbo
- HURON SPEED update, And 98-02 F body "v2" line of turbo kits.
- Will these heads get the job done?
- 5.3+T56, what budget turbo, GT45, T76, T70 . . .
- Breather setup / valve cover gasket?
- Front mount intercooler and front license plate.
- LS1 bed mount single turbo
- post dyno number using the s476
- Fox Mustang Turbo LS Swap **Dyno Results** page 6
- Sources for pipping and fittings
- Thoughts on 5.3/f1
- whats the difference with these coil packs?
- LSA vs LS3 Ignition Timing - What Gives?!?!
- 4 inch exhaust
- Dad's water tanks.
- Boost and timing at altitude question.
- Returnless truck rails and boost referenced regulator. Pics?
- Eforce boost reference question
- can Anyone can help me with 2step wiring off clutch
- lq9 turbo build help
- lq4 turbo build
- ARP head stud torque spec opinions.
- Leaky Blower? Help!
- Boosted C6 Guys. Is My Car Running To Hot?
- Snow Performance Meth Kits On Sale @ Hinson Motorsports
- Going twins on iron block, suggestions please
- wrapping up my turbo install, do i need/what gears?
- 98-02 Camaro Fascia Opening- Yay or Nay?
- Few pics of my Twin Turbo 5.7 forged setup
- Stock Radiator, Pusher Fans Hitting Radiator Support Huron Speed Kit
- What procharger brackets for d1 on 240sx?
- [VR] 891whp/786wtq ZR6X Supervette - RHS, MAST YSI - Pictures and Dyno Graph!
- Help with fouling #6 spark plug
- head help for boosted ls2
- tuned a 4.8t volvo wagon today
- Flipped manifolds and ruined coils
- L92 Longblock + LSA Supercharger - What Cam?
- APS Twin Turbo Kit LS1 Fbody
- Why is my injector DC so high?
- Why so many spun cam bearings
- Post up your best welds on your kits
- Please help w/ used Procharger instasll
- NW Chicagoland E85 Quality Log and E85 Info - Injector Goo Found
- What turbos for 441 LSX?
- '84 Cutlass 5.3L Twin BW Turbo Build
- Whats heads for lsx 427
- wrong section but all other sections suck.
- Truck fpr and boost
- Question about turbo cam
- GT45 with cam vs VS 88/83 no cam...
- Some e85 boost ?s
- Lq9 408 or LSX 427 or 454...TT or supercharged??
- Eboost2 mount in vent
- Thoughts on EGT probe location needed...
- Input on proposed 4.8 turbo build please
- AEM boost gauge not reading boost??
- 416 LS3 Turbo Camaro w/AC **ALOT OF PICS**
- gt3076......too much, too little?
- Looking for a basic Supercharger kit?
- Fast Track
- Camshaft Advice for Turbo Setup
- swaped in my ptc convertor tonight.
- Finally got track times : (
- First Start up with custom 94MM set up
- Intercooler help
- 8:5:1 compression skat rods and pistons what performance head should I run.
- I have an extra set of black LS1 Supercharged emblems for sale
- Please help Need help routing pcv on turbo ta
- Low coolant after turbo install.
- LQ4 vs LQ9 vs LY6 for Boost
- Waste Gate Exhaust Pipe
- rebuilt motor loosing oil pressure once warmed up!!!
- S475 still having back pressure issues??
- Eforce supercharger IAT sensor
- Ly6 help
- Does anyone know how to Change Procharger Belt? Help!
- northstar blower+ 5.3?
- Anyone use thse turbo's
- Anybody sell a SS GT55 exhaust flange??
- eBay WG Recommendation. Denmah?
- how much power would you push a stock lq9 crank
- sts twin turbo
- on3 turbo smokes (brand new)
- Procharger head unit upgrade worth it?
- Aftermarket cams for "Street" cars
- Realistic HP on stock ls1 cam, heads on turbo
- 408 turbo build.
- 6.0l voretec turbo ;) !
- Bosch 044 pre filter?
- 07 impala SS 5.3 turbo wanna do ls9 cam
- converter, turbo set up need help
- looking for cam, head set up for my turbo 347 c
- 408ci LS2 + YSI + Nitrous C5 Z06 Build
- New Accessory Products for those guys running Borg turbos....
- Project thoughts
