PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228
  1. Ford style throttle body
  2. 5.3 Turbo build
  3. 408 billet S480 makes some numbers
  4. Holley EFI-High Ram or FAST92/102???
  5. LS2 TB upgrade on Maggied LS6 probs
  6. 408 pt94mm
  7. UPP Twin turbo Vette, STOCK lq4, Stock48 cam 830rwhp/890rwtq
  8. Turbo sizing question?
  9. heads which are the best ?
  10. 044 Bosch, ck valve
  11. lq4 possible turbo
  12. Time-Sert or Helicoil in front of cylinder head?
  13. 5.3 turbo powered 240 swap
  14. Intercooler to no intercooler PT76
  15. Stock head gasket and TTY bolt limit
  16. fuel injectors
  17. How much power can I make with this 94mm turbo?
  18. eboost2 problem
  19. Keep stock t6 or swap to t4 on s475?
  20. MAP placement question
  21. ERL Block Questions
  22. turbo coatings
  23. Any 4th gen f-body's run high mount a/c with a turbo setup
  24. 6.0L turbo build........GT45 or On3 78/76?????
  25. Bran new Borg Warner s475 shaft play?????
  26. Running down pipe, have question.
  27. LS 6.0 compound turbos?
  28. Trying to sell a few things
  29. Handling difference between h/c and s/c?
  30. Need help with converter choice
  31. Fastest on a 4 bolt motor
  32. What temps are you guys are seeing with the ATI coolers.
  33. Any new quick spool valve data.
  34. Question on wastegate I bought??
  35. Working on new boost controller thoughts please
  36. Gear opinion 373 or 355
  37. Cam opinion?
  38. Looking for best deal on S366
  39. T6 Turbo Blanket
  40. Stuck , need some advice!
  41. Turbocharged LS Platforms
  42. Turbo 5.3 build... GM's TTY headbolts?
  43. Started my new Mild 383ci PT88 setup what should I expect?
  44. STS and Truck Manifolds?
  45. intercooler worth?
  46. Turbo LS swap into 60s-early70s muscle car
  47. 700+ rwhp 93 octane daily driver C6 Grand Sport build thread
  48. I have an announcement to make
  49. Anybody making any big power with stock LQ4 Cam?
  50. A little too late for boost or meh?
  51. Huron Speed - Your #1 Turbonetics Supplier!
  52. denmah..tune 4 my set-up blow-thru.please
  53. Help with truck manifolds.
  54. any of you boosted ls guys at woodward.
  55. New to the ls turbo game
  56. Turbo kit that keeps a/c?
  57. Rebuilt the motor and installed a new fuel system, now won't start. Details inside.
  58. RHS 427 Block limits FI
  59. ground clearance on a FI car
  60. Help! Twin Turbo TA heating issues
  61. derale fan guys! 30 or 40amp fuses needed?
  62. 5.3 single 76mm cam Q's
  63. 6l80e reliablility boosted application
  64. PCV or Evac fittings
  65. Look over my tune?
  66. Cars that came factory super/turbocharged
  67. A2W Setups Lets see some pics!
  68. Derale 16925 pusher fans
  69. Holley Dominator boost controller question
  70. Forged for FI
  71. Huron Speed V2 T4 Turbo Kit
  72. What size turbo for 1000rwhp 408 build?
  73. ls3 heads or prc heads
  74. Concerns ,questions , and suggestions
  75. fbody procharger question
  76. Help Identifying Turbo
  77. daily driver,turbo with a/c newbie
  78. LMR800 Twin Turbo C7 makes 831rwhp through an Auto!
  79. Haltech or Holley or Megasquirt
  80. meth in lieu of a2a intercooler on the street?
  81. 5.3 TT build help.
  82. How Much Power???
  83. Recommended prefab turbo piping
  84. Any gt45 dyno or track results ???
  85. Turbowerx exa pump questions.
  86. stock fans flipped with huron speed turbo kit?
  87. on3 76mm on a 5.3, good idea?
  88. Turbo lsx and wheel setup- post pics of drag setups
  89. 1964 408LS TT Nova
  90. Turbo braces solid or flexible?
  91. Where to hook up wastegate/bov vacuum lines?
  92. Excessive TGT During Cruise
  93. ZL1 Supercharger Issue
  94. Alky instructions
  95. Wastegates for twins on 408
  96. turbo cruise tuning
  97. Twin Turbo LS Satin Black Fox Build
  98. help me drive my car- clutch issue
  99. Turbo not turning at idle help guys !!!
  100. Which coils?
  101. Best 8 Rib Belts
  102. Powerdyne BD11A
  103. e85 and 93
  104. 3bar map offset values
  105. Compression help
  106. Transmission options
  107. DR44G Alternator wiring
  108. 4L80e Stack shifting under boost?
  109. best head flow for procharger????
  110. Piping question
  111. will my D1sc work with this set up?
  112. Aluminized hot side painting/ wrapping
  113. Help Planning My First LS/LQ9 (twin turbo)
  114. What cr should I run?
  115. Biggest low mount twin turbo kit for ve commodore
  116. New turbonetics billet 7575...
  117. flycutting and boost?
  118. Turbo for pulling
  119. Used Magnuson Superchargers
  120. How big is too big for a Maggie?
  121. Twin Turbo vette smoking
  122. Alternator Relocation with Auto Tensioner?
  123. First LQ4 build
  124. Starting my 04 CTS V twin turbo build
  125. Forged lq4 motor with f1a blower hp guess?
  126. How much boost will silicone couplers and clamps hold?
  127. THE next true street car build
  128. Building boost off the line
  129. wastegate fire ring where
  130. Boost Referenced?
  131. Question on lsa & ls3
  132. twin turbo intercooler? what are you running? huron speed ?
  133. lsx procharger transplant kit
  134. 2002 WS6 6spd, huron speed kit car i tuned yesterday
  135. Wastegate failure?
  136. ls3 manifolds on a 5.3
  137. help with turbo build
  138. Anyone broken an ARP head stud?
  139. 1961 Impala LQ4/TC78 T56
  140. 370,390,408
  141. Turbo car overheating odd scenario.
  142. Alternator wiring
  143. 73' Nova SS Turbo 347lsx swap. "The MistreSS"
  144. 6.2 help
  145. Air Water IC- Water core leaking. Sealant??
  146. D1SC Custom Build...Question Before I Head To The Tuner
  147. Fairmont 5 - 6-28-15 SOLD
  148. 1998 240sx LS TT swap
  149. Who makes the best flowing mufflers?
  150. 2004 GTO turbo install!!
  151. Grand National Turbo Build
  152. Belt Tensioner question- fixed or spring loaded?
  153. newby to the ls world I need some advice
  154. GT45 Question
  155. Buick gn with 75mm turbo and nos
  156. P1sc max power capability
  157. Was there actually a gen 4 motor 5.3 in 04?
  158. Corvette Build v2.0
  159. It's a Pusher (coolant loss)
  160. F1R on LQ4 in 68 Camaro need help with bracket
  161. How much larger is the F1-X than the F1-R
  162. Derale 16925 fan wiring?
  163. Huron Speed *New* T6 Kit!
  164. Time for fuel system on 850hp E85...Ideas?
  165. whipplecharged lq4 questions
  166. 73 nova 4.8 gt45
  167. Anybody have this?
  168. what is a GOOD sounding exhaust on a turbo car???
  169. Fuel System for 650rwhp max ls3/l92, turbo
  170. Gen4 rods in a Gen3 motor, does everybody balance crank?
  171. 02 Fbody F1r and Dan Schoneck COG - What Fans?
  172. TiAL MVR 44mm Wastegate any good?
  173. Anyone have any pics of turbo braces?
  174. LSx Budget Dyno Queen. Ls1 Rx7+turbo(s)
  175. Help with a diy t6 hotside
  176. Regear or up boost question
  177. Who's running a LS next block? Few questions
  178. Front mount Turbo Guys w/ T6 - Sway bar or no?
  179. Bmw 745 4.8 4l60e single turbo swap
  180. New lsx build! Need opinions
  181. Fuel system help
  182. 5.3 boost
  183. Turbo car acceptable back pressure ?
  184. 90 degree turbo elbow with wastegate flange?
  185. What wastegate for 370/317's/S476R/TH400
  186. 2100cfm 14" fan enough for my 408TT
  187. Boostleash, eboost 2 or AEM Tru boost for a mostly street car.
  188. Deciding on a/which catch can(s)
  189. 430lsx turbo build?
  190. Huron Speed guys???
  191. new to turbos: lq4 turbo questions
  192. Absolute Max effort twin S366's on 400"???
  193. 403 LS notch now billet84mm and LJMS cam 7.86@174.5 11-15-14
  194. built 408 for boost
  195. Huron Speed Build w/ On3 78/75 - On a truck!
  196. Turbo kit blowout sale!!!!!!!!!!!
  197. I go with 5.3 for turbo . HELP
  198. Why are there so few twin turbo setups on here?
  199. Injectors for L33 S475
  200. S480 billet wheel wastegate?
  201. Can't find certain off-name brand supercharger, can you help?
  202. Will this be high enough for oil drain line?
  203. 5.3 Motor Pics about to be dropped in (Cxracing Kit)
  204. Huron kit, can't figure out the oil return.. opinons?
  205. 417 motorsports intercooler
  206. Vac/boost manifold ideas..
  207. Centrifugal Supercharger Fabrication
  208. aeromotive fuel pump
  209. Truck Inlet Hat On D1sc and F1a, How Are You Guys Keeping It From Falling Off?????
  210. NB O2 Sensors Required?
  211. Turbo 5.3 WAY down on power...HELP!
  212. project 2FAST4U 346/88mm/th400 build: critique my plans!!
  213. Advice needed: Theoretical lt1 twin turbo build.
  214. Fan Wiring, Derale 16925
  215. Accel 4150 TB User's......
  216. Turbo checklist - Am I forgetting anything?
  217. Good Radiator for turbo with A/C?
  218. who makes a "budget friendly" 50mm wastegate
  219. Sparkplug wire length
  220. LSA charger on a l92
  221. Need help picking a cam for twin turbo 5.3
  222. please help me on my rear mount turbo oil issue
  223. paxton novi 1200 truck kit on ls1?
  224. Help identify this turbo
  225. JS products Bump Box are awesome installed mine today.
  226. Oil feed size for S480 Turbo
  227. 3.905 bore size on 4.8 iron block
  228. D1SC and Brian Tooley Jam Cam - What will it do
  229. megasquirt and dual fuel
  230. Rip cut a supercharger pulley - got some boost back!
  231. T4 vs T6
  232. ls1 tubo question 78mm/80ar
  233. V-band reducer
  234. Most power on stock ring gaps?
  235. 1900hp 427 Lsx-Sleeper
  236. Twin on3 76s on a Ly6 go 8s on shake down passes
  237. Any discussion on alternative liquid for liquid-to-air intercooling?
  238. 317 Heads, Wiseco-3.2 CR build recommendations
  239. 1998 Trans Am 402/4L80E/S484 build
  240. 2014 Z71 5.3 ecotec+boost=??
  241. boost controller function
  242. boost on 6.2
  243. [VR] Stage IV CTS-V Wagon (6-speed) - Pics, video, and dyno!
  244. Timing and fuel at the starting line?
  245. lsx turbo is the only way to go.
  246. 5.3 motor 04 yr which rods
  247. Help Building Turbo LSx FC Rx7 (LS Noob)
  248. What radiator ?
  249. Power used to spin a blower... Discussion ???
  250. Downpipe out of fender
