View Full Version : Forced Induction
- advice on 4.8 turbo builds
- ARP head studs for L33. 234-4317 or 234-4110
- Wideband bung location on downpipe?
- Flipped exhaust manifold dimensions for Mustang II front end (help)...
- pt 88 turbo shaft play already
- Cam and Torque Converter for Procharger Setup
- Anthony Manna wins LSX Drag Radial and sets new class record 2014 LSX Shootout!
- Pro Charged 2000 SS Camaro
- LS1 D1SC Torque, Stalled Auto
- 1982 Fairmont Futura
- F1 cog belt questions
- need help
- help with borg warner turbos
- LJMS equipped cars Dominate NMCA LSX True Street in Indy.
- 76mm with 5.3 straight e85 no intercooler?
- Ring gap?
- mast ls7 heads 285cc
- Big thanx to Doug@ East Coast Supercharging(ECS) 914rwhp novi2000
- Need help, why didnt i hook off the line?
- Help me diagnose this :)
- Twin Turbo fender exit exhaust
- dyno numbers
- Tu2 hurt more than help?
- Lets see those On3 Turbo Ls builds!
- Re-gapping rings, what are you guys doing about rod bolts/bearings?
- Progress on the shop turbo street car.
- Anyone with Huron Speed V2 Single T4 Turbo Kit oil drain question
- two turbo LS cars just under 700whp? just another sunday lol
- getting rid of vortech and going twin turbo
- to big of turbo?
- How to option my Holley Dominator???
- 1971 Chevy C10 Stock bottom End LQ4 10.1@133
- 2002 Camaro SS AC Retaining Turbo Build
- Turbo gears can it work ????
- need help which turbo for project c10 opinions welcome
- M90 on an LS1
- procharger pulley size
- Good IVO\IVC\EVO\EVC for 383CI blower cam??? Would this Tick Performance cam work ???
- Help Choose Cam for my Turbo Build BTR Specs listed
- 58-64 Impala/BelAir/Biscayne turbo build help
- Noob building Turbo LS1 Nissan Sand Truck
- Exhaust sound help
- will the car start with 60lb inj without a tune?
- What is the best product to "glue" heads on??
- ATI ProCharger Supercharger kits for the 2014-15 Chevy SS Sedan
- Open flange on a divided turbo?
- My turbo project "1FastSS" getting ready to ship
- Vengeance Racing | 2015 Tahoe Lays Down 423/424 with Whipple Supercharger!
- what turbo for a 370 street car? opinions welcome
- winter turbo setup
- 5.3 with ls7 heads and 70mm turbo work?
- What V band is on the FI s480 standard Compressor cover?
- WG Placement
- Problem with 2012 GMC Sierra turbo
- Proven HP numbers with single Walbro 450 w/E85
- cnc 317 heads ?
- L33 s475 BW Fuel pump question
- Meth Kit or 2 step : What should I buy first?
- Alternator Brackets these days?
- Compression for my ls E85 motor
- knock sensor and oil on head questions
- prepping ls1 for boost. what else should i do?
- SC Dedicated belt vs 8-rib All on one
- dedicated turbo oil system, Ideas and inputs welcome
- Any reason I shouldn't run this cam and springs in my budget turbo build?
- Any point in custom cam?
- Quickest and Fastest with an 88mm turbo
- Blow-off valve location
- 5.3 questions
- Keep nipping the #7 plug.....
- 2014 Tick Performance Customer Appreciation Day Pictures and Videos
- how slow will it be
- Vortech V2 Question
- how to properly set up a horizontal mounted intercooler. What do you guys think.
- Shorty headers on mid mount twins LSX 5th gen
- twin turbo kit from ebay
- Help Me build my first turbo Car, Huron Speed kit ???
- looking to buy a supercharger kit or turbo kit
- K1 billet H-beam rods???
- Horsepower numbers for vs Denmah kit?
- Gen 4 YL6 6.0 block
- Turbo 383 idle hangs after WOT pull.
- LS1 with GT4294 blowing blue smoke after coming off boost
- Help choosing intake
- LS1/t56 s14 here - Turbo build coming soon
- Almost tossed a belt
- Magnafuel regulator & boost control
- ***biggest numbers out of twin s366's***
- Lsa head on a lq4
- Which brand throttle body?
- Supercharger or Turbo?
- Porting heads after valve job has been done?
- 370ci turbo build questions
- heads for boosted 408
- LQ4 or L99 for boost
- about to order a new clutch. which weight flywheel?
- New PB, 5.6 at 123mph 1.28 60' ...317s
- First Turbo Build
- Need help with twin turbo set up.
- Supercharger CI motor
- Turbo Review; On3 Billet BB 67mm
- Planning my turbo set up, input/ideas welcome.
- Best 3 bar MAP for 411 pcm
- 2010+ Camaro turbo kit
- Procharger price increse coming 11/03
- Burkhart Chassis LSX Shootout sale
- 317 heads
- Question about making turbo headers (twins)
- 80lb or 100lb injectors
- 67' Chevelle back halved, Caged, painted, It's hot side Fab Time, Help!
- LS9 Cam
- hooker manifolds
- **SALE ENDS TONIGHT! huron speed summers end sale!!**
- f1x COG driven
- Sts turbo replaced with oil less comp turbo
- 2004 gto blower help needed.
- Largest Procharger available with truck brackets?
- Turbo mounted in front bumper??pics?
- which intercooler
- Stock 48 @Holley.com
- Completely STOCK LS1
- Looking for a popular boost reference FPR that can flow 75+psi and has -08AN+ ports
- HELP 4.8 Bonneville motor
- What truck manifolds are really made of
- help me with choosing great heads for FI
- Header coatings
- Need help with a setup
- Pics of t6 divided hot side anyone?
- C6 ECS supercharger owners: Improve cooling and intercooler performance
- Safe timing for pump gas
- Steam Ports (tap to 1/8npt?)
- What Radiator Fan setup would you do the first and only time
- loudest 60mm bov
- SN95 Built 370-L92 headed-78/75 turbo Build!
- Who's had overheating issues switching to turbo?
- Stock car to Race Car.....??
- 98 Camaro build thread. L33, GT45, Tick cam..
- gt45 failure no blow off?
- 1.25 or 1.10 AR? S476R T4
- Looking for a Dyno in the Michigan area
- Meth/ tune question Centrifugal Supercharger
- Boost by speed control - sensor hook-up to Holley HP
- Twin outlet for holley 1800 pump... anyone use it?
- Need to upgrade TB?
- 2 bar MAP
- Counterfeit shooting for 8's on 17's
- Shortblock options?
- Dirty dingo turbo manifold?
- Procharged car problem
- Head gasket issue
- TB questions?
- Specific Hobbs switch??
- Spal fan install (d1sc 01 trans am)
- S-10 turbo builds. Anyone have any pics
- Grand national turbo on an lt1 ? Thoughts..
- first turbo car, should of got one a long time ago
- Turbo Recommendations
- best turbo kit
- Just mounted an Awsome set of D 585 coils, now Knock
- E85 help
- Turbo help. Hp tuners, dominator or fast
- Drivetrain loss
- 5.3 turbo build
- Not Enough Fuel Pump? (Video)
- Supercharging an LQ4 questions
- Blow Thru Cam Thoughts
- Huron speed twin turbo week!
- 5.3 ERL super deck I block
- turbo selection
- water line routing for a2w on f-body
- injector help
- basic boosted LS compression question
- procharger guys or mechanics
- Twin Turbo LS1 Jet Boat
- Question on twin turbo size
- 5.3 turbo, or 243 heads cam?
- Dual rear calipers
- RHS Block Reliability for Big Boost ?
- Cast Iron manifolds for ls motors
- wastegate size?
- FI question
- procharger cam question
- Correct Turbo Size?
- Fuel Bucket/AN lines
- 427 TT '65 volvo wagon ( V-Rex )
- 07' Classic Silverado rebuild, 408 and FI billet S484/96
- Where did you guys mount your boost leash controller?
- billet 475 vs billet 480
- Tial DEALERS (GT55 VBAND Housing)
- Will These Fit an LS1 F-Body?
- Any twin turbos with hydroboost conversions?
- 600hp turbo ls1 cam?
- Piston recommendations?
- ls9 blower questions
- breaks up under load
- BW k29 and 5.3?
- Turbo Trans Am Build "The Whore"
- 219\224 lift is .634\.610 114 LSA
- Which turbo between
- PB Ran a 9.75 at 140mph.....now what do I do?
- Iron 5.7 turbo?
- Non Intercooled E98/E85 timing
- New F-1A blower! ATI PC325A-001 F-1A-94 3.70 new design impeller, new 9” volute
- S400-78mm
- Rear mount GTO?
- need help with boost builder holley efi
- Steering shaft interference with manual rack/Huron kit
- PT88 low mile failure
- 4.8 LS 2-step launch RPM suggestions?
- Filling Engine Blocks
- Starting out on a 5.3 Turbo setup for my 96 Z28...
- LJMS is now a Tech sponsor/Vendor!
- How many guys here have bumper exit down pipe
- Efi source 3 bar map parameters
- Any Lil john stage 2 or 3 billet 80 results?
- Swapping Rods / crank. Which bearings do you use?
- pulling the trigger 6.0/l92/turbo... turbo Help!
- Oil feed for turbo question
- Fueling Question
- Turbo build just kind of happened.
- Base tune for T76 5.3
- Want a roots blower on an 02 Trans Am- What vendors are "all-in-one?"
- Hard Lines and routing..show me yours.
- [VR] WannaGOFAST 1/2 Mile GA '14 - First Corvettes over 200mph!
- Help.... turbo 5.3 with false knock (or real quiet knock)
- Question, why not use 5.3 iron block for turbo
- ON3 Performance Turbo Kit
- Oil pan drain-back fitting?
- Twin turbo camaro - new vid
- help me spec out a new ls build
- who turns meth off when on the trans brake?
- Anybody swapped the Holset H2C exhaust housing?
- upright headers with a turbo on top pics?
- Need a set of wastegates?
- What is this part called?
- N20/Meth Question for FI setup???
- my 91 s10 4.8 turbo build
- Crankcase venting?
- Need help choosing the right set up
- Timing thread to end all timing threads (self proclaimed timing gurus, enter please)
- Which intake manifold?
- truck manifold vs ls1 for driver side?
- No LS but turbocharged 6.55 pass better video
- Anyone put some sort of wrap on fuel regulator or lines?
- ls1 vs 6.0 truck engine turbo ??????
- new best still 10#
- Removing timing from rear cylinders
- 418 12.7 compression 2300??
- on3 p in a fbody
- Any 5.3's in the 7 second zone
