View Full Version : Forced Induction
- Cam and springs for 4.8 build
- 4.8 twin turbo or single turbo
- Already supercharged, going forged...much research has gone into this, thoughts?
- pick apart my build
- How do you feel about treadstone?
- 1970 caddy sedan deville(sinister) lq4 s475 turbo cam=)
- 2000+hp CTS-V build LOTS OF PICS
- 5.3L torque monster...
- STOCK 4.8 with 80lb injectors and gt45 "kit"
- Factory to 3bar map... Will it run?
- cutting universal intercooler pipping for a camaro
- ASP Pulley for blower?
- Is this detonation?
- Holley EFI 105mm TB
- question about what heads to use on a 5.3
- map sensor
- Just your basic turbo motor
- Help choosing single turbo for 6.0L 1200HP
- Combo opinions
- New best with the 4L80
- Need some help with gearing!!
- Converter too tight??
- Acceptable amount of engine movement? (Cool turbo video inside)
- The 65 Buick/LS/turbo is alive
- hc turbo spark plug help
- Header question on procharged engine
- LM7 Z28 Build Questions
- 5.3 L33 Turbo, Help me choose a Cam
- Those running the Aster Bracket, let me know your pulley/belt lengths
- 853 vs 799 heads
- My Budget C5Z TT Build
- lost all boost pressure
- Ls3 valve limits
- Head choice for 408ci 91mm turbo
- numbers game
- swapping to 2.73 gears......
- How would these two turbos respond?
- G-body + Ebay headers. What you using?
- Physical size difference bw475 to bw480?
- Turbo Ls 408 won't idle
- Scavenger pump question
- Turbo Beanies
- Twin turbo foxbody newbie
- 383 + F1A Build Thread
- 347 t56 and twins
- Tell me about a T4 single kit and 390 cubic inches.......not good....?
- single or dual fuel pump opinions please
- Proper dyno tune sequence
- 5.3 Build
- What springs to use for BOV & Wastegates?
- Fuel System Help....
- Using Truck Manifolds for Twin setup located on block sides
- current pic of malibu wagon with tubo'd l33
- 440lsx Gt55 Garrett Wasregate????
- on3 76 or 78mm turbo
- Best cutting device for hot side tubing?
- Turbo size?
- Graph. What do you guys think?
- What Converter you guys running? Please step inside
- Borg Warner Turbo S400SX4-75 1.32A/R T6 Airwerks 171702
- Leakdown shows I need to revalve LS6 heads. How bad will that mess my tune?
- How a turbocharger is made
- What is the best place for boost control solenoids
- my d1sc lq4 build
- Tube size for wastegate crossover?
- Trunk mounted ice intercooler tank
- 1700HP TT Glide 9" C6 Z06 Build
- Manley crank and reluctor wheel problem
- Aster bracket tensioner question
- Turbo setup advise/help
- New 408 t6 91mm turbo set up
- 120k mile gto... is a tvs2300(6psi) safe
- D3PE Presents The PumpKing LSX F1X World Record 1491whp/1169tq
- Forced air newb. A couple questions.
- Oil dipstick with Turbo headers?
- What is the best intake I can ause on a 6.0 trans am and keep the wipers
- Opinions on ETP 255cc heads for my combo?
- Vendor with best prices on bw turbo?
- L33 for boost
- Ideas to help keep car cool? High per water pump? Rad?
- 2013 Camaro SS with boost ,what plugs and gap ?
- Best place to get a turbo...?
- Need turbo ideas! Post pics of downpipes exiting driver side
- Finally got the car Dyno'd
- Another: FI vs NA thread...
- first start up and build questions?
- Fuel and Headgasket.
- 317 unported @ what lift does port stall
- Midwest turbo rebuild shop?
- '96 silverado lq4
- tc78 to s475/96 swap q's
- F1a and inlet screen
- how much meth can you run w/91
- 75 Chevy K10 w/5.3l s475 build thread
- E85 will it gum up injectors?
- 87 octane + meth? Need advice
- Boost reference on front vs rear of intake
- Anyone running AEM failsafe gauge?
- [VR] C7 Corvette - 851whp/794wtq - VRSC850 Package - Build pics and results!
- 09 9-7x Aero Procharged
- ZR1 SC'er......anyone fit one in an F-Body.....?
- True Pig build twin turbo 280z
- vacuum pump needed? if so what kind?
- Twin Turbo Caddy Exhaust @ SNL Performance
- Turbo aluminum 5.3 do I need a main girdle??
- Rotella T Conventional, Rotella T6 Synthetic, etc 15w-40
- f body up and foward turbo headers
- X02 BOV Leaking
- Finally got my truck ready and dynoed..
- Fuel lab filters
- 2" TSP Stainless 4th Gen Fbody Headers
- 10° max mounting angle for BW S480?
- 58 tooth or 24 tooth reluctor wheel?
- Header Pipe work
- ? boot in PSI to increased compression ratio, is there a formula ? TIA
- Turbo setup Cam question??
- 7 or 11 blade billet wheel?
- 800hp with a 044 pump?
- [VR] 675rwhp / 584wtq C7 Corvette - VRSC750 Package w/Methanol - Build pics/dyno
- T Trim, Novi 1,500, Novi 2,000, D1SC Headunit. Anyone have one for sale?
- 1999 PCM/FMU question
- Cfm= HP ?
- Mid mount turbo questions 04 silverado
- Who builds the best 6.0L for boost ?
- optimum compression ls3416 boost
- Anyone Ever Use Variable Vane Turbos?
- ebay twins or single bw cast for budget 6.0 build
- Walbro e85 450 pump enough?
- LQ4 Stock bottom/TH400/Moser 9"/S475 build thread
- New Member, New Build. Lots of ???'s
- Most boost on LY6 with MAF
- Turbo PSI question.
- what valves are best for 16 to 22 psi
- twin turbo 6.2
- Been out of the game for awhile....
- 806 heads and graphite gaskets?
- I have an Idea, tell me what you guys think
- Alternator spacing brackets by D3PE!
- LJMS Air to air intercooler... now available!
- Will an S480 lag more than desirable?
- Overspinning a D1SC blower: Your thoughts?
- lsa super charger into ls1 camaro
- brute speed ls2 water pump
- Boost Reference Lines for LS6 Intake
- Stock 5.3 vs Normal upgrade "Stock-ish" 5.3
- Garrett GTX4508 on 5.3L???
- Are my heads the best option??
- I beams or H beams for ls3?? also rate my build
- Two wastegate ?
- In desperate need of help to resolve boost issue.
- ATI Under Drive Pulley
- 97/98 oldschool c5 heads and composite gaskets, low boost
- New 85 and 88mm S400 Borg turbos are here!!
- ATI super damper, steel or Aluminum? for a Turbo car
- Useless Threads
- Best knock sensor location?
- Gen3 VS Gen4 Stud length requirements…
- A/F ratio through boost range
- sn95 lsx turbo kit help (budget friendly people only)
- 1010hp 16psi grocery getter & can pull a trailer
- Vortech / ls1 intake swap - belt wrap?
- Reverse split cam with a supercharger ?
- 2000 firebird formula turbo ls1 build
- Latest & Greatest - Huron Speed V2 A/C Turbo Kit
- Another cam & boost question
- Twin turbo/T56 to 4l80e/ standing up radiator build thread!
- Need to clean up engine bay/ vacuum lines ideas?
- Pulley help on a TVS 2300
- Exhaust wrapping
- Wastegate placement.....
- Lucas Ethanol treatment & E85 Goo
- Mega Truck turbo sizing???
- Issue with supercharger and brakes
- Blower cam suggestions?
- 2013 turbo camaro mass air placement
- Procharger D1SC build question????
- Best all around boost controller
- Magnacharger 1900 on my LS2 GTO
- LSA Supercharger question
- Joshua Jenkins former owner of Ky turbo Update
- How do i modify a return-less fuel pressure regulator
- Holley EFI methanol twin turbo turner in the Midwest?
- what turbo cam should i go with
- Tvs 2300
- 98 trans am front mount intercooler install ?
- [VR] 416c.i. YSi Supercharged LS3 C6 Corvette - Build Pics/Idle Vid/Results Inside!
- Sould i pulley down a size or no?
- Start to finish, how much did you spend converting to an aftermarket ECU?
- Gearing
- What coils are you guys using?
- exhaust flange pipe for bw s475
- LQ9 CTS V Supercharger questions
- Ls2 street/strip supercharged suggestions
- On3 turbo install instructions
- P600B ls supercharger kit
- Water cooling line for turbos from coolant drain plug
- Hummer H2, turbo, procharger or blower?
- Lets talk big turbo, 6 speed, and spooolllll
- 408 stroker turbo question
- Cam Change and Tuning
- single turbo c6 corvette
- Recommendations for twin turbo oil drain lines
- Spark plugs for twins?
- 1993 YJ Wrangler 6.0 4L60e w/ON3 Truck kit
- On3 70mm turbo on a 5.3?
- Trans cooler and intercooler on 67 Camaro
- intake manifold selection
- obx cross ram individual throttle body intake
- wastegate spring proportion advice.
- highest reliable RWHP for a 408 boosted LS
- GT 4788 on 5.3 to big?
- Want built a lsx engine for big boost application on a cts-v need help for my set up
- Fuel pump for carbed turbo 5.3?
- Would you run this head on a JY motor?
- Will this wastegate placement work properly?
- ProFlo Surge Valve
- Turbo Advice on 555ci musi/edelbrock chevy
- V band clamp reducers
- 1987 Grand National LS Swap with 76mm Turbo
- hot side piping size
- need help with heads for turbo build on my 370
- Which cam & fuel set up for 4.8 D1SC Silverado
- LS Swapped 408 Billet ETR-HO S484 Toyota Tacoma makes 1050rwhp
- Whats Fasteners Are Needed for Turbo LY6?
- L92 with Procharger P1SC cam??
- on3 performance: buyer beware
- which plugs for boost prc ls3 heads
- Why must I use a t6 set up for my motor instead of t4?
- Holley HP EFI no start
- need help building a twin turbod ls 6.0
- 1969 Nova SS - 5.3 - Holley Dominator - S480 Build...
- Procharger Truck Hat Users HELP!!!!
- 1998 Turbo Trans Am
- Ls7 procharged RMS orentation opinions
- Ati super pulley?
- Tial BOV
- Turbo Air Filter?
- Will this turbo work? New edge mustang
- STS kit showed up today
- low boost d1sc
- Buying a Forge block
- kit like APS or CAS?
- What cubic inch is too large?
- Hugger orange TT project Progress pictures inside!
- stock lq4 fuel pressure regulator and boost
- FAST intake boost limit
- Boost limit recommendations?
- calico coated engine bearings for turbo motor
- Turbo for a stock 5.3
- Turbo LQ9 questions..
