View Full Version : Forced Induction
- Turbo 402 for 80 TA.
- How are you storing your methanol?
- Help with fuel system for TVS 2300
- best turbo converter? yank/ptc?
- forward facing headers on a 00 silverado
- FI LQ4 Build Ideas
- Stiegemeier Porting Claims and Post Your Experience Porting Your TVS 1900/2300
- How do I quiet this for street driving
- Fuel and Air Limitation Guesses
- Ams-500 controller ramp rate function
- Looking Maggie Intercooler for High Boost
- Need Help with cam selection for Magnuson
- is this an 4th gen fbody intercooler?
- Results w/ video of swapping from TC78 to Comp Billet 7479
- ? for on3 No/AC turbo kit Fbody guys
- LS 280Z Build
- quiet turbo cam 402 ls2
- Twin s366 wastegates too small or?
- Stiegemeier Supercharger Porting???
- novi 2200 SL supercharger
- 38mm wastegate?
- Grocerygetter part #4 *autocross* !!
- Procharger or whipple supercharger
- 5.3 or 6.0 for my 60m Garrett twin turbo kit?
- Wiseco Or Diamond pistons?
- 408 S484 Huron Speed build begins.
- Turbo LS Long Haulers step in and school me...
- When to pull timing for IAT on 91 octane?
- Turbo 5.3 question
- Project Blackbird .Twin Turbo Build
- 240$ turbonetics turbo?
- Pcv valve turbo setup
- finally ran my car at the track, didn't do so well
- oil drain question
- TSP 408ci + Huron Speed T6 Turbo kit shooting for 1000+rwhp 8s 160+mph
- Turbo 408 stroker??
- EBC Setup Prior to Dyno
- Best turbo for M6 370ci shooting for 1000whp
- white smoke after boost out exhaust
- S475 on a STOCK 5.3 tahoe...
- Lq9 L92 Turbo
- F1r- standup rad- what fans?
- Do any aftermarket valve covers take factory fill cap?
- Feasibility of stacking MLS gasket layers?
- meth?
- Looking for TVS 2300 porting service and info
- Need help my my LQ4/LSA supercharger build
- snapped the crank in the turbo Ls9 RX7
- Paxton/Vortech supercharger fluid?
- Oil Smoke Issue
- What BOV for Twin Turbo setup at 8-10 psi?
- 700rwhp on a Budget?
- Drill a weep hole in wastegate body?
- Piston dish vs head cc debate
- Budget Rebuild Turbo 5.3
- SCG-1 users, what gain % are you running?
- gt4788/402ci trans am with heating issue...
- 2004 GTO procharger, turbo, or roots options
- Need inputs on exhuast for a 84mm turbo...
- Tick Performance True Street(Ultra) Camaro 5.14@137.49
- Blowing smoke until engine gets hot on turbo 5.3
- How to install meth and run 9s on a stock 5.3
- Turbo Oil drain fitting
- Tapping oil pan.
- Tuning with 110 race gas (9.85@138)
- Z Reborn Part II: Big boost, Big nitrous shoot LSX build
- Started the firehawk wicked1 new twin turbo build
- my new custom s480 setup!!!
- Which wideband with Microsquirt
- Benefit from a bigger TB?
- Twin turbo/cam recommendations
- Converter Lockup or turbo surge/wastegate causing hesitation? thanks NicD
- 5.7 budget boosted
- 4.8L E98 single blowthrough 1966 Chevy II
- Recommendations on Lq4 turbo/240sx swap
- LM7/S475 Reuse stock intake gasket?
- 05-07 lm7 or 2010 l33 for boost STOCK
- 62 gmc s475 exhaust question
- ctsv supercharger bypass valve swap
- T76gts flow rate
- Griffin radiator
- compresser wheel not spinnig at idle
- Wanting to turbo a 2000 TA, sponcers welcome,pics please
- Boost Leash controller owners, step inside....
- Turbo 5.3 280Z, "Reroy Chang" SBE 5.3/Billet 366/PG/8.8
- problems with first start up on my 98 turbo ls1 brand new motor fully built having a
- Is this cam ok for boost?
- Fuel injectors
- Like downpipe clearance? BMR is working on a new option for you
- Which set of twins?
- On3 LSX turbo headers
- APS replacement turbos ?
- Lq4 + LSA supercharger
- Mayhem Motorsports Ultra Street / True Street 275 Camaro making some noise!
- Dual or Single Valve springs for turbo?
- Solid mounted engine/turbo, what to use for heat expansion?
- V BOX users step in.
- 5.3 twin turbo question
- C5 owners that need a lower passenger alternator relocation on the cheap
- Engine Component Sale Wiseco, K1, Callies, RHS, & ARP @ Hinson Motorsports
- PCV Help LS1 Procharger D1SC
- Anybody running a two (dual) stage boost controller for better launch?
- vortech supercharged ls1
- When to meth ?
- Eaton M62
- anyone have experience with the precision x275 88mm?
- 5.3 Turbo Build Help Needed!!!!
- post pics of fbody with bumper exit downpipe
- high compression e85 turbo step in
- How thick is too thick?
- injector size for x275 turbo
- Turbo guys. How much on stock ECU?
- First build ever! Am I on track?
- Ebay gt35 power potential
- Updated Build Pics of the custom Turbo set up
- Curious Question - Avoiding Detonation with timing
- LQ4 s480, holley dominator build , back from chassis shop, VIDS updated 10/29
- Turbo 4.8
- Building a LQ4 twin turbo for my Jet Boat
- Best place to get a borg warner s400sx
- turbo 403 stroker??
- 1979 Fairmont 4 door - Bone stock 4.8, GT45 turbo, Powerglide
- Procharged 408 corvette advice!
- 317 or 243 heads on turbo build???
- Spark plug for 1000 to 1100rwhp
- Oil pan return drain fitting help!!!
- 1997 Camaro SS 5.3/4l80E 78/75 Turbo - 6.83@102
- Help Me Choose Between Two Turbos: Paging John Bewley
- Just your average every day 1450 rwhp Street car.
- Searching for a hose coupler
- holley hp help
- Turbo 5.3 gt45 '93 trans-am build.
- procharged, maf question
- Are there any Turbo LT1 guys in here?
- Head casting porosity ?
- Boosted 383 spark gap on lt1
- PT88 vs PT8285 vs ???
- Callies Compstar crank 1000whp procharged??
- 2.25 v bands or 3 bolt flange?
- Universal Downpipe Sources?
- Allpro Cathedral port heads ???
- The Blower Shop LSX
- 9.0 at 163 on true radials(not drag radials)
- Tryin to fit s476 with t4 V2 huron kit HELP!!!
- My LS-Turbo build thread : 98 formula
- What heat wrap for your hotside?
- HP Tuners issue
- Procharger guru's, I need some advice.
- 1998 vortec with Whipple SC throwing code for 17 years?!
- f1r procharger kit
- When do you have too much injector?
- $2000 Turbo Kit
- Loud alarm on STS turbo
- Procharged forged ls1 oil problem in boost
- Bearings
- 5.3, on3, 4th gen; started last week, won't start now .hpt attached
- Fmic
- Rx7 TT "Dyno and discussion" thread.
- meth vs bigger injectors?
- Catalytic converters and forced induction
- lq4 turbo help
- turbo oil feed?
- Stainless Works LS Turbo Headers
- 80mm gt45 compressor discharge
- Does this procharger torque curve look typical?
- 1 bar vs 3 bar question
- Oil inlet on turbo leaking
- Thoughts new intake for N/A 468 other than fast
- Removing intake fitting
- compression ratio advice
- LS Boat Motor help!!
- 5.3 turbo with truck rails and adjustable fpr ???
- Forged 370 guidance
- turbo too small? for twins on 418
- 230-240 ECT while cruising? boosted ls7
- s13 hatch turbo lq4 a/c????
- 98-02 F-Body Turbo Sway Bar HELP!
- Need a new intake for boost. what one though?
- 30GPH methanal injection, please post tune.
- I WANT 600HP!Whats your advice
- plugs lookin lean.. thaughts?
- List your fuel system setup
- Huron speed Group purchase?? anybody got kits
- procharger hat
- ebay turbo buid looking for some help.
- Live your car dream through me! Need help!!!
- Track Results from a PT7675 CEA to a PT8285 CEA BB
- could this reference port & line be too small causing hesitation ???
- What to expect forged/supercharged ls3 15psi
- First turbo car initial startup?
- what size and brand intercooler for 1000whp
- turbo 4.8 compression ?s
- F1A verse the F1A-91??
- any one have any experience
- First fire of Alchemist 3.0.
- P0106 map code help
- TT Ranger mega truck
- looking for wastegate and blowoff
- What size injectors should I run. need advice
- Any Run Harris Performance Controller or HPC for Methanol Injection?
- injector size suggestions for TT 6.0
- 900whp turbo auto car... what tires?
- fascia removal cx racing intercooler 4th gen trans am pics
- Steam lines / Surge tank?????
- FI build
- LSA Crankshaft
- My Build
- N/A vs Nitrous vs FI cylinder heads
- Help pls, forged 5.3, gtx45, low power figure
- Turbine Inlet Gasket
- Looking for reviews on Brian Tooley's cam
- Modifying stock oil pan
- Size of fuel line for FI
- Tap stock oil pan or buy an aftermarket one?
- High HP Procharged guys, need advice!
- Sponsors need help on cam for supercharging my 2007 silverado please help!!!!
- Bottom end options for LQ4?
- boosted ls1 heads
- Should I open the ring gaps on a non intercooled E85 turbo 5.3L?
- Consensus on IAT Sensor Placement on Meth
- Gear selection for procharger
- boost controller
- To stroke or not to stroke. That is the question.
- 900whp+ outa t4 onna 400+ CI motor
- 377"/PRC 260cc LS3/D1SC@13psi/93 octane=773/665
- Fuel rails for TVS1900?
- What should target lambda be?E10+30gph methanol
- what tires do you guys use/suggest?
- FI heads advice needed
- turbo questions
- Cant get the timing down
- turbo build
- sts-v supercharger on ls1?
- Help me pick rear mount oil less
- 10:5 compression on E85. How can I get more boost?
- Thompson Motorsports 370 baseline ECS 2500 Dyno
- Best MAP to use for 20 psi
- Solid mounting Rad and Intercooler??
- Wrapped downpipes, how close to fuel lines?
- 66 chevy II,twin turbos or a whipple?
- Moran's Billet Atomizers with Holley fuel rails?
- Low cranking compression. Possible causes?
- 4.8TT/T in z32
- which pulley should i get? for F1Procharger
- Anyone seen a belt come apart like this?
- Daily driver
- Opinions please
- My car is making this sound ???
- Ball Bearing Turbo Allowable Shaft Play?
- Huron tubo
