- my car made it in car craft magazine
- turbo stock bottom 98 ls1 efi or hp tuners?
- 3rd and 4rth gen similarities
- anyone have any info on callies Ultra billet rods
- I think i'm going to change my 2.75 gears
- boost on a stock ls1 crank??
- Help Identify Turbo
- Pics of your cold side
- Are turbos all the same?
- oil pump delete
- Questions on running VVT with Boost?
- Garrett GT-91 turbo
- AES 390ci - Now with Callies Dragonslayer crankshaft
- intake elbows
- Regal+6.0+turbo in d/s front corner=how do i run oil feed line?
- what do I need for a d1sc on a stock trans am
- Kytp Tube Header Issue????
- twin MP 70's with .96ar's??
- Catch Can Special For The Holidays!!!!!!!
- carb vs efi need help
- procharger p1sc low miles
- need input on the last components for my truck mani turbo build
- Anyone use Arizona Trubo's for their project?
- APS TT System parts?
- front mount intercooler kit for 2002 TA
- vband questions
- who's running a budget 347 or 370 shortblock?
- 415 LS3 4.2LC Twin Screw Supercharger
- hand ported 853's vs cnc'd 243's
- Procharged LS1 tuning issues
- Old guy, new company. Hello from GSS Speedshop
- Stock AFR 225 72cc vs CNC ported 317s
- keep my turbo headers or build a manifold kit???
- Need a suggestion for a converter and tranny.....
- wastegate position
- synapse wastegate
- Need help getting a turbo plan together
- Question about 6.0 manifolds? Come on in please.
- L92 Blower Cam Choice
- Alky meth kit, but need windshield washer
- 4 Thoes who have removed hood latch
- twin s400????
- 408 turbo camshaft
- GTM turbo fabrication
- injector help
- Whats the limitations with boost an 98' PCMs again?
- 91mm Thumper, too much?
- Anyone boosting with iron 6.0 heads?
- Question re: spark plug choice and turbo build
- any one have good luck with carb set up with turbo?
- What Transmission are your running for ur boost?
- GT-88 408 Dyno Graph inside. See what you think.
- Divided vs undivided
- coolant coming out by head gasket
- Having problem with rwhp
- Ls6 turbo mustang.
- Need opinions on turbo
- 80mm turbo
- TVS 2300 Install issue
- Cam help?
- kentucky turbo kits?
- air to air twin turbos on an ls1
- Procharger rotation
- i'm going to set my car on fire
- ls1 alum block help
- Fastest 1/8 mile Roots Blown LS anything anywhere?
- Ideas of what kind of power yall think this setup will make
- Need some cam help
- Scavenge pumps
- Need Oil Pump for Maxed out D1SC
- Fuel Pressure Problem
- check my pcv setup
- EGT gauges..anyone here using them?
- turbo kit 1000hp
- I finally got my car on the dyno today. Please take a look.
- custom cam or off the shelf cam?
- exhaust
- Electronic Boost Conroller with Scramble?
- Would this be a good turbo?
- S88 oil drain canton pan advise plz (pics inside)
- Garrett GT4708 Opinions on a 370 LQ4
- looking to learn from your experience d1sc install
- Quick Question
- procharger twins
- Truck manifolds
- k member question
- 5.3 Turbo Cam Choice
- Suggestions for my upcoming build?
- Would like some help with turbo and parts selection
- Built 347 Seized
- ***LMR Reality Show Clip #7**
- Question On Wategate, Blow off Valve, and Boost Controller
- One empty box. Need suggestions.
- Any D1 or F1 Cars in St. Louis Area?
- boost question!
- 2001 RCSB GT-42 Build
- Worth switching?
- Wastegate selection
- Is this turbo too small?
- LS6 help
- need help on figuring out a FPR to buy
- Choosing a charger
- 5.3 bored to 3.905 w/ forged internals, 1k whp capable?
- cheapo FI PCV stage 3 or something
- Supercharger guy What gears
- **LMR in Las Vegas for Street Car Nationals**
- 90* bends = restriction??
- Introducing the Aster Auto Spring Loaded Tensioner Bracket at Brute Speed!
- Cheap turbo setup
- map sensor?
- SDCE (SD concepts) fan and shroud for procharger
- pump gas limit without methnol
- **LMR Episode #6**
- need help with vacuum hoses for wg and bov!
- v3 t trim
- procharger install....relocate cruise control?
- Ls2 d-1 procharged questions???
- Should I buy this Garrett 88mm turbo? **Pics now added**
- Fi on a lsx 454 ?
- Turbo airflow + filters question
- Change Of Heart - Procharger Now
- 423" Boost Shortblock special
- putting a blow thru maff on my turbo setup?
- new best
- Relation between IAT's & AFR
- RPM Motorsports Built T76, 370" Z28
- best supercharger for a chevy 355
- turbo piping?
- Running more than 2 bar of boost on a 2 bar tune
- Fbody STS kit
- should i keep my factory stroke or 402 stroker with D-1
- finally maken the switch from NA to FI tell me what u think about my setup
- Simple alt. To dual breathers? (blowing oil like crazy)
- cool website for helping pick a turbo
- Result of leaving at 4300 rpms and 8 lbs. of boost
- want your opinion for my build V.S91
- will these work for my app/goals?
- can a turbo work well with a stick shift for drag racing?
- whats the box in front of the wheel below the framerail?
- Turbo cam
- Mast cathedral port 245 heads+370ci+F1R+E85?
- New best again, getting there!
- Anyone know where i can find a 4" to 2.5" 90deg silicone reducer?
- ebay intercooler HP limit?
- TURBO CAM (match or rev. duration)
- 1948 hp :)
- 408 stroker
- Speed Inc. Twin Turbo 1965 Chevelle Malibu
- 408 ls twin mp70 build.....
- 5.3 Vortec Ls ring gap compression ratio
- Supercharger To Turbo
- turbo all tacked minus the wastgate
- LS1 and D1SC, what cam?
- HELP ME PICK A SET OF HEADS! (AFR vs Trickflow)
- Speed inc Thanks!!!
- Start with the heart... teaser
- Stock Ly6 VVT cam or LS2 timing swap and perfoamnce cam
- Garrett turbo model # breakdown
- Wideband not working or is this normal?
- Turbo Car PCV Question
- does compressor side affect spool at all?
- what MAF? turbo setup?
- Anybody know where this shop is?
- Turbo GTM
- do sts turbos really work?
- What block prep for the high HP 347's?
- is a s475 to big for stock 5.3?
- 418ci lq9 block ... want to boost??
- Brand new TTY main bolts vs ARP mains with built bottom end?
- Mr Freeze meth injection??? Anyone use it?
- Help
- whats a good meth kit?
- Trans brake/ 2 step launch
- Ky Turbo System
- few procharger questions
- 370 inch and EZ-94 turbo
- **LMR Reality Show #5(RC)**
- stupid ? about twins
- How to Clock turbine on TC78
- Worth it to ditch the ls1 for the ls6??
- little bit of a wheelie finally!
- if i switch from my twin 57s what single would work
- APS TT kit
- 383 + 2 x gt4788 =....
- 5.3 turbo build,?about 1.8rr.
- Opinions on this cam for blown app... Specs inside
- Episode #4
- Single turbo or twin with small shot of spray
- New PB for Armando in his 99 Turbo Formula @ PBIR
- Artic White 67 Camaro Forged Ls1 Iron Block Turbo Build *UPDATE 4/5/11 X-OVER WELDED*
- what the limit with a tfs and stock rocker on boost?
- Welding V Bands To Truck Manifolds?
- are flat top pistons ok for a supercharger? thinking of buying used motor
- thickest headgasket
- Spark plugs/ground straps
- Rings for Boost?
- Power Potential
- Couple Questions...
- LQ4 forged pistons, stock rods?
- Oil feed??
- BOV as a BPV...
- speed inc sc2 cam
- TR6s+pump gas+18degs of timing+700rwhp= a bad thing????
- ROUND 4, LQ4 TC78 Front Mount GTO
- MP70 rebuild kit?
- Looking for turbo kit
- Anyone make a 6 rib crank pulley larger than 6" OD?
- 12psi Procharger, alum elbow - keeps blowing off my tb?
- 5.3 with t60s - what to expect?
- 10.5 Cr/ 18 psi/ E85
- ***LMR Reality Show #3***
- New PTE 71HPS HP turbo, how tight should the shaft be??
- My new single turbo build !!!
- use my fresh lm7 5.3 or a alum lh6 5.3 boosted?
- Procharger BOV
- Time to Super Charge My Camaro
- starting my t-76 rearmount build im i missing anything guys a little help plz
- Is this air filter too small???
- ls1 vs 5.3 vs 6.0
- Critique this 1000rwhp TT GTO combo
- SLOW BOOST...Are my turbos mismatched?
- What else do I need? (piecing a s/c together)
- RPM Motorsports 1000 RWHP 2010 Camaro !!!!
- Procharger Kit
- When is somebody gonna break the LSX record?????
- how much (if any?) could i spray ? based on my set-up ?
- What adapter for brake booster line,boost/vacuum gauge
- Stock tb ok for turbo? Also choosing turbo size advice.
- Need help guys,2nd forged ls1 blown up this year.Whats my problem?
- Sponsors that sell pt88s
- My completed front mount turbo kit (finally)
- Fuel Lab 42402 or Magnafuel 4301 for big boost
- AMS-2000 is coming
- 6.0 block..stock stroke, 6.125 rods..what pistons for 9.5:1 with 72cc head??
- Whats your thoughts on useing stock short block
- weird SC setup fround on CL
- tuning for different boost levels.
- Air/oil seperater anybody running one?
- what would you run!!!please people with experience NO "BOZO" COMMENTS
- Differences between sbc and lq4 procharger kits
- ***Late Model Racecraft Twin Turbo Corvette makes 1300rwhp on Pump***
- Kind of new member just saying hi check out my setup
- is melling oil pump good or bad?
- Stage I Water/Meth setup! $270!
- Bunch of passes packed into 9 min of video from our Track Rental
- 317 heads + 15 psi = o-ring?
- what turbo might work?
- Street car, twin turbo, no intercooler... just meth inj?
- Magnuson 2300 sucks...
- Dynoed my setup and quite happy
