- E85 with no intercooler
- Want advice on spooling a larger turbo.
- turbo downpipe question..
- Anyone used a comp turbo?
- What size turbo
- What puller fans you guys running?
- Best C.I.D. for a TC78...?
- 150k dd
- procharger/ Head Help?????
- typical cost of turbo charging?
- Possible Valve Float
- Build Thread For New LS BMF Outlaw Drag Radial......
- Big time Turbo cam- you spec it
- Need a good tuner, Tulsa OKC KC
- Speed Unlimited President's Day Sale This Monday !!
- sts turbo build pics
- 2" vs 2.5" turbo piping for truck manifold build
- log headers
- tial 44mm and 60mm wg questions
- Twin Turbo with Twin Tial Wastegates Help ?
- ...anybody using stock head bolts with boost?
- +First build- 404+GT-91 **Updated Track results+VID**
- carb blower fuel question
- On the Fence Boost long block+ i need a vendor.
- TC78 + stock radiator location - doable?
- 3.5 inch dp on pt88
- Alky kit
- Garrett ball bearing turbo question powerstroke 6.0 turbo
- D1sc with pro flo valve need help
- Valve train question
- Another Poor Mans Belt Wrap Method
- Cheapest combo for 900-1000rwhp...
- need help from the turbo guys..what turbo?
- downpipe pix
- methenol injection
- D1 Procharger Help
- anyone have a used turbo cam for sale?
- EFI Live FI Users..2 Bar Sensor Help
- Time for change...Max effort iron 346...
- Procharger Installed..Oil Leak Now. Please Help!!
- LS2Formula New Personal Best 7.87 @ 179 @ #3695 Raceweight
- please give some advise
- Thinking turbo..
- which heards for 5.3 turbo
- Which heads TFS 225 or AFR 230 or ????
- Msd bap 2351
- 408 ls head suggestions and comments
- F1A vs Twin GT35 turbo setup
- 91 Z28 370/ST80/4l80E Build
- any trick to building a/w intercooler
- C6 manifold on passenger side = keeping AC on turbo setups?
- Stock crank/main saddles/bearings.good til?
- Twin Turbo Sizing Question
- Twin TC76's GTO
- Bent turbine, what do you guys think??
- pt-88 housing ?
- 100% turbo noob, admitting it ahead of time~
- Turbo Camaro build - TC78 + 4L80e + E85
- My new x275 legal turbo has arrived
- 04 GTO Maggie on a 02 Trans Am???
- 02 Z28 Turbo Project...
- What do you guys think about this cam for a pt88 370.
- P1SC Oil Change
- s-trim on a 383 ?'s
- Dyno shop in new york
- who all has turbo headers that keeps the alt. in stock location?
- cam to big??
- st78 or billit gt 42-76 for a 370
- Custom Twin Turbo Dilemma
- Started my custom rear mount
- Alt relocation belt problems
- Budget Turbo Engine Buildup
- Hi-flo turbo kit
- MagnaCharged 555 rwhp on stock motor
- Whipple question
- need help choosing intake
- Flowmaster Mufflers new contest - "Show us your flows"
- hot side pipe thickness?
- Procharger belt problems HELP!!!!!!!!!!
- Suggestions????
- Help .......
- Rear mount BW s475 forged 364 ws6 trans am. Begins soon
- painting procharger!!!
- which truck manifolds?
- Paxton Sn2000 for a 3rd gen fit LT1?
- Cam profile for Forced induction?
- intercooler and cooling?
- Need opinions
- Where can I get good boost line?(non rubber)
- LMR Standing Mile Update #2
- Exhaust routing for NOOBS
- turbo kits
- Does it matter what a turbo comes off of?
- LS9 headgaskets with a 4.005 bore piston?
- sts turbo build
- What heads are good for a 390ci turbo motor
- Procharger D1SC impeller?
- Turbo VS Procharger
- Best Engine to Boost?
- holset h1c
- pte 7682
- Q on re-torquing head studs
- Bypass Valve Location ....
- completed pics of my 25-3 cage C6 Z06
- Scorpion 1.7 Roller Rockers or Upgraded trunion stockers?
- 4l60e
- Supercharged engine pics
- I want more power what would be the best setup for me?
- Turbo Hot Pipe design/ log's vs headers?
- Want to maximize current setup, opinions wanted
- Hey any one ever seen the ARP 2000 7/16 bolts break ?
- What's it worth?
- Vortech supercharging my LS1 swap. Help!!
- Twin TC 67, 70, 72, or 76
- good turbo cam?
- boosting the LQ9 a few questions
- Questions on Maggie 112, and 112H, 112HH
- waste+centrifugal!!!!!
- can I get away with this cam until rebuild
- Lets talk correct Turbo air filter size
- Champion Motors 1082rwhp dyno video
- Turbo 94 Camaro build
- Need pics of twin turbo f-bodys
- open letter to Spohn about your solid motor mounts
- What's a better turbo rear gear?
- MAGGIE Wheel Size.
- Which spark plugs for Turbo
- Upgrading...Again....Goodbye P1SC, Hello ...
- ls9 head gasket + ls1 heads + ls1 lifter = what pushrod
- EBC location pix
- Help me plan my boosted LSx build
- Ar distribution issues on lt1/4 f/I apps
- Using a FMIC on a TA?
- ProCharger Front Mount Intercooler for 98-02 F Body
- I need some turbo input
- All this activity and no timeslips?????
- Cats or No Cats with Procharger and True Duals
- F1-A on a cam only GTO
- Hydrogen Cell
- Would the stock bottom end be OK?
- LS3 stroker durability as an FI engine?
- forged 347 d1sc reliability
- **Wanted-LSX Mechanic**
- Noob FI questions. Take a look at my parts list please.
- Backpressure question
- Dual wastegates?
- What size turbo for my sts
- T70 on 6.0??
- New build Info and Sponsors added 2000+ HP Build
- On the right track to FI?
- Pics of BWS400?
- gt-3582r upgrade to ...................
- Vengeance Racing custom Twin Turbo C6 Z06 build
- what maf sensor do i need?
- thermostat for griffen radiator
- Stock Head Gaskets Question
- Piston selection... Wiseco K444X3
- Jaw dropping turbo engineering at its peak
- head selection: tf 235 vs mast 256 square port????
- AES Block Coming Soon!!
- So i had no idea what i was getting when
- 370 rods and pistons
- Mustang MP 112 supercharger??
- 25-3 Cage is done in my C6Z06, 7's this year!
- Procharger fmic
- 237/249 .585/.585 115lsa +4 is this a good cam for d1 ls2
- Pics of the pro-mod!!!!
- anyone sell already done spark plug wires with 90* boot for plug?
- ChevyChad pulley mod on F with D1-SC!! Having problems installing! Pics inside.
- Solid roller cam?
- need help on turbo identification
- In need of a cam
- Big KB Blowers
- is a tc76 a direct replacement for a Mpt70? lines,v band etc?
- Return line: Pics needed
- which pulley??
- Methanol + Vertical Radiator Mod
- Newb to FI...So a newb question
- Merge pipe- will this work, or?
- divided t4 and spool
- procharger a2w intercooler
- Ls2 formula build
- Need your opinions...Greddy Boost Controller or AEM Boost controller.
- F2 procharged 408
- Need push-rod advice please
- BEst cam choice for my forged ls2 d1 procharged
- S/c ls? C5
- D1 procharger with 3.4 pulley... How much boost will it make? and what size injectors
- 1500HP Build: which TB?
- cary intake on lsx TT
- pt88 oil feed fitting size?
- looking to finish up my 408 short block have a few questions
- Fast 90mm for high boost
- ARP singles?
- 6-71?
- EPP Front Mount Intercooler
- Alky Control Questions
- Adjustable boost supercharger
- Meth vs n2o
- Intercooler question
- Final stages- PTK FRC PICS
- MPGT45 vs. PT76GTSH on a 370ci ?
- NEW TO F/I. Some Newb Questions?
- TC76 vs TC78
- 5th Gen DIY Turbo Build
- LQ4 or LS2,3,6, what is better for tub or supch
- catch can to close?
- Fans
- How is the magnacharger tvs 2300??
- Little teaser shot...
- Need better Drian lines!!! APS
- precision hps vs gts ?
- anybody recognize this car?
- Tick Performance ProCharger BLOWOUT: Installed AND Tuned @ $500 Off Retail!
- How to measure Procharger Pullies?
- Boosted GMPP LSX 454 Cylinder Cracks Like An Egg Shell
- wastegate?
- Help!! vedio of red race bypass
- How would an LS9 cam do with L92 heads and turbo?
- Fast Or Vic Jr ?
- Turbo guys be careful...
- Egay Kit out, Truck mani's In!
- PVC solution for Boosted Motors
- Estimate on what RWHP will be
- Adding Turbo To LSX Swap -TELL ME WHAT TO BUY! PICS ADDED OF BUILD
- Tried to dyno 383/ST80 with 4200 stall
- How often should you change lifters on a Boosted Car?
- Pusher Fans
- personal thoughts
- stock ls1 with 853 heads on 91 octane boost?
- Turbo prices...
- whos runnin stock lifters?
- Best place to mount computer in a 68 Camaro??
- Ls3 vs. 317 heads
- Will C6 manifolds fit LSX block and heads?
- Trans cooler in front of intercooler
- Supercharged 3.8l?
- Is this something to consider for boosted applications?
- Coolant Tank Relocate
- L92 and LSA heads on 20 PSI
- check it out
- JDM's turbo kit ?!
- Recommend me a turbo!
- which spark plugs??
- 1000+ HP Guys... What Oil Pump Are You Using?
- first time turbo
- Changed my build
- head install with arp 12pt
- schedule 10 stainless steel piping
- head gasket blown already, few questions
